View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. I'm baaaaack
  2. Do steel and aluminum get along?
  3. Question for Thrud re lathe stand
  4. scraper sharpening & scraping techniques
  5. Machine tool rollers
  6. Cutting D2 tool steel? HOW??
  7. Gear shaping update...production rate improved
  8. Injection Molder - update
  9. parallel thingies??
  10. Inside Micrometer Question
  11. extra money
  12. Tapping in Stainless
  13. Tapping fluid
  14. Emco-Maier 7 question
  15. Unique Machinist Pocket Guide
  16. milling 3/32 slot
  17. machineing "UHMW" need help with tool angle for the lathe
  18. machineing "UHMW" need help with tool angle for the lathe
  19. A link to standards publications
  20. Question for Ragarsed (and others) on Thread Forms
  21. screwcutting on a lathe is it neccessary?
  22. Rebuilding blocks,large wooden sailboat.
  23. Furnace
  24. help for a starter
  25. Single point gear cutter
  26. muffler for vacuum cleaner?
  27. Turning Titanium ?
  28. Price of Jet tools....
  29. Bench Vises
  30. Gauge Conversion Charts
  31. Math tools for gear heads
  32. cleaning up oxidized aluminum
  33. gage blocks
  34. 1-2-3 blocks.
  35. Table of screw threads and tap drills
  36. LAPPING TECHNIQUE
  37. Diamond tools
  38. Another Great Machining Book- half off!
  39. clausing 5400 or 6300 vs 5900
  40. facing large diams -- tips?
  41. Swivels
  42. 9 inchsouth bend model -alba shaper question
  43. Travers Catalog
  44. Source for Urethane
  45. Countersinks
  46. machinists speed / feed pocketbook
  47. Any one for hire here?
  48. Concrete raising /jacking? question
  49. The truth is stranger than fiction
  50. Whitworth taps & dies
  51. Single Point Threading Problems
  52. Grizzly Knife Grinder
  53. Smoke/fume removal on the cheap....
  54. 5C index heads. Any good?
  55. Die filer
  56. Sony DRO's
  57. sources of play
  58. Measuring equipment and testing stuff
  59. Geared head lathes versus pulleys
  60. old style shops
  61. woodruff key cutters/ METRIC
  62. How large a chuck can I put on my lathe
  63. mag starter
  64. Required equipment for making guitar parts
  65. Making flexible gaskets using recycled thermoplastics?
  66. milling machine quality?
  67. Tilting Vises (Milling? or Drilling?) ?
  68. comet milling machine
  69. Appologies and War
  70. round bottomed deep hole drilling
  71. Induma Mill
  72. Help needed with Bijur coolant pump
  73. Old question revisited
  74. Router Collet
  75. Lathes: first, second operation, engine, etc...
  76. International Cutawl
  77. Lathe Tapping Head?
  78. Tufoil
  79. boycott
  80. Tesla turbine
  81. turbo chargers
  82. Recutting End Mills
  83. Taps
  84. Metric Drill Bits
  85. Edge finder
  86. Heat Treating
  87. Metric setup equipment
  88. Need help with halogen task light problem!
  89. horizontal mill for sale
  90. The root cause
  91. SBIR proposals Anyone familiar?
  92. Suggest a standard text on engine machining
  93. Fuelless engine?
  94. reviving an older small Lathe
  95. Livingry
  96. Band saw blades
  97. The High Tech War
  98. Anyone have a OKDPM, Inc. coupon code?
  99. lathe painting Spray or Hand paint ?
  100. adhesive
  101. Lagun ACME Screws For Sale
  102. Groups!
  103. MT2 End Mill Holder
  104. Welding a bucket
  105. south bend lathe
  106. Anybody ever take apart a Nilsson (Nilco) dial bore gage?
  107. Bearing Questions....
  108. Cutting circles
  109. Indexable toolholders
  110. newbie advice
  111. Boric Acid???
  112. Homemade Boring bar??
  113. Need some information
  114. Bolt circle
  115. ? about metal working shop vac sys
  116. Convert turret lathe to standard???
  117. Boring Bars as Lathe Tools
  118. 7" aamco shaper
  119. EDM
  120. Minimizing "bow" when braking HR
  121. Pressing bearings
  122. Piston rings
  123. Hot vs Cold roll
  124. Troop Support
  125. How is this assembled?
  126. Tooth form used in automotive starter ring
  127. Harbor Frieght
  128. way oil
  129. GRIZZLL 4"x6" BANDSAW
  130. threading tool
  131. Rights and Other Stuff
  132. "Free Power" Minto Wheel
  133. Welding stainless to mild steel
  134. DeskCNC Software?
  135. arbors
  136. Machine work video tapes
  137. lathe type question
  138. Solvent for Silicone Lube
  139. Materials Question - Synthetic Marble
  140. Lathe head specs
  141. Neat tip for 4x6 band saws
  142. Woundering why
  143. Rubberflex Chuck
  144. cnc mill drill
  145. Powder coat generator used as EDM?
  146. Recent Projects
  147. Southbend vs. Atlas Shaper
  148. MT2 Arbor
  149. Kasenit, any experience?
  150. Lathe Storage
  151. south bend lathe mod a collet inside spindle
  152. faceplate on ebay
  153. Advice requested
  154. New Mill! Removing the table?
  155. Brazing over chrome plating, can it be done?
  156. Gravely Tractor
  157. Thank you Toronto
  158. NO to politics, religion, etc topics
  159. Electromagnets, no politics
  160. White Metal
  161. Question about fuel consumption
  162. Converting Mig Welder
  163. How to Drill Plastic Delrin Rod
  164. Past projects that saved money
  165. Long Table
  166. Threading a Barrel
  167. metal stock for indexable toolholder
  168. LARGE stepper motors For sale ...to Ebay?
  169. Jet Mill/Drill
  170. History Channel
  171. What stainless stock to use
  172. Novel use of rotary table
  173. Air Powered Drawbar for Bridgeport
  174. measuring the thread /spindle bore of a faceplate
  175. Rebuilding an old JET?
  176. square threads!
  177. Feedrate specs for milling? Any help?
  178. The Greatest Thing about Metalheads
  179. Lathe identification
  180. what size chuck should i run? also, any got chucks 4 $$$?
  181. Jim's recent project
  182. Pictures of Alistair's shop
  183. Picture posting
  184. HF Compressor 47065
  185. Runout on my drill press
  186. Pinging Forrest
  187. Advice on lathe choice
  188. Pictures from Lynn
  189. Cleaning loaded oil stones...
  190. heat resistant board
  191. home shop lathr!
  192. Building a small die set?
  193. How is manufacturing doing in your area?
  194. Program for doing geometry
  195. bosch part
  196. Kasenite
  197. Old time gear cutting machines......
  198. Best DRO for small shop?
  199. DOM Tubing
  200. rotatery table
  201. Inventors
  202. Tool Post
  203. Bench for bench lathe
  204. General board questions....question
  205. Free drawings?
  206. Paint question
  207. Hartford mill, Should i take it?
  208. What's it called and where can I buy one?
  209. M head or J head
  210. Cutting & drilling small parts
  211. Engine prints
  212. HF Pneumatic Tools
  213. Flutes
  214. Darwin awards, 280+ tons over my head
  215. VFD Programming for Bridgeport
  216. A Good Product
  217. 1994 AWB Sunset
  218. Bridgeport Series 1 CNC - Anybody have one or knowledge of them?
  219. Where's the best place
  220. Band saw
  221. Richard10557
  222. Fritz Werner model 5 .160 milling machine
  223. Which is better for the HSM?
  224. ridding your computer of Spy-ware/PITA-ware
  225. Motor Problem
  226. Opinions Please
  227. Doing some work, need some advice
  228. Hole punching
  229. replacing cast iron with nylon
  230. Two questions....
  231. rollers
  232. My "new" lathe
  233. schmatics
  234. DC Welding
  235. Cadillac Lathes
  236. Sq Threads for Wire Twist Pliers
  237. Mastercam tutorial
  238. A math puzzle
  239. Bridgeport motor wiring
  240. brothers and sisters
  241. Bridgeport move
  242. No reference to a cold...
  243. Toronto Model Engineers
  244. 1 inch arbor
  245. Slitting Saw
  246. Lathe headstock
  247. Metal Master
  248. Shotgun Chokes
  249. Turning a taper
  250. Has anyone made a louver punch?
