View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134
  1. has anyone heard from
  2. Where to find a DEAD or ALIVE cnc mill in CANADA????
  3. H/D Electrolytic Rust Removal; Get it done in 2 hours!
  4. Trip hammer questions
  5. Handy little case.
  6. Band Saw Blades
  7. Woodruff cutters and T-Slot cutters
  8. OT -- Adding computer memory
  9. Pin gauges
  10. Smallest possible cut
  11. Hardinge Horizontal Mill in NJ for Auction
  12. Case hardening and Rosemills "Cherry Red" compound
  13. All this talk about home brew stuff,how about...
  14. Steel building recommendations?
  15. NAMES EXPO 2008 fast approaching
  16. R.I.P. Dennis Jones
  17. Weld quality comments requested
  18. casting sterling
  19. ElectroDischarge Machining (EDM) article
  20. South Bend model??
  21. Southbend heavy 10 in central missouri
  22. Lathe Flex
  23. Bridgeport J head 1hp motor replacement
  24. Can anybody ID this machine?
  25. Ford sells Jaguar?
  26. More blackening observations/questions
  27. My new machine's spindle...
  28. garage layout help
  29. Free Radius gauges
  30. Photo essay: CNC assisted chemical milling
  31. Craftsman
  32. A tricky little cast weld..
  33. Spring steel (?)
  34. Alistair's childhood photo??
  35. Aloris clone boring bar holders
  36. Micrometer free to a good home
  37. Free coil pins
  38. Motor poles V power
  39. Dragging Crosslide - outound only.
  40. Riddle me this: how to square ends?
  41. Phonautograph recording
  42. CNC and unit costs?...numerous pictures 56K beware.
  43. boring titamium
  44. Phoenix Miller
  45. The Shop Wisdon of series of books ...
  46. 8101 steel
  47. Metal suppliers
  48. Aligning upon a hole so another hole can be made.
  49. Mini Lathe, part 4
  50. Lincoln mig pak 15
  51. Resolvers
  52. Bridgeport J head problem
  53. Stainless aluminum and salt water
  54. Simple Tapping Aid
  55. Surface and machine finish standards
  56. WNY forum members take note.
  57. Another VFD question
  58. Cast iron or steel tool holder?
  59. OK whats with these diamond tool bits?
  60. Hey, Bob Warfield....
  61. Toe Clamps
  62. Question about powerfeed
  63. Fuel Safety @ the NAMES Expo
  64. Import dividing head models
  65. 1/4-26 Grub Screws
  66. Newbie question on Delrin.
  67. Import Boring heads?
  68. converting to digital readout by using digital Vernier caliper
  69. split nut stops thread dial
  70. EMCO adapter plates
  71. The Betz Limit, and the Manchester Bobber
  72. BP J Head End Play
  73. FOUND IT!!! CNC glidemister lathe
  74. Link belt
  75. Mom's Wheelchair Mod
  76. Lubrication, sensible answers only please,
  77. Sticky motor start mechanism
  78. Big Suprise! Ot
  79. ER16 Collet chuck
  80. Threading Gear Box Design?
  81. Free MS DOS 6.0 Upgrade
  82. 6-48 Taps???
  83. Sharpening Ironworker Punches???
  84. The Journey Begins
  85. Let's talk about diamond grinding wheels.
  86. Opinions on HF Router Speed Control?
  87. New guy saying hello
  88. Large Hadron Collider, a doom machine?
  89. #1 machinery handbook
  90. OT: lights out?
  91. anyone tried these e books for milling?
  92. NEW (to me) EMCO JUST UNLOADED!!
  93. Thread grinding
  94. Source for Small Job Nickel Plating?
  95. What grade steel?
  96. Removing Tin and Antimony from Lead Alloy?
  97. Williams M51 Horizontal Mill?
  98. Some amazing model tubines
  99. multi V belts
  100. "Little Giant" adjustable threading die
  101. Another case of way to much time on his hands
  102. Proper engagement of V-Belt
  103. Yet "another" use for digital calpiers???
  104. Testing
  105. Help With 6" Atlas Belt Setup
  106. Log splitter questions?
  107. Torker, check this out
  108. flexible work light
  109. Battery Charge enlightenment - for rust removal
  110. Not OT - Trailer rentals
  111. OT: Maybe it would fetch you a beer or tool?
  112. Minor tool gloat
  113. Goofy 4-jaw article????
  114. Question about regulators
  115. Fly cutter problem
  116. How do you make a 3 jaw chuck accurate?
  117. CNC wood milling
  118. X2 vs X3
  119. OT - extension cord reel
  120. Centering a rectangular piece on a rotary table
  121. Need ideas on production forming stainless steel
  122. TAP for Hockey Puck ADJ. Foot
  123. Cutest 4 axis CNC project
  124. digital display
  125. OT - CAD drawing on business card
  126. Clausing question
  127. Machinery for sale & Gloat
  128. 3 Jaw 6 jaw question.
  129. What to do with battery acid?
  130. Latest new product from LMS
  131. lead screw nut modification for old tired Bridgeport
  132. Sabots for Bullets
  133. Canadians - where do you buy your stuff.
  134. OT, problem in posting
  135. advantage collets or not
  136. OT This is not an april fools joke, but ya got see this!
  137. CNC G-Code question
  138. Man!!!! Have I got balls!!!! :D
  139. Am I Alone in my shop clutter phobia??
  140. My Mistake Top Marks For Welsh Firm
  141. what are these for
  142. April Enco Code
  143. end mills for plunging?
  144. Stanford engineering puzzle
  145. Info about mig welder
  146. FS 9" South Bend lathe in MI
  147. Grade 8 Bolts needed
  148. Would Everone Please....
  149. mystery mill, please help with ID
  150. Baby bridgeport?
  151. Myranda Stirling Fan... It Runs!
  152. sysintonline in Sydney
  153. All That Glitters is Not Gold
  154. Amazing swarf, but what steel?
  155. O1 drill rod
  156. Color codes for steel
  157. ????Milling an oval????
  158. Canadians Where Do You Buy Your Stuff Part 2
  159. Test
  160. Reasonable Shop Rates for HSMs
  161. New lathe
  162. How do you separate the yoke from the spline on a Jeep driveshaft?
  163. Paint / Finishing...
  164. OT, but cool! For mineral and 3D enthusiasts
  165. re: "Dragging crosslide"
  166. square a vise on mill table
  167. Did you ever destroy someone's part?
  168. OT -- Tiny URL crashed?
  169. air cylinders direct?
  170. Found: The Holy Grail, raster to vector software that works
  171. Wrong steel or harden it??
  172. one for mark jones
  173. GFCI Breaker Question
  174. Universal vs. Standard Shaper
  175. What would you use reverse for on a mill?
  176. To knurl or not??
  177. OT building a tripod
  178. Single point lubrication
  179. Wells Index 860
  180. Large Diameter Measurments
  181. Large Diameter Measurments
  182. enco?
  183. Need advice on welding helmet
  184. Mill in reverse?
  185. Gravity Probe B
  186. For Doc Nickel
  187. Delrin Question from a newbie
  188. OT:DIY PCB Q's
  189. X1 Vs X2 Revisit
  190. Casting Brass in the home shop
  191. Shop Tip #743
  192. Mystery part in Grizzly DRO
  193. HSM back issues interest
  194. Sony Millman LH51
  195. Old clock oiling and cleaning?
  196. Lathe tool choice...
  197. Another newbie question - drawbars
  198. Wood, alumyum and plastic turning
  199. cast iron repair
  200. Free File Sharing Service
  201. I'm very sorry guys... Thrud...
  202. Mill in reverse? Thakds 4d responses
  203. Boring Harley cases for "big bore kit"
  204. 110 from 220...is this correct?
  205. poor David
  206. Holy Cow!!! Made my first tool.
  207. Wolhaupter Boring And Facing Heads
  208. Drill arbor question.
  209. My Airgun Projects
  210. So where does neutral go?
  211. Greenerd Arbor press
  212. CNC Cutting Shaper Bits?
  213. A Nice Upgrade On An Older Enco Mill/drill
  214. bearing operation
  215. Welding positioner
  216. Steel banding
  217. OT: The sound of light
  218. Bolt clamping force.
  219. My President has Died
  220. Old John Stevenson T&C grinder thread
  221. Cyclone chip & dust collector
  222. Fracional To Decimal Diamensions
  223. Choosing the proper
  224. O/T Old Schooler needs web help
  225. O.T.Strippers for Pollyurathane?
  226. Pics of my 1941 Sidney Lathe
  227. Aircraft Aluminum Redux
  228. Ultrasound vs. ultrasonic cleaning
  229. Wow, I actually completed a project
  230. VERY OT - Instilling a sense of respect and pride in ones work
  231. Ebay Tool Listings Dropping Off?
  232. Precision Machinist Levels
  233. OT-Prayers for my wife
  234. jkilroy: How is your Eaton Air Compressor?
  235. Why cast iron welds fail
  236. Annealing Cobalt tool bit
  237. A shop made gear cutter
  238. Anyone tried these dressers out
  239. speed pot
  240. non-detergent oil for lubing
  241. OT: Expand your vocabulary
  242. er collets
  243. Bonnet / hood support ?
  244. Bull Gear/Spindle Pulley Engagement
  245. Ideas for organizing reamers???
  246. HF/Grizley sheet metal machine
  247. Question about old electric motors...
  248. RF45 Sq. Column Mill Y-Travel
  249. DRO Search
  250. How to make clamps to secure welding gas bottles to trailer??
