View Full Version : General
- OP Projection lamps work around
- Van Norman Verticle mill
- Best machinable plastic
- Sieg White & Blue line?
- Y-Axis Powerfeed
- How practical is this Idea?
- casters and such
- had to relocate
- Taig Lathe Spindle Dimensions
- Herbert quick change
- Enco 10% code
- Ivory-bone
- Aloha
- OT - Getting Oil out of clothes
- Previous post. Moving wall art
- Making Your Own
- Schaublin lathe
- Did I Do OK?
- what can a rotory table benifit me
- O/T Windows Service Pack 3
- street railways make a comeback
- Finished Ring Roller
- Bonnelle tool cutter
- OT: Nausea over Denver, non-OT finale
- Speedometer cable end
- Chipping Drillbits?
- Does anyone use the CDCO DRO?
- HELP! Obsolete Thread Standard Info
- Tell me about Rockwell/Delta surface grinders...
- Advice on thread required
- Help/Manual wanted, Themac TPG
- Need help sourcing silver solder in Ontario, Canada
- sparkplug longevity
- Gear cutting on a 'spindexer'
- Broach bushing
- Interapid DTI Question
- Convert CWT ( Hundredweight ) to LBS.
- Anyone know the typical distribution of ABEC ratings?
- The DIY Lathe
- Source for Small (#3-48) Acorn Nuts
- PM site down
- Machining mirrors from aluminum; part II
- Propane Burner
- Knurling diameter
- ADMT vs APKT inserts
- 30% Off Today at MSC
- New 15% Harbor Freight coupon 8/29-9/03
- Some observations on machining---By a "new guy".
- Politics Posts Question
- Low-profile X-Y positioner to go on top of a rotary table??
- PM Site Up and Running!
- help with a bent Oscilloscope post/rod
- Vibrate or Tumble
- Pitch circle diameter calculations
- intermittent DRO display
- OT: Photomultiplier
- OT. email problem
- cutting 3" solid round
- Speed for gear cutter
- Another addittion
- Treat for Bridgeport users
- Flinging it across the shop
- OT.. my new toy...
- punch
- OT: Paint removal, ideas wanted
- I need new balls for my friends hand controls on his hoe.
- OT: DOS boot question.
- Bogus machinery RFQ's
- Making and Relieving a Gear Cutting Hob
- OT Birthday gift
- Band saw problem-HELP!
- Gear Cutter Relief: Necessary or Not?
- Drilling hardened steel- Help please
- i got board today so made some custom knobs
- die stock
- Newest addition to the shop...
- ahh, bask in pure bore measurement luxury
- Pucker factor
- Need Math Help?
- OT: Electric Motor Rebuild Question
- Induction-Repulsion question
- The true state of (at least) CT's economy
- Home made coolant Hydrocyclone?
- what i have been up to
- seeing the fourth dimension
- G.e.a.r.s.
- Rebuilding a ball bearing taper attachment
- Fritz Werner - Opinions?
- PA Live Steamers 30 August 2008
- Potential new project
- Need some minor electrical help or a suggestion
- Brass or bronze for flashlight?
- Turning an MT2 taper with my lathe
- CNC/surface grinding, how is abrasive wear compensated?
- Dead Blow Hammers
- The New Toy!
- Hobbing a gear
- Pinging Laslo
- Locking threads?
- O.T. Oil reserves in ANWR
- OT Source for very fine filaments
- Sources for a deal on AXA tool holders and brazed bits.
- Ancient Dykem blue with personal touch
- How to figure max load on a ball screw from a given motor torque?
- the world's best calculator
- VFD with Bridgeport - how to?
- stainless turning question
- semi OT: Irwin Quick clamps
- Free gas engine plans
- What size chuck for rotary table???
- mags
- Using stepper motor as generator
- how to get rid of iodine deposit on copper?
- Tool bits for interrupted lathe turning
- September 2008 Enco Code
- Perfume Bottle Neck angle Maybe OT?
- Anyone make a 5C holder with a MT-3 taper?
- Which wood for mic cases?
- how do i grind a cam?
- Horizontal bandsaw project
- B P Troubl
- New toy for an old fart
- Question for all you pyro-manias (paper)
- Leblond Lathe
- Armillary Sphere
- Rust Belt
- Spell Checker, Chrome
- Small Gloat .... and sharing some too
- Turning hardened steel
- O/T Anchor pots
- what can i do with an old Neptune????
- Dros and Calipers
- Questions about Enco
- Material gloat
- what type of taps should I buy?
- Slivers / cuts etc
- DRO issues
- Jacobs Chuck Parts?
- Electric motor balancing
- OT: Cable internet fragile??
- Newbie Question - Please Be Gentle
- engraving stamping score!!!
- Living the Good Life - Tool Gloat
- Re Sliver
- Vicegrip shutting plant and moving to China
- Cast Iron or CRS
- air rivet gun
- Gears on a 6 inch Atlas Lathe
- Question about electrolysis rust removal
- Hair ripped out with a drill
- Tiny DRO
- Clarification on bandsaw blade size
- Sourcing micron sized apertures and selecting film types ... pinging photographers!
- OT: Internet Explorer tabs issue
- A power hacksaw I built many years ago---
- arge-Diameter Holes From Small-Diameter Drills
- Cheap Sprockets For Ring Roller
- Better Than Sex Not Ot!
- Livecenter for large pipe
- Drill bit sharpener...
- I finally have my Clausing 6903 working!
- Index mill
- Any suggestions on my first lathe???
- Typical error for thread mics?
- Ot memory caoacitors
- chewing on bike tires
- interesting hinge designs?
- Issues with Making a Screwless Vise
- OT:Astrophotos
- OT - Deck Cleaning
- Help - Elliot Mini Jig Borer
- Friday afternoon project Pic.
- Need Tap and Die
- NEEDED: Pinion shaft for Trav-a-dial Model 6A
- SQ. Column Mill Help
- picked up a Taig lathe
- Belsaw 10550 sharpener
- Refractory Bricks & Cement
- imports from china to rise again as yuan falls
- Source for small water-cooled 4-stroke engine???
- welding table or fixture ideas??
- For sale to the lowest bidder: 1972 Dixie Gun Works Catalog
- single point a tiny thread on brass
- Wherez David Cofer?
- Pin Vice??
- Photo-voltaic chargers?
- Geometric 3/4" die head on Ebay
- OT:Groaning bobcat
- looking for a 4" or 5" 3 jaw thats decent
- Tapping heads
- Ring Roller
- See Snake Part
- Need help making screwdriver blades
- Shop Progress
- Really impressed with Nature's ability.
- Identify Cast Iron in scrap pile
- another question. dull small drill bits
- Lathe Motor Stopped??
- Prints For High School Students
- Can you cut threads with a Bent needle file?
- thread
- You shamed me into it...and tool gloat
- A garden cart for my wife
- pre ground hss internal threading bit
- Some inspiration
- Value of Babbit
- How to turn a dimple?
- Rex tool steel
- Cutting metal
- Taps sure do break easy
- Die filer yes, knowledge...no
- Tool Serial Number Lookup
- Scottish Navy
- VSpd Bull Gear Pinion Needed
- Bike trailer
- O.T. - "God particle hunt" (never heard it put that way)
- L.E.D. Overvoltage (HF windup flashlight)
- DC vs AC (induction) motor
- Are Tormach cnc mills any good
- I need a new camera..what's good???
- maybe OT, maybe not- painting pvc
- tips for turning ASTM A36 ?
- Hypoid spur gear??
- OT, Does this internet device exist?
- Turns darn well for mystery metal
- Need some motor help
- Grinding wheel loaded with aluminum
- Way OT: Just because they said I was crazy
- Removing Jacobs Chuck ?
- Fleming EDM
- Rusty Tool Steel
- My first 3 phase machine... questions.
- Any Canadians own or know about IH 12Z mill?
- thread Repair
- Looking for *other* uses for (old) vice grips
- Equifax credit history scam email , beware.
- OT computer How to open a .dbl file
- where to find 1\4-28 threaded shank carbide burrs
- O.T.--Where the heck did my work go---
- Newest rumor.. gas at $5 a gallon by weekend
- Lipstick on a PIG! (My new grinder stand)
- Ballway surface grinder opinions wanted
- what does this bandsaw cut say?
- Scraping dvd's
- OT- I got a job at Fastenal
- Seriously heavy metal
- Phoenix Miller
- Source of Surface grinder use information?
- Noob Thread Redux
- Speaking of surface grinders...
