View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134
  1. Need a lathe. Have experience with Atlas
  2. Any engineers out there?
  3. cnc stepper motor help needed
  4. Need ideas for an RC Motor Needle Valve
  5. 6 inch Cuck for 7x10 lathe
  6. Roller tips on steady rest
  7. Large Diameter Threads
  8. Honing stone ??
  9. Multiple collets?
  10. How much is a pound of Cerrobend?
  11. Looking for an old copy of Machinerys Handbook
  12. recycling carbide
  13. 440 stainless
  14. Anyone able to contact "metalchipz?
  15. suggestions for lifting boat dock
  16. Bridgeport clone draw bar
  17. "16ths"
  18. Re-busted crank...HELP
  19. Milling Machine Spindle Tapers.
  20. Okay to replace ball bearings with needles?
  21. Stainless Steel Easter Eggs
  22. Need drill chart for taping
  23. Machinist Handbook on CD
  24. chatter -- whats it telling me??
  25. Grizzly
  26. Happy easter to all
  27. Moment of Reflection
  28. WOHLHAUPTER UPA5 BORING/FACING HEAD on ebay
  29. "precision" boring head
  30. Just curious about Lenght/Time Commute
  31. internal tapered threads
  32. Are Chinese cherry pickers any good?
  33. Quick Change Tool Post
  34. Big thanks to Ragarsed and Thrud
  35. 2 vs 4 flutes
  36. Stevenson QC ToolPost mod ??
  37. How critical is gear-tooth shape?
  38. power suply
  39. Hey, a Tub of Lard!
  40. Punch Press dies
  41. High speed threading
  42. If a lathe could talk.........
  43. Anyone turn your own crankshafts? on a lathe?
  44. Lathe- cutoff help (Mini-bit)
  45. Knurling Tool
  46. Any good web streamed science shows?
  47. Proper use of lathe cutting tools?? Online diagrams or help?
  48. Threadless Screw
  49. Belt Question
  50. MT2 Arbors
  51. Solder Residue
  52. K&T mill update
  53. Acurite DRO change
  54. Work Block
  55. What are "construction balls"?
  56. APT boring head
  57. Lathe tooling
  58. D1-4 chuck
  59. what do you want?
  60. Bending exhaust pipe
  61. Machinery Clutches
  62. project: pushbutton depth gauge
  63. End Rounding Milling fixture
  64. Machining ball joints
  65. arbor with pillows
  66. Hand fitting and filing
  67. Aloris Tooling
  68. End Mill Sharpening
  69. Info Needed
  70. Any experience with bench top knee mill?
  71. Casting Pattern Question
  72. Genuine Antiques
  73. Canadian Holidays
  74. Spot Welder
  75. Banjo Part
  76. OD grinder on Ebay
  77. Humorous--Dixie Chicks
  78. Endmill Question
  79. Toolpost - Height Adjustments
  80. Grooves in Bronze bushings
  81. Metal Checkering Question (Caution-pics)
  82. Power hacksaw : Are they still made?
  83. Quick change tool holders info please
  84. Neat trick
  85. Most recent tool or machine
  86. A new gecko drive for my indexer
  87. oil seal question
  88. 1 Inch Jam Nuts
  89. x39's TIG welding advice...
  90. Work Shop Tips (series)
  91. MIG gas flow question
  92. H/V Band Saw note
  93. How to evaluate Bridgeport without power?
  94. bidding
  95. Lapping Plates
  96. Shop items
  97. Mitutoyo DRO
  98. sanding mandrels
  99. ebay large lathe
  100. 5C Spin Index
  101. Thermal spray welding
  102. hose
  103. off brand measurement tools thru ebay
  104. Chemistry of Aluminum Slag Question
  105. Sharpening Cutters
  106. Grizzly G4515Z lathe/mill/drill
  107. Rotary table for G4515Z
  108. ? AGE
  109. Keys and Slots
  110. Straddle Knurlers
  111. NEW KID ON THE BOARD !!!!!!
  112. Back for more advice...
  113. More on Spyware - more protection available
  114. Can 12L14 be Case-Hardened?
  115. Why are Tig machines more expensive than migs?
  116. Source for 1/4-24 taps and dies?
  117. Bridgeport mill wiring?
  118. My morning, almost got the bleeding stopped
  119. Cost question on turning Nylon
  120. HSM Powder Coating
  121. Need Some Equipment Advice
  122. Also need advice on.....
  123. Surface finish on a shaper
  124. Heads up on 7"shaper
  125. Used 3-n-1 machines in KC
  126. Opinions wanted on Craftex
  127. Air compressor alert, Attention shoppers
  128. Enco Tools
  129. Dah Lih horizontal mill
  130. Where is a good foundry to do iron castings?
  131. Roller pins on the gib?
  132. Kevlar gloves?
  133. #40 Machine Tapers
  134. R8 collet
  135. Grinding Wheels for Sharpening Milling Cutters
  136. Rotary Table or Dividing Head???
  137. Where to find small parts for old Southbend
  138. Looking for new HD Floor Drill Press, Single Phase
  139. Ordering Online from US Tool
  140. four jaw chucks
  141. Help (!) ....About Welding......
  142. REX Toolbits
  143. Cut 1 x 8 thread
  144. Keystock
  145. metric translation gears
  146. Milling machine consideration questions.
  147. Locking Collars
  148. I think I can.. Well maybe I can..
  149. Good Idea
  150. Lathes are very handy
  151. Work Shop Tips from Tim (#2)
  152. Fast mill (cheap) vise for large objects
  153. Millport Machine Tools
  154. feed screw nuts
  155. Work Block
  156. I'm scrared!
  157. Determining purity of gold
  158. 5 inch chuck on my 7 x 10 lathe
  159. 4-jaw centering square bar stock to .0005''
  160. Another oil seal question...
  161. Aluminum Casting experience anyone have any?
  162. Drilling Stainless 14 Gauge
  163. Making an air compressor
  164. Upgrading a Spectralight lathe and mill
  165. Feed Screw Covers
  166. Centre Finder
  167. flexable gooseneck-like tubing
  168. Need 5C Closer Advise - Quick : )
  169. making a dust extractor
  170. Thread specs
  171. Home made Spade Drills ?
  172. Large sheet metal circles
  173. knurls
  174. Tire shaving ??????????
  175. Gonzo Machine Tools
  176. Fixed Bridgeport power feed
  177. Welding Cast Iron
  178. Help Identifying Bridgeport mill Please
  179. junkyard nuggets
  180. Anodizing question
  181. Lukes Machinery in Canada
  182. Spindle bearing replacement
  183. Rollers
  184. FRYER CNC EASY TURN ET 14
  185. turning a half-round groove
  186. Radial air motor for machine slide power?
  187. Welding copper
  188. damged tailstock
  189. Brazing Stainless
  190. Theretical Bearing Design Question, Just Curious
  191. Alistairs very Smart & Brown, with Baby Fritz
  192. Harbor Freight 12 x 36
  193. changing chucks on my drill press
  194. Threads
  195. Suggest a project for some big Torrington bearings
  196. Precision sliding fit
  197. Spinning Machines
  198. NOW WHAT!
  199. What the Heck did I buy!!!!!
  200. Injection Molder - finished
  201. Replacing axle studs
  202. Question about Layout fluid
  203. STUPID QUESTIONS?
  204. Brain Teaser
  205. Cat Food Machine
  206. Land Rover
  207. Metal Mesh Matrix Composite Laminate Stuff
  208. Protective Atmosphere or Inert Gas Oven
  209. Home grown plasma cutting
  210. electric oil pumps????
  211. Machinery show in Edmonton 6/17 - 6/19
  212. photocopied lathe manual
  213. cnc router plans?
  214. bench grinder safty
  215. pictures of Alistair's machines on the moving day
  216. Thinking about buying a Smithy Granite 1340, need advice.
  217. Corroded Bronze
  218. Honey. I'm Home!
  219. Advice needed on Millrite milling machine
  220. lending library?
  221. The Nut in The Sea
  222. Buck Versatapper
  223. O/T Yahoo & Spam
  224. Colouring Aluminum
  225. Lawn Mowers
  226. 1940s Machinery's Handbook
  227. ?s on files
  228. Ballscrew on milling machine
  229. Loctite question
  230. toolpost grinder rotation
  231. steam valve silver seals
  232. Will the county allow you to have a workshop?
  233. Question about wave soldering machine
  234. Ebay Can Be Fun
  235. Glue cast iron?
  236. Article on lathe compound repair/upgrade
  237. Go Spurs Go!
  238. advice please on buying Die Filer
  239. Aerodynamic tractor trailers? Why?
  240. Indian drill
  241. Lock for a dual tandem gooseneck trailer
  242. heat treat oven
  243. Wanted - Boyar Schultz info
  244. Anodizing power supply? suggestions?
  245. Tool Chest
  246. Smallest machines I have ever seen
  247. Partnership ?s
  248. Measuring Punch Pressure
  249. Thrud tried to steal my new lathe
  250. getting started
