View Full Version : General
- OT - file and printer sharing in XP
- What are you using to read downloaded books?
- OT Drat! New virus warning maybe?
- More tool ID: Old drill press and radial-arm saw
- Wanted: back issues of Machinists Workshop
- OT You fellers are good a numbers, what's the chance?
- Bonding Unimat Belts
- Sir John?
- OT Why do people leave their diesel engines running?
- Great Waste of time
- Motor Trouble and a Bearing Question
- When drilling on the mill
- Tool Research
- It ain't off topic
- Semi-OT computer question.
- Question Hydraulic Powerpack, Homemade
- Nice when the basement machines come in handy
- Elliott 10m Shaper dismantling info
- something OT
- soldering slot car track rail
- Music Box Movement plans ???
- Building your own machines
- New Chuck
- Air Pressure Question??
- Small shop big money
- tapping cast iron?
- RF-45 Clone Disassembly site
- Yippee! bought a shaper
- ON TOPIC: some pics of my home shop
- O.T. Glueing Glass
- Any shareware CAM programs?
- Hobbing a Gear
- (OT) Model Engineering, pastime of the svelte
- DeskCNC / IM Service Router
- OT/Why does my backhoe think it's a hydraulic jack??
- geometric solution for circular bolt hole
- I need tool geometry help (Internal threading)
- Turning / Boring query...
- OK, I have had enough...
- What finishing equipment should i be looking at?
- Brightside of Economic Slowdown - Materials Price Declines
- Harbor Frieght Vertical Milling Machine
- Cushman Chucks and Republic Drill
- Precision square
- Checking motor & capacitors in air compressor
- Las Vegas Machinists
- Lathe height from floor...
- OT..sort of: Info on back pressure on small engine mufflers
- Team builds?
- Variable speed motor from treadmill for lathe
- Grizzly G4003
- Can't get my bearings!!!
- Source for oversized tap?
- craftsman, bearings or babbit ?
- OT posting point of interest.
- Crane Idea???
- Must be in the doldrums---
- Cutting Tools - What is it, When do I use it, What the heck are these numbers, etc
- Two quick 3~/VFD questions:
- Anyone still make a *quality* drill chuck?
- Is there a end fitting for rope that develops the full strength of the rope?
- Shrink fit question?
- Why do drill bits always drill oversize.
- clearance between the wall and compressor
- need help with motor wiring on an old mill
- OT, Paint and tar paper?
- what are collets used for on a mill?
- HF Grinders and the Search Function
- last nights project
- HSM ad expirations - Anybody in charge?
- Tapping Heads
- Has anyone plumbed there compressor intake outside?
- Preferred method for breaking edges?
- Hydraulic freewheeling limiters???
- OT, Stock Market???
- An old shaper
- New Shop
- Cutting belt pulley
- Grinding Wheels
- Semi OT: Inch Standard
- De-bugging programs (CNC)
- Buffer/Polisher
- New Shop Interior
- OT - Firefox bookmark question...
- recomendation for a quiet air compressor?
- Another day in the home shop
- can i use Woodruff keyway cutters for general milling?
- Pricing of HSM jobs...
- Early Gosiger drill press
- Free to good home
- the ultimate pocket watch
- I hereby swear this is the LAST vise thread
- Free welding gas = CO2
- Help Using Diamond Wheel
- Recycling Rant
- Rifling and Backlash and cutters, Oh my?
- Remember the complete set of plans for a Beam style steam engine?----
- case hardening question
- o/t barn
- Anybody have experience with PRECISION MATHEWS machines?
- OT help MUCH appreciated!!!
- Indium??????????????/
- morse taper advice
- what's your tip radius preference
- Analogy of a drill bit in comparison to the swarf it creates...
- Got a problem with a shrink fit
- powerfeed problem
- LeBlond Lathe Serial Number
- Line boring
- Shop and Planer update
- First Lathe
- Tetra Project
- Making tube bending dies?
- What's up with Sobel?
- OT: I told her "Don't come back without Cake and Ice Cream
- Metalworking Charts
- TechShop Portland Open House
- Shop Safety OT
- identifying brass or bronze?
- Gear Hobber/5P (not 5c) collet questions
- Got a new shaper tool gloat ~
- sattelite industries ?
- OT - Car repair question...
- I need or want wad punch advice
- Are you good at reading machine drawings?
- Improving An L5
- The thing at the end of a C clamp?
- Tool snobs
- using a rotary table on a surface grinder
- my first attemt at making an airgun breech
- OT carrier merger
- Pipe Thread Abreviations.
- So you want to buy a metal lathe
- Macbook machining
- Motor brush question
- Air Pipe Code?
- need a materials recommendation
- TOOLS, this is good, this is bad:
- Making something, to make something, to make something.
- Magnetic Parallels?
- Diamond pocket hone
- OT Solve your petrol cost problem
- How is Diamond Plate Made??
- am i expecting too much from bison
- Tapered Endmills
- Machinery
- Is this Starrett new or old?
- Milling Vise Alignment Procedure Request
- Machine related cell phone gripe
- If I were to hit the lottery.....
- Making socket set size more visible
- Spindle for woodworking shaper
- Two diameters + length = what taper?
- ER collet series - drawings/dimensions?
- Year of Manufature from Serial Nr - Elliott
- jet 1340A
- Downham Mini Jig-Borer for Milling?
- Lag Screw Pilot Hole
- today project , project milling vice
- Thread mount chuck retainers
- need advice how to make surface grinder
- Careless mistake turns out to be a good thing.
- Pearlitic iron
- How to take buffer apart
- Free SME Movies
- Diamonds aren't for steel, or are they?
- cordless drill planetary gearsets- uses
- Index 740 Mill
- Lead alloy hardness
- Doctor cut a hole in my back
- Grinder on E bay check it out
- small motor shaft repair
- What happened to this?
- Ductile Iron- !@#$ing minimum orders
- Converting Bandsaw to Dry Sump.
- New one on me! 27tpi
- This has kept me out of mischief for a day or two
- A HUGE Thanks to Timewarp!!!
- Need ideas for BIG bearings???
- Who owns what power tool brand and where is the company headquartered
- Sears = dumb.
- Tiny tool storage idea
- Drill Grinder, TDR
- PM Research 1890's lathe
- Todays project complet
- Gorilla vs Loctite
- Birthday Presents - Need a machinist's perspective!
- Why do they leave the smallest and largest sizes out of x64ths 5C collet sets?
- Horizontal bandsaw HP, and older Wells saw questions:
- PoorMan Grinder -was small motor shaft repair + pics
- Tube bending
- Stupid or what....
- S-l-o-w Diamond Wheel
- Hendey Lathe Age?
- OT The nations longest covered bridge
- I need book information help please.
- O.T. 1.2 million dollar valve
- Valve pics
- Source of SMALL HSS toolbit stock?
- Jib Crane bearing ideas?
- cutting speed for cast iron
- More on the Big Grinder
- OT- What's in a date?
- Estate Sale, Whats This ?
- three more pix's
- and while im at it .
- OT:110 to 220
- Gantry crane
- Camel Grinding Wheels...?
- OT (or maybe not) - any members play with hydraulic motors?
- Unusual t-slot nut size?
- US made bench mills and other mystries
- Drill Press on CL
- Is a pool pump motor worth fooling with?
- 6 inch aluminum oxide grinding wheel...
- Internal O-ring Groove
- Wells saw adjustment??
- Hoisting Pipe To Ceiling
- Jet Mill/drill speeds
- made a new tool today
- Gota question for ya'll about a lathe
- Thread ID
- bearing slop in a bandsaw
- now i need to fix my new bison 6" 3jaw
- Help wiring a 2-speed circulator fan?
- Cole drill use.
- Identify this HSM Horz Mill?
- Leasing my personal tools to my shop
- solder question
- Reed Prentice on Chicago's CL going for scrap price
- mill/drill spindle bearing re-greasing
- OT, Stickey Tape and X-Rays
- Alternator Strip Question
- New Toy! Porter Cable 7" shaper
- Wiring a 3-phase
- laser module use?
- 220 wire for shed
- Carcass of Delta Carbide Grinder
- OT Question for You Truckers
- Info and background on the Rong Fu tools?
- disposable propane tank threads
- MIG tip length
- How is this done?
- video of the crosman airgun tool i made
- Who does what for a living
- This site no longer is reachable, VP is bankrupt (or not)
- Rockwell 11 Inch Metal Cutting Lathe
- I just won a drill press on ebay for cheap, have a question or 2
- Chinese Grade B surface plates
- OT Wife's Old Machinery Watercolor
