View Full Version : General
- question about wiring phase converter
- BRIDGEPORT 4J Question
- Model Engineering show at American Precision Museum
- o/t For Sir John
- Source for decent vises?
- more from the estate sale
- bridgeport power feed
- New tilt table
- Coolant pump - minor problem
- Little high speed spindle adapter
- Will battery acid freeze?
- Name that saftey violation!
- need opnion on an arc welder
- JD2 model 3 bender
- Gauge Block Usage and Storage
- What to do with hydraulic cylinders?
- KO Lee Gone
- Collets for Jet Lathe
- Metal spinning tools... at St Louis sale
- Enco "USA" Drill Bit Manufacturer?
- new vice followed me home today
- Semi OT: 3PH lathe motor has stray voltage on frame
- Am I expecting too much...
- Cross slide lock ideas?
- New York to LA, three hours by land
- OT heavy hauler
- collet identification plese
- Lathe parts interchangeability
- OT - anyone have ideas for removing stains from stucco
- But how much to expect?
- Lathe Tooling, where to buy?
- Well pump, manual? bucket designs??
- Way wiper material
- Arrg!
- Drawing package for the home shop guy?
- Chinese ER collet quality...?
- Shaper gear?
- Need Sketchup help!
- lincon 120 volt 70amp arc welder update
- My simple tailstock lock
- VFD Questions
- tig welder from harbor freight
- Burning wood in 55 gallon drum
- MIT developes new method to generate Hydrogen.
- What's the secret for downloading SketchUp?
- Coventry screwing die parts - sale - in OZ
- Evan?
- Replacement vise screws?
- Thoughts on Horz Mill
- Shop Expansion (pics)
- OT, but Pinging David Cofer
- Potts spindle
- Liberty Ship Cruise
- Sine bar question
- Metric Thread specs.
- woodruff key cutter question
- Anyone in Milwaukee able to do me a favor...?
- US Iron SB
- Pipe connectors
- Cleaning mill scale with vinegar question??
- Way OT history ques.
- report on VFD upgrade for HF 12x36 lathe
- OT: Non-Staining Dye
- Semi OT: Air Fish
- 316 s/s pipe
- Drilling and tapping hydraulic cylinder rod?
- Anyone have a pic or plan of a radius grinding jig?
- I just love my "know it all" customer..
- ER Collets – I need to get smart
- OT: Google error. WTF????
- made a chipping hammer today
- 4-jaw chuck trade?
- ???? on small mills
- Sliding fit between pipe sizes?
- I'll feel a little safer now....
- LFA chucks are pretty darn good...
- O.T. Need help please
- Shake hands with danger.
- OT Treadmill / motor help
- Energy efficient Shop Lighting?
- Hossfeld bender plans
- Drill Doctor saga
- OT: Small propane bottle refill
- Cut Off Blade
- Looking for ideas
- Horizontal cutter score!
- Jacobs Industrial Keyless Chuck in a DP
- Taper reamer for pipe threads
- Grinding Aluminum?
- Now thats a big Grinder
- Plans/Ideas: Motorcycle trailing arm support
- Rockwell 10" lathe?
- 60 years of Model Engineer
- Tool Bloat
- Valve Grinder mods?
- made some weired stuff on the lathe today
- OT: Stainless Steel Cars
- oxygen CGA fitting
- How do Subaru Robin OHV engines compare to Briggs OHV and Honda OHC engines?
- OT.How do you feel about this guys.
- OT - Online Web Cam
- Speaking of Bender Plans
- special screw
- OT - Electric motor ?
- Multimachine
- Mit machining movies
- download videos at MIT tech tv
- Government auction looking pretty good!
- Nut... slotted holes and washers?
- New choices when you sign on to HSM??
- OT/ Happy Halloween!!
- Lathe lubrication questions.
- Rockwell Bandsaw
- South Bend mill.....13 by 60.....
- WARNING SCAM LETTER "FROM BARACK, same as one from MICHELLE OBAMA
- Another special screw
- The $32 Leland-Gifford drill press makes it home….
- cam locks for the mill - do they work?
- OT SS 1936 Ford Coupe
- Common 5C metric collets
- OT old pieces of railway line
- Time indicated on posts
- Is this a tool gloat?
- OT: Brass Spark Plug
- Johnson Horizontal - CHEAP - Sac CA
- A few "ask a wiser person" questions
- OT / lugnut saves the day
- Cutting Huge Slab
- Scored some tooling today!
- Single flute endmill?
- Soule' Live Steam Festival 08'
- Time to buy a new tool for the shop.
- OT/ What are metal eye glass frames made from?
- Solenoid/switching queries.
- Renault Dauphine on a pedestal
- Ball Turning Attachment
- Craftsman 8" X-Y rotary table info
- Boring bar question
- what's santa bringing you boys?????
- KO Lee auctions getting a little crazy?
- Past issue article question
- OT again- 92 geo metro problem
- Syil cnc X4 or Smithy CNC 622 ? opinions anybody?
- Patch???
- Finally Made the Gear for the Cinci Thread Dial
- O.T. Guarantee'd to warm up even the coldest of hearts...
- keeping brass bright
- 303 stainless steel polishing
- Still not avaible at times
- Jet Riser Block
- Help with a Baldor Buffer
- Higher personal taxe?? why not raise import tariffs??
- Discontinued inserts - Circle Machine
- Suggestions need on "what lathe" to buy?
- Different Twist On An Old Metal Bender Design
- ENCO November Free Shipping
- Scrap crashes to £0 per tonne
- Buy new or used?
- Painting a machine question
- Machining again!!!
- Stuck collet, stuck BS #9 Taper
- OT/ I just blew up my hydraulic pump!
- Sawmaster band saw?
- BP Fine Feed Handles
- Anybody got plans for a flyball governor?
- Short Piece of 1 1/2'' Acme Threaded Rod Wanted
- Cheap and easy R8 collet holder
- Your choice for a toolroom lathe
- O.T. Ground Source Heat Pump
- Rockwell-itis??
- Tool Gloat: New Doringer cold saw and broach set
- Pet Peeve, Taps and Cordless Drills
- Where to buy small screws in bulk?
- It's a done deal !!
- Anybody know about a Washington Mill?
- Help finding recent grinder/buffer image
- Maxmill motor and 3 phase converter
- 5th of November.
- congratulations on your new brilliant president
- Couldn't Let Torker Have All The Fun
- Need a favor from the British crowd
- DRO cold sensitive?
- Boring head arbor search
- Another shaper followed me home
- big iron
- What can go wrong with a #15 Buffalo DP
- Hydraulic pump repair eh???
- Santa says I can buy me an air compressor...
- Machining SS and First Time TIG Welding
- How to make a Nichols halfnut in 163 easy steps!
- OT Hard Hats; Handbooks for a Civil Engineer
- Checking a taper/bluing?
- boring head
- Centrecam
- HF Grinder (again)
- Can you repair the Jacobs taper in a chuck?
- Best way to put a 3" to 4" hole in a block of Aluminum?
- Todays cobbled together tooling...
- Unusual dividing head spindle - Int 40
- DeWalt's latest offering
- Made a dohickey and a thingamabob...
- What is this really, and what does it do?
- Any tips for cleaning aluminum out of saw blade?
- A strange injury..
- Electrical Feed?
- Grinding Booth
- So you think a turner's cube is hot stuff...
- In search of the "perfect" shaper cutting edge
- Thank God for Our Machines...
- New HSM website features are live
- Finally subscribed after all these years !
- Anyone using indexing / dividing head as RT ?
- Satin Chrome Finish - Clean/Polish?
- Alternative cutting fluid for short-term
- The new "Seig" X3 mill is in - almost
- More Nichols bits
- Measuring and storing reamers
- Insulating Garage Door
- Time to buy a decent mill
- Reworking 5C Indexer
- My $20 phase generator, pictures, youtube vid
- drilling concrete
- Peep sight
- Vertical wire feed
- Cracked bar stock?
- Good video on edge finders
- Shop wiring, three phase
- Motorize Rotary table
- Seattle scraper class info
- I hate leaks - the new lathe...
- 1950s Bridgeport Milling MAchine
- Making terminal
- OT Railway line deformation?
- Acme threads
- New plan, new lathe troubles...
- Kwik Switch tooling
- Working in miniature
- Good times ahead, almost free electricity
- Air Dryer Problem
- 45-70 Front Sight
- Shop tips - whats your favorite?
- 7" Lewis shaper speed
- Way OT: My first two encounters with a pit bull.
- Things I never knew.
- Pacific Scientific treadmill motor. Diagnose/Rebuild/Replace
- You don't need fancy tools to be an artist in the shop
- Boring Head Shank
- delta unisaw blade adjusts itself
- Spindle Bearings for a tool holder, air vs. linear?
- Process For Aluminum Identification?
