View Full Version : General
- Ball Turner in HSM
- ram wiper plates - the shaper gets one step close to completion
- New telescope pylon, New Astrophoto of the week (APOW)
- Major upgrade to my CNC mill
- Florida machines on the block
- GRIPE AT MY BRIT friends..
- considering: Hardinge HLV-H
- Congratulation Rich
- OT: Time for Tea?
- Help me find a use for this.
- need help geneator honda E300
- two piece jaws on three jaw chuck.
- Bent Shaft
- NAMES update
- Need Leather Machine Belting?
- Formulae
- Micarta wheel
- Atlas 12 Inch Lathe Attachments
- Mitutoyo 101 adjustment?
- motorized milling head raising gear
- Motor/switch issues once again
- Dana 44 drive slugs
- Case Hardening recipe
- Air over Hydraulic Vessel question
- OT Hot water systems
- OT UL / Nema
- Home made rotary table
- 2 axis DRO for Vertical Milling machine
- 9" SB lathe numbers
- Cold Grind??
- Cutting through steel with bacon
- Gear and rack discovery
- Looking for a 3" grinding wheel
- Air compressor advice..
- Oxyfuel Cutting With Bacon (no seriously)
- Air Motor piston ring material?
- O.T.-Coleman Lantern
- Searching for taut wire alignment topic
- OT: RC Sidewinder Missile
- Considering buying used micrometers -- need advice
- what determens the SCFM in an air compressor
- Anyone setup to sharpen 1 7/16 taper shank drills?
- Micrometer "feel"
- Thread Grinding
- Old Iron
- Lathe Columbus Ohio Craigs list
- Square Bits aren't Square ?
- Semi-OT Propane weed wackers?
- Cross Slide Lock for Grizzly G4003G
- Parting tool -what am I missing?
- Well I am finally a
- Kearney & Trecker Divding Head - oops
- OT - Shortening a door
- Need help truing chuck
- Re-purposing a band saw
- What am i doing wrong ?
- Welding steel truck wheels
- patenting a virtual device
- Battery Chargers & Sulphation
- Enco
- Carbide inserts: Please educate me
- steel steam pressure vessel, will it rust, pressure questions...
- Mill Lube question
- Grinding wheel recommendations?
- Removing rust without removing color-casehardening?
- Vee belts, pullies, etc
- OT Hey Torker
- boring sunday afternoon, its snowing here
- That water-cleaning controversy...........
- Tailstock indicator holder
- HSM Q about Wheel Balance
- OT Low mains voltage issues...
- Sherline challenge
- N.A.M.E.S expo 2010
- Richard Carlstedt selected as 2009 Metalworking Craftsman of the Year
- For the computer experts: Suggestions on the best way to proceed
- Seeking knurling tool advice....
- OT: government take over of Chicken Ranch in 1998
- What's at a show, other than models and why should I go?
- Here's a slick vise
- Need places to buy short pieces of metal
- What's your longest chip?
- Just to hard to manufacture in the country
- OSHA violations.
- Autocollimator's
- Thank you for your help
- Electric motor squealing question
- What would this be used to check?
- Thrust Bearings fitting
- OT: Battery charging dilemma
- Question RE: brazing HSS
- I sometimes wonder....
- Newbie here
- DRO Question
- Removing Aluminum Chips From An India Stone
- hydraulic fluid leak from frame of ford 4500
- OT-41 Ford Dshaft removal.
- hill climbing
- National Hardware Show
- Let's talk about shop/home security
- TechShop Portland Grand Opening (Big Pic Warning)
- Auction thoughts and mild tool gloat...
- Reverse Dial Indicator
- Enco Free shipping?
- OT - Buick Keyless Entry Failure
- Desktop Question
- Bandsaw blade guide - what metal
- How To Sharpen A 100 Degree Countersink?
- a great bargain for someone buy of the year
- bargain of the year
- Adding T slots to lathe cross slide?
- why can't I mill at recommended SFM?
- Best fix for rust hole in air tank?
- MiniLathe-How to use 21 tooth gear
- Exploded Indicator
- I need/want some balls
- OT- sort of.. PCB etching, silk screening
- Coolant and dentists
- HSM Ball Turner
- Need help with Enco 1525 mill plug wiring
- Myford ML7 Lathe Rebuild
- Von Wyck 15x60 & introduction
- What rpm motor for a South Bend 13"?
- Press fit
- Harbor Freights made in the USA Comperessors
- small gear sets.
- different mindset fom industrial environment to home shop environment
- Boring Bar Advice
- Looking for small qty. of 5-40 set screws
- i'm looking for a source for very small stainless screws
- how to figure out the missing step pulley
- Enco 1525 spindle brake expedient fix
- cutting a worm gear
- Starrett Micrometer Calibration
- Long Eye Relief Scope Mounts for Vintage Rifles
- Gib strip taper question
- Looking for a replacement work-light shade
- Would like info on Quality Machine Tools
- How do I replicate one of these?
- Running multiple 3-phase motors?
- Help is at hand for Lucas owners
- Steel Selection
- Question For mainly the Canadian members
- Help Identifying Vane Pump
- Wiring to a machine in the middle of the floor
- NAMES Shelly's 1/8 Galloway
- The BBS link is gone from the HSM web site
- For the slow kids in the class...
- AutoCAD in 1963
- Metal Epoxy Recommendation - Aluminum
- Teflon coating quality
- Lathe tool post sizes
- Tapped Out or We Have Nuts
- Uh oh. This is very scary news.
- Rather unorthodox, but hey, it worked
- Book gloat
- CNC Lathe Gloat
- HSM May/June Article: The Odd Screw
- Mitutoyo KL DRO instructions
- Project update - whats your new project?
- OMT rotary table
- lathes and tubes?
- Who's used one of these?
- OT How Do Horizontal Directional Drills Work?
- Wood working
- Gearbox for Logan 820
- Using a blade welder?
- My new coolant system
- Central Machinery Brake
- Tool AND Auction Gloat
- NAMES 2009 Photos
- Tool grinder wheels selection?
- Holding ability of various standard V threads?
- Need some help finding info on a Beaver CNC Lathe
- Shop Insulation Question?
- Spell Checking
- ID gizmo's please
- Spell checker
- Educate me on knurling, please
- Slightly OT ... Pinging Photographers
- Camera's - mega pixels
- Found a lathe
- aol warning
- Anyone put a J head on a millrite?
- VFD up Lathe down
- Anyone you know?
- scary fabrication
- OT - We farmers have our bad moments too...
- 5C "pot chuck" or step collet use
- Albrecht Chuck Runout
- Comparing surface grinders
- OT: Info on a GI 8521 IC?
- Good or bad time to buy a Pontiac?
- OTx2 I can't take it any more.
- New/ Old South Bend- Proud new dad!
- Bye-bye Blu-ray
- Advice needed on bonding dissimilar metals
- Tool Gloat - Holdridge Radii Cutter
- Handwork & Craftsmanship Are Alive And Well
- Drilling deep holes
- OT: Sometime people astound me, in a good way.
- Ya'll had a surprise lately? Snake in the machine.
- OT - Admiral Nelson 2009
- OT- 2 stroke engine won't start
- A scraper sharpener
- Atlas Mill needs help
- Audit cnc lathe attachment?
- Help with size & type of endmill
- Can someone help me wire my pump?
- old Seattle company selling off inventory, tools
- Terminology question
- 14" Rockwell Lathe (back gear help)
- Broaching questions...
- Rockwell Toolmaker Grinder Query
- American axle will not make axels in the USA
- one for Mark jones's pals
- motorcycle stering stem?
- Enco May Free Shipping
- OT: Right to want it all these years, or, vindicated?
- Use of MT3 collets
- MT3 collet use
- Now, THIS is a Model Rocket!
- What do these punches & dies fit?
- Madmans Pics?
- OT: Stepper motor drive circuit....
- Need custom spline shaft adapter made
- Threaded inserts in acrylic?
- Vactra oil 3
- Checking actual hydraulic pressure.
- Ot, I love my old 1976 hobi cat
- Retrofit of Hercus CNC Lathe
- New Gloat: Mitsubishi Injection Molding machine
- need some Monel 400
- Checking the Monarch internals
- Slightly OT: getting the mower tire off the rim?
- Enco 20% off...2 days only
- Since we are doing OT tires
- spray for electronics?
- Machinists' Yard Sale (etc) May 16 Easton MD
- 1988 Jet JMD-18, need info/advise on cracked head casting.
- 1988 Jet JMD-18 with cracked head casting.
- South Bend Lathe
- english model engineering shows
- Scrap value of a Bridgeport
- Durapipe - plastic (ABS) air pipe.
- OK I give up... What are these things?
- A Test of my insufficient computer skills
- What Steel cable should I use?
- Way,wayOT. Mushrooms
- Rotary converter befudllement.
