View Full Version : General
- 3 Phase Static converter sometimes works
- New member new lathe
- Reversible jaw chuck question
- Can I use this to Replace a smoked VFD ?
- Determine the HP of an unlabelled 3PH motor?
- Riser block for Enco 1525 mill 8x36
- Uh oh, Pandemic decisions
- Lever feed tailstocks
- qt missinformation
- Material for Motorcycle Axle?
- Magnetic Chucks?
- OT - Electronics questions
- The future of CNC ??
- Mounted Dremel on may lathe post
- OT John Deere 450 Dozer
- Calling all Chinese caliper hackers
- Grinder Info Needed
- Mill Table Regrinding In B.C.
- Rebuild/improve Chinese Drill Press??
- Astronomy Picture Of the Week (APOW): Ursa Major in motion
- Columbia Machine Works, 1915?
- DOALL DH-612 Manual
- Printed material on 960 KOLee T&CG
- 6" Lathe Chuck
- Accupro ball bearing drill chuck
- My most intricate milling procedure to date.
- Using a insert for threading?
- Todays project, a wrench
- Brass Flower
- fifty-to-one long shot
- injection molding questions
- Help Identifying Carbide Inserts
- Wolfram Alpha
- Which would be stronger?
- OT Digital Cameras
- OT - How to get 24 volts from a Cummins Dodge
- anvil stands question
- Welding Course in St. Louis
- I need help identifying this drill press
- Bench Work
- Shear delight
- Delrin, plastic knurling tips needed
- S.B. Questions
- My Mystery Tool Acquisition
- er32 or small 3jaw chuck
- Which tool to countersink groove?
- photographing the aurora borealis
- Shop built router bit
- CAD program for moving linkages? Anyone.
- Celtic 12 by Mondiale 8x32 lathe on Tallahassee Craigslist
- The promised S.B. pics
- $30 electronic micrometer
- Horror Frieght chain hoist miss-labeling...
- Preferred buffer speed?
- Farm tool Custom-hoe-grabber made in HSM
- USB microscopes
- Harrogate show
- big fan of extractors
- Jacobs chuck arbor removal
- Milling machine and metal saw on Craigslist SW GA/FL area
- Anyone have May enco free shipping code?
- Most appropriate DC motor control
- looking at getting a Jet 321376 BD-920W lathe
- Sticky red grease on gears.
- Rarely Seen Shuttle Pre-Flight Activities
- Bicycle repair stand
- Cut too heavy or not?
- Small, cheap, compressor...ideas?
- OT question??
- Man what a Hassle Tapping?
- 8" Steel Rings
- grinding threads with a TPG?
- Would anyone have a Cameron micro drill press?
- .664" -32 tap???
- Kearney Trecker #2 Die Mill
- Golden Gate Bridge arch
- Greetings Everybody
- 9 inch swing lathe
- Upgrading to IE 8
- Cole drill improvement??
- Question RE: Bison 6 Jaw Chuck
- Reversing a motor
- Tee Shirt Launcher
- DRO power down memory
- OT--New Star Trek Movie and Beer (if you haven't seen it, spoilers)
- custom repaint
- Need help with rotart converter-PICTS
- Pinging Wierdscience
- OT: Magneto Problem?
- I like chemical polishing
- OT: Germany to ban paintball
- OT: need advice on voting system change, STV
- Fitting a chuck to a back plate
- Was told its a cobra?
- Picking up punch marks?
- just to introduce myself
- Wireless laptop adapter problems.
- between centres drive!
- end mills cutting speeds and feeds
- 618 atlas or lathemaster 9x30
- O/T Seals off Coast of NL
- Free Compressor Tank
- Cannondale's going taiwan
- New shop floor and chip scrubber
- Cutting Threads
- OT: Auto Steering Problem
- need to make a wind chime "more responsive"
- Quick n dirty light wire bender - unless you add fire
- Outside cherry picker, trailer concept drawing
- Threading tool question
- always nice to have the proper tool for the job
- Monarch builds repair parts
- (hate when they do this) Machine Price Ballpark
- Trying to Find Used, No Longer Needed Gears
- Enco 10% off + Free Shipping
- Video of 180 degree folding toolbar .
- How to make a splined hole fit existing spline
- How do I read this wiring diagram?
- pinging John Stevenson.....
- Generator MOD
- email with less memory hog habits.
- To Ball Screw or Acme? (Sieg X2)
- Electrical contact horse power question
- Trueing a drill table
- Proper way to unscrew lathe chuck?
- Oliver Die Filer Files??????:
- 15HP static phase converter
- Sport Flying
- A lesson learned about lathe chucks
- O/T Pinging Evan
- Mean Nasty Lathe Eats Machinists
- How to stop edge chipping when turning hard steel
- Proper scaffolding?
- ot/ot homeshop only by proxy
- Delrin/Acetal
- OT - Automotive Air Conditioning
- A bit more on yak CAD software...
- Ideas for clamp's swivel pads.....
- Using a Rigid 450 Tristand ?
- PVC Machining
- Vairable speed motor?
- Question - Boring on a lathe
- Bridgeport to HBM conversion?
- Play in spline shaft and receiver.
- Machining a sphere within a cube and a ball
- Fly cutting cast iron
- PayPal
- Bigfoot repair
- nother silly question
- HF spot welders
- Atlantis and Hubble transiting the sun
- Did Hawking shell out a connecting rod bearing?
- bridgeport powerfeed
- Does It hurt the collet to leave the tool in it?
- HSM Index
- Taper Attachment Sillyness
- Van Norman Horizontal Arbors
- OT/Trouble with Hubble
- Steel Suppliers in Eastern Massachusetts
- RPC question
- Steering on Cart
- i was a machining madman over the weekend
- Cleaning diamond bits & carbide...
- HI and a question
- Bridgeport quill play?
- Trueing Up a Three Jaw Chuck
- Rust & Cast Iron - What To Do
- Maintaining a Surface Plate
- Fell into some old iron today!!
- Recovering silver from plated brass?
- drill size?
- Really basic taper attachment question...
- SolidWorks Bible
- Rebuilding a bandsaw
- Slots in Drill Press Base
- Industrial sewing machine, stuck after housefire?
- Upside down tool holders ?
- Handle and Wheel kit for Lincoln AC 225
- HF micrometer
- That'll learn 'em...
- Endmills...
- Backplate Quandry
- HF cupons in MW and....
- Inside radius, lathe work. Help?
- What you can buy for $1400 - Tool Gloat: Mills and Drills!
- Surface grinder coolant flow
- Identifying Collet and a Stuck Collet
- OT origins of 4' 8 1/2" railway gauge
- Rattle in my head
- APOW: Astronomy Picture Of the Week
- Talk about an optimist - check this c-listing
- Comment/Opinon On These Material Prices Please...
- Estate Sale in Ridgfield, WA
- Extension Cord
- has anyone else noticed??
- OT - Direct Steam Injection for Heating Water
- Just my thoughts on a subject
- Dayton 3z325 dill press
- Newbie - in spite of the screen name -
- grease clearance
- ABS feeds and speeds help
- Help! I think I'm going nuts!
- Electrical - stray voltage
- OT- Fixing an electric Oven
- Bridgeport Powerfeed Full Of *&$%! And Fail...
- OT- Disc brakes on boat
- new Storage idea
- Scewing around
- Everede boring bars ?
- Question for UK members. When did CVA
- 9" Comparator Projector.
- Nardini 1230E Lathe problem
- Matals ID via the Seebeck effect
- Preventing rust in an electric motor?
- Posting pictures other than Photobucket, facebook account
- best way to clean up an old chuck
- hourly shop rates?
- lathe tools changing my ways
- OT: tire mounting
- APOW II: As the world turns...
- OT: Zenith System 3 Space Command Console TV
- Pinging David Cofer O/T
- chuck question
- LED lighting, no longer a novelty
- OT:Sound card ,hard drive or what
- How to find application info for driveshaft??
- Just finished a project.
- need help bad
- Firefox advertising <grin>
- OT California East ?
- Climb or conventional mill for long slots ?
- Delta Toolmaker Surface Grinder Project
- How does a Machine Designer pick an oil?
- Quick Change NMTB 50 tooling
- Lubrication for Milwaukee 2H Vert Mill ?
- Turning red rust into black oxide
- 'Nuther Question about NST 50 taper holders ...
- And one more ... TG Collets?
- 10% off entire Enco order - expire 6/30/09
- Mounting for Cheap Import DRO Scales on Bridgeport
- South Bend 9" Indicator Mounting
- Go-Kart suspension upgrade
- Help, problem with mower tires, solution to clutch
- Carbide insert mounting
- Expanding mandrel help.....
- Chatter in the work piece
- Wife left town, Party at the Cofer house... woo wiieee WAY OT:
- shortwave portable
- nylon jaws for re-chucking
