View Full Version : General
- OT A perfect day and hey Torker
- Silver Soldering 303 SS
- Surface Grinding Reading
- spotwelder with ignitron contactor
- Lapping A Granite Surface Plate
- Scraping Questions
- Milling Machine Ring Light
- Dolly for A Bridgeport
- OT -- Electrical Question
- Kid can't touch the ground :Simi-OT:
- Material strength data
- New Shop Invention for Bridgeport mill
- Test Bar Trouble
- PM 12 X 36 Lathe
- Tiller Shaft Repair - Advice/suggestions?
- European G 1/8 pipe threads?
- OT, but a good time was had by all-----
- Today....., packaging is everything!
- OT - Explaine this
- OT Time for a fresh start on California East
- Question About Hot Rolled Steel
- OT - For us firewood users
- MEW Article
- Fail-Tastic Powerfeed On Brideport: Take Two
- Drill shatter-why?
- So You Think You Want To Be A Shop Instructor
- looking for advice for my M-Head Bridge
- My recent project on the CNC
- OT: Pump pressure for irrigation
- Springs and the ends of them
- New guy with a few projects.
- Newall M20 DRO's
- Source for 4032 Aluminum for model IC engine pistons?
- Machining problem: How to make this?
- Material prices
- New guy with question :)
- Why A-nose spindles are a pain. [pic]
- OT: Downloading despite having to use a proxy site
- Enco Free Shipping
- OT 25% V.A.T. for the USA
- Using A Starrett 199 Master Precision Level
- Should A CNC Machine Tool Always Be Level?
- I need help with a different sort of project!
- Model Engine by a Brian perkins
- Tool size question from newbie!
- It's been a strange day
- OT A short story of stupidity, half tracks, forklift, pics.
- OT - Products that drive you crazy?
- Milling and surface results
- Maintaining X-Y position on a round column drill.
- New shop basement-storm shelter, concrete question
- Kit Car Problem?
- Machining Hastelloy
- Bilton Machine tool Co
- Universal Sharpening Fixture
- Bliss press?
- BP cnc question
- Tools Need To Scrape
- Why Chrysler is in trouble
- Strange resonance with 6 flute end mill
- Transformers useful for some CNC ?
- Blood....
- Cutting Thread On Spline
- Small Screw Storage: Idea I Just Had To Share
- OT Theft, anybody else get lately
- This guy has the right idea about retirement
- Trying to make a wrench
- Noise in Jet 1024 lathe headstock
- Semi OT: Stumpy gets a transplant
- Dividing Head Question
- Removing Oil from Inside Webb Mill
- Simple ball and radius turning tool
- R8 Adaptor/Mount
- OT: Propane Prices Next Year
- wiring dc power supply
- OT; Useful parts of a microwave
- Spindle encoding techniques
- Rotary encoders again.
- OT: Should I keep her around
- Alum Oxide vs Silicone Carbide?
- transformer question
- Fly cutter Q's
- suggested depth of piston ring grooves?
- What this forum and PM are really about
- O.T - Using emery cloth on wood?
- Cutting Problem on Bridgeport
- Plans/dimensions for media blaster gun?
- Energy ?
- what do you think of this milling machine
- Cast Iron Suppliers
- What does a 'Lathe Dog' do?
- Shaper manuals
- The Rockford Fi... er, Project
- The Fusion @ Home Project (free energy)
- New ways?
- O.T. UK question?
- Small lathe on Columbus Ohio CL
- Millport 12X36 Lathe
- Vertex Super Spacer - runout???
- Omni-post pics
- logan lathe motor
- Zero Morse Taper?
- Cutting holes in foam
- this is only a test
- Is It Possible To Make Or Purchase Oversized Roller Bearing Races
- Online Bearing Vendors
- Used Zip 100 Drive +
- Mill motor reversing/wiring question
- Hamilton metal lathe...
- Steel bushing press fit tolerance
- Schedule 40 Steel pipe prices
- Rotab Chuck Adapter
- Unknown-grade carbide inserts for Home Shop use?
- OTM Humor Subject: Calling in sick - this is hilarious!
- Local Man Will Save Auto Industry
- I want this.....
- i need to make a pulley
- Heavy Storage Tool rack
- OT: GM deals Hummer to Chinese buyer
- Fuel Injectors
- How do you use a rotory table?
- Please recommend me an AC servo motor
- engineering puzzle: the thesis committee
- Lathe tool bit question(s)
- Making my own K O Lee T&CG accessories
- Locks and their design
- Finally finished my work bench project (kind of)
- One for the brits..Did Ajax ever make their own lathe??
- Does twisting a flat bar increase its resistance to buckling?
- Trying to make chips....not strings
- basic lathe operation, turn to shoulder
- new grizzly band saw.
- I feel like a Loser again
- what is the difference between a leadscrew and power feed on an old lathe?
- I bought some very nice tools steel gauge plate
- can you offer advice on sharpenning a flycutter tool properly
- OT Snow Motor
- DRO on lathes?
- Round Ram Bridgeport: Worth Considering?
- Anyone built a vacuum casting machine
- Internet phone services?? anybody use them?
- OT : pressures on airplane wing
- Thread Cutting Challenge!
- Pressure Regulators
- Sewing Machine motors
- Electrical problems w/ Chinese dovetail mill/drill
- Bearing Retainer Adhesive
- OT: Any one need a ocscilloscope
- Mach 3 setup question. HELP please
- Toy Gloat: I got myself a Honda HT3813.
- My new fork tools, thanks for your help!
- Shop Lights?
- Threading Tool Holder ?
- Inserts
- OT - Computer question.
- I guess I need a bigger drill press or I need a mill
- Diode question
- Machining holes
- MT3 Taper how to break loose
- help me with small engine carb
- Sargon 652 DRO displays raw numbers, not inches
- OT: CAT 426 Backhoe trouble shooting questions
- What is a lathe?
- Grinder Project Complete
- Any parkerizers out there?
- OT: Electric Bill Fun And Games (Rochester Gas And Electric)
- Manual for Mill
- DeWalt Cordless Impact Wrench
- used carbide inserts, what to do with them??
- How accurate is high def. plasma?
- Etched PTFE
- Cheap Chicom drill bits.
- Calling Lane et al RE: Super Spacer
- Table Saw Blade Insert
- My daily question ...More wiring
- DIY electroless nickle plating?
- O.T. outgoing email
- printer cable advice
- I need help, gotta fluid engineer in the house
- Semi ot - Drum brakes warped
- Gone CNC??
- Gone CNC??
- Bridgeport cnc working schematics, Insanity on HSM, Choke
- Auction trends in an recession
- Need plans for a chain trencher
- Seriously OT, to a degree
- Black Iron pipe airlines
- cutting oil or water soluble coolant
- Tool find
- Open Headers
- Electrolytic rust removal and babbitt?
- Problem: Stock flex in the lathe
- Shear Pin
- How do you figure Hp on gear reduction motor?
- About time I had a tool gloat
- British association taps?
- Basic Bridgeport info wanted
- Clamp Knurling Tool
- Stepper Motor Stalls
- I need dimensions for Honda GX360 water-cooled twin engine.
- Harbor Freight Mill/Lathe/Drill-mabobber
- Electrical parts
- I got board today
- Silicone failure to cure
- Air Drive Hub
- Running multiple CCFL lamps
- shop made hydraulic cylinder question
- Home security/material check
- Craftsman/Atlas 6" lathe
- Rolled threads vs Screwcut threads.
- Enco free shipping and 10% off
- Tool post mill
- how is the hole in a hub of a cast flywheel located?
- Another Enco Deal
- Fuel Filters/ Oil Filters
- Better ENCO offer 10% AND Free shipping
- boring rods - what are my chances?
- Holt model engine videos
- Bridgeport power feeds
- heat treat a drawbar thread?
- Hurco cnc with min max
- heat treating or hardening gauge plate?
- Working in my virtual shop: My next big project
- Craftsman 6" lathe
- Evan's shop built lathe
- 6" 3 jaw chuck
- Right/Left tool holders and threads?
- Tap and drill recomendations
- Optimal computer needed for Sketchup?
- Doall C916 horizonal bandsaw
- Webcam for optical comparator?
- OT BPAP Mask missing
- Self Priming Fuel Pumps
- 110v motor wiring help for a drum switch
- Electric motor size (physical)
- Interesting site posted on the Home Model Engine Machinist site
- Jib Crane build with pics
- shaft material?
- Rack for QC holders
- Anyone in Vancouver, BC? I need some eyeballs on a shaper...
- Alternative to way-oil
- compressor motor question
- Very annoying banner ads
- Shop safety Forrest Grump: Stupid is as stupid does, to a new level !
- Eagle question (not the bird)
- Shop Wall Paint Color
- price of kerosine paraffin
- Hotrodding appliances
- Lies, Damn Lies, and Horsepower Ratings...
