View Full Version : General
- New to a horizontal mill, advice sought...
- Need an carbide insert parting tool for AXA sized tool post.
- Screw extractors
- O.T. another one grid locked Alistair
- Metal lathe for sale on Tallahassee FL Craigslist
- Garage Pak air lines
- Belt progress
- difference in % thread on screws
- Need a quote from a local hobby machinist.
- 5C Collet Workholding Issue
- Hard Lines
- Optical Comparator
- Sharpening station for wood tools
- cutting a diagonal line....
- Brians Flying Circus---
- Neat old pictures
- Cast iron tube stability ?
- Best fuel tank seal material
- OT, probably for Evan
- Machining forces
- Chaser dies
- Pi approximation
- OT: Trends in automobile wheel sizes
- Central Flood Coolant - crazy assed idea of the day
- Great News! ABC just declared the recession over!
- Cast iron question.
- Fly cutting with Criterion boring head
- surface prep for 6061 aluminum for acrylic lacquer
- OT Best Monitor Height
- Hybrid trike update
- What load can I put on this beam?
- Cincinnati #2 TC grinder manual
- How to get 55 degrees without protractor
- Cole Drill revisited
- Slitting saw Life
- calling lazlo
- Update on my latest "followed me home" surface grinder...
- How good is your eye ?
- Bridgeport Question and Photo test.
- 200 MPH Steam Car?
- Know of a good steel salvage or surplus in Albuquerque?
- Looking for vise
- Grinding Lathe tool Bits
- Wow one nice looking mill !!!!
- Waaay off topic Nasa type math question
- North Texas CNC Users Group Workshop
- interesting find i think
- Hour meter on Compressor
- How to disassemble Sherline 3 jaw chuck
- chuck adaptor
- Hendey lathe question
- Pinging Lazlo
- Congrats to the new Bridgeport owner
- Huge iron worker!!
- OT: Cash for Clunkers--anybody done it?
- Working with less quality machines
- die filer update --RTV prep cleaner
- Source for "flat" (not warped) delrin under 3/8"?
- Coal vs. wood burning stoves...not totally OT..
- Drilling lathe chucks for lifting eyes?
- Need Help Identifying Part
- Need Expanding Mandrel Plans
- Delta 1/2 in drill press value
- Measuring spline shaft
- Kent Vertical Mill - any good?
- Welders - Take Note!
- Underfloor Safes
- net book for CNC
- Question re diamond wheels ?
- OT: Acetelyne powered Vortex generator.
- question about dividing heads
- Pinging John Stevenson
- Even more about flat belts.... improvements
- Looking for a cheap 2 axis DRO display
- On the hook
- Pantographing / Engraving Titanium
- Question for the Aussies, mainly
- R-8 Taper Turning
- There - I fixed it !
- Free Camping on lake in Michigan, 49274 zip, inheritance land unused
- Self-Centering adjustable chuck?
- Any tips for turning on a mill?
- Can you cut external threads with a die?
- o/t the English
- what to do with this
- ID thread measurement
- OT: Quality of American Homes going the way of Cheap Chinese imports
- Help needed with profile? cutter
- OT goldwing aspencade
- Lineshaft going up
- OT -- Photo manipulation software - suggestions?
- How to cleam kerosene blow lamp?
- What would you buy for $80.00?
- Warning: Machining content. Making a timing belt pulley
- Squeezing it all in, looking for ideas..
- O/T But I'm Amazed
- Latest Project
- how plug and play are DTO scales?
- Darex for sale on Central Illinois CL
- cutting spokes in a wheel
- Custom lincon auto dark helmet
- CAD - Trouble Learning
- albrecht chuck
- AC Motor Suggestions?
- OT: The view from my deck - pix
- Grinding angles on threading tools.
- LED work lights, here is a deal
- Carbide Inserts and Drills
- Lathe drills
- Trick to measuring a hole diameter
- Is it an air compressor or jet engine?
- O.T. Alzheimers
- H/V Bandsaw Blade Questions
- OT - Help needed for trip to Oz
- Who's the best at rebuilding a B'port head
- t-slot Al source in Austin area ??
- How do I know if I have exceded the rating?
- Clark Vert Mill?
- Members located in Great Britain
- How Was It Done?
- My Latest Small Project
- Hockey puck + machining?
- Enco Deals
- "Printing" Stainless Steel
- Steady rest modification, what material to use?
- Making your own insert end mill/face mill?
- Trouble milling aluminum- What am I doing wrong?
- Jib crane
- OT: Any Entomologists On The Board?
- Another VFD question...Hopefully simple
- How Much??? Starrett Australia.
- Tool gloat and a question
- Buckley (MI) Old Engine Show
- Lapping in Cams?
- snagboat accumulator
- OT:- Cleaning Diesel Stain from block paved drive.
- Split clamp design...
- Chinese quality changing
- Free shipping on vises from Enco
- Surface Grinder on CL in North Calif.
- Hanger Bearing?
- Help with pipe angle fab
- Small Gears
- Converting Baldor buffer to grinder?
- OT, Big brother reaches british homes
- Home sandblasting
- Mill/drill surface grinder construction help
- 1" tool in MT#2 tailstock
- Technoweld
- need some advice on busy bee 7x8 lathe
- QCTP and the essentials?
- Knurling Flats
- Filament wound fibreglass tubing source?
- OT: At last, an age old question is answered
- 3 jaw chuck problems
- Cleaning House
- Sticking with "Old Faithful"
- Machining spot welder tips
- Seattle's Wilson Machine Works
- Is it true? VFD question
- 9x20 H/F lathe owners
- Best way to locate Rotary Table jobs ?
- Need a decent link to removing a 2J BP quill
- Level Calibration
- Does anybody own a machinist's level from CDCO?
- Model Engine Builders
- Auction Report – Sacramento CA
- Chinese - good with numbers?
- Some parting thoughts...
- OT - Open Office
- Prepping concrete floor for paint
- Been waiting for something at HF -- nows the chance .. 20% off
- My first Tool Gloat
- OT/ Sticky steering wheel???
- stuff you shouldn't burn
- Source for import tools ... ?
- Varying spindle oil level
- Quick ENCO/free-shipping/drop-shipping question...
- insulating board
- Of CAD, CAM and a new camera
- Lathe Leveling with 8 Pads?
- Semi OT: Heroes and machines (BIG pics)
- Thank you Frank Ford!
- Steam Explosion
- bad timing
- Cross slide stop--
- How to I machine this(?)
- Irwin Bit Set
- So I made a "fittin"
- How to make this tapered hole?
- OT- humor myself, my losing battle with hospital.
- need a toro s200 snow blower diagram
- vfd
- Moving BridgePort.
- Sellers 1G Drill Bit Sharpener
- OT: Lasers replace spark ignition?
- Selling an old Southbend Lathe
- Sony LH30-2 DRO- looking for the Manual
- What is this stuff and why is it so hard to machine?
- Vacuum pump help/advice needed
- Here's a few projects! Just whish I could read it
- small shop ideas
- More LED lighting
- OT Huge Vise G.F.E.
- vfd
- How to machine an internal hex?
- HSM Magazines
- Product Review: Milwaukee ˝ Drill
- Vacuum Table - Finished
- the cost of pucks
- Trav-a-dial vs. DRO for a lathe
- What"re your favorite countersinks and work stops?
- Most common 220V 3-phase outlets / plugs
- WTB Acer mill parts
- Silver Soldering/Brazing
- For sale posts?
- T&CG motor bearings
- Centering tool for the lathe--like the old Starrett No. 65?
- Machining dead soft aluminum against conventional wisdom
- Internal threads
- Backlash in DRO?
- NPT pipe thread into shallow hole?
- Bright Mild Steel
- I'm never going back to Machine Skates
- Breaking news....
- Maybe I'm retired---
- Collet Chuck with 12x1mm threads?
- Treadmill motor control
- Aluminum vs steel
- Scary Saw Blade
- gear blank caculations
- Scary Saw Blade
- Home Shop First-Aid ?
- Fasteners at reasonable prices
- 5c collet reducer
- Ideal tool customer service
- Super Duper Shiny New Tools!
- Starting the addiction - Will need HELP!
- Where are the machine tool places in the Dallas area"
- OT - I brought a large endmill home today.
- OT England visit
- Power Twist links V belts
- MSC Discount Days?
- 1026 steel heat treating specs?
- Speed lathe?
- OT: USA Today scared the p!$$ out of me today!
- Source for *very* thin #4 "washers"
- Selling my 9in SB
- Testrun Triple Expansion Engine
- 15% off at Enco
