View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 [128] 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209
  1. Motorcycle top end re-build
  2. Curious........
  3. Hardinge DSM 59 questions
  4. Posting pictures
  5. Newbie gear question
  6. need help suzuki intruder rebuild and bad oil burn
  7. Steel source
  8. 3D CAD on the cheap...
  9. ot - Anyone with HD radio experience?
  10. Speed Control for 120 VAC Drill Press.
  11. What material are disk harrow discs made from?
  12. OT: Anybody here know about DVR's (Digital Video Recorders)
  13. Using a horizontal mill...
  14. Coolant pump...
  15. Problem boring on my lathe.
  16. Chocolate martini rotary table
  17. Help with a reamer
  18. Need suggestions on industrial things to see on cross country trip...
  19. Wayyyy OT Shooting star bonanza
  20. Help with South Bend 9 taper attachment bracket
  21. Nationwide money making idea, home shop machinists unite
  22. This may be of use to someone here good luck.Alistair
  23. Strength of material issue or bad design?
  24. It's real - but is it steel
  25. Couple of neat sites:
  26. Cutters sharpened in the UK?
  27. Plastic standoff for holding insulation???
  28. Dro's
  29. How to make sandpaper last longer?
  30. Idea for a wiggler from edge finder
  31. o/t planet
  32. OT: 4 Gauge Vacum set for MC
  33. O/T (sort of): Reconsidering the manual arts
  34. An Amazing Scope of Craftsmanship
  35. DC Motor Question
  36. any one here live close to north bay ontario
  37. please recommend oil based coolant for Hardinge HLV
  38. For all us knuckel busters
  39. Heat pump compressor sounds like impact wrench when voltage fluctuates. What gives?
  40. Chip clearing vs lubrication
  41. Theives
  42. gear reductions for hobbist. .
  43. Homemade planner
  44. Need help ID old Century 1/2 HP motor
  45. Cutting Acme Threads
  46. Help - Compound lathe gears coming loose
  47. Arbor press tool gloat
  48. Troubleshooting AC single phase motor
  49. Cash for clunkers SUCKS
  50. Poor Mans Dovetail---
  51. Clausing Model 100 Mk3 Question.
  52. Oil Equivalent?
  53. Bandsaw blade tension
  54. Old style soldering irons
  55. Engine Hoist - refill cylinder?
  56. Unusual Bearing
  57. New Toy
  58. 24-42V AC on a lincoln Mig welder???
  59. OT: Scored a "vintage computer" need some pointers...
  60. 2 flute endmills for aluminum
  61. Cash for gold review, they pay18%
  62. Lorch Schmidt Parts Found
  63. Semi-noob welding/fabrication question
  64. O/T Clutch Saftety Switches On Vehicles With Manual Transmissions
  65. How to save CAD image to jpeg
  66. Free to a Good Home
  67. Which Lathe?
  68. Mill tool changers ?
  69. Getting Morse taper precise to bore ?
  70. How to engrave graduations on tailstock spindle?
  71. OT: physics question
  72. My new toy.
  73. Portland Ind show
  74. binocescope OT
  75. The same damn tool grinder question
  76. Any reason I can't cut threads with a TCGT insert?
  77. Espingarda da Perfeyta
  78. Question for Oldtiffie
  79. K O Lee BA-960
  80. electrical questions?
  81. Need help identifying material in collet closer
  82. Question About Flycutting With A Boring Head
  83. Will an annular cutter cut through weld?
  84. homemade hole saw tubing notcher
  85. How to cut an INTERNAL CONVEX radius?
  86. pinging john stevenson
  87. Bridgeport repair
  88. Painting a Clausing 4900 10x24 Lathe
  89. OT! Interesting YouTube vid
  90. Help me choose babbitt grade for taper attachment bracket
  91. Roughing end mill
  92. Are niagara cutter endmills good?
  93. Interrupted thread pipe taps
  94. Harbor Freight stuff made in Russia?
  95. DNA assembles itself into machine parts
  96. O/t X 2
  97. Machining figures, verification please...
  98. Twisting square tubing
  99. Boring a reloading die (how to make the neck loose?)
  100. Making my own reamer
  101. OT.. kinda - Gallileo's Telescope!
  102. HF mig welder experience
  103. All in one lathe tool grinder jig project.
  104. Hendey electrical question
  105. Holy Cow--I'm published
  106. Diamond file wanted
  107. how to measure internal threads?
  108. 1 Hour Timer
  109. OT glass cutting
  110. SEARCH doesn't work
  111. Harbor Freight press
  112. PM really has some odd ads......
  113. K.O.Lee brkt. for Lane
  114. My Monarch dial project
  115. Interesting Shop Floor
  116. Your old doggie: email box full?? MOderator?
  117. new 12x36 lathe
  118. K O Lee B-943 Motorized Workhead
  119. polyurethane 2k
  120. Material Choice - Pan handle
  121. ot - suggestions for a decent free firewall?
  122. Standard Modern 9 inch Lathe
  123. Shear for 11 ga stainless
  124. ot - Alone in the wilderness
  125. Nut and Bolt Stress Calculators
  126. Some motorcycle porn for y'all
  127. Let's say I want to drill holes to fit AAA batteries...
  128. Mill cutter query...
  129. Sir John
  130. Accurite 300s
  131. Not completely O/T - mailing to GB
  132. OT, Win XP question...
  133. Scottish justice is VICIOUS!!!
  134. Old CAD/CAM software compatible with Vista?
  135. OT: Amazing cloud display
  136. new dial for me 12" craftsman / atlas lathe
  137. Another taper issue
  138. Strong Arm Shaper
  139. Gas struts for HF-45 style Mill?
  140. blade balancer
  141. Brake drum Machining
  142. D-4 C-frame pin questions
  143. OT: Anybody upgraded to Firefox 3.5? Any problems? Worth the trouble?
  144. Sort of O/T, Making a Gear Shift Knob
  145. Used machines
  146. OT again hard drive disc reflectors
  147. jaws for 9 inch chuck
  148. Help identifying lathe part
  149. ot International hospitality
  150. BP mill
  151. wringing gage blocks?
  152. Design of mating threads
  153. Thread cutting, how many turns? Maths query...
  154. OT - Laws
  155. Cutting a radius, not a sphere
  156. Adjusting Air Compressor switch?
  157. installing DRO'S
  158. South Bend Shaper Sale
  159. Bridgeport Descriptions ?
  160. Non Circular Gears
  161. Kurt Power Drawbars
  162. R8 to ER adaptor
  163. More steam engine foolishness
  164. Coolant Evaporation?
  165. A Durable Anvil Mount
  166. Tell me about this Tray-Top Cintilathe...
  167. Lathe and flycutter rake angles
  168. Making quotes, business question
  169. OT; import favorites to Firefox
  170. Logan lathe, Good deal?
  171. Cutting 1/2 circles what tool do I use?
  172. Pinging Capri
  173. Dviding head formula ?
  174. Interesting Projects from German Guy.. link
  175. Gorillatorch Shines Light Exactly Where You Need It - A possible shop light
  176. Metals source
  177. Small Screws
  178. recoil spring winder is now built and works great
  179. rotary table and deviding plates
  180. Hardinge HLV
  181. Surface plate cart
  182. oil field drilling rig
  183. sometimes you win
  184. Lathemaster square column mill
  185. Finally sold my 9in SB lathe
  186. Grizzly DRO
  187. new to me vertical mill (FREE NO CHARGE)
  188. Making a radius cut in the middle of a bar
  189. Need Help with a Jet 1024 P(Y) Metal Lathe
  190. Chuck size in 9" SB
  191. CDCO Rotary table
  192. Thread Milling ???
  193. Bridgeport DX control
  194. Broken Sector Arm
  195. Shop made hydraulic seals?
  196. Reality Check On The Price Of Steel
  197. Grizzly Quill Stop
  198. Increasing Logan spindle RPM?
  199. Paint recommendations?
  200. Snow Leopard -- worth upgrading?
  201. Gun Blue / Black Oxide Supplies
  202. Monarch ee lathe question
  203. speaking of rake angles ------- ?
  204. Ot Mac Os
  205. All geared up----
  206. Plastics & Adhesives
  207. OT This should put a smile on your mug!
  208. Kicked some Lathe tires today
  209. Aluminum: When, or is, stress relief needed?
  210. Enco 20% off for 2 days
  211. Tinker tool and cutter grinder attachment.
  212. Clever ways to maintain parallelism?
  213. Long Chang goes walkies pt.1
  214. Brit's finally did it!
  215. thread BSPP or UNS
  216. How Would You Make This Thread
  217. What lube for table saw gearing?
  218. OT: Where are desktop photos stored in XP?
  219. An interesting site
  220. Gearcutting newbie seeks straight advice...
  221. Depth of cut.
  222. Tools tools and more info on those garage sale finds!
  223. what DRO to buy.
  224. Shop Layout: Walls or Center for Machines
  225. What is it?
  226. OT repair manuals online
  227. Jet-vs-Grizzly lathe
  228. mill vise
  229. Height gage.
  230. excel help please ? ? ?
  231. Way covers.
  232. Can I Drill/Tap my magnetic chuck?
  233. tool score- vise
  234. Telescope Clock Drive 220v AC 50Hz (OT)
  235. Concrete form help
  236. LED Questions?
  237. Note to Alguy
  238. Interesting tool article
  239. Socket Racks, Trays, Rails, Whatever they are called.
  240. What type of plastic....
  241. I need some SS pipe for a customer
  242. Toneu cover latch
  243. The PM guys can relax!!
  244. 600 group (colchester/harrison lathe etc)
  245. Lathe button colors
  246. Divisionmaster and Vertex Rotary Table
  247. Used Equipment Swap Site
  248. Starret marking rule
  249. OT: Web browser graphic downloads "time out"
  250. My mill vice again
