View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 [130] 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211
  1. OT trailer brake ID
  2. Pallas V1 vertical milling machine
  3. Loose y gib on Bridgeport
  4. Machine Lights ... which ones?
  5. Billet 70 series Block
  6. OT: Charging a deep cycle battery.
  7. Lets build a pump---
  8. Msc
  9. Free online book "The Art of Engineering"
  10. Noisy Bridgeport Head
  11. Chemical Polishing of Lexan
  12. Box tools & Die Heads.. Awesome!
  13. The shaper is done!
  14. Building a cooling mist system
  15. vfd installed, a few problems
  16. Heidenhein DRO-help or manual
  17. Rust considerations in an unheated outbuilding.
  18. Cincinnati 19 Drill Press
  19. Atlas Shaper
  20. check this tecno stuff out its cool
  21. DRO off by 0.05" per inch
  22. Collet Idetification
  23. Hydraulic question
  24. BenchMaster Mill
  25. Wax vs Oil
  26. centering a .250 steel shaft for drilling
  27. Tapered Pin Reamer, Spiral or Straight?
  28. Ford F-150 Truck
  29. OT Masonic ring; how to sell
  30. Converting small engines to run on alcohol?
  31. Army Machine Shop Document
  32. V-Belt lengths for Rockwell 14" metal/wood band saw?
  33. Fishtail drill bits
  34. finelly bought a mig yesterday
  35. simple smoke bomb (way o/t)
  36. DTI question
  37. OT Head Light Lenses
  38. OT - PTO-driven hydraulic pump on tractor (Cecil, are you out there?)
  39. Drilling a hole in a hardened shaft
  40. M2AL Tool Blanks
  41. Insides of a grip throttle.
  42. Hydraulic quick fittings that don't leak?
  43. Annular cutters on a mill ?
  44. Lens to increase apparent size of dashboard display??
  45. 3-phase tool gloat... sorta...
  46. New cut off saw
  47. is this correct?
  48. Gatling Gun Project
  49. Anyone using Alibre?
  50. Anyone heard of this kit manfacturer?
  51. Am I allowed a tiny gloat ?
  52. OT: Auto Safety
  53. O.T. formula for speed in miles per
  54. New workshop, workbench ideas
  55. New Milling Machine
  56. Almost free energy (loss)
  57. Machinery Label Attachment Fasteners
  58. check out the new old iron
  59. Guidance cutting internal cone.
  60. man in space
  61. Total loss coolant?
  62. O.T Iowa
  63. Like new, eh? scary trolley
  64. Tough Nut
  65. Advertisment in the Mast Head.
  66. New way of saying "Made in China"?
  67. Where do you look for auctions?
  68. New Peerless power hacksaw - horsepower needed?
  69. turned a internal thread today
  70. Quickest way to set the cutters on a face mill?
  71. Whent to the Portland show
  72. Shaper auto down feed?
  73. What effect does heating cured epoxy have on strength??
  74. garage sale finds
  75. Took It Apart And Now It Works Good As New!
  76. Magenetic Gearing
  77. Loctite shelf life
  78. Useful machining/engineering software?
  79. Newbie question: Sterns brakes
  80. ot - southbend lathe in LA on CL
  81. Cleaning Mold From House
  82. Workholding Question, excuse to buy more stuff?
  83. 4 jaw independent independent chuck
  84. 3/16 keyway in grade 8 bolt
  85. more mystery metal
  86. Off Topic Times are Tough
  87. "Shuttle Express" manual control for CNC-ed Sieg X3 mill
  88. Metal Choice for Square Repair
  89. you have to check out this blog
  90. Retrofiting a series 1 bridgeport with boss 6
  91. Building a RPC motor hp & phase questions
  92. [Vendors] Sources for Valenite's Products
  93. Making graduations on dials more visable
  94. chiped carbide tooling
  95. O/T Scammers, again
  96. OT/ Woke up on Mars This morning!
  97. Been to any good auctions lately?
  98. Online Machinist Technician's course - for beginners
  99. How would you make a few of these?
  100. Concentric brand Boring/Facing Head?
  101. Acme thread adapter?
  102. Bad Starrett Acme Thread Gage No. 284
  103. Woodenclock Plans
  104. Carbide Tool Grinder Question
  105. What steps to take making a Fly Cutter ?
  106. My cannon build
  107. here you go guys
  108. Anyone have a cannon drawing?
  109. Crane driver wanted
  110. Interapid question
  111. Lithium Ion cordless tool batteries
  112. And It Begins...
  113. Dake Press, manual to auto???
  114. I want to support local retail, but prices are insane sometimes
  115. 2 56 Tap guide not working
  116. Mill finish on aluminum
  117. Opinion on drill required.
  118. OT: AC charge valves on Silverado pickup??
  119. I need gun help
  120. Clausing Vari Speed Lathe Advice Needed
  121. Any DRO experts around???
  122. What will happen in
  123. Looking for some MT2 tooling
  124. A little restoration project
  125. belt lacing
  126. Tell me about your 11 x 26 lathe Grizzly G9972Z
  127. Need drill press parts ?
  128. When bad monkeys attack, internet assault by others
  129. Layout fluids/ scribes
  130. What qualifications do you need to become a Journalist ?
  131. water in gear oil of tractor
  132. Coventry Die Head chasers
  133. Lever action tailstock ram linkage question.
  134. Internet Air Travel Bookings
  135. Will Grizzly be similar to what Craftsman or Atlas was?
  136. welding cart is now built what a job lol
  137. Different approach to gearmaking
  138. O/T Garage door spring ?
  139. Long radius grinding
  140. Info on Axleson engine lathes
  141. Computer problem
  142. What do you do with seconds?
  143. cheap ebay bearings - anecdotes & such
  144. bearings for use with grinding aparatus
  145. what is the proper way to use a reciprocating saw ("Sawzall")?
  146. Just Got Screwed on E-Bay, can someone help me?
  147. Examples of 7"-10" Bench Lathe Stands/Cabinets
  148. Examples of 3"-5" Bench Top Lathe Stands/Cabinets
  149. Coolant control on a mill
  150. ok, so what IS the rigidity of a Bridgeport vs CNC machine vs crappy mill-drill?
  151. Need manual for Kysor/Johnson bandsaw
  152. Book Gloat
  153. Science Fair Projects..Ever do one?
  154. 12x36 Craftex lathe arrived yesterday
  155. Rotary Table for X2 Mill
  156. Possible surface grinder tool gloat?
  157. valve drawings
  158. Free Forklift..you just have to go and get it
  159. Source 4 - Grizzly Surf. grinder arbors ??
  160. My new milling machine
  161. Different guidelines for using roughers?
  162. Shipping to Alaska
  163. motor find
  164. extremely O/T pumpkins
  165. Looking for VersaTapper 6200 manual??
  166. New season for astronomy
  167. Grinding Endmills
  168. Bridgeport Quill pin?
  169. Softer plastic for injection molding
  170. Nice Artistic Bit
  171. Sending Her Off LOL
  172. magnets
  173. What place is better to buy OR sell...Ebay OR Craigslist?
  174. suggestions for a cleaner/degreaser
  175. Damm EBone Seller LIED to me - $&@%
  176. How to indicate chuck
  177. How to Remove a Stuck Roll Pin?
  178. OT: is anyone here a UL508 shop?
  179. Vfd enclosures
  180. yep, I don't just argue here, I work in the shop too
  181. O/T Magnification needed ?
  182. O/T Need a chuckle
  183. best chilli recipe
  184. Job sight pic.
  185. More free machining course material for newbies...this from MIT
  186. Broaching, with a cute factor
  187. Motor repair - plastic fan needed
  188. Hobart Simplified Welder
  189. OT - Goggle Redirect Virus
  190. Need book titles on knifemaking please.
  191. Looking for toolman
  192. Powermatic #87 Bandsaw Trunnion
  193. Bench Tool Quick Mount Systems
  194. The Messiest Shop...Got a candidate? ;<)
  195. Capstan lathe info how much do they weigh?
  196. Micro Polishing
  197. Thinking about buying a sander
  198. SketchUp 7.1 available
  199. General Windows moan
  200. Attack of the aerosol can
  201. Who resharpens end mills
  202. OT - Ken Burns's The National Parks Special
  203. AOL question: Favorite places aint no place
  204. Is manual milling really a prerequisite for CNC work? (Warning: long and babbly)
  205. Where did the paper clip go?
  206. The Langlois EDM Design advancement
  207. Bench Testing Fluorescent Ballasts??
  208. What should a Bridgeport cost?
  209. Balky power feed
  210. Securing part on lathe with double-sided tape.
  211. Plans
  212. Log Splitter Upgrade: MORE POWER
  213. New Bridgeport Tools
  214. Excavator Pins & Bushes
  215. CNC parts, For UK members
  216. A gold mine of free downloadable books
  217. New mill on the way
  218. Cutting oil infections
  219. connecting ac drive to computer
  220. motion control
  221. X, Y & Z...Is it only me????
  222. Bearings ... The infamous topic
  223. Bridgeport M-head
  224. Good old cutting oil
  225. 4 Cylinder OHV engine drawings
  226. Semi OT: Pancake Pickin' Robot
  227. Seeking lathe drill-chuck recommendations.
  228. Pinging Lazlo
  229. Hardinge HLV-H
  230. Black Hills Model Engine Show 2009
  231. servo power feed
  232. OT Soldering tips w/sensor
  233. Help! Any Sharp mill owners out there?
  234. Tool gloat: Went to dentist, had tooth pulled
  235. Pipe threading on a lathe
  236. Another site...
  237. Yet another spindle / bearing question
  238. Metal hardness testing
  239. American Precision Museum
  240. Rusty stock procedure
  241. New toys
  242. OT, Computer/internet question
  243. HF 6" Digital Caliper $9.99
  244. BBS project of the month
  245. Old towns in New England---
  246. Hoarders The Show
  247. Archtectural Cast Iron Photos?
  248. All back issues of Home Shop Machinist magazine from 1982 to today.
  249. What you think of this Milling Machine?
  250. Ok, so I did it
