- O/T Hearts of Oak
- Simplex lathe, #001
- How do I fix this?
- leatherman tool review..xmas is coming
- Just made an impulse agreement to purchase..Anybody with info?
- Bandsaw blade welders?
- Finished My Lathe Slotter Tonight
- Combination drawbar tool
- Reproduction Spitfires
- OT Jeeze guys did I screw up?
- Fourth time's a charm
- Bandsaw hydrolic downfeed
- Burrs after side milling.
- What is your favorite time to work in your shop
- Power Head Adjustment--Chinese Mill
- How can I Narrow Laser Line
- BOLICBAR wrench ???
- finished my Follower Rest
- Lagun Mill in Tucson AZ?
- Metallurgy?
- 4 jaw self centering chucks
- OT - Best one liners
- Powder Coating T&C Grinder Parts--Opinions?
- Help with silver brazing question
- Broken Casting-I need help.
- A rave from the grave
- Metric vs SAE Threads
- Bandsaw Blade Advice
- Facing Cutter - NOT INDEXABLE
- Glacern vices
- Afternoon project
- Casting a South Bend follow rest with pictures
- Polishing a Turd: Salvaging an import mill vise
- Belated Tool Gloat
- Glacern Vise review
- Soluble Oil what do get
- Best Drill Chuck, 1/4" or Under
- Oil filter search?
- Ya'll remember my totalled civic?
- vanamo 14" shaper
- Question for the UK members
- morris taper
- Building Trailers...Let's see what you have done.
- Buildiing a Greenhouse...Looking for ideas.
- Sheldon 12" Shaper
- Auction anvil I didn't buy.
- Need a new AC motor for compressor
- O/T: Know of any On-Line VIN look up
- New Grizzly Mill
- Semi OT: Plug Versus Plug
- I made a drill chuck arbor ?
- Building An Injection Molding Machine
- Vacuum Table - upgraded and improved
- I need brazing barrier, or pin for brazing alignment that won't solder!!
- Funny looking holes
- how to clamp multiple pieces in vice
- How do Leeson and Baldor motors compare?
- Where to find? T-Sloted Plate For Drill Press Table
- Why are height gauges so $$$?
- Meteor Shower tonight
- Old Timers office decorations. OT
- is there a site on the net that shows?
- John Stevenson
- Small oven one-day special
- Anyone here in the US bought from Arc Euro
- Lathe 4jaw 2 part jaws
- Any Idea Why My Lights Flicker When My Air Compressor Runs?
- OT: Finding a water leak in a buried line.
- Suzuki turned generator.
- OT: Electric wiring in basement
- Headstock alignment
- Which spindle taper is preferable?
- What di I put in my coolant pump for the mill
- Mechanical Timer Sources
- Harbor Freight vs. Princess Auto...how do they compare?
- OT War Of The Worlds
- thought for todays H.S.M.
- OT: Water/ash stain removal from brick?
- What do you do in the shop?
- Looking for an oddball tap...
- Name that tool
- Bridgeport Series 1
- Improveing Taig Mini Mill
- Different kind of workshop
- OT - Hanging Laundry and Having a Shop
- Why more woodworking books than metalworking ones?
- how to post pics using picassa?
- what is this
- Any HSM use magnetic chucks ?
- Does John Foster still hang out here?
- Bandsaw project....
- Recommended Archival Storage of Images?
- Used cars
- Help with cutting stainless steel
- The Software guys are at it again#%!*&
- off to the beer store o/t
- Windows 7 - Beware
- Trying to figure out phase converter needs.
- R8 vs MT3 mini mill
- Ejecting Drawbar?
- DRO recommendations for an EMCO V7/V10
- solder? screw? rivet? Attaching this to that
- Fixturing for odd shaped parts.
- Using the 5C endmill sharpener on a surface grinder?
- What would you call this nut?
- true or fales gravity in space
- Secret Life of Machines
- Cheap expanding arbor
- Thread inserts
- OT talk like a pirate day
- Machining Acrylic
- intro and Mastermill question
- Yet Another Injection Molding Thread
- uk question re delivery and uplift ot
- Want an Aluminum oxide wheel for my HF tool grinder
- Re: What do you do in the shop?
- Material for small shaper vise?
- OT - Lost Network Access - Vista
- OT - Gotta love the UK Heath service
- Buying a lathe
- surplus motors
- free energy
- For Sir John!
- How come HSS endmill usually have a wider shank than cutter?
- Insert parting
- Did ya ever wonder----
- Need Tecunseh 143 806062 power curve info
- Bore size
- Fanuc control
- Modifying engine valves
- Seattle Craigslist Horiz. Mill
- Looking for Lagun owners for HELP
- Help with an Aciera F1
- OT - LHC Operational
- Sulferized Steel
- Adjustable tailstock quill bushing?
- O-ring chamfer seat dimensions?
- Speaking of Spitfires
- OMG one of our HSM'ers neighbors are complaining...
- Belsaw Operators manual
- Skip Diving
- Poor man's genny
- Article: Low-Cost Induction Heater--Pinging Ernie Henne
- HTD timing belts?
- Finally a Drill Press Tool Gloat
- The "doh" grinding rest.
- OT-Worst splinter ever!!!
- How to tell what backplate I need
- Power hammer, Rube Goldberg style. built from scrap
- Home Made Quick Change Gearbox
- Off Topic- But still an engineering problem
- too bad for you UK guys - I'm just lucky I guess
- 9X20 HF lathe help
- ot: hit and miss engines
- riveted hulls
- Work table
- "A" verses "D" lathe spindle types.
- Oil hardening tool steel
- How to remove backplate
- Calculating Bolt Hole Radius....?
- Anyone ever buy from Ozarkwoodworker
- Can't use indexable tooling on a series 1 brigeport?
- My last job.
- water power
- how much would you charge to make this?
- For those that havn't hardened 01
- Forging and Forming.
- OT Vista Computer
- Auction advice????
- Which shape most flex-resistant?
- pneumatic motor.
- Bandsaw blade formula
- Need datasheet
- Desperate retailers seek holiday season rescue
- Heat Transfer Question
- What is this
- Designing in Fractions or Decimals? Preference?
- excello mill oil seal
- Started on a HSS cartridge
- south bend 9"A threading
- Help removing chuck from Craftsman King-Seeley drill press
- ID a mystery metal?
- Got very lucky today
- OT: How the Earth Was Made
- Trouble making dovetails - darn bits keep wearing out!
- Lathemaster LMT25L Milling Machine
- A couple of my recent projects...
- Brierly ZB 21 Drill Sharpener, any good John?
- Wheel shapes for tool grinders?
- OT Pickup Truck and 4X4 Woes...
- Webcams and Mach3
- OT: I'm thankful early this year.
- Pinging The Moderator/Editors
- OT, Computer, RAM upgrade
- Information needed about mag drills
- Bridgeport Parts Dealers
- Update to broken lathe and broken leg
- OT - 1 in 3 laptops die in first three years
- OT - Feds find association between drywall, corrosion
- Busy Bee doesn't deliver
- Need Help Drilling a Rockwell C50 Material
- Storing brass pieces
- Air compressor valves
- Z axis drive
- What I did in the shop
- Semi OT High lumen flashlight
- Clausing lathe opinion
- Bizmark (sp ) Mills
- A little jig
- Bridgeport mill: How many turns on the return spring on the quill downfeed handle?
- Two transmission assembly stands I just built.
- New Jacobs chuck collar same as my old 633C chuck?
- Fluid valves
- Gotta love the scrapyard...
- Polishing Polycarbonate
- rocket scientists I have met
- he Machine Is Eating Its Creators
- Gripping/holding a MT2 taper for machining
- New member and an Atlas question...
- todays project modded my pocket rocket
- Any NEW bike Lift Ideas?
- Replacement glass plate for microwave, $38 to $48! Outrageous!!!
- saving a widow's gmail
- Any Logan 820 owners in the Group?
- Obtaining a Odd Chemical.
- Old Starret Dial Indicator Attachment
- real or fake????
- Pics of my last job
- compressor problem and update...Before and after pics..
- HF Impact Sockets
- A good place for a Unimat
- Making Bolt Hole Circles Using Trig
- Early Happy Thanksgiving to all...
- Ambition without restraint...
- Chinese Threading Torture
- Replacing the drive/timing belt on mini lathe
- O-ring groves.
- 15% off Enco
- Three phase in and running...
- Metric threading with 120T/127T gears?
- ebay problem sometimes
- OT: I think I'm going to write a book too.
- Hillbilly engineering "gitn' 'er done"
- Antique repair suggestions
- OT - Dirty Secrets of Black Friday 'Doorbusters'
- Proper/best oil for 2 stage compressor?
- OT Supposed Training Video from Chrysler
- A non-ghetto way to grind an endmill radius?
- Drum switch for rockwell lathe
