- R8 Collets - Cheap vs. Quality
- A digital Macroscope
- The other, other machinist stuff site
- Boring Bar Adapter
- Grinding a HSS bit for a boring bar?
- Collet nose
- OT: Spin-off from P.S.I. / "H2O Conversion
- OT!! Retired and looking for a purpose..
- Starrett 199
- t bolts
- Metal question
- OT: Photography question for Evan
- Headstock bearings
- Everede boring bar and sleeve
- Cleaning out the shop: keep it or toss it?
- OT; August 1955 Mechanix Illustrated
- Hildebrand & Wolfmüller
- Convert PDF image text to editable text.
- Torque requirements for Bridgeport head bolts
- Logan Model 200 Lathe
- Upgrading from my chinese mini-lathe.
- Metric Screw Search
- This is so cool!
- First finished project!
- OT: Photobuck / Reposting / Trace?
- Lapping a collet taper?
- Benchmaster MV1 Horizontal Mill
- Acurite Digital Probe
- More power
- Diamond Laps for dressing HSS
- OT Leak in a fuel assembly
- Bull gear pin sloppy, chatter, what to do?
- Cut my first single point thread-- questions now...
- Need gear for Drill press table or idea
- hopefully not a stupid question??
- Carbide bit sharpening with diamond cabbing wheels
- Acme tap drill chart
- Using Mister on horizontal band saw.
- I bought a Logan 200
- Made a collet rack today
- OT Chevy Truck Question ... Brakes
- Carbide insert names.
- The first law of new projects
- new to site
- DIY Insert Holder (pics)
- Shear pin found! the hard way..
- Silly Bugger
- shark-proof diving suit
- OT WWII Bone Yard (vehicles)
- Restore a Gerstner?
- Replicating cast wheels
- OT another project completed
- Demystifying Coaxial Indicators
- Chicom B2227L esthetic upgrade
- French ironclad battleships
- Learning a bit about stainless steel
- Checking your indicators
- A bit of tool gloat
- Need Manual for Older Anilam MiniWizard DRO
- When endmill diameter overshadows R8 rigidity
- Toss one out to the metalurgists
- Accurate machining to 100 of a millimetre ?
- Hand Hacksaw Blades
- Educate me on HSS parting tools.
- Engraving glass
- Clausing Lathe turret attachment at Cabin Fever
- CNC pinewood derby car
- Vertical Mill Purchase Question
- Cabin Fever Show Goodies!
- Need gear material stronger than fiber
- Selecting fixture clamps - How much force is enough?
- Making a D-bit reamer?
- half-tracks
- sheldon lathe, good deal?
- Gatling gun finished
- Screw this world I am leaving
- Having Trouble reading the text in an old post.
- What is a 3/8 26 NSCY
- Old time accuracy
- Help! Laptop wireless problem again.
- How do you use a Key way broach??
- How to make a wireless laptop more sensitive?
- CDCO BXA Tool Holders
- electrically conductive paste
- parts for s Sharp 1230 lathe need manual
- My "new" used surface plate. Now questions!
- Any experience with Longevity brand welders?
- Expanding table
- home made powder coat oven
- Cabin Fever photos
- What are these?
- Mass production accuracy in the 50's by Cox
- Free Machine Shop
- Machining T-Slots
- Sourcing UHMWPE rod in US?
- Bandsaw Questions
- OT: Wooden Spoon
- What is it Used For?
- Commercial airline pilot's day off
- Which holder and DTI - Noga & Interapid
- Need a 4x6 bandsaw, is HF total crap?
- Mill for sale in the detroit area
- Small Springs needed
- Cabin Fever photos one more time...
- Accurate DRO edge finder probe for 50 cents
- OT -- Where to go now that eBay won't let me sell?
- My new mill
- Keeping bearing bores concentric
- 5C Collets range
- Quick Change Tool Post?
- Shop Made Tools
- Setting the top(compund) slide for taper turning.
- Hi You all!
- Cabin Fever pics
- SchumaTech DRO Kit
- How much?
- King Midas TFY-515 Drill/Mill: Spindle Lock?
- Amazing Price Differences
- Is there a correct way!
- 5C collets, sent a suggestion to McMasters
- Ebay success.
- Phase II boring head
- O/T a nice place
- Torsional strength of shaft
- Cylinder leakdown testing and tools
- Suitable reading material
- Crazy idea for a wood lathe..
- Thread depth
- Anyone ever built a sled for hauling stuff behind a tractor?
- Advice before I take the plunge
- What could or would you do with a 3D Pringer
- Article on lathe tool grinding
- Drain plug with magnet (lathe)
- Material and Hardness
- Gaskets for model steam engine
- Solidworks mate question
- Standard Modern 9"
- Molding... Need help with a loader design...
- seven league boots
- O.T. craiglist question
- Converting Mill from 600 to 220
- Get thee behind me tool dealer!
- RF 31 Milling/ Drilling machine
- what plastic ???
- Die Filer Overarm
- Compact bender instructions
- Coaxial Indicator Calibration
- Turning question
- jmt 360x1000 lathe
- Chaski site....
- How can you tell the difference between real carbon fiber and fake?
- VFD/3phase motor in BC
- mirror finish - fact or fiction?
- Ball turning WHY-CANT- I
- How much would you charge?
- OT: It's been a year now.
- chuck stress
- Bench height - workbench and for lathe
- Shipping container for an EMCO V10 lathe/mill
- Rebuilding a Myford cylindrical grinder on youtube
- anyone recognize the maker of this die filer
- First astrophotos for 2010
- Nice Experience with Shars
- Fly Cutter Bits
- Looking for Advice on CNC Upgrade
- dial gauge test
- USPS is a bit vague!
- end mill sharpening services
- My "New" Lathe - Clausing 5900 - 12"
- Millrite Gibs
- Photobucket has a virus?????
- Tool extensions
- Fixing a VCR
- Threading question
- Help
- Cast Iron Skillet
- Storage, small parts
- Shars and Discount Machine any info?
- Anybody Want a Large Steam Engine?
- Source for L0 8" Backplate
- Greenlee punch Q
- Fixing worn holes
- my google-fu has failed me
- Benchtop mill
- Cleaning porting bits?
- OT --- Looking for advice on browser selection
- Morse taper sleeve tang removal ?
- Site back up and running
- motor for lead screw ?
- Harrison M300
- Morse taper hones?
- Norwegian steam engine
- Bardons and Oliver Collets
- Did they ever make a JT3 ot JT4 adapter
- Some junk yard finds
- Tool Gloat-question
- Hydraulic oil for my DoAll surface grinder
- Griz wood/metal mill G9977
- Camlocks.
- Help finding a US distributor
- atlas / craftsman 12" lathe carriage indicator
- Injection Molding And The Home Shop -- A Thought
- Steel V. AL
- poor mans ski doo lift
- Threading disaster!
- Atlas 7B clapper box taper pin
- Logan 200 lathe "restoration"
- CNC Mill acting up...again
- Anybody know some thing about X-Ray equipment?
- Bandsaw/Hacksaw Stands...Let's See Them
- Best BENCH Lathe for an HSM shop
- OT - gravity always wins (unless your an eagle)
- Greetings from Albuquerque
- Small difference in thread lead.
- Sometimes you gotta just move a 4300lb machine to sweep behind it
- Finally Finished My Planer and Jointer Fixtures
- Tapping a rack
- Paging George Bulliss
- OT: Latest Browser Benchmarks
- Popular Mechanics do-it-yourself Encyclopedia
- Ebay VFDs.
- Spindle spider
- Machine mounts; your preferences
- Shop made battery terminal???
- Hartford Vertical mill
- Enco 20% off code
- Mango Sheet metal deburring tools
- Question for shaper owners?
- Thoughts on tailstock tool turrets ?
- Slightly OT: Craigslist fun
- What lathe can you use and then store in a closet?
- Repairing drill chuck collar teeth, possible?
- OT: storm door & entry door - opposite hinging
- Wilton vice issue
- OT, Downloading pictures
- Closing the loop: Max torque from DC motors - Stone simple
- The LODTM
- How much pressure will an auto AC compressor housing withstand?
- Looking for John Oder from Tx.
- DoAll blade welder
- Use of the Hardinge TT Tapping Head??
- I think I know why the R-8 collet taper has a key...
- Industrial Sewing Equipment
- Building a Seismograph
- Anyone use Searchtempest?
- 3 in 1 recommendations?
- Stiffness question...
- electric motor/spindle spec question
- Happy Birthday Thomas
