View Full Version : General
- EXtream thread cutting
- Machining tungsten alloys?
- What I do.
- Grizzly G9003G conversion to Var. Spd.
- Tiny Shops to go with tiny houses
- What is the smallest shaper?
- vfd controlled lathe question
- 3-d indicators
- Rogue's Gallery
- Do you make your own step blocks?
- Rothfuss G-2 Angle Dresser & Tool Holder
- brass musical instruments
- Home made jib crane with photos
- TV with no real content!
- O/T How Sharp Should a Mattock Be
- AUCTION-- Chrysler Plant--Newark, DE
- Three or Four jaw self centering
- New Bridgeport - A little help
- Slightly OT: Looking for small wire splices...making them is tedious
- Cut Knurling tool in March/April issue
- Want a general oppinion on this Riten live center
- I get to play with a new machine for the next 8 weeks
- Attn: Evan
- 3D-probe
- Bridgeport brake shoe worn out
- Hand tapper adapters?
- Killer application for the DX laser
- Machinist group
- I built this project Friday.
- Too much Acrylic
- Getting ready to attempt scraping-ink question
- Strobe Gloat
- Looking for a Rutland manual...
- Puller Threads
- Cutting a radius with a boring head
- outboard cylinder boring machine suggestions?
- Colchester Chipmaster VFD Conversion
- Incredible grinder build
- [OT - PSA] Snow Hurricane Approaching NY & PA
- CP Gear Cutters
- Search term for a safety switch
- Tachometer for a lathe
- OT - Building acrylic and glass aquariums
- EDM in soft materials
- Blade Welders: Carbon VS Bi-Metal
- My first non-trivial part
- Brierley Point Thinning Wheel
- What I made today, boring small holes in ductile iron
- Dentist Light - Craigslist Asheville
- Supermax lathe
- OT - What happens when you let your computer run a long time?
- Gantry in Use - Pics
- H & W
- Uh oh. I think I may have messed up.
- Question for Forrest Addy
- Is there an easy way to square the ends of 4" pipe?
- Integral Shank Modification
- Vibratory Finishing & Media
- Rock Saw
- Leblond tool post
- fighting rust
- Best of the Chinese Drill Presses?????
- Bandsaw Blades - Best Place to Buy?
- Aluminum grinder ideas?
- GMT Milling vises?
- Building a DC PS for servo amps
- Protractor information
- What steel type should I get/use?
- French machinist making a home made SLR
- Knurled tops
- Storage of tiny drill bits
- Avast! 5.0
- OT: Need an artificial hip joint??
- OK, What's the secret to Knurling?
- Auction Mistakes
- 6" Parlec: Handle Hex Size
- Chuck jaw salvage
- Odd Allen Key Size: 15/64"?
- Wiring 3PH motor problem
- Iron Casting Material?
- Vise Swivel Base -- help
- AutoCAD or Solidworks Training
- Online auctions sites?
- Older Wilton 20" VSG DP help please???
- Lathe size vs 4-jaw chuck capacity
- Laser Toys
- Swarf on the floor
- re my hacksaw more advice needed please
- A quick fixturing tip
- speed and feed for fly cutter on mild steel.
- Basic electricity question
- loosening up tight bearings...
- Bison vs Buck 6 Jaw Chuck?
- Knurling Tools Are Expensive
- Obsolete bearing?
- if you were PM'ing me....... I cleared the "box"
- What is the smallest series of ER collets?
- WEB fatigue!
- OT MS Office to Jpeg
- CNC - My aching head
- software download help- machine shop
- What is 50/50 silver solder?
- Number drills question
- Clamping to Bridgeport Knee Ways
- No Oil Milling
- Organization of small containers
- Honda Car, key stuck? anti-theft? OT but could use help
- Cutting internal keyways
- what kind of steel for a small vise?
- Cutting round stock at a angle?
- Gauge Ball with art deco handle
- Explosively forming stainless
- Biax motor overheating
- Scrapefest in Seattle
- got wifes new ring holding vice done today
- Sometimes it just has to be for fun!
- Evan and others, what insert for Hastelloy?
- Another Hub Project
- tube cutting jig for table saw
- Making a large fly cuter
- OT:Copy protect mechanism
- What's wrong with the SEARCH feature
- Sewing machine
- ER-32/16/Turret ups & downs - Need advice
- Excellent stepper motor tutorial/trainer
- Bridgeport Jib Crane
- Free metal
- Forklift...LPG or electric
- That was close you POS Bridgport
- Problem with ATPK inserts.
- Think I may have buned up my lathe motor? :(
- carbide vrs carbide
- Still trying to get 20" Wilton VSG answer
- Math / Drafting Question (or Daft Mathing)
- A project that I put together last weekend
- South Bend Fourteen help
- Welding on tire rim.
- be honest?
- Looking for High Ba
- Quick cut knuler
- Advice on lathe dog usage ?
- 2-sided tape as fixture?
- pipe-making lathe
- Black pipe for LPG use.
- Prayers for OIL MAC alias DAN
- More LEDS.
- Semi OT Telescope building questions
- need advice on tooling for titanium
- WWI Truck restoration.
- Piston ring project
- Compound removal?
- ENCO Free shipping?
- How to correct a tapered gib?
- XLO's, gantries and OH&S
- OT: I want one!
- Tractor Bucket Pins
- OT: Is there a test to determine if a motor is 115VAC or 230VAC?
- computer memory
- Help with insert ID?
- OT: Another browser question
- Need some tooling
- Collet lube?
- how hard of a steel can you machine
- Grinding HSS taking too long
- Cutting something in half to see what it looks like
- Harbor Freight - Non-contact thermometer - Any good?
- tis the season OT
- OT - how long before 64-bit computers rule the world and 32 bits is obsolete?
- Belt sander - speed ?
- My Little Tap Starters
- Found me some old iron!!!
- OT Electronics Question - Perf Board/Etc
- Chart for what insert to use for XXXX steel?
- Ribbed Belt Pulley
- Lead screw shear pin size and material?
- Kill App, part II: The PCB burning nuclear LASER-O-DEATH
- OMG bearings again
- Milling Machine Power-Feed Attachment
- Free NAPA hat
- Help with mill on table it leaks with coolant
- Totally OT...Olympic stuff
- Diamond wheels- shapes, grits and sources
- Can anyone ID this transmission?
- Rockwell or Clausing horizontal for m head conversion?
- Pipe Tap & Die ????
- OT: Source for these rubber bumper things
- Coolant or no coolant?
- Suggestions how to introduce metalworking to children
- I don't know whether to gloat or cry....
- can you identify this?
- Mystery bits #2
- Mystery bits 3
- JackShaft
- OT- Am I seeing Satellites?
- Permatex vs Dykem hi spot / prussian blue
- Anyone made anything with front wheel unit bearings?
- Kuhn Radius Dresser
- Timing Pulley Design
- Suggestions for scraping-table?
- 3 Phase question
- Sieg X2 Mini Mill Power Feed
- OT: Password Instructions / Interpretation
- Sale of goods act UK and Rutlins UK
- some of you might find this handy Grandpa Alistair
- Lever Operated Collet Closers
- Handicap trike speed controller
- OT: What are they?
- Induma Vert. Mill Quill, Powermatic bandsaw welder -help
- Wiring Help
- 2" X 60-72 inch Belt Grinder build pics.
- 5C Collet Internal Thread
- OT: Earth Quakes > 5.0 Specifically Chile
- Other uses for DP?
- Help with posting photos
- Scrap Yard Woes
- Converting surface grinder table to bearing travel
- OK. What is this thing?
- Gas Springs / Struts
- OT- Best cheap 5.1 receiver
- Unusual End Mill
- Was in another Man's shop today and.......
- Need a part for a Vernon vertical mill
- [Semi-OT] Treadmill Guys Get Out Of The Gym And Into The Home Shop
- Block and tackle
- k&t vs cincinatti
- ID this micrometer carriage stop
- Had any trouble with your fluorescent fixtures?
- Trailer safety hitch
- Rust prevention
- old ENCO Bore Head kit
- OT modern audio amplifiers
- Parting tool making magnetic chips
- Costly Mistake
- building up a shaft
- Front Wheels for a Bushhog
- OT Jeans Button Rivets.. ideas anyone ?
- Search Doesn't Work At All!
- OT Quit smoking! How long did you quit?
- How do you mount and center D1-3 collet chucks?
- Dang puter virus
- Who Sell Weiss Machine Tools In The USA?
- OT-Need replacement for microsoft photo ed
- Blind Hole Laps
- Tapmatic Aquacut, rusting?
- Made in the USA?
- Coolant recommendations
- Before DRO, how was it done?
- It'll be better with a washer!
- X2 on the Way!
- Atlas/Crafstman Lathe Question...
