View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 [143] 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. Making Coil Springs
  2. Safety First
  3. Lathe spindle speed "locked" to work diameter.
  4. Searching for tools & supplies
  5. loctite
  6. Yeah, we got what you need!
  7. Atlas 10x24...Good Deal or Bad???
  8. Shop Swarf web site?
  9. Need bed wiper for 13" South Bend
  10. Wifes mini steam cleaner, what can it be used for?
  11. Milling speeds and feeds calculator
  12. Northern California HSM Members Meeting
  13. member classification
  14. Poly V pulley photo rendered with new Alibre ...
  15. Whacko OT: Longest mare's tail cloud I've ever seen
  16. New toys
  17. OT Chevy Avalanche emergency brake
  18. 6" Kurt on Chicago CL for $125 (not mine)
  19. pinging John Stevenson
  20. How to adjust Mitutoyo DTI tip angle?
  21. Source for "liquid" Neoprene??
  22. nedd some help with carbide insert
  23. OT: Ouch, not so hard!
  24. How do diamond coated edges help?
  25. D1-6 chuck mount questions
  26. Filter for Honing Tank
  27. Lathe tool grind w/lowest cutting force?
  28. How can I remove an engraving?
  29. High pressure gas strut question
  30. Myth busted: can't use carbide on a small lathe
  31. Who to visit
  32. Your tricks for juggling shims?
  33. Lathe tailstock adapted to rotary table?
  34. RF 45 Drain hole
  35. Gas line safety question
  36. Four Jaw Chuck
  37. Mechanical design question
  38. New strap bender
  39. Kurt, Starrett, quality question
  40. Fabricated mill on ebay
  41. Single pointing left hand thread
  42. Got to visit with 3jaw
  43. Insurance Company Ripoffs???
  44. please could someone tell me what these are for ?Grandpa Alistair
  45. countersunk screw angle
  46. Still worth learning 2D CAD ?
  47. OT: Save Any Picture On Your Screen
  48. morse taper reamer question.
  49. Reamer floating chuck plans
  50. Tumbler or ?
  51. OT - Coffee Makers
  52. New stlye Chipping hammers
  53. Q's for ML7 owners
  54. Remove Loctite residue?
  55. Is an M head Bridgeport a good buy?
  56. Facemill Recommendation Request
  57. Is it Christmas yet ?
  58. Need a cheap current production digicam for the shop
  59. Any "Impact Bearing Co" experience.
  60. Alternative to Hitachi SJ200-022NFU VFD?
  61. Saddle Way Worn ????
  62. Can someone show me the July/Aug '05 HSM cover?
  63. Degaussing large parts, Thanks Forrest
  64. Monsanto liars! health warning
  65. HSS tools i grind and over hang in holder
  66. Turning a profit - pun
  67. Farm shops
  68. MY health problems and those sniggering classes
  69. Grinding Wheel Removal: Carbide Tool Grinder
  70. Lube For Hypoid Gear Box?
  71. Cutting Tiles
  72. I need Help fixing my Bridgeport Mill
  73. GMT (Glacern) customer service kudos
  74. Producing an Oval on a Mill
  75. Best tooling grade for interupted cut on 360 brass?
  76. face cutting/ fly cutting on my mill on aluim
  77. Build your own CNC mill on the cheap
  78. metallic oxide exterior finishes
  79. Drilling a hole in a mirror
  80. OT- Motorcycle Accessory
  81. Steel stresses and strains
  82. Square corners/Scraping.
  83. Single point threading-problems
  84. Sparks & Flames & Smoke ... OH MY !!
  85. Spindle bearings for a Central Tool surface grinder
  86. Bend & shear project?
  87. ER32 Collets Which Brand?
  88. Identify this Colchester Lathe
  89. Delta-Milwaukee Toolmaker Surface Grinder Value?
  90. Hammer bumping commercial on TV
  91. New Panther motorcycle
  92. Camera choice for use with mill
  93. Rolled Threads Designation
  94. Acu-Rite Master TP Scale Problem?
  95. adjusting a Slocomb Speedmike
  96. Lock Picking - Semi OT
  97. What am I doing wrong?
  98. What's a Variac and what can I do with it?
  99. OT ground shaking
  100. My latest find - T&CG
  101. Go ahead ... call me a fool.
  102. Thread dial
  103. OT vacuum systems
  104. Lathe Setup? Facing thin parts.
  105. Bridgeport quill spring source?
  106. Question, milling, drilling spindle.
  107. I finished a little project I started a few years ago
  108. Bolton Lathe: Looks like a bargain?
  109. Van Norman head rework
  110. Silly sellers
  111. Motor prices
  112. Dumore Spindle Thread Size
  113. westec how do i get in for free
  114. Atlas shaper wiring
  115. Carbide Insert Identification Help
  116. anyone need a crankshaft??
  117. A miracle happened this morning!
  118. Todays Project knulering tool holder
  119. Paul Alciatore's "Quick-Change Tool Post"
  120. I must be doing something wrong
  121. Need a new pulley for my very old Sears Drill Press
  122. A weekend of indulgance and abaondon to pleasure.....
  123. What did you do today?
  124. Universal Vernier Protractor
  125. OT-Punching holes in steal
  126. HSMer's at old Folsom, CA powerhouse
  127. What is the most popular hobby lathe
  128. Ever been curious about the submarine TDC?
  129. How many guys would wear a HSM hat?
  130. Wooden gear in cement mixer?
  131. Setup with Bison TrueSet Chuck?
  132. Case hardening how to?
  133. how do I transer drill holes from piece to piece?
  134. Cryogenic Steel Treatment
  135. honing a cylinder
  136. Source for "X" shaped aluminum channel?
  137. Homemade edge clamps
  138. Hamilton Sensitive Drill Press
  139. Finish for Restored Starrett Dividers
  140. Making Belt/Chain Guards
  141. Making Rubber Parts
  142. Craftsman/Covel Hacksaw-How to mount it?
  143. Heat Treating Setups
  144. Pi day
  145. making a rough ball, what type of tool
  146. Why I Need a Woman in My Life ... or ... Pacemaker #3
  147. Linux / Firefox inside windows... still vulnerable?
  148. Hypoid Gear Project
  149. Work holding jig.
  150. Good deal on ebay surface grinder
  151. why men prefer guns over women
  152. What I made in the shop
  153. Loose pulley
  154. Electrical connector ID?
  155. Now you have time for a museum trip
  156. Jeff's Amazing Technicolour Dream Lathes
  157. spur gear calculations
  158. What is the world's most common thread?
  159. OT Hammer ID
  160. 9" x 42" Bridgeport Vertical Milling Machine For Sale
  161. Shop Layouts...What Is Yours Like?
  162. How a sine bar works.
  163. A Machine Shop For The Mobile Renter
  164. Good Paint Needed
  165. where to find 20x1/2" t&d
  166. Photobucket Uploading Problem !!!
  167. replacement ways
  168. Pinging Evan - is all OK?
  169. Repair parts for 12x36 lathe
  170. What is wrong with my bench grinder...
  171. Will Drill Rod make a good boring bar?
  172. pinging Torker
  173. Shop Chairs!!
  174. How do I make my lathe stand more rigid
  175. Heat Treat Distortion 8620
  176. Making large rings from rouond stock
  177. 7 mins of acetylene tanks
  178. ENCO 20% Off - Ends Friday 3/19
  179. O/T HSM Member praise...
  180. internet software purchase
  181. strength of materials question
  182. A new member
  183. Electrical item what is it?
  184. Just got a Surface grinder...yay
  185. What combination of CNC transformers to offer?
  186. Fandangled new wrench
  187. Any one need a new mill for their shop?
  188. case hardening
  189. 2MT Shell Mill Arbor
  190. Bridgeport plunges a larger diameter than it slots...
  191. OT - Got to drive a Chevy Volt
  192. Pulley removers
  193. Anybody here Irish that will admit it?
  194. 1st post - Help to adjust a Friction Clutch?
  195. O/T -- Talked To Some School Kids Today.
  196. What type of insert is this?
  197. OT:Tax return woes
  198. Roughing with CBN wheel?
  199. V-twin (my own design)
  200. Today it's the reverse Midas touch.....
  201. Making internal gears
  202. Repairing Draw bar
  203. Need help drilling brass
  204. Who has a Good Deal on R8 Collets?
  205. quick change tool post and holders
  206. Ribbed vs non ribbed belts?
  207. 5/8 Reamer at Folsom
  208. Condensing boiler efficiency
  209. New To Me South Bend 10
  210. Van Norman head cleanup and repair
  211. Another unusual tool request for info
  212. Mill Drill Speed Range
  213. Can I get Morse Taper adapters apart?
  214. Toolholder dovetail ?
  215. Shaft Friction
  216. Parting a scary thing happened yesterday
  217. Sawing aluminum plate
  218. Replacement parts for AE HQ-400?
  219. Snap Flow stupid question
  220. Boley 5 LZ spare parts
  221. Microwave oven steriliser
  222. Thought about advertising for George ...
  223. DIY electric motor re-wind?
  224. Deep slot
  225. Poly-vee belt HP
  226. Choosing a quick change for a 14" Hendey.
  227. Adjusting 14" band saw
  228. Need help ID'ing a "Fairbanks" Lathe
  229. Swarf Recycling
  230. newbie
  231. Barker Production Mill
  232. Machine Bases..Let's See Them!
  233. Grinding Centers for the HSM shop
  234. JET 1024 lathe troubles
  235. Calling tyrone shewlaces
  236. Nothing but Hot Air...
  237. Drill Press Bearings
  238. Drill Press Bearings
  239. 30 Taper Boring Head Arbor
  240. Your Machinist job
  241. Making an esspresso machine,,,hand pull
  242. Cleaning a Machine...How do you do it?
  243. Quoting my first job
  244. Fitting DRO Quill Scale
  245. Slitting/slotting saws for Bridgeport
  246. DIY Cocktail Mixer
  247. Emergency plumbing patch, need help!
  248. Milling vice accuracy vs. MK1 eyeball
  249. Help taking apart a drill press spindle
  250. Tool gloat
