- 4 cylinder OHV engine drawing update
- How can I weld this?
- Ok "metal masters" I got a difficult one here...
- Linear BB Cleanup?
- Adapting a K. O. Lee BA960 to Variable Speed 3 phase.
- School me in Boring Bar Angles
- Looking for 2011-T3 plate...
- Bridgeport home - worked a treat!
- OT: iPad
- CNC Your Lunch?
- Need bed wiper for Logan lathe
- OT discount for vets
- Gerstner box identification
- jeweler's screwdriver set
- Thanks
- Product review: 3M headlight polish kit.
- Flycutters and brazed carbide.
- Major SCAM alert!
- Oil on the slide!
- Building a Tig weld set.
- How to flatten sheet metal?
- BA thread gauges
- Punch Die question
- Electrical Switch Question
- New to me: Bridgeport Manual, Any Good
- HF rotary table
- Motor selection questions...
- How thick is the copper on printed circuit board
- How to mount a tapered roller bearing
- Torque about power!!!!
- Tumbling
- I.D. This tool
- Tecumseh tec manuals - link
- DRO help
- Rotary Table Gloat
- Dowel pin extraction from B'Port crank
- Hoist loading
- What steel to use?
- Repairing a casting
- varispeed belt making noise
- What size Machinists' Level for leveling a lathe
- Buying Metal in Calgary
- Mrs Cofer's little boy has a birthday today. HBD David
- Copper pipe fitting allowance Charts
- OT Once I built a railroad....
- OT Dog/Pet Clippers
- Bit the bullet on this shaper.
- Why does motor HP affect CFM of a compressor?
- Sharpening stump grinder teeth?
- Way OT, Klystron Specs?
- 90 Degree belt spin
- Wearing gloves when working on a mill/lathe NOT!
- Can I read pdf books on an E book reader??
- Heat treat furnace: The controller
- Motorbike project
- Deckel KF1
- US made motor vs Chinese motor
- Misc. Machine Tooling Specifications
- Round again
- Gasket creation
- OT:Nuts, Bolts & Thingamajigs
- I need some help..its a simple thing
- What kind of files to fix internal bumps on morse taper
- OT -- DVD confusion: DVD-R, DVD+R
- Solder strenght???
- Looking for basic metal working projects book with center punch.
- Edge finder questions
- O/T i-pod touch
- OT: Network Connection Question
- looking fo an old one of his lordships posts so I guess I am pinging sir John
- Any uses for old auto AC rotary compressors?
- How would you fix it?
- Where's me white stick ?
- Wot a plonker
- Putting Wheels Under Heavy Cabinets
- Craigslist Scam
- OT. Need help finding a company
- Fishing Tackle Boxes In the HSM Shop
- Rhodes Slotter
- OT: John Deere Lawn Tractors
- What's Up With The Emoticons???
- Screwdrivers for the UK guys
- OT: Repair Sears Plastic Tool / Socket Case
- Pinging JoeFin
- Wood joints
- cleaning white powdery gunk off pot metal parts
- Old chuck and key
- sodder sukker
- Joining a shaft.
- Drll bit sharpening question...people w/out drill bits need not read.
- why part out a good machine??
- 1904 International cylinder head part 1
- 1904 International cylinder head part 2
- Pinging Russ Toker
- Drilling Styrofoam
- Question for all the welders
- Making lawn mower deck full floating
- Elliot #5 cutter grinder
- Could anybody help identify a machinist box?
- Reamers
- N.A.M.E.S show meet
- How do you remove R8 alignment pin in quill?
- Transformer question...
- Before the Red Light Camers
- Finally, a lathe
- Buffing wheels
- What happened to my glasses?
- anyone able to offer advice/help with this lathe
- Industrial Manuals?
- early 1900's Cincinnati planner
- OT: Painted my dumpster
- Splined shaft dims 1 3/8" 6
- Shop stress...
- Need Help Cooking Duck !
- O.T. What is it and how was it made.
- Search Engine
- morse taper adapters
- Honda 600 XLR
- Torque measurement of rotating shaft
- What would you do...?
- Did metric run out of puff...
- Removing shank from boring head
- light for aging eyes
- Cylinder Head work on the Bridgeport ??
- Steady-rest pulls workpiece out of 3-jaw
- Help centering large stock in lathe
- cutters
- rotary convertor transplant from static ?
- Help With Fireplace Burners
- Bad tooling, right out of the box?
- OT: Question of taste and growing up
- magnetic vise
- New to me welder.. and need some help
- Did PM go down?
- 5 x 6 Bandsaw issue
- Always buy the best brands.... Maybe
- OT Steam Locomotive Auction + stuff
- Ladder Material moving Aid?
- Magnet dial ind. fustrations
- Why I don't use Craig's list
- Stir Casting Silicon Carbide into Aluminum
- Fire safety...
- Machining by Hand
- OT - Tin Type Photos
- What to have on hand to move machinery?
- One Man Portable Gantry Cranes
- Drill grinder question
- 16 Speed drill press-all I got
- pinging sir John
- Darex M Series Point Splitter any good?
- Quality of SPI tools
- Is HSM running slow for anyone else?
- OT - Dental Implants
- Swarf Curtains
- Tax question on work for pay
- OT Heat content of modern petrol v 1930 petrol
- OT Maths Question
- More than one way to skin a cat
- MK5 arbor question
- Bending with a brake
- Looking for a pulley
- old lathe motor rpm
- locomotives in the movies
- Where do the HSM'ers live????
- There aint no planes in the sky tonight [well uk] OT
- OT Question: Portable GPS for US & W Europe
- 7 in Rhodes shaper
- Sourcing Spanner Wrench for Chuck LeBlond Regal
- When tools were jewels
- I wrote up a "how-to" ..
- Tool for cutting large circles in sheet metal?
- Semi-OT UHF Internet
- printable tables
- 302 V-8 running improvements
- North American Model Engineering Expo
- Board-level repairs for machines...
- Installing circlip
- steady rest SB 9a
- tooling supplier Hengst Kessler!
- Building a Trailer to Move Machines
- How to Imnprove an Engine Crane
- Making a micrometer
- Testing a circuit board
- DIY machine dolly set
- Spaneour
- Storing sanding belts
- Step pulley size standard
- Sources for Good Value Casters
- drill rod
- what do you think
- Did I cock up ?
- Reviews needed for Enco 5c -> 3" or 4" scroll chuck
- Ever seen a water jet cutter?
- Bought a surface grinder today!
- Oxy Acetylene regulators and industrial gas prices
- Pinging tmc_31
- Ladies!!! I'm baaack! (in BC...fabbib up a storm...)
- Wireless wall switch
- OT: Pinging computer experts
- Dial bore gauge feedback
- South Bend Dials
- Fly Cutter: Cutting Tool Bit Geometry
- Still looking (thread dial)
- Pinging Tim Leech
- Casters - more please
- Found the intermittant slow problem
- Building Hydraulic Scales
- Basic question: fitting rod to bearing
- Pinging Dockrat
- Lost a link
- Bench top material for a slight gloat
- New Tool
- Belt Sander Radius adapter
- Raising a Trailer Roof Mechanically
- 25,000 PSI hydraulic pressure measurement
- Varaible Speed/Lever Mill Vise Handle
- Sorta gloat
- New Product Idea?
- 3ph motor won't spin up on its own
- OT Telescope
- Machinists and truims
- Reversible AC motor wiring question.
- OT:access to Mach 3 pdf documents
- Buying used equipment on fleaBay cautions
- Electronics Discussion Groups like HSM?
- vertical milling attachment for a horizontal mill?
- Measuring rack/pinion gear to make a new rack
- Has anyone ever seen
- Small Part Storage Units Using Empty Film Canisters
- Is that the space station ?
- Going Green? Need help with solvent tank....
- Uses for 1-2-3 blocks?
- Need help: Idler pulley on a shoulder bolt..
- ATTN VP IT department
- Fire scale on Brass
- pinging Computer buffs
- South Bend Lathe
- OT: moving.
- Baoji Machine Tool: ET CNC 2060 QCT - Do you Recognize This Lathe?
- Turning a crankshaft..Help!
- Newall DP900 DRO: USB port?
- Human Powered Generator
- A Shop On A Boat
- OT: Displaying the output of a vacuum gauge
- Deep collet stop
- Worth $100?
- EDM Hole-burner-thing mounted on BP
