View Full Version : General
- Plastic lube? PVC Delryn. and milling tips?
- Tape Dispensers for the Shop
- Lincoln PowerMig problems (macona??)
- Lusting for new "Good old 'merican iron"?
- source for brass?
- OT Dodgy overhead wiring
- Anyone seen a John Deere tractor engine in a Ford pickup?
- How to make a boring bar holder
- Favorite Threads
- OK, OK, I know you all told me not to buy ChiCom
- What is a door like this called?
- Shars Dro with glass scale for lathe
- Welding Fixture materials
- Trying to measure torque on a rotating fastener
- What's a clock chime rod made from?
- making a lathe mandrel
- ebay check box - search within description gone
- older southbend
- Decent Lathe?
- The Chinese sure do work fast
- Jenix DRO scales?
- Mill question
- Weld Bead in Square Tubing
- Doc Nickel Empty Your Pm Box At Once!
- Enco free ship code for April 2010 needed?
- Dry wall or sheet steel for garage walls?
- phase converter question
- Syil America X3
- CTC Tools?
- The value of XP licenses
- Minor Tooling Gloat
- The inherent perversity of mechanical things.....
- Hydraulic reservoir question
- Bridgeport Lubing?
- Power factor mods for my home
- N.A.M.E.S. 2011 Exposition April 30th-May 1st
- OT: I Found My Vice-Grips
- Field trip today
- B&S #2 Surface Grinder dissassembly ?
- Failure rate of electric motors
- Converting rolling bench to welding table..
- Online Metals Discount
- Rivet nomenclature
- Bottle jack press
- Mill Quill DRO
- What The Hell... Temp Service Hard-Sell...
- When disaster stikes, how much of your shop could you save?
- Old 3.5" swing plans in Model Engineer
- Boxford ACL Controller
- CDCO dro
- Ot: $%^&#$% Barn Flies
- BIG LATHE for your home shop.....
- Building the Webster i.c. engine
- It's been a bad day
- What CAM software?
- Failing at making small brass parts
- how to put a Bridgeport onto a pallet without a crane
- IEC Controller
- NC homeshopmachinist'er Take notice
- Gloat: Lost my bearings
- Flip this Vice. Is it worth it?
- Ms things to see?
- Clarification of Lubrication Terms
- Sandblasting problems
- Small lathe grinder for grinding IDs cheap/improvised
- OT- Best type of glue for Swarowski Crystal?
- Patriot CNC router oppinion?
- A shear for a HSM?
- How well do you think this would work...
- Best glue for hockey pucks?
- Gantry crane in WOOD?
- Wow this looks interesting Soda Blaster
- the best way to mill a slot?
- Sad day for Ivan
- tool gloat
- Company "Loyalty"
- Tapped holes on AL, long term
- NAMES 2010 pics
- OT. Ride in a Ferrari
- Shuffle off to Buffalo for some heavy cast iron
- Double rainbow
- Northern Calif HSM get together
- Product plug
- Atlas lathe (10" TH54) on Tallahassee Craigslist
- Motor capacitor size?
- Bridgeport Mill Clone Spindle Taper
- How far to go ?
- Video of various running engines at NAMES 2010
- Vinyl Form Die
- [Bragging] Dust collection on BP... My solution.
- Temporary Machine/Material Storage
- OT- removing coatings from cds
- what kind of lathe bit for a fly cutter
- Has anyone tried the harborfreight 9" angle grinder?
- OT: Buying 1 Capacitor
- Know of a good work positioner to carve bass cello?
- O.T. Video Editing Help
- Miserable machining experience. What happened?
- Sheetmetal work handbook
- Looking for an advise on caliper type.
- Ammco 7 in Q (How do might I fix this?)
- electric fence problem?
- Some in the UK are doing OK
- Turning Al Trick
- One Shot Lube Leak
- How come nearly everyting in my shop is getting magnetized?
- Internal threading compound won't do it
- Threadex Floating Die System
- 5C collet closer
- Morse Taper 2 Blanks?
- Finally Broke Down and Did It.
- Nut Plates
- Free foundry sand in Central Columbus
- What do I use to cut a railroad rail
- OT Maui visit for May
- Steam Monorail - amazing!!
- Can I do this job with a drill press?
- [tool loss] Goddamn it...
- OT - Cordless Phone Batteries
- Tapping Pipe Threads
- Sony to Kill Floppy Discs Next Year
- need help figuring out how to cut a angle
- Rotary Phase Converter Query
- Hot water at the ready?
- Pratt & Whitney Model C M-1801
- OT: An Internet Time Waster
- Need advice on a milling machine
- Weak handed machining
- o.t. can paint but can it machine??
- Shell Tonna 68 in Weiler headstock and gearbox?
- Some shop videos.
- Obsolete Machine Manuals
- Best techniques for holding small parts in a big lathe?
- Coin rings
- the future of personal rail transport
- Sheaves, pulleys fixed bore or tapered bushings
- Sherline XY-table height?
- 5C Collets
- AHT steel?
- Info on the ROCKWELL/DELTA Vertical Ram Type Radial Drill Series 15-120
- Gas Tanks (for cutting torch)
- OT - Lost Job
- Crossslide binding
- Material Specifications
- threaded center punch?
- Rotary Table ID
- which 7x12 bandsaw?
- Will Mig weld stick to a carbide insert?
- Off Topic- engine light Dodge 3.7L
- Parting Spindle HP / Rigidity
- New toy! Plus a call for cnc help
- Kiln/Furnace Expert Witness
- bought a new 5000 lb toy
- Testing an oil cooler?
- Thoughts on new forum
- looking for scraping guidance. Repost (Pinging Forest Addy)
- Noobish question: Best way to find the center of bar stock
- sine vise question
- Moving Lathe
- Doall Surface Grinder D-6 - $200 (Sacramento CA)
- Magnesiumn Question
- Morse Taper Blanks
- 16" South Bend in the Louisville area
- Deep hole drilling - again.
- Tool post is on
- ENCO 10% Off AND Free Shipping Code!
- Headlight polish...
- Names 2010 Photo's
- Mitutoyo Inside Micrometer
- Steam Jenny
- Who uses one of these 5c chucks?
- Tree 2uvr or Gordon Mastermil I-22?
- Books For Free!
- Bed frame steel...is it really as bad as it seems?
- Suspenseful Reading
- Mower and bush hog mods
- Cross Atlantic Shipping Costs
- May/June HSM A Radical Tool holder for HSS Tool Bits
- Last call for Northern Calif HSM Meet up & BBQ
- Hybrid Electrotrike MkII: Sneak peek
- Powdered graphite for way lube?
- OT:co2 compatable O-Rings
- WEMEshow (Cal),Black Hills ME show (S.D.), and the Estevan ME show (Sakatchewan)
- divided by a common language
- Looking For
- Auto Oiler - plumbing, tubing, fitting help!
- slotting width vs depth when profiling
- Aluminum flat bar suppliers..??
- OT soda carbonators
- Taper ID
- Chip collecting - do you?
- Dovetail cutter help needed to finish project
- Horizontal Mill question
- new HF Web page
- Groz Taper Spuds
- OT: Zen and the art of lawn mower repair
- Rechargeable Batteries
- Steel Square Tube Size ?????
- Air compressor bearing spec? Making a new bearing
- Oilfield "Pumpjack" model plans
- HSM BBQ at Joe Fin's
- Question for the home A/C gurus.
- Phase II of Dogs SB9 cross slide build. Need help with woodruffs
- Obvious tip or trick ?
- 5 c collet threads
- Need a job?
- Help with stuck Y travel on Sherline mill
- Free electronics
- Why tanged MT so common on boring heads?
- Got a new toy- machine review-CNC router
- PM "no posting"
- Round tube versus square tube stiffness
- JAP Harley
- Building the "Loop De Loop" (lotta pics)
- Thread Dial Gear
- Possible Chevalier Mill Purchase
- Lathe jaw screw actuator repair
- OT: Need help determining "Fair Market Value"
- Another "What The Hell" Story--Unemployment Hearing
- Once again the spammers struck
- Heard from Warren Buffet today...
- Vega Metal Lathe ?
- Enco End mill sharpener
- Wood handle manufacture
- screw removal
- Help getting parallel faces in a lathe
- why oh why didnt I get a welder sooner..
- Atlas Horizontal Mill Bearings
- Harbor Freight digital calipers
- facing large disk on lathe
- How many starts.
- Heads up SB Lathe Owners..
- restore batteries
- Dynamic Balancing in the Home Shop
- Bandsaw blade joins, silver solder.
- Drill Chuck find ~ something special?
- New member needs help on instruction
- Old Thread for the less experienced viewers.
- O2 Cyclinder explosion investigation results..
- OT: May the Fourth be with you
- Kurt power drawbar test drive
- WTD- Shaper Vise
- Another Atlas Bearing question
- OT: New shipping times?
- Shop speak ?
- Where to buy Haimer or similar 3-d indicators
- Torch regulator issues reviewed
- Read Carefully
- Hand scrapping questions
- OT-360° tour of WWII Submarine...and more!
