View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 [149] 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280
  1. To saw or not to saw, Which one
  2. Feeling really old. (depressing thread)
  3. Amazing home machinist shop
  4. New Shop
  5. how to bypass computer passwords
  6. Chip Breaker Questions !!!!!!
  7. Jet-16 lube ???
  8. patching mill table
  9. HSM collection on ebay
  10. He bought a new boat.....
  11. What do you think of this little mill?
  12. n00b of the day
  13. Might have to mill some Titanium next week
  14. anyone in ontario canada know where to get tapered roller bearings locally?
  15. ClustrMaps
  16. removing aluminum from a file?
  17. Bridgeport heads
  18. Rejuvinating Your Files
  19. How do you replace bearings in a TEFC motor?
  20. Need a longish V-Block..anybody make them?
  21. Why Liger Zero Is Going To Hell (Free Sample Gloat)
  22. Anybody want to go for a ride????
  23. auction buys....but not me!
  24. Carbide rake
  25. Remember the Early '70's Craftsman Tool Sets
  26. OT:Fathers day came early for me today
  27. Please I.D. this follow rest
  28. Weakness for certain stuff
  29. Most efficient way to mill small parts
  30. Out of work, building a bender
  31. Rant. This is a very frustrating hobby
  32. Cute gizmos but worthwhile
  33. Sleeving a cylinder rod (pics)
  34. Homemade Thread Dial
  35. Removal of Jacobs 33JT from a No. 2 MT Arbor
  36. OMG! Actual quality tools at Lowe's?
  37. Who'se turn is it to "Rescue a LeBlond"
  38. Craftsman Rolling Tool Chests on Sale, Good Deal?
  39. Whew up and running
  40. Good way to co-ordinate files on multiple computers?
  41. Getting started in home powder coating
  42. Evapo-rust Questions?
  43. Cutting my first gear---
  44. Steady rests
  45. How to make a very smooth surface on the mill?
  46. what is this gadget" pixs
  47. Has anyone worked with CADLOY armor ?
  48. What's in a Name?
  49. It followed me home
  50. What makes a good 4-jaw chuck?
  51. OT: Coax cable question?
  52. Tilted keyways?
  53. Back plunger indicator
  54. Motorcycle chain lube questions
  55. Unimat DB-200 Pulley Bearing Replacement
  56. Which lucky bugger won this
  57. Cool Spring, PA
  58. Grinding Wheels for Table Top Sanford
  59. Quality Lathe Dogs?
  60. Anyone have the Enco June Shipping Code?
  61. Help With Internal Splines
  62. Q of the week: Bent tail dogs Vs straight tail
  63. Myford Spindle Nose
  64. Book Recomendations
  65. New guy and key slots
  66. Chuck trouble
  67. Drill rod hardness ... before hardening.
  68. Air tools that blow.
  69. 14 mills in Portland
  70. The Old Dog was right about the Gulf and Green Power Push.
  71. Sneaky CAD pacakge needed
  72. Been given control of a cool project
  73. So now that you are retired...
  74. Finished my new bench
  75. Way OT Volkswagen TDI
  76. Ultra basics: Why are reamer shanks so loooooong?
  77. Enco 20% discount
  78. Making shims
  79. Thanks Guys - You have no idea how much you helped me
  80. Out of level lathe;unintentional taper
  81. New tips for cutting tools
  82. OT/sorta...fork lift fork question???
  83. OT: Grill I have to finish
  84. High-Tech Gloat
  85. PM Research Model #1
  86. Granite Surface Plate Advice
  87. Rotary table/Divider plate question
  88. Hi Everyone, new member here, lots of questions.
  89. How to Bend Tubing and Pipe by Hand Square or Round
  90. OT: Can someone please tell me what happened?
  91. Corner notcher clearance
  92. B&S vanguard engines
  93. Need Help with Delrin
  94. Machining Beryllium Copper in the 1940s
  95. Degaussing units, can they be used in our hobby
  96. One Shot Broaching
  97. Hobbing Question
  98. Taperturner
  99. OT floppy disks
  100. 5MT to 5C collet holder?
  101. need help identifing a small shaper
  102. Best way (or tool) to open a shipping tube from onlinemetals.com?
  103. Cleaning sandblasting media
  104. Compressed Air Powered Fan
  105. Tool gloat! (finally)
  106. threading with or without compound
  107. Harbor Freight digital micrometer
  108. TT races
  109. Casting material?
  110. softening a spring?
  111. Atlas Clausing Mill Quality
  112. Finger Brake Sizing?
  113. Way OT-T. Edison speaks...
  114. All Rise??? Installing a riser block on a B-port
  115. Where to Find Miniature Chain / Gears?
  116. wheel balancing shaft what to make it out of?
  117. the best laid plans...
  118. Hayabusa!
  119. OT: I may be offline for few days
  120. O/T Eye Ball "Floaters"
  121. Making Greeves Motorcycle parts, Could use some UK advice.
  122. OT:Weird computer problem
  123. Finally found an oxy/acet rig
  124. Tool Frenzy! (Gloat)
  125. Telegraph I made with my dad
  126. Bolt Strength
  127. Microprocessor Control
  128. My Entry for disgusting shop story of the day
  129. If you fancy watching a boring 5 minutes of video
  130. Drill bit assembly
  131. Super Spacer Rotary Tables
  132. Interesting sale I did NOT go to!
  133. Milling with the quill extended
  134. Ebay's "Buy It Never"
  135. Half Nut Repair
  136. OT-1 week till FREE IMPROVEMENT SERVICE!!!!!
  137. Help me save my face mill
  138. magnetic table for milling
  139. one shot lube how do I do it
  140. Induction heating DIY
  141. OT? First week of blacksmithing
  142. Crankshaft Crossing
  143. Help double conical thingamadoodle from last HSM issue
  144. Kinda OT....New edger
  145. Father's day & mad at the wife....
  146. Help with R8 Arbor
  147. Facemilling for smooth aluminum
  148. Don't ignore your chuck
  149. Threaded Chucks
  150. A form tool for gearcutting
  151. TYDTWD (Reminder)
  152. ball turners (again maybe)
  153. Steady Rest
  154. Bending Titanium
  155. Ways to hold down drill press or vertical bandsaw vise
  156. Whats the Difference?
  157. 3-D Scanner & Replicator!
  158. Gas engine ignitor points
  159. Me new toy.
  160. Rebuilding a failed pressure switch... ( Barksdale Series 9048)
  161. More facemill exercises. Make you own for a buck.
  162. Show us your small home built machines !
  163. HELP comprehending reversible motor wireing
  164. Never look a gift horse in the mouth. Material gloat
  165. What Do You Do When The OLD GIRL STARTS TO SAG
  166. Material storage and organization
  167. Which VFDs can run 1 phase in / 3 phase out
  168. Loading/Unloading a Machine On/Off a Trailer
  169. Sometimes no matter how hard you try it goes right
  170. Plating setups...what do you use?
  171. Why can't I post attachments?
  172. Compound angles
  173. Blast cabinet - how useful
  174. End Mill Wear
  175. gear cutter range
  176. convert sandblaster to baking soda blaster
  177. We are very lucky here.
  178. Just Joined
  179. Enco free shipping code
  180. Manufacturing Reurning to the USA
  181. Building a small X/Y table
  182. Yet another rotary phase converter question
  183. PlywoodServo Project (OT?)
  184. Gorton mill
  185. Too many questions at once, so I'll ask them all here
  186. Milling cutter change
  187. Going Off Grid?
  188. Forum Bore 'Em
  189. Good deal alert for Canadians plus a tooling question
  190. OT: Earthquake
  191. Suggestion for HSM magazine website
  192. Compound gib needed for a LeBlond Regal
  193. Reducing parts washer smell tip..
  194. See, this is why SERVO MOTORS trump Hydraulics.
  195. Broken stud
  196. What lathe is this and estimated weight?
  197. Craigs List Ad of the Week
  198. Small low tooth count gear question.
  199. Please help cracked clausing headstock case
  200. mounting sb lathe motor & countershaft
  201. Cheap 1.00" shafting
  202. ACRA CNC Mill -- Help w/ Price
  203. Tool gloat and questions
  204. MSC Free shipping code
  205. Shrinking and stretching sheet metal
  206. Forge design ? OT
  207. Will aluminum stick to copper?
  208. OT: iPhone 4
  209. Armor Mills
  210. New tube of glue/grease/etc., squeeze from the end or the middle?
  211. SATA HD Recognition Problems
  212. turning a tool in a sb9 lathe
  213. power switches and limit switches in ontario canada
  214. logan lathe
  215. oiling a lathe
  216. DOM 3/16" SS tubing?
  217. Total old school to cnc ... Dr's orders .. HELP please .. UNIQUE.
  218. Deep drilling 303 stainless steel
  219. drill jig setup
  220. Dumb Question about Four Jaw Chucks
  221. Ring roller
  222. Atlas Bandsaw
  223. OCC what's happening choppers
  224. homebrew one-shot oil lubrication
  225. o/t tube amp
  226. Matching flow rates
  227. 12" swing lathes with hydrodynamic bearing spindles
  228. J-Line parts
  229. Ideas that didn't make it
  230. windows 7 home premium 64 bit
  231. Side topics from - plugging the Gulf oil leak
  232. Tool Gloat - from The CNC Workshop
  233. OT - need a truck hauled..any good brokers?
  234. Magnetic Question
  235. Question on Rivet Spinning
  236. Haimer 3-D Sensor
  237. Awsome air tool of the week.
  238. What collet system to use for a big lathe?
  239. Anyone know about this model Bridgeport?
  240. Computer Thingy... Only $1... now what's it good for?
  241. Aligning Tailstock
  242. Splined Shaft Advice needed
  243. Mild tool gloat, my 15th grinder
  244. Who has a Benchmaster? Question or two..
  245. a must have tool you seldom use?
  246. square wrenches/ spanners
  247. Good way of marking the center line of flat stock?
  248. A very talented machinist and gunsmith
  249. Ball turners, and how to use them
  250. Weapons Grade Uranium
