View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 [150] 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. square wrenches/ spanners
  2. Good way of marking the center line of flat stock?
  3. A very talented machinist and gunsmith
  4. Ball turners, and how to use them
  5. Weapons Grade Uranium
  6. Need to buy small insert
  7. Will welding distort these threads?
  8. Here is another work in progress thread from another forum.
  9. I'm rich!!!---I'm rich!!!
  10. cleaning out the barn,
  11. Dial indicator - jeweled?
  12. low budget coolant system?
  13. Dollar Tree
  14. Sleeving a cylinder rod part 2
  15. ping david coffer ? ? ?
  16. Boring a hole off vertical
  17. Sony Memory Stick (Old School) is it compatable with Memory Stick (new school)?
  18. Jiggering a VFD to work not as intended
  19. Thread cutting help.
  20. Vacuum System Problems
  21. The cats away so the mice came out to play
  22. OT: Scam reported
  23. Wall Chart
  24. Follow up on Low cost coolant system
  25. where to buy 0.3mm mechanical pencil mechanism for self-made pencils
  26. New shop, need advice
  27. Need a worm gear made
  28. Book Gloat
  29. Grizzley's Shop Planner
  30. Which is harder, a ball peen hammer or claw?
  31. What is all this cool stuff?
  32. Engraved holograms revisited
  33. New Invention- Help/Investors Needed!
  34. Weird question: Diesel for cutting oil???
  35. Caliper, any good?
  36. At last, It's my turn to gloat.
  37. slow leak compressor drain what's it called?
  38. OT Computer problem
  39. Brought to my knees
  40. G0602 Qctp
  41. Look! Another flying car
  42. 1" Facemill
  43. Differences - SB 9" versus 16"
  44. metric seal for coolant pump
  45. Need Help figuring this gizmo out.
  46. Machine choice advice needed
  47. MSC free shipping
  48. Loaning Tools
  49. Microproto DSLS 3000 fully CNCd minimill .. any dirt on this? (Taig)
  50. Clausing vs Millrite Vs Rockwell
  51. OT - Script to use when a telemarketer calls
  52. Ball screw vs lead screw ... hype?
  53. You can get excellent rotary tables .. why not X-Ys?
  54. Need A Book Recomend -- Steel Rule Dies
  55. Lift on the side of a Mill
  56. Didn't want to hijack the "Ball screw vs lead screw ... hype?" thread
  57. Mystery plastic ID...?
  58. How much stiffness could this chassis brace add?
  59. What to do when you haven't the right tool for the job?
  60. Wrammer - drawbar wrench
  61. Canada Day
  62. Homemade Belt Sander with 12" Disk
  63. Lessons learned--The hard way
  64. Wanted Tap!! 7/8-20 Heli coil
  65. Minor Tool Gloat
  66. Hyundai to offer hybrid with lithium-polymer batteries
  67. A Dictionary of Units of Measurement
  68. Homemade Sander Picture
  69. Resurrection of a Dean Smith lathe
  70. OT: Audio help for meetings
  71. Radius gauges
  72. My first tool gloat, free saw
  73. searching for a post....
  74. Sprag Clutch Question
  75. warpage potential when machining 1054 bar..?
  76. A question about measurement tools
  77. Interesting online magazine
  78. Daft question re microwave ovens!
  79. New 'Tool'
  80. 4th axis milling May 1, 1945!
  81. Tramming and Centering
  82. Bison Collet Chuck: Set-tru or Direct Mount?
  83. Epsilon's comment re: facemilling got me thinking...
  84. OT: Anyone tell me how to figure Horsepower?
  85. What Do You Use For Portable Optical Part/Tool Inspection?
  86. OT Firefox becoming a hack job ?
  87. Lathe Change-Box Lubrication
  88. DOR Problem. Sympathy Needed.
  89. USB microscope
  90. Forgotten technology
  91. 1965 tool exhibition catalogue pdf
  92. Trunnion on a indexing spacer?
  93. OK I think even green would be better than this :)
  94. Looking for help with a stuck item
  95. Can anyone ID this old machine sticker?
  96. O/T Tractor Battery Problem, electrons disappearing
  97. How deep to tap NPT internal threads
  98. It's Christmas! What the heck did Aunt Edna give me?
  99. Sacrificial Board
  100. Thread calcs.: Machinery's Handbook makes no sense
  101. need help sharpening end mills
  102. Happy fourth of July to all My good American friends
  103. the culmination of WWII piston engine technology
  104. Problem renewing feedscrews
  105. Sorry John...I'm giving in
  106. Went to a car show downtown yesterday---
  107. How do you decide what something is worth?
  108. Need manual and shipping/packing advice for a ValuMaster 6"x12" surface grinder
  109. Maximizing end mill life
  110. Jib Hoist
  111. Timing a model beam engine
  112. Evapo-Rust (Bad Experience)
  113. A zillion times better is a ...
  114. New product out there called "Makerbot".
  115. Snap/retaining ring pliers
  116. Looking for OLD version of Autocad, where to find?
  117. OT: need some help with MS Excel
  118. DRO on mill - which way is which.
  119. Enco free shipping code
  120. Graduated dials on rotary table
  121. wiring schamatic ?
  122. Power Feed Spares
  123. "Experienced Machinist" wanted
  124. Following Instructions/Direcctions
  125. OT..Lost 500 gigs of all my stuff ..unless someone can help
  126. Help me find these!! Dial level ?
  127. What About Health Care? Good or Bad?
  128. Electrical grounding question
  129. Older style Surface Finish Symbols
  130. Turnkey 4 axis CNC to go on a fully manual ZX45.
  131. One of the things I like about HSM
  132. OT Barbeque smoker plans
  133. Need source for Astron Power Supply.
  134. Looking for refractory board
  135. Looking for info on 7/8 20 Heli-coils
  136. Tool gloat: measuring wires
  137. Calling Electrical Gurus And Practitioners Of PLC Magics...
  138. Flies!!!!
  139. OT Postal rates
  140. Rule of Thumb...
  141. Where can I buy this, and I have looked everywhere!
  142. I need to make a pulley - any advice
  143. Bailing wire horsesense
  144. Knurling Alternative
  145. Setting lathe tools on centre
  146. Carbide Aluminum End Mills?
  147. Enco promo for schools, students & educators
  148. Getting a new lathe...
  149. Wire Size Drill Bits - Where to find
  150. Tool & Cutter Grinding Information
  151. OT:Is there a low cost DXF to CNC software?
  152. OT computer TV tuner any luck ?
  153. Need belt for Mitre box saw
  154. Interesting article : Companies brace for end of cheap made-in-China era
  155. HF lathe parts
  156. countersink included angle
  157. How do you adjust a round split die?
  158. Turning Internal taper?
  159. Anyone tried grinding jaws of a DRILL chuck?
  160. Air compressor condensate problem.
  161. How do I get that dam plasticizer smell out?
  162. Press for use with steel stamp on aluminum - 1 ton? 2 ton? 6 ton?
  163. Delrin question for Evan
  164. Any ideas for freshening dog teeth on a gear?
  165. Dull broach
  166. Butane refill spigot (slight OT)
  167. Help! - need collet ID
  168. Potential big tool gloat for someone in Ohio
  169. Show me your lathe faceplate mounting options
  170. Sector shaft pins and steel selection
  171. Back in my own workshop...
  172. Multi-function tools (Fein, et al)
  173. Prayers for my husband Alistair
  174. Ace Bodge
  175. H2 or H3 taps?
  176. OT - Get your cheap Chinese tools while you can...
  177. HF air compressor pump
  178. Advise sought for compressor conversion
  179. Weiler lathe information inquiry.
  180. RIP Big Joe
  181. No good deed goes unrewarded.....
  182. OT - Jacuzzi water treatment advice requested
  183. Scale Drawings for German WWII 88mm Flak Cannon
  184. Scooter project
  185. Kudos to Onlinemetals.com
  186. My Grand Father's tool box
  187. O/T X3 Haiti recovery.
  188. OT question (sort of) on hydraulics
  189. Field Boring without a boring bar
  190. Need help installing circlip
  191. Eureka moment: Wire wheels
  192. Old machining pictures - for your pleasure
  193. Aliistair Update info
  194. Made in USA = trash
  195. Alistair update 2 from Bronwen
  196. Tube bending die question
  197. Machining Bronze
  198. OT - Probability Problem
  199. O.T. Gas regulator
  200. OT - Pressure Cooker/Canner
  201. WAX Molds
  202. Holding a Washer
  203. OT Windows (real ones) question
  204. first turning from the lathe
  205. Compressed Air Drier
  206. Silver Solder Hydraulic Lines?
  207. Compression releases added to shovelhead
  208. OT - Yard edging
  209. What filler for lawn mower blades?
  210. Properties of 7073 aluminum
  211. How long do things last?..How long should they last?
  212. Enco free shipping and 15% off. Can use both
  213. Bolton ZX45 and 12x24 lathe landing tomorrow!
  214. Dividing Head vs Rotary Table .. ARRRGGG!!!!
  215. Inside micrometers... I don't understand.
  216. OT, Home Made Rodent Poison
  217. OT: Not machine related...read at your own risk !
  218. Check your new 5C spin index or other tool
  219. DROs ... last big ticket item on the shopping list guys.
  220. shop upgrade
  221. Shop Tip: Colour Matching for Equipment Paint
  222. OT, a little. Need some electrical help
  223. Litchtenburg figures,neat!
  224. Scraping question for Forrest (or??)
  225. New Book A Guide to renovating a J head
  226. Semi O.T. Subscription Question
  227. Anyone Made a Central Heating Trap/Filter
  228. To make ° symbol--
  229. Picking up hole centres...
  230. Base Modification Ideas for the 4x6 Chinese Bandsaw
  231. Four Jaw Questions
  232. Hydrolic flow combiner question.
  233. Getting started with finishing
  234. Compression gauge question.
  235. Nor-Cal Field Trip
  236. 123 blocks with metric threads
  237. SPEEDTV Series: Ultimate Factories
  238. Tips Requested for Aligning Shafts to be Concentric
  239. Old iron for sale in my community
  240. Osha rant
  241. Compound slide.
  242. Long Reach Snap Ring Pliers?
  243. Need Pexto shear parts
  244. Bastille Day
  245. Universal Stands for Small Shop Machines?
  246. Free shaper (Connecticut)
  247. Junkyards..What's in yours?
  248. Belville washers - where to buy?
  249. LeBlond #1 T&C Grinder Help Needed
  250. Guess how much I paid for these.
