View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 [151] 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. JPEG up-load
  2. Compression tester adapters questions.
  3. Changing chucks in lathe
  4. What would cause this?
  5. Is this site viewable in China?
  6. Garden cart
  7. Couple projects of mine...
  8. Enco and MSC promo codes
  9. Photos of scale items
  10. Size of hydraulic hose
  11. Involute gear generation on a shaping machine
  12. Phase Converter options
  13. a million thanks from Bronwen and Alistair
  14. Made in USA = Superb
  15. Convert AI file to CAD?
  16. Ever been hurt in your home shop?
  17. wood versus metal cutting bandsaws
  18. tire pump
  19. floor prep & application: Old Space, New Shop
  20. Need a stamping machine or a pantograph engraver
  21. Elementary tool & cutter grinder question
  22. Craftsman Commercial Lathe
  23. Unbelievable auction and whats going to happen to my stuff
  24. OT - USB Hubs
  25. Thread wires in captivity
  26. Grinding HSS and carbide with little dremel tools on a CNC
  27. Fluted reamers vs D reamers
  28. OT - A "Feel Good" story
  29. Heinrich Vise quality clone?
  30. Show us youre can crusher
  31. What is this thing
  32. Bronze casting manual
  33. Romi Falls Short, Withdraws Bid for Hardinge
  34. power tool replacement parts
  35. It's not from 'Blakes 7"
  36. Air compressor selected.
  37. Gear cutting question..
  38. Checking email
  39. OT sotr of: cable out
  40. OT but important: Fabric softener can burn faster
  41. Aiming a drill press
  42. OT: buying used small outboard motors. Which ones?
  43. Today's small project: the QCTP of mallets
  44. Source for materials
  45. Need major & minor diameters for 1.240 x 20 TPI
  46. Where to buy a backplate?
  47. Where to look for scrap perforated steel or stainlesssheet metal??
  48. Snapped return spring on 17" Rockwell DP. Any good DIY options?
  49. Safety glasses recommendation
  50. Knurling question revisited
  51. Grizzly Bandsaw
  52. Scale for BP DRO?
  53. Need to measure something that's inaccessible?
  54. I don't understand -- 3ph motors/current
  55. USA Quality - Baldor, for example
  56. Biggest 'Little' Engine Show
  57. A Great Motorcycle Build Article
  58. Anyone own a Dake #4, #5, or #6 Compound Leverage Arbor Press?
  59. Good Tupperware recommendation
  60. OT: (electrical question but related to a machine)
  61. Sherline AC Motor Brushes
  62. questions on lathe profiling and lead angles
  63. A good chuckle from Harbor Freight
  64. Another tool gloat for you to dump on......
  65. Does the USA need more booze and less oil in its water?
  66. What's wrong with my band saw?
  67. DRO's and Compound Cross Slides ????
  68. Which vertical bandsaw to buy?
  69. Cannot view pictures in this thread
  70. communists
  71. If your shop was destroyed tonight, what would you replace it with tomorrow?
  72. Source for Brass Tubing
  73. Colours for 3D CAD parts
  74. Making a ER 32 Collet Chuck
  75. Furnace Build Sucsessful
  76. perpetual motion , Overunity and free energy nuts all over the web.
  77. Desiccant Air Drier (Take Two)
  78. collet closer
  79. Worked on my first part I mustn't mess up today
  80. metal used for punches
  81. Butterflies that don’t conform.
  82. HF 6x12 surface grinder on sale $300
  83. Magnetic starter electrical question.
  84. some interesting QCTP mods
  85. Measuring a conical flat?
  86. cutting lengthwise slit in long thin rod
  87. Has anyone automated a manual surface grinder?
  88. 2 new projects to keep me busy
  89. Old heavy iron (engines) and machine tool photo's
  90. MSC promo code
  91. Sizing a winch for pulling
  92. DRO for Rockwell lathe
  93. Trying to remove vertical muffler from old tractor.
  94. estwing leather hammer handle repair
  95. Drilling small holes.
  96. Gigantic epic 800-ton tool gloat (needs some work)
  97. Shapers...Fixed speeds or variable speed?
  98. OT: small trailer wiring harness?
  99. prof risks life for a dog
  100. Such a newb question, I'm so embarrassed
  101. Website with downloadable mechanical engineering references
  102. Is there a Bridgeport copy called Sharp?
  103. Champion post drill pics
  104. Need help forming copper cone
  105. Paryers requested
  106. Ideas for expansion mandrel?
  107. Danger real or imagined?
  108. Hole Drilling Progress and Milling Attachment Update
  109. Round stock for free
  110. Hand scraping setup. Looking for cheap granite straight edges.
  111. shortening a battery charging cord
  112. A.M.F.-Wahlstrom tapping head
  113. Obituaries
  114. How hard should it be to replace a light bulb?
  115. Torque with Crowfoot type spanners?
  116. propane burner / forge
  117. Anybody wanna go in with me on a set of threading dies?
  118. OT- Campers/RVs/trailers for HSM type Swap Meets
  119. Advice on how not to scrap old machinery
  120. Calling Electrical Gurus And Those Well-Versed In Wire-Fu...
  121. Milling in a Drill press ???
  122. gauging interest on a project ftp and format
  123. RA2205 stainless steel
  124. Look what I made....
  125. chuck jaws?
  126. 9/16-6 Acme Thread?
  127. OT - Company takeover
  128. Heat resistant plastics ?
  129. Upgrading my web cam microscope to stand alone mode
  130. Online Metals ...Trojan
  131. Cylinder Over Wear Limit?
  132. Liability for your work
  133. Help ? 1/2 -20 Helicoil Tap size ?
  134. Aluminum casting plant closes
  135. Chinese boring bars. Can they be fixed?
  136. OT Tire Inflation Cages
  137. OT: Digital Television - UHF only?
  138. attachment problem
  139. pipe miter.
  140. Well... So much for BALDOR ...RANT
  141. Homemade Belt Sander progress
  142. Bevel Gear Cutting
  143. Safety and George Bullis' unbelievable editorial
  144. Bridgeport Vari-Speed...doesn't vary...help!
  145. Metric Threads with English Lead Screw ??
  146. Threading to a shoulder, worry free!
  147. Supplier for SS T-bolts????
  148. Failing eysight? OT
  149. Who uses a <= 1/2" indexable end mill?
  150. How to remove LOTS of rubber from a torsion dampener???
  151. Enco: 10% Off Plus Free Shipping
  152. Attack of the Angle Grinder---
  153. Spray Painting Motorcycle
  154. How do I measure a small part without a comparator?
  155. Designing Small Belt Drives
  156. Roughers...TiN coating vs plain?
  157. Welcome Back
  158. The 'What is this tool' thread.
  159. grinding wheels speed limit; breaking the law
  160. OT - Rearview mirror adhesives
  161. maybe OT - anyone know of a source for info on the original 1-cyl Harley engines?
  162. Shop safety for newbies
  163. How much left to ream
  164. OT: These guys have no clue
  165. FREE analog TV better than Pay Cable or Satellite
  166. Harbor Freight - Free 9 LED flashlight coupon...
  167. OT- Electronic question re: Batteries
  168. Assymetric spur gears
  169. An open apology to George Bulliss
  170. Starter Tooling for Mill
  171. OT Reverse Mortgages
  172. model engine show
  173. Made something today :)
  174. Unknown Riken Collet
  175. Boring head size for small mill
  176. CC tool and cutter grinder
  177. Machining a set of dies
  178. Making valves for old stationary engines
  179. The school of hard knocks, or What you don't know CAN hurt you
  180. OT: Butterfly, can't get an ID.
  181. Metal shrinking and stretching
  182. I'm Cleaning...Please Help
  183. Show off your CAD renderings
  184. LAM winchester Bench Lathe CM1224
  185. Welding bench - make it or buy it?
  186. Water. Its not simple.
  187. the worst automotive fad of all time
  188. Junction Valley Railroad - Michigan
  189. Thread Die Cutting Off to One Side
  190. frogs,,, really O/T
  191. Lathe Order of Operations -- Cylindrical Square
  192. Two more jumping into the online auction world
  193. Smoke generator
  194. Lathe Finish - Vibration
  195. Threading question.
  196. Actual Machining Content Of A Sort -- Dremel Mini-Mite
  197. Teclock 1" indicator, opinions?
  198. keller manual
  199. my wood working ot
  200. Teco FM50 VFD
  201. Electric motor - back from the dead
  202. Do you unplug your equipment?
  203. Bijur metering valves: FJB/FSA vs. MJB/MSA
  204. Atlas / Craftsman 12" Lathe Question
  205. Lathe won't turn
  206. How many tones does it take to cold form copper?
  207. OT - Looking for that special gift?
  208. Drill press spindle options
  209. Flexible indicator holder
  210. Parting off
  211. Acetylene tank valve leak
  212. Interesting Project
  213. Gear Caliper
  214. Your input on this problem please.
  215. Grizzly 4016 Electrical Problem
  216. Drilling Question
  217. building up a shaft with spray weld powder
  218. HF Bender instructions
  219. another small job....
  220. Paint for a rusty trailer
  221. Machinists University
  222. thread dial adjustment
  223. Kudos to HSM & George Bulliss
  224. giant book of metal working projects??
  225. Best way to make this cut?
  226. Is there any tricky way to make a rounded end on the lathe?
  227. Motorcycle design
  228. CNC router
  229. Find myself in need of a mill
  230. Grizzly Model G9249 lathe
  231. Bad times at Harbor Freight?
  232. my turn
  233. How to keep mice out of the coolant tanks
  234. Brainstorm time! How would I...
  235. OT: Garage door opener?
  236. Leveling a mill
  237. Champion post drill now has a post....
  238. Pinging Sir John
  239. unplugging vs switching off
  240. Sheet metal tools.
  241. How would you improve Harbor Freight?
  242. Data logging in your shop
  243. OT - What's next in space?
  244. Enco free shipping code
  245. Albrecht chuck, worth rebuilding?
  246. Don't leave us out-----
  247. Should towns zone for HSM activity??
  248. Used prices of American vs. Chinese metalworking machines
  249. explicit versus parametric?
  250. OT upgrading to XP (from Windoze 7)
