View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 [152] 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. hydraulic lines
  2. OT - Someone is watching your phone usage
  3. self-destructing plastic
  4. Anyone ever repaired a harmonic balancer/crank pulley?
  5. Identifying Aluminum
  6. In need of some milling work . . . On the Gulf Coast
  7. bearing 51103
  8. Would this attack make you feel better?
  9. eBay + Tax - is this coming to a revenue office near you?
  10. Water contaminated oil in gear box...
  11. 60 tooth XL pulley needed!
  12. Drill chuck arbor TIR
  13. OT-Vertical ATV Hauling
  14. OT:Transporting heavy load.
  15. OT mostly, labor of machining love
  16. Opinions needed on shaper cutter shape.
  17. OT: Question for the pilots about getting rid of excess airspeed
  18. Probably stir up a wasp nest, but...
  19. MIA tailstock(s)
  20. Hardening Steel
  21. Machine tool finish --- (not what you think)
  22. Experiment in additive machining: Putting the chips back on
  23. Bijur 'one shot' pump oiler repair (sad/poor quality casting)
  24. OT-Central Heat & AC Units
  25. Hockey Puck Feet for My Pop-Up Trailer
  26. knife edge rollers
  27. Lodge & Shipley lathe
  28. Too_Many_Tools post are fine with me
  29. I’m both pumped and pi$$ed at the same time ( A machining thread :) )
  30. The CNC laser / punch arrived :)
  31. My W&S BAR MACHINE
  32. Shop Rag Cleaning ????
  33. New Wheels for Barbie
  34. ? mount for a Hossfeld bender ?
  35. OT? : brake line vs hydraulic line
  36. Newbie tool gloat
  37. Central Machinery (HF) rant...
  38. OT but relevant
  39. Wire dimensions for measuring a gears.
  40. A satisfying project - tools were involved
  41. Bulking out an order
  42. Way OT - Money Scam
  43. Factory Made on TV yesterday
  44. Setting up a compressor?
  45. Press Brake Dies
  46. Polypropylene bottles
  47. O.T. My novel is on Amazon.com
  48. Anybody created a NOGA like Holder?
  49. OT Old Lawn Iron
  50. Electronic Threading - my method
  51. Lodge & Shipley Pics
  52. Rudy Kouhoupt video link
  53. Generator Slide out.
  54. A Good Quality Oil For Lub and Rust prevention
  55. Machining hot-roll steel - just complaining
  56. What insert does this indexable mill takes?
  57. Nice looking little mill
  58. Internet spying
  59. Finally some tool gloats of my own
  60. trouble removing tapered shank from tapping head
  61. Mill build?
  62. Need advice on motor for mill
  63. Brainstorming Time! Mold prop-blocks and insulation board...
  64. how is this grinding wheel used?
  65. Sinpo DRO
  66. Clausing Colchester Lathe
  67. Need help choosing my next lathe!
  68. Sheet metal stamping question
  69. HF direct to store
  70. Your Old Dog, thank you
  71. Baldor grinder rebuild questions ...
  72. O Ring Groove Cutting
  73. Another newb question on parting...
  74. Did some experimenting this weekend.
  75. Compressed air distribution
  76. More pictures of restoration and new toys for your viewing pleasure.
  77. Grinding wheel for Darex?
  78. Vise for Mill/Drill
  79. A couple of small tool gloats
  80. I'm thinking the price on this is a lil high.
  81. Something Neat On The 'list... Burgmaster Six Spindle Drill
  82. A-Frame Trailer Jack Quick Attach Ideas
  83. OT: Situation report
  84. Getting good finish with 12" Atlas lathe
  85. ENCO promo
  86. OT - Flash Cookie removal add-on...
  87. OT: truck bed storage?
  88. Box turning tool ???
  89. OT- IE does not connect to WIFI
  90. Lumber dimensions for cribbing tractor?
  91. Zero Adjust Indicator Holder
  92. Chinese re-cycling
  93. First Shop Questions
  94. My first tool gloat...
  95. Chuck adapter plate
  96. What is the correct name for this tool?
  97. OT:Just in time for the Summer
  98. OT - Cheating scandal at U.S. Open rocks bass-fishing community
  99. OT long time friend found on face book.
  100. Washers, types..?
  101. Cutting a driveshaft down for my 63 C10
  102. Calculators and the Shop
  103. Lazy newbie question
  104. Roller Bearing with Race source?
  105. Getting a nicer look and keeping it square.
  106. engineering question brain teaser,I need advise from my betters
  107. Society of mechanical engineers
  108. shaper accessories
  109. MAXNC Still around?
  110. Somebody must have heard him
  111. Protecting your shop from fire
  112. Copper pipe soldering editicate
  113. Grinder Wheel Setup Help
  114. ON Topic - Need lathe spindle adaptor
  115. Quiet Compressor Project
  116. How a differential works
  117. OT: An Interesting Geometric Puzzle
  118. Boring head for IH mill
  119. Really OT - rhymes
  120. Checking Satellite Signal
  121. Adjusting satillite dish pointing
  122. Help with lathe switch installation
  123. My Swing Up Threading Tool
  124. Angus and the Parrot---(No machining content)
  125. Upside down threading away from a shoulder.
  126. Demagnetizing
  127. Al-U-Min-ium expansion: Need to size a rod (NOW WITH MACHINING CONTENT!!!)
  128. Magnetized
  129. using 123 blocks
  130. Mititoyo is OK!
  131. Toy Gloat!
  132. OT - After 107 years in Milwaukee, Harley could leave
  133. My picture of the year
  134. Tool and Die Maker tools - help
  135. Build your own Nuclear reactor
  136. Attempt to purchase Knight Foundry ends
  137. how solid of a vertical bandsaw to cut 4" steel rounds
  138. 14" Delta Band Saw is cutting out
  139. Power drawbar on R8 without pin?
  140. Need help with a BIG ol' safe. . .
  141. Production Machine Idea: Looking For Feedback (MACHINE CONTENT AHOY!)
  142. Spindle on Index 645 Mill
  143. Magnetic chuck help
  144. Switches
  145. WAY ot green tomato wine
  146. Question about anodizing aluminum
  147. computer or site settings
  148. bender die question
  149. O.T. - Widower Advice
  150. OT - OCC resurrected.
  151. MGB Armstrong Shock rebuild
  152. Anealing copper.. dunk or not to dunk
  153. BP clone knee Z DRO
  154. annealing tin??
  155. Another tool gloat
  156. Index Milling Machine
  157. OT - How old are You?
  158. What's this Hardinge thingy called?
  159. Would you know how to get my mitts on a Sony Millman LH51 Manual
  160. Mister cfm
  161. OT,Drain plug
  162. ? soldering ridge cap ?
  163. More about threading
  164. Bandsaw
  165. 3 D Modeling, A Must See
  166. From Freezer to Refrigerater
  167. Is MIG welding OK for this stainless job
  168. OT- How old do you feel?
  169. They sure don't make comic books like they did when I was kid.
  170. Now that's engineering:
  171. Drilling chuck sighting tool.
  172. Arbor press fun
  173. OT Question for Electrical Engineer or Master Electrician
  174. Fabricating a broaching die
  175. Unusual mechanical principles
  176. Structural Engineering help
  177. Slide hammer attachments
  178. OT - Setting Timing on a TBI 350 Engine
  179. Salvaging Components: Modems, Wireless Routers, Cordless Phones
  180. In Using a Wiper motor for my X-Axis Mill
  181. how to build a hydraulic press?
  182. Drill press rewiring: electrical connections with questions
  183. duMont keyway broach shim usage ??
  184. turning a drill bit into an endmill?
  185. Switching a 220V single Phase line
  186. What to do with SWARF?
  187. Project: Laser Cutter
  188. Google Sketch Up?
  189. OT. Excel help needed.
  190. First Tool Gloat
  191. Computer Question: svchost.exe, 12 of them running at once...
  192. Turning a window AC into a ducted one for basement shop
  193. Beginner Projects
  194. vertical bandsaw 12 inch????
  195. Safe Sandblasting for home use ?
  196. KBC Tools Bags of Crap
  197. Tool and die resurfacing
  198. Practical Thread Cutting Help
  199. i need a 1 inch radius cutter
  200. Source for 2" o.d. x 3/8" wall 6061 tubing
  201. Ever see a horizontal mill like this?
  202. AXA vs. BXA
  203. OT: First astrophoto of the season
  204. Plug in for Alibre Design to POV Ray?
  205. OT: HDMI Cables
  206. Cold Cash $$$ for your old Drive Manual
  207. OT Google & privacy
  208. Saving metal
  209. Right Lefthand Drill
  210. Home workshop valuations.
  211. Contouring, no math or cnc
  212. Close enough?
  213. Sunspots.........Evan
  214. OT: Sharp 22" TV.... Random "snow" and "slanty line snow"
  215. OT: BATTERY GAME CHANGER, Dramatic breakthrough
  216. solar energy breakthrough
  217. Video: Scraping in a dovetail -detailed-: You asked for
  218. Recommendations for a first lathe/mill needed
  219. Question for Nardini lathe owners.
  220. OT: Need help with stair lift wiring!
  221. The Value of old welding/cutting tools?
  222. Has anybody made ER Collets
  223. Geometric Dies
  224. OT: Welding class registration insanity
  225. How do you change a 9V battery to a 12V?
  226. making a thread chaser
  227. Pressure pot sandblasting in a garage
  228. Taper attachment for Rockwell 10X36 lathe
  229. All Powerful "Wife Of Brian" Has A Question...
  230. OT - Online Store software
  231. OT- maybe? Blood filtering.
  232. Does aluminium work harden?
  233. How do you store your taps?
  234. Free Tooling Just pay postage
  235. Rodin Coil
  236. thoughts on small sandblasters - not blasting cabinets
  237. Making up band saw blade problems
  238. Magnetic chuck
  239. MSC Promo
  240. OT: For Doc - "Dudes bring your cash"
  241. What tool is needed to remove a part with indexing holes?
  242. How do my half nuts look?
  243. Did some welding.. Forgot to shut of argon.
  244. Making gear hobbs
  245. Where can I get a splined 3 step pulley made?
  246. Haas Funds Scholarships in Machining Technology
  247. Aicraft latch/fastner type question?
  248. A machinist should be able to weld.
  249. HTRAL, ? re: centers
  250. Foundry patterns.. cost?
