View Full Version : General
- ot new cars
- OT - View inside the A380 office
- Really OT...website talks about Psychiatry.
- O/T very interesting old color pix
- Rack & Gear questions
- Where is Sir John?
- Finally got my new Mill. Warning - 3MB of pics.
- Clausing 5903 leadscrew issue
- Horizontal Mill to CNC or Not
- A spotting blue recipe
- 1/2" DOC on small lathe!
- Broken Thread on Shower Head
- Virtual keyboard
- Monster Machines
- OT - new Spike TV show - Scrappers
- Plastic Guesses?
- Way OT: Itty Bitty Bathroom
- DIY Steadicam
- LR 44/357 Batteries 8 for $1.00
- Drill bits/Reamers/Taps New or Used
- Starrett comb. square
- I'm sure there was some machining involved in the making of this
- Deep hole drilling?
- Chinese works inside a die set
- Manual Download Site ???
- Just saw a sign hear in Houston. Antique tool sale
- We need to design a better grease gun!
- Usually a day late or a dollar short
- Evan, I am "compiling" a list of your posts!
- ever heard of air drill + tapping head?
- Moslo Injection Molder MC75
- CSE height gauge
- ot. saving favoites on explorer
- T-slot size for 6" rotary table?
- What is this?
- Odd fly cutter...
- OT - DC PM motor source??
- How to cut pattern to weld round end on pipe??
- OT - Smile! Aerial images being used to enforce laws
- Anybody here ever moved a K.O. Lee B2060?
- head spacing
- best use of cutoffs/drops
- Form tool grinding question
- Annealing Stainless Steel?
- Selecting a propane torch
- Hydraulic Engine Hoist - Trouble in River City.
- Why use Air Tools?
- OT: Just one Youtube video....
- Air Compressor wiring hookup?
- OT: need advice for cleaning Anodized Al BBQ parts
- Do you make drawings of your HSM projects?
- O/T 4 cyl honda, 4 carbs, someone ?
- newb shop is spinning up slowly
- Refrigirated Air Dryer
- OT - How old a tire is still a SAFE tire?
- variable speed pulleys
- What oil for bronze bushing?
- Question on BP M type rotary head mill
- BXA on Clausing lathe? (sizes)
- DIY Optical tool setter for CNC lathe
- clausing Colchester Lathe
- The perfect flathead countersink?
- Help...stranded farm equipment
- MSC Promo
- Coolant Recommendations
- OT: Oshkosh video
- Compressed air- filtering and pressure regulating
- HF Bench Top Sand Blaster Help Needed
- Suggestions for Simple Drawing Program
- Another Swing Threading Tool
- converters
- Crankshaft keway repair -also posted at PM
- Welding class... resolution (You'll like it)
- Trading How did I fare?
- CL ad for lathe near Boise Idaho
- import lathe disappointment (do they use their own?)
- OT Another Project Follows Me Home
- Machining Polycarbonate (lexan)?
- Enco promo
- OT Dutch Troublemakers Turn Surplus Army Target Drone Into Autonomous Wi-Fi Sniffer
- Question about friction
- Van Norman valve refacer
- Bending aluminum plate without cracking it?
- stereoscopic lenticular screen monitors
- Downsizing a shop
- Found this on ShopFloorTalk forum about tubing bender new tech.
- Get the most out of yourMagnetic Drill
- O/T cool mechanics of sorts.
- green wheel too soft?
- lathe Dog for small parts
- Mitee Bite and Gibraltar fixture clamps.
- The biggest advantage of using CAD for designing
- Wood band saw for metal?
- Painting Aluminum / Telescope
- OT: Screen resolution
- Radius Gauges??
- Excello Ex-Cell-O XLO model 602 manual
- Rejuvenating concrete shop floor
- Power tool drag racing..
- Best/easiest 3D CAD?
- Couldn't be any more on topic if I tried.
- OT - Bedbugs
- Can anyone identify this compressor?
- Vertical 5C collet vise - anybody have one?
- ISO 9001 & Quality
- OT, Dymo label maker
- How to sort this? Tapered jib adjuster.
- Tristate Gas Engine & Tractor show
- crap, what next ? chuck issues
- Alternate Toilet paper uses
- Power hammer, overhead guided Helve for metalshaping
- NuVinci CV hub
- Holy Metal spinning Batman!
- The Joe Martin Craftsmanship Museum
- new rotary phase converter
- Oxygen-Acetylene welding
- 28 mm Thread Question (Cameras, Telescopes, etc)
- Cincinnati #3 restoring project
- Gerstner anyone?
- Drilling a centered hole on a crappy lathe
- OT The 545 people responsible for the USA's problems
- Grizzly coupon code
- Emco Compact 10 rebuild - need info on motor drive set-up
- What are you up to today?
- New toy soon to be home....
- OT Now for something completely different- aerodynamically
- A personal thank you
- Tsudakoma mill vise quality?
- TP Tool -never again!
- More new toys
- speeds and feeds???
- Radiator Woes
- emco maximat v13 gap bed lathe
- Help with Darex drill Grinder
- H/f Mag Chuck
- Innovative File Handle
- OT -- I am going about this the wrong way...
- Ot F150
- Another "new" aircraft type for you
- OT - Camcorder suggestions?
- Benchtop setup
- Subject: Solve an argument.
- 5C Collett Chuck
- Compression fitting angles
- Airport Scanners
- Sorta OT: Finally, a fix for those blasted noisy and ineffective bathroom vent fans
- Better Brass copper???
- OT-Hearing Aids
- Ever build a RV camper?
- Keeping cool in the shop..what works and what doesn't
- semi OT - storing IC's
- American Can, Fairport New York
- 123 block
- semi OT: how's business ?
- Problems with Drill Doctor solved
- chinese mill clamp sets - good or save for Gibraltar
- OT - America : Land of Houses Too Large and Shops Too Small
- Which direction for bandsaw blade
- Paging electricians. 3-way motion activated light switch installation
- Its Alive
- Efficiency: Electric vs. Gas
- Spanner size for Dickson Toolpost?
- Harbor Freight 20% coupon???
- Help with DAREX D3
- Bronze bushes and D reamer
- Reverse Switch Help?
- float charger for generator battery
- Zero backlash nuts
- Atlas 10" Lathe dials
- Bridgeport Rapid 8 power drawbar
- Using a box tool
- cincinatti gear holder attachment; how does it work
- Now I got 2 of 'em!!
- Close Quarter Deburring Tricks
- 240 volt AC question
- Help with Parting
- Help with Parting
- Anybody have the grizzly dro for calipers?
- What material are boring bars made of?
- OT: How to buy FRESH Li-ion batteries?
- How do digital protractors work?
- Gearing down a gear motor?
- New shaper :-))
- Anyone ever made a dipstick for checking the fluid level in a car battery?
- 2 Cycle Engine Mix Ratios
- Need help Substituting a metal ???
- OT - Downloading on Dialup
- i need help to make an inside coilspring compressor
- I thought expanding foam could only make ulgy.
- How to Cut Shim Stock
- where to find?
- Cut knurling tool again
- Is your shop for fun or profit?
- Acetylene sensor
- Beeswax and threading
- X-3 Spindle Grease?
- Situation report update
- Looking at buying a Haas TM1P
- Checking large plate flatness. HSM workarounds?
- MSC Promo
- Looking for schrader fittings (female)
- Any reuse for a big 50 or 55 gallon tank?
- Can an admin enable polls please? it would be helpfull.
- Air compressor outside?
- Buy a gas can lately?
- Gear reduction and fluid level questions
- Restoration 101
- Paging "Fastrack"-Look at the Video
- HHS Drill bit repair?
- Recommendations on a Face Mill for a vertical mill general use?
- Estate machines and tooling, Victoria BC, Canada
- OT: Medical problem: Hemochromatosis questions
- Shaper setup for square hole
- Anyone tried new Laser Center finder?
- OT - 747 million pound take-off
- Snow Engine Project
- C4 collets
- help with cutter head identification....
- New 4 jaw needed - Shopping advice please
- L-W Indexing head help....
- My first sprocket
- OT Explorer 8
- Enco: 10% Off Plus Free Shipping
- Collet Identification Help
- OT TV antenna info.
- Turning Axis Height
- Wife's anniversary present.
- Explosive LED failure
- A good save
- Open Running Model A Ford Engine
- Way OT: Morse code telegraph question
- OT:Astrophoto of the week: The Moon in colour
- New member. Great site
- Sandblasting with 5hp air compressor. Please share your experience.
- AutoCad Lt 98
- A Stark no.3 lathe
- Webster I.C. engine redesigned as "Hit and Miss" engine
- Horror Freight bandsaw blades - HA!!!
- Forklift forks
- Help!!! Need Advice
- vortex tube cooling gun
- A Versatile Dividing Head
- line bore question
- Pics from Al's Iron Ranch
- O.T. YouTube Down?
- ration question on sprockets
- Enco promo
- Now I got 2 of ‘em II, The Sequel
- help please, removing alum from burr
- Paint for Outdoor Metal Projects
