View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 [154] 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. OT-Unusual scrap steel
  2. Mig Welding wire spools.
  3. Ever worked in the shop under the influence?
  4. HF bandsaw blade( not to hyjack the thread
  5. Making a weatherproof door/hatch
  6. Source for 2" Dia Aluminum Disk 1/32" Thick
  7. Chip Welding
  8. HELP! - bandsaw cutting too slow
  9. The flat belt article
  10. Lathe Chuck keys - opinions sought
  11. Micro Micro Mill
  12. O/T: Hubble shots
  13. Tools & Cutters - efficient grinding
  14. OT: What type of plastic and glue for it?
  15. Ot; Old Vinyl Sundeck New Vinyl
  16. Alibre to Pov-Ray rendering interface, aka Pov-Ray made easier
  17. Chevalier Surface Grinder
  18. Cutter diam and surface speed to RPM calculator
  19. chuck up large drill tu turn down shank
  20. Enco promo
  21. My cast was removed yeterday
  22. Storage of Honda g200 Engine
  23. OT - Yahoo Probelms on Dialup?
  24. Lab Volt CNC
  25. Letter drills: what was the system developed for?
  26. Gears and Gear Cutting
  27. 5 Years after Katrina...what happened to the tools?
  28. OT- EPA wants to ban LEAD
  29. Big tumblers
  30. Quick Tapping question
  31. How dumb do they think we are?
  32. Unusual Question??
  33. MSC Coupon - 30% til 11:30 EDT 8/27
  34. Door catches Any knowledgeable carpenters here.
  35. Lufkin 299 Back Plunge Dial Indicator
  36. GE Electric motor help needed
  37. Thermal Imaging (paging Evan, Evan please report to the Internet...)
  38. Don't like this one damn bit..
  39. Bronze bearing source
  40. OT It's mechanical, but what is it?
  41. Mill backlash
  42. Split Point Drill Question
  43. New tool gloat!!!
  44. OT: use a lathe to protect yourself from snakes
  45. Oxygen Concentrator/Generator
  46. Mill light via "free" HF led flashlights (or how to waste time)
  47. Speaking of snakes and lathes.....
  48. A future work holding technology?
  49. Arranging small tools around the lathe.
  50. OT: Laptop question
  51. Plotting involute curves
  52. Hobs, hobbing, but no Hobbes
  53. Polycarbonate (lexan) frustrated
  54. What kind of hammer ??
  55. Id material! How to tell phosphor bronze from leaded bronze?
  56. My first crash.....
  57. Clausing Tailstock Wrench
  58. Racine Power Hacksaw
  59. Inicol on a G0619
  60. Braking a lathe motor with DC injection.
  61. When Foam Goes Bad....
  62. Machinist - 8th most dangerous job in America?
  63. OT Mobile Web Access
  64. Koolmist questions
  65. Machining Bearings
  66. Shop Door - Overhead with entry door?
  67. I need some math calculations for a punch press die.
  68. Torque wrench? Tailstock?
  69. turn 1" alum to zero in 2 passes on Logan
  70. Semi-OT: Nice pocket knife?
  71. Different grades of HSS tool?
  72. ENCO 4 jaw chuck help
  73. Headstock bigger than my barrel
  74. Best Method for Removing Rust from Lathe Ways
  75. Atlas 7B Shaper Stand
  76. how to add a photo to a posting
  77. OT: Android App Recommendations
  78. One more DAREX M3 question.
  79. Ebay Tool Gloat: Mitutoyo Snap Caliper!
  80. Shop Secutity - Revisited
  81. Got a mill vise from Plaza Machinery
  82. Screw in A Roll Pin
  83. O/T: Again, but could save you some money
  84. Model Hit and Miss Engine
  85. DRO Scale parallelism
  86. OT - Image editing software
  87. Metric thread fun! (Pics)
  88. a question for mr mueller about the sold, small gack shaper
  89. Whoa. Déjà vu. What did you just say?
  90. Boring head stupid question moment
  91. OT, Idiot TV commercials
  92. Help Repairing Calipers
  93. Surgical loupes for machining ?
  94. Some threading questions
  95. Semi OT, Perkins diesel help
  96. Enco promo
  97. Knurl pitch: in industry, how specific are knurling spec's on print
  98. OT: Low Scumbags to Watch Out For
  99. Should there be a tax deduction for a hobby home machine shop?
  100. OT: Computer Question
  101. How do I cut a tapered, coarse thread?
  102. Leadscrew Wiper?
  103. Live Centers - Buy New Import or Buy Used USA?
  104. Horseshoe Magnets for Rickenbacher Pickups
  105. beeswax
  106. incremental gear hobb cutter
  107. Continuation from my headstock being too long
  108. Cnc Parallel Port Software Breakout Board
  109. question about morse taper
  110. As the Hob Turns
  111. Most readily available lathe oil
  112. Outdoor sandblasting- your choice of media
  113. Using a Rotary 3-Phase Converter
  114. Question about wax
  115. Machinists in the news again
  116. Keyless chuck for mill
  117. Tool lust
  118. moving a surface grinder
  119. Discount Metals........BEWARE........
  120. Clausing Conversion
  121. Monarch 10EE in the Vancouver area.
  122. Old Black& Decker 8"grinder
  123. Threading/Thread Specs - What did I do wrong??
  124. Update on the C4/4C collets
  125. David Cofer
  126. OT-new type flourescent light question
  127. CNC parallel/breakout question...macona, et al
  128. best way to set up barrel bore in lathe?
  129. knee power feeds for Bridgeport mill
  130. How does HF decide what to sell?
  131. Clapper box on shaper
  132. Change of pace OT
  133. heavy 10?
  134. gear box
  135. Drilling a really long hole
  136. Anyone using an instrument or watchmakers lathe?
  137. Viagra needed - On Topic actually
  138. DRO Mounted :)
  139. Scraper People question
  140. Do you buy tools from Sears?
  141. OT: Way OT, Help Tying Balloons
  142. Image measurement software
  143. What toilet paper do you use?
  144. Help me, I've been window shopping
  145. OT - RF help needed
  146. DRO Help ? Displaying 2X Distance Traveled??
  147. Best machine for the job?
  148. OT-Generator Wiring Question
  149. Press Fit A steel bearing in Aluminum
  150. Broken air compressor rod. Will my idea work?
  151. OT: Kudos Zenni Optical
  152. Power drawbar riser for my sqr col. mill
  153. Bolt Blanks 1 1/4 X 7 tpi x 8"
  154. Need a better idea than hand cutting centers
  155. Deep Hole Drilling 101
  156. Quick Change Toolholders
  157. Welding fumes respirators and others!
  158. generator problem
  159. backplate
  160. Locating & accurately drilling holes
  161. O/T NZ Members
  162. Where to get pulley for metric shaft?
  163. American Precision Museum Show
  164. Solar energy for the shop
  165. Choosing steel type
  166. Meccano/Erector/Tool Sets for Christmas
  167. Where did Paul Jr get all his money?
  168. Added 17 more Pictures "Belt Sander"
  169. Stainless Steel Ground Shaft ????
  170. single point threading tools
  171. 8X36 Mill Calamity
  172. Photobucket test
  173. HSS bit geometry for cold-rolled bars, for finish
  174. Easy to machine steel(?)
  175. Magnet strength
  176. materials with high thermal expansion
  177. Thinning down cutting oil
  178. messed up my back plate
  179. Solidworks Draftsight
  180. kiwi damage pix's O/T
  181. Atlas 7B Shaper Feed Timing
  182. Another stupid newbie question on tools...
  183. I pimped my lathe!
  184. Engine hoist capacity
  185. Cincinnati Shaper clutch
  186. More electric motor help OT?
  187. R8 to JT6 Arbor to 1/8"X 5/5" Keyless Chuck
  188. Bearings balls = some air hardening?
  189. Purchased With Archive Help
  190. low price metric reamers
  191. OT:95 monte carol abs problem
  192. Best thread sealant for compressed air fittings
  193. How do you attach filters/regulators to your plumbed compressed air network?
  194. 240 volts vs. 120
  195. Sparks and Bangs
  196. Improvised low tech rotary table
  197. People who neglect tools should be .........
  198. Spending a Dollar to save a Dime...
  199. 2 nd post?? better way of hand cutting centers
  200. Htral
  201. Free small metal gears
  202. ID resister for makita 9.6 volt drill please
  203. micro centric chucks - what can I do with them?
  204. Improvisation of the Day...
  205. Let's see your improvements to and accessories for Harbor Freight hydraulic presses
  206. Atlas 6" Lathe #10100 Back Gear?
  207. New 7x12 Band Saw
  208. George Matov - may be right
  209. CDN Members: Interesting Oakville Auction 9/23
  210. Dial caliper disassembly
  211. Change gears for older Grizzly?
  212. Exhaust Manifold Repair / Antique Tractor
  213. Running timing belts upside-down for a toolpost grinder
  214. Unusual shop experience.
  215. Measuring the pressure anglle of gears.
  216. Band saw blade thickness
  217. make a tap
  218. When I'm not buying machine tools...
  219. anyone want a large dust extractor??
  220. An improved craigslist
  221. I am tired of Thieves on Ebay....LOOK OUT
  222. Light question (shop light)
  223. 3J Collets
  224. Vision On
  225. Dang, D1-4 8" Bison won't fit my D1-4 lathe
  226. Older Modine or new Hot Dawg
  227. Buffalo Forge #21 Drill Press
  228. Need wiring diagram and suggestion for type of switch
  229. Stepper motor coupler for Sherline/Denford?
  230. Let's your HOMEMADE engine cranes
  231. Any deals on prescription Safety Glasses?
  232. Favorite Threads
  233. question about lathes (semi-automatic, maybe)
  234. Question About Brazing Rod
  235. Good deal?
  236. Ever seen this lathe?
  237. Beginner Question
  238. Dangerous or What! (Uncoiling Band Saw Blades)
  239. What is... "CNC Jig Mill"
  240. Acme "variations"
  241. More "EBoner" Funnies
  242. Introducing myself...I'm a knifemaker from Southern Oregon...
  243. ? relating to deephole drilling - rifling
  244. Help Need info on Lathe
  245. energy in falling water
  246. A different tapping block
  247. Battery help needed
  248. Proper use of Boring Bar
  249. OT - Electrical Question
  250. OT -- Amusing Supplier Mishap
