View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 [155] 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211
  1. Source for 4" x 3" x 1/4" 6061 Aluminum tubing
  2. Smoker pictures
  3. Pinging John Stevenson
  4. how do you use small taps?
  5. OT: Meet the Latest Statistic
  6. Bridgeport J Head Question
  7. Grinder motor RIP?
  8. Milling through spot welds?
  9. Cylinder Quotient
  10. Flashback arresters
  11. OT -- Shop heating with small space-heaters
  12. Parallel cable for CNC use?
  13. ENCO promo
  14. Anyone have experience with the Ingersoll-Rand air compressor recall?
  15. electronics question
  16. Taper Turning Help
  17. OT: Ford must be stoped.
  18. 1.25" Boring Bar Recommendation Sought
  19. Centerless grinding
  20. Knifemaking great Bob Loveless passes away....
  21. Telescope mods, colours in the sky
  22. Just got +200' of 2" iron pipe for FREE...what can one build with it?
  23. Silver and Demming Drill Bits
  24. Preventing nasty oil-and-crud buildup around hydraulic equipment...
  25. Buying North American
  26. Jet BD920W any good
  27. Bearing Cross Refrence Info?
  28. Surface prep for chrome plating
  29. Cleaning and Protecting Aluminum Surfaces
  30. "waiting for ads.villagepress.com".....do you get this?
  31. OT: Poor economy or Poor business practice
  32. Another what is this?
  33. Does this site have a virus?
  34. slightly OT Penn Tool
  35. OT: What's wrong with this picture?
  36. OT - Mastech HY3020D Problem (Power Supply)
  37. O.T. My Adventure novel
  38. Finding a Bearing
  39. Waaaay OT: Gameshark/Action Replay
  40. Wierd
  41. Need help rewiring lathe from 120v to 240v.
  42. Rotary Phase Converter.
  43. Today's failure
  44. Home made power scraper
  45. 208 - 460 volt conversion (Bought another machine)
  46. OT - 'Security Suite' malware
  47. Rotary phase converter question
  48. Good electronics size wire stripper?
  49. OT - Electrical Question
  50. Size and sourse for VFD
  51. Monarch CBB lathe weight?
  52. Screen tools
  53. 3 in 1 Lathe, mill, drill press.
  54. Procunier vs Tapmatic Heads
  55. Shortwave radio in the shop
  56. Socket Set Screw size for AXA Tool Holder ?
  57. Pictures for your viewing pleasure; shaper, TPG, various projects
  58. Rock Solid Led Flashlights
  59. modern marvels tv show
  60. Torchs: Y or quick disconnects?
  61. Planetary Photography in the daytime
  62. Is This a Plastic Injection Machine?
  63. Old Wagner Electric Corp R-I motor need brush springs
  64. Knife Maker Belt Sander Recommendation?
  65. carbide inserts
  66. Ettco vs Procunier, etc,
  67. Lathe Indicator
  68. 'End mill sharpener' on Oz ebay
  69. The new South Bend 10k
  70. Help with a steady rest
  71. Do you use diamond files?
  72. OT: does anyone here have and use a corn/wood pellet stove?
  73. Small bandsaw
  74. Homemade Benches for Bench Lathes
  75. Free to a good home stuff...
  76. Farm Fence
  77. ACME Threads "Here we go again" !!
  78. Cheap, low-backlash, low-friction leadscrew nuts?
  79. reply from Super John M.B.E.
  80. What is needed to cut left handed threads.
  81. variable speed scroll saws---Looking to buy.
  82. Linear Rails
  83. Drill Press Vice
  84. OT Windows Essentials, and Defender
  85. O?T, Electrocution warning
  86. Physics/maths question.
  87. Milling machine upgrade
  88. all in one machines
  89. What machines have Jarno No. 7 Taper?
  90. bison plain chuck with D1-4
  91. Tips for milling off splines in 4WD hub
  92. Rotary Burs
  93. collet holder
  94. Drill rod type
  95. Tip for Mill/ Drill Vise Bolts- Carriage Bolts!
  96. Look at what my wife bought for me...Gloat, Gloat
  97. OT Strange request and copy righting
  98. what's the largest TPI thread you've ever cut?
  99. Rust prevention product
  100. Making Acetal leadscrew nuts the easy way
  101. lathe dog clutch
  102. Suggestions for setup turning with a mill (mill/drill)?
  103. Hanging Tranglular Doors
  104. Help me with more shop equipment choices?
  105. south bend heavy 10
  106. Acetylene tip with ruby?
  107. another boring bar question
  108. Uses for a honing machine?
  109. Valve seat fint info needed....
  110. OT - testing an O2 concentrator?
  111. Event: Field Day of the Past, Rockville, VA
  112. Forming Acetal gears.
  113. Less fail!
  114. Useless degree of freedom?
  115. Boring on mill
  116. Gat a spare C note?
  117. Threaded Rods? Or is there another way?...
  118. How can I get an epoxied clutch coil apart?
  119. Need help identifying Valenite insert holder
  120. Source for brass set screws in Canada
  121. Aligning a Mill vise
  122. Lathe Turning of Rubber Seals ????
  123. Reforming a main bearing cap
  124. How to use an edge finder?
  125. Grindeing HSS
  126. Odd Holdown clamp
  127. Proper Idler pulley design
  128. questions about die filers
  129. Hardening air hardened drill rod
  130. New Member
  131. Crank Pin material
  132. Workholding in a different light
  133. Engine project
  134. It looks good, but is it the best answer?
  135. Its my birthday...40yrs old!!!!!!!!
  136. get ready for big lay offs
  137. Used Polyethylene Cutting Boards - Salvage for Shop Use
  138. Forklift Battery: Is it SUPPOSED to do that?!
  139. Some wiring questions for VFD and minipress
  140. Old style key steel?
  141. Free
  142. Checking in
  143. Brown & Sharpe 2L surface grinder
  144. So guess what this will make...
  145. Thrust bearing material?
  146. Lever Collet Closers?
  147. Making an Acme tap
  148. Plastic help needed
  149. Need to make a thread in cast iron
  150. longer lasting hinges
  151. OT: An EE brainteaser.........
  152. Belt lacing question Clipper VS Alligator
  153. Where do leather machine belts come from?
  154. How to change a light bulb
  155. Starting up 200 Hp AB Drive
  156. Help me diagnose a wobble in my back plate plx
  157. External Threads on 5/8" DOM Tube Using a Die
  158. Galling and precision sliding surfaces
  159. Interference Fit Question
  160. Got to try out my sunnen hones finally yesterday. Gloat
  161. Any of guys going to the portland show
  162. OT: Friends
  163. Yesterdays quick project, Microscope stand
  164. 91 yo Completes 7 yr Basement Build of 1:1 Scale 1918 Fokker D.VIII
  165. "For Sale"
  166. Markout techniques backing plate to chuck ?
  167. Centering a rotary table
  168. bridgeport knock off, i guess
  169. Another 240 vac question
  170. Can anyone identify this tool - Take 2
  171. New impact gun design
  172. OT, which NJ area airport to fly into.
  173. Advice on solid carbide endmill
  174. 1/6th scale of 1911 Simplex auto engine
  175. O/T Kindle
  176. helical gears
  177. reconditioning a grinding wheel
  178. Where to buy flux for brazing steel & cast iron
  179. interesting lathe bed
  180. "Rat Rod" style surface grinder tool gloat
  181. Freekin amazing free software for macro images
  182. Can this bearing be saved?
  183. OT Small cars for New York Congestion
  184. 'C ' clamps
  185. OT New home furnace recommendations?
  186. What grease to use on drill press quill?
  187. Interesting drill press
  188. Right Hand/Left Hand ?
  189. Restoring the Old Gas Cap
  190. Planning on making some gearboxes - advice sought
  191. Forging a blacksmith's hammer
  192. Recommend fan motor lube please
  193. New Toy and Kudos to Clausing
  194. CBN inserts in canada
  195. Slightly OT: CO2 gas leak in the house
  196. turning of hard materials & identify this insert
  197. smie OT, Fluke DMM gloat gone bad
  198. Where is our Sir John ?
  199. identifying blacksmith vises? any experts?
  200. New Guy. What machine(s) to start with?
  201. OT - Plumbing Woes/Sharkbite Joint System
  202. Brian builds the Kerzel Hit and Miss i.c.
  203. drill press
  204. 3 Volts from 6 Volt Pack?
  205. Shop Air
  206. Nut piece at end of a pipe
  207. south bend lathe
  208. Different Voltage Cordless Drills..are the motors different?
  209. rust resistant surface treatments
  210. OT:Breakers yard.
  211. OT: My turn to ask a computer question
  212. commercial Hot Water systems pipe material.
  213. Another Tangential tool holder
  214. OT - Suggestions for Email Suppliers
  215. Blacksmithing Meets Machining: Resurfacing Power Hammer Dies
  216. Enco 328-1310 Lathe-Mill-Drill 3 in 1 Multi-Machine
  217. The Great Shop Move
  218. Looking for a good quality 5c collet block
  219. Problems with the HSM BBS board
  220. Jacobs Chuck??
  221. Newbie needs micrometer help
  222. Storage for thin long stock
  223. o/t Roboform Does anybody have an opinion?
  224. Boxford Lathe Opinions
  225. question for Evan
  226. Motorize Suburban Punch Former
  227. The Cut Knurler
  228. Question on turning plasitcs...
  229. Milwaukee 2H
  230. Control wiring for motor starter... clarification help.
  231. Cincinnati bickford no 1 plain mill
  232. Oil through grease zerks
  233. Eccentric end-mills
  234. Trying to 'true' a 3 jaw chuck
  235. OT non machining questions, transducers
  236. Heads up for the guys in the Boston area...
  237. Lazlo....
  238. D Drive
  239. Contest notification
  240. Travers Tool Housebrand Quality?
  241. Old Craftsman lathe, sell or keep?
  242. Looking at buying a new lathe
  243. Free image zoom for tech web pages
  244. OT: Help needed on 12V winch as used on ATVs
  245. nuts and bolts
  246. Connterbores
  247. Homemade Belt Sander gets some paint
  248. Decisions,decisions
  249. Hey guys'!
  250. Workholding on a Rotary Table ?
