View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 [156] 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211
  1. Gears, gears and more gears
  2. Acetal Ball Screw nuts
  3. Anyone know of good quality import 4 jaw?
  4. Opinion about a supplier
  5. How do you move heavy stuff around your shop?
  6. Another.... WHAT-IS-IT?
  7. Polycarbonate Cover For Vacuum Chamber
  8. Holy Moly!
  9. Snorkel valve?
  10. Busy Day
  11. Fly cutter Sanvdik
  12. building an IC engine
  13. Faceplate Stud Mounting
  14. Prepping Stucturual Steel for Paint
  15. Tool Gloat
  16. Compound angle question
  17. portland or. show
  18. 4 jaw screw chuck
  19. sparks from a face mill?
  20. TOTALLY OT for Evan
  21. Draw Bar Question (possibly dumb !)
  22. Electro mechanical project... "Pause" button for molding machine.
  23. Kind of a Test Message
  24. working room for bridgeport?
  25. Just want to know?
  26. My new model diesels
  27. wow what/not a bargain????????
  28. Way OT- Web Page Builders
  29. horizontal bandsaw
  30. I tapped my first hole today...
  31. O.T. CB antenna
  32. OT: Say good bye to sunspots and hello to global cooling?
  33. This job Blows .... ...........Totally
  34. Old mill, worth the effort?
  35. got my bd920w today
  36. HSM'ers at railtown 1897, Jamestown, CA
  37. What sort of mill should I be looking at?
  38. another 4 jaw chuck
  39. Aussies look here!
  40. OT: Bizaare accident killed Segway company owner
  41. Having picked a miller & lathe, what about the toys?
  42. Die grinder SFPM
  43. how to lap inside holes
  44. Was Quite Surprised
  45. 4140 prehard - warpage?
  46. Gears
  47. Roller stands
  48. What's this clamp on my Standard Modern?
  49. Oxygen regulator still shows pressure after draining torch
  50. Educational videos for brushing up on your studies
  51. Heads up! Clausing on craigslist in Indiana for great price
  52. How do you clamp large flat plate for face milling
  53. 4 jaw or faceplate off-center work: your method for rotational balance?
  54. Odd thread size
  55. Best leadscrew oil?
  56. Just bought a surface grinder on ebay
  57. Just finished, a Rider-Ericsson hot air pumping engine
  58. Jet 1224
  59. Don't make my 5C collet mistake!
  60. odd threads,ship work and Euopeans!!
  61. Enco Shipping Code
  62. Gear for a Sheldon lathe
  63. Goin to Grizzly
  64. Fix for camshaft dist. drive gear?
  65. BF20 Quill Stop
  66. Why friction lighter with OA torch
  67. What steel to use?
  68. 10EE for $800?
  69. Champion B&F Drill Tool Gloat w/pics
  70. I saw this on craigslist
  71. Support For Outboard End of Arbour in Vertical Mill
  72. Pretty much everything you need to know about plastics can be found here:
  73. Request for opinions (mini-lathe & mini-mill)
  74. Building a webster engine
  75. HF Belt Sander?
  76. Defect in MAPP bottle/ torch heads
  77. Which way for dovetails?
  78. Adventures in threading
  79. Pressing in bearings
  80. ENCO 10% Off AND Free Shipping Code! NO MINIMUM ORDER
  81. Barker Mill CNC conversion
  82. What's a fair price?
  83. Chain Saw Blades OT
  84. Clamping surface-finished work pieces without marring?
  85. Toolbox find, about 1955
  86. Smithy 1340 3in1
  87. OT: Strange problem with Firefox and Yahoo
  88. Clutch repair job
  89. Nutserts, I want the opposite.
  90. new wrinkle in aged scam
  91. Internal tapered keyway on CNC lathe?
  92. Baldor Grinder
  93. Layout Fluid For Dark Materials - Delrin
  94. Z axis drop on mill-drill
  95. Popular Sicence - Plans for an adjustable radii turner
  96. The Home Shop... Chemist?! (Warning: Metalworking Content)
  97. O/T Kop Hill Climb
  98. Steam engine question
  99. Max fly cutter diameter?
  100. Small bench grinder for small home shop?
  101. I actually finished a project
  102. Dr McMaster-Love, or How I learned to stop complaining and love their service
  103. Anyone Else Use NYLOG?
  104. Who was in China
  105. You never know what you can find on Craigslist...
  106. Where was John Stevenson?
  107. My 3rd prototype water cooled Ruger 10/22 rifle
  108. Ot- #*!$*@!! Vista
  109. OT - Accoustic/Textured Ceiling Coating
  110. OT, Maybe- Kohler Engine troubles
  111. Indicator problem
  112. OT- Auction screwup?
  113. Need Welder, Which?
  114. Who Makes Rubber Angles
  115. OT: Help with identifying a coin.
  116. Help with a tractor
  117. CNC for dummies
  118. Duplication on a SB
  119. Why is the world out to get me! A milling problem.
  120. Need help trouble shooting 5c collet chuck
  121. Snow blade help
  122. 14" delta bandsaw setup question
  123. Tool Gloat (Dial Bore Gauges)
  124. OT: Vista 32/64 bit upgrade??
  125. Bending 3/4" 304 stainless plate
  126. Setting overload Amps for motor starter
  127. acme thread
  128. Anybody need a blue lathe?
  129. Any comments on a Dorian economy toolposts
  130. oil cap threads
  131. Arbor press stand. What are those pins for?
  132. Going to Diamonds
  133. Tramming a round-column mill-drill?
  134. Small Gloat
  135. Help going from flame cut to machined
  136. small Collet Extension
  137. Square Collet Blues
  138. Good 5/8" - 3/4" boring bar?
  139. Tube bender project and junk yard score!!!
  140. No casting machined
  141. Feedback wanten on HF Rod/Bar Bender and 30" Bending Brake
  142. How would you have done this job?
  143. It's almost time for Christmas....
  144. Halloween
  145. Did I do Something Wrong?
  146. Another Scam
  147. Electronics Cleaner
  148. Making a Flat Plate...
  149. Spinner Tool and cutter grinder
  150. Deep slots in aluminium
  151. What do you call those little drill chucks?
  152. McMaster Catalog
  153. how is the ball turner tool mounted to the cross slide
  154. Question ,hydraulic jack, weighing heavy stuff!
  155. OT: Windows 7 - W2000 networking & other software
  156. Anvils Anyone?
  157. High speed spindle bearings
  158. Cable for Caliper type DRO
  159. more free CAD
  160. Small lathe bed: scrape vs. lap vs. do nothing?
  161. inches to degrees help
  162. Long B&S #9 arbor for vert attachment needed
  163. OT -- GM auto transmission hunts. Why?
  164. O.T. Tool Porn
  165. Do you have a favorite tip(s) you got off this board?
  166. Speaking of spindles: Simple shopmade ER32 lathe spindle?
  167. Wanted: Atlas-Clausing Mill Column
  168. Gerstner Tool Chest alternatives
  169. Not Really OT: Does anyone here raise cattle? (yes its home shop related)
  170. Mill Vise Swivel Bases - Alternative Uses ?
  171. CNC For Dummies Second Try.
  172. #40 MMT/National Standard Taper: Equivalent to NMTB 40 ?
  173. OT sorta - Dakota spare tire holder
  174. OT - Energy Monitor
  175. Setting up QCTP holders?
  176. 5C collet dilemna
  177. ot - car motor sensor question
  178. How can I tell if this tube is hollow?
  179. Free(ish) shop made press frame
  180. Best source of info for new machinist?
  181. OT: Grounding DC Control systems
  182. Best manual mill for 'dream shop'?
  183. Handy tip for molding people!
  184. Need spindle sizes!
  185. Any Idea What These Are For, How They're Used?
  186. end mills
  187. M.I. Twice
  188. Vertical bandsaw fence ideas
  189. OT: Should be an intresting story
  190. Cutter holding on a horizontal arbor
  191. Help choosing a lathe
  192. OT - clear macro pics of glass?
  193. CNC Lathe or screw machine job
  194. Republic Lagun Lathes
  195. change gears?
  196. Yard Sailing
  197. garden tractor forklift
  198. California's over estimation of pollution levels by 340 %.
  199. new 9x20 Jet
  200. Paying job/project, machining teflon
  201. tailstock repair on chineese 13x40 lathe
  202. MSC direct now blocking non USA IPs
  203. Motor Speed Controller
  204. Good ENCO Code
  205. Stock over the internet w/o shipping! (not spam)
  206. This week's Craigslist Funny (Rochester)
  207. Anyone ever heard of this lathe?
  208. I am shocked and dumfounded!!!
  209. The Rotex Vertical Mill- Do I have the only one?
  210. Mcgyver's boring bars
  211. [Liger Gives It Away For Free] Fiberglass rod drops! THOUSANDS OF THEM!
  212. tapered aluminum pipe or tubing
  213. Rivet Nut Tool
  214. Unusual thread cutting feed system- circa 1888
  215. mutlifix toolpost for my lathe
  216. request design help on shaft collar
  217. Computer Router Problem?
  218. Wells Index 55 lube questions
  219. More Sherline mill fun & games.
  220. A tip for cutting AL on a 4x6 bandsaw
  221. Product info needed
  222. How should I move a Bridgeport w/Boss IV
  223. More parts for UPT
  224. Castin Flaw
  225. Question on Quoting Protocol
  226. How would you handle this vendor situation?
  227. Perplexed over measurement result
  228. What can I do to block this hole?
  229. Any idea what these are?
  230. OT: any one from China I need some help
  231. OT Plumbing
  232. Inexpensive little tool for sharpening knives
  233. three phase converters
  234. This years Christmas pressy [Early one]
  235. key holes in chuck repair
  236. Machinery's Handbook Anniversary Edition.
  237. 2 tips for the shop
  238. Cincinnati shaper restoring pics
  239. More Hardened Stainless
  240. Semi-on topic with Harley content
  241. 4140 Choices Question
  242. Australian buying heavy items from Shars ?
  243. "T" style air fittings question?
  244. Run out query
  245. I know how to make a scraping expert cry!
  246. Anybody had dealings with this German Vendor
  247. Ariston lathe
  248. Mechanisms 101
  249. OMG Live video on Chilean mine rescue
  250. DOM tubing question
