View Full Version : General
- spur gear tools
- Keeping a morse taper in a drill press
- Anyone else getting "Attack page" warning from HMEM?
- DP spindle repair
- Warning! Someone is impersonating Brian Rupnow
- What constitutes a home machinist?
- Flat or gloss white for shop
- Looking for belt-sander
- Latest acquisition....Gloat?
- How to remove stripped hardened set screws?
- Riding 2200 ft up in a tube
- Anyone try die drills in copper?
- Two knees, a picture
- Tool and Cutter Grinder
- Way oil weight
- Question for all of you.....Dies
- OT - Photo copying, can Evan come out and play.
- CNC Rotary Table Motor Size Help
- Minor tool gloat
- Ever make an injection molding machine?
- Ball turner
- 1/4 Scale Bugati or Similar
- OT Fair way figure taxs
- Tailstock ram problem sorta long
- Star or Enco or other.
- Load cell works!
- OT - Has anyone here seen Comet Hartley 2?
- Grinding Wheel Bore Size
- OT yahoo mail
- Small safety problem
- picking up centre punch marks
- Chuck grease
- 3 phase voltage regulation
- Anerobic adhesives
- I need a DRO for a Jet 1340.
- Bandsaw tires quality
- Need help pricing some old US Lathes???
- Model engineering show 10/22 & 23 in Ohio
- Midlands Model Engineering Show Warwick UK
- Etching copper with ferric chloride
- Anvil lover's video clip
- OT- XP Question?
- OT paging OMC outboard gurus
- My new (old) Barnes Velocipede Lathe
- On the quality of steel
- Toolsteel heat treat and small hole shrinkage?
- Moped motors?
- mini air compressor
- Micrometer - is this even worth buying?
- My nutso pawn shop purchase story and gloat.
- Semi OT: Soy based wiring.
- Question about electrical plugs and ground
- Made in America Snow Plow
- Facet cut gears
- Site Maintenance
- enabler
- Collet Specifications vs Attack Sites
- best way to make a pdf of my manual
- Looking for 1/4-18 screws
- copying vhs videos
- copying vhs ???
- forklifts
- Kibitzing this Board
- Any tricks for keeping track of 'zero' without a DRO?
- Tool inventory software?
- What kind of glue to use?
- So... air-circuit questions.
- Just tried the "Ignore List" function. Magic!!
- Today's tool gloat
- Busy Bee 6" Rotary Table mfg by "YIYEN"
- Rotary Table/Indexers bearing arrangements
- Changing username
- Alibre design help
- Tool review: Igaging digital scale
- Now available, the Edible Automobile
- What college to recommend?
- Shaping knives
- [Windows XP]Renaming a system folder...
- What are advantages of pressurized sand blasting outfits vs siphon type?
- Google has locked me out of HMEM
- WNMG Cutting Tools, Like or Dislike?
- Concrete resurfacing question Anyone done it?
- OT: RIP Benoît Mandelbrot
- Foam tires
- Filtering machine oil
- Aluminum oxide Verus Glass
- South Bend lathe on German Ebay?
- Metric Pulley
- YATG (Yet another tool gloat) ...
- 5ft prybar, jack bar, jimmy bar ???
- Doall band speed indicator?
- Brown & Sharpe dial test indicator
- Help needed with AC motor for hoist.
- Another WHAT THEHECK IS THIS thread...
- Concrete work bench?
- You having problems with this server?
- O.T. engine oils
- Nick's Ruhla
- Questions on electrolytic rust removal.
- Bridgy boss issues - EMC upgrade
- Unusual radii gage set
- willson slant bed lathe
- Waaaay off-topic: Looking for a song!
- OT, leading to small, small tool gloat...
- A visit to Artful Bodger's shop
- knee mill quill rigidity question
- Craiglook shuting down?
- Rockwell Model 15- 201 Drilling / Tapping Machine-Drill Press
- Hardening / Tempering steel
- Bringing back This old Mill
- Prayers for bronwen Please
- Tramming a hobby mill
- v belt for lathe
- OT: an odd computer peripheral question
- Bashing about or each one teach one
- Is there hope for me?
- Recent acquisitions
- It is time for some Bans
- best Battery for electric car
- This is nuts: Tool Grinding Shop in Rochester, $5,000
- Need help measuring spline
- OT: ForEx Rant
- Lots of Info here.
- The Gun
- Ping for John Stevenson
- Looking at used CNC lathe
- Vibrations analysis
- Small/Miniature Endmills
- thermal actuator
- Cleaning Brass Gauze Hydraulic Strainer
- Threaded rod strength..
- Torque wrench + Crowsfoot
- Threading, lathes, taps and dies
- Rip-Fence Rip-Off
- Inside Radius
- Shortening a lathe bed?
- CNC parts source in Canada
- Catchy tool drawer edges
- Sheldon 11" steady rest
- Watch your copper fella's (again)
- import milling machine
- Back from the Midlands show
- need help what metal is this
- 220/440V nameplate on 2-speed motor. Changing voltage wiring?
- OT: where can I get skid-paint in toronto canada?
- Making small, clear plastic domes/lenses
- lathe and bolt circle procedure sanity check
- I bought another lathe!
- The Mirror
- My CNC Table
- Countersinks
- OT - chainsaw bar sizes...
- Finaly figured out what a cheap air body saw is for...
- Amazing machining project: SLR camera from scratch
- OT: Glass or plastic to protect intruments
- OT: Shipping company let my new compressor fall over in trailer
- Collant pump repair
- Checked your compressor oil lately?
- Question For The Electrical Folks: Industrial Timers
- Need DVD R/W drive suggestions
- Home made Power Feed electrical question
- Line Boring
- Source for Preground Form Tools?
- Metal Primer Question
- Relubing a "sealed" bearing
- Another Lathe Stand
- large drill press
- OT: Wife wants a digital SLR...
- OT: Looking for web site building software.
- OT-Mozilla Problems
- 3 phase converter quit working.
- adding power steering to an old Clark Yardlift
- Another insert related question
- How to tell horsepower on electric motor?
- cheap metal: where do you get yours?
- Die clearance info found.
- Guy has a Barnes drill press down the road from me.
- Priming metal question
- Help with Bearing for Powermatic 1150
- A really stoopid treadmill motor power question.
- Battery Chargers for Electrolysis
- digital camera for biological microscope
- Lathe Saddle Starting to Get Sticky
- Standard Modern Series 4000
- Manually cycling big shaper
- Nozzle Design
- Levelling a bench top lathe
- Poor man's DRO...
- So does beer remove rust
- OT: GMC Sierra Seat Belt Problem
- Motorize a rotary table?
- Clutch plate surface.
- Tormach Mill
- Humorous Afterthought, OT
- OT DISH Network and FOX
- Watch/indicator hand removal tool
- Tool rack made from bed frame
- Cincinnati Mill on Craigslist - $1500 (Iowa)
- Harbor Freight in Australia
- Stock Storage Ideas for New Shop
- Replacing leadscrewbearings/supports on a rf30 clone(chester)?
- Taig mill/lathe spindle upgrade
- Threaded Inserts (in wood)
- ot maybe but need help mf 35 diesel
- What I did today.
- OT - MicroSoft Outlook Issue - Need Help
- OT ? message line lenght
- steamrollers
- OT- a wood grain question
- Nice cutters on sale
- Turret Threading?
- Today's job...cap for deep sea probe
- Cut Knurling Tool Done!
- More Knurl Tool Pix
- Repairing tapered splined shaft
- polycarbonate
- Snaped a chinese cutter. My fault?
- New telescope, major design step complete
- Tapcon anchors, crazy hard concrete...how do they do that??
- Boring head fun
- Accounting Software for the Shop/SB
- O.T. Water tank exaust
- Tool bit for engraving
- bead roller
- Material selection for a threaded puller shaft?
- Misuse of an aircon compressor?
- Good HSS flycutter
- OT: Crooked EBay Buyer
- reversing a lathe
- My cut knurler
- Power supply question
- OT - The Blue Screen of Death
- Snow Plow Lift Angles
- Telescope design, rebooted.
- Woodwork instruction from a master
- Lanes "no casting machined machined" thread update
- Fixing the wheel on a Little Red Wagon
- Tigerstop-how to?
- What do think of shop fox tools
- My lathe speed indicator
- smoothing aluminum edges
- Old time shop for sale all on line shaft!
- OSG die sets.... group buy
- Lucas IGN bezel threads
- OT: eBay product warranties?
- live center recomendation
- What do you think this equipment is worth???
- Dimple dies - anybody made them?
- Advise to newbies from a newbie
- Thank you George
