View Full Version : General
- blasting cabinet
- Polishing milled aluminum?
- Facing 101
- OT: Applying for a job requiring "Blueprint" experience.
- Over Priced End Mill
- Food grade stainless?
- Going batty, help would be very much appreciated
- I think I'm keeping UPS in business
- QCT tool holder stock
- Mini CO2 Regulators
- Tat tat or tut tut?
- Surface Grinder oil leaking?
- Standard Modern 11" 2000 Series Bearing Seal?
- I just needed to share this... and not OT
- jet 1024py
- acme
- Computer for CNC rotary table?
- Shopoutfitters Tubing Bender Questions
- The shaper's nice but (OOOH) the price?
- Hand Crank Drills
- Milling coolant
- So what use can I put these to ?
- Re-inking fine graduations?
- heavy cutting oil
- Knurling tools and holders
- just acquired a bertram shaper
- OAIG? Oxy Acetylene Inert Gas
- How Do You Pronounce "Acetel"?
- Another quote question
- Steady Rest Substitute
- hot water systems .off topic
- deep drawing, but with plastic...
- Anybody use roughing/finishing endmills?
- Concept for water heater HSMMs could make!
- Possible find, anybody know anything about this shaper?
- OT Shear Pins
- OT: Totally OT but way cool. You are HUGE! And TINY!
- Zeroing The Back Of YOur Milling Vise
- Pulley RPM Calculations help needed
- Christmas DRO
- Looking for Hercus Grinder Manual
- DC power supply...
- Fignoggle
- Help determine cutting speed
- Question about concentric-ness
- Deburring set
- New Guy
- Can't spell OH SHI! with out OSHA...
- Getting a BXA 53 holder on centre
- Power switch for drill press
- last visited 03-03-09- I'm back!
- Really nice ccgt inserts
- OT railway question..... dangerous tank cars....
- Extended Locking Handles HF-45 Y Axis
- Hand Knob for Mill Vise.
- Revisiting the Macondo well disaster
- TMT got anything to say?
- OT: 30" capacity log splitter
- Suggestions for making stainless alloy stock thinner?
- Malware warning on Practical machinist site
- Gentlemen, I'm out of here..
- Need Help moving air compressor
- OT The Apple Game
- How can I blame...
- where i used to work OT
- Emco Compact 10 lathe from Katrina come back to life
- PM "Attack Page"?
- Looking For Lathe Manual
- Why was this lathe topslide designed like this?
- Whats the trick to keeping handles from falling off?
- Scope design update: Lower optical assembly complete
- Pipe saddle templates?
- Lever Locking Topslide
- Grit recommendation for belt sander
- Saftey stuff Right NOW
- Press Questions
- Oregon GEARS photos
- Phase 2 tooling
- Building a metal tool storage cabinet
- DNS problems?
- Why is my lathe SCREAMING ???
- OT: Help With Steering Leak Ford 555A Backhoe
- Does this sound like a run cap gone bad?
- Bridgeport motor swap
- Source for bearings
- Confusing rpm spec's on Bison chucks
- Lard Oil?
- lathe belt skweeking, my lathe won't shut up!
- Yay, another Grandkid!
- Oil donkey
- Toolpost problems
- Extension Cord Repair Question!
- Spindle machining sequence sanity check.
- Question for Evan's expertise.
- Crap!!! Now I've done it.
- Poor man's DRO?
- Hey Internet-Technobabble Experts!
- Starrett No. 1 - 7" nippers question
- Was tis site down earlier today? (31 Oct)
- Machining a jointer table
- hobs out of acme
- Shameless Gloat (air compressor)
- Parts for Kao Feng OB mill
- Need a Thin Corrosion Coating
- O.T. Book Reviews Requested
- Belt Grinder is finished
- How to cut gears that mesh?
- Gantry Design
- ENCO Free Shipping Code for Nov???
- VFD, need source of parts
- Press fit R4A bearing
- Bearing info needed
- Machining in video games!
- acme left hand
- changing direction of pitman arm
- Loctite cure time?
- Site seems slow
- Unknown taper turning attachment identity
- New member
- "ImPressed"
- OT: Testing an Electric Motor?
- Lubing a lathe
- Steam Engine Car Question
- how to safely thin brass rings
- The vise jaws of my bandsaw aren't square
- OT: I need to take pictures of carved pumkins
- OT Ryobi reciprocating saw blade retention
- A Killer deal
- It's like a boring bar but different. What's this called?
- Steam engine governor
- Blade Lift Finished
- What is Unleaded Gas?
- Fixture For Sharpening TPG Style Inserts ??
- Lucky old Alistair
- The electric engine.
- Short term preservation
- I'm back, but I've brought my bit bucket.
- Sizing a VFD
- Frozen tundra?
- Is this drill sharpening attachment useful?
- Universal welding cart
- A D bit grinder can also?
- Silicone lubricants
- Semi OT: Thanks to Craig Foster
- electronic question
- Ball Screws
- Mill backlash question
- My latest project Air draw bar
- Small diameter faceplate
- VFD Madness
- OT:but just got these done for a customer
- Lathe dog holding a drill bit secure in a tailstock ?
- 1018 Hard Spots
- Handy toolholder for lathe?
- Machining questions
- Help! Buying a Lathe
- Edge finder?
- cold drawn vs hot roll
- u joint book
- allen key driver head for new screwdriver/battery drill etc
- Got Mill. Got a RoTab...do I really need a Boring Bar?
- HELP! need to fix my lathe motor.
- Locating small squirrel cage fan
- Nov/Dec HSM magazine
- Atlas shaper on craigs list.
- Rohm vs. Jacobs
- Tool Gloat - Bandsaw
- Insulation for a hot surface
- What is the magic of Boring Bar manufacturing?
- CNC Cookbook site down?
- Blue Spring Steel Source
- Guy Fawkes
- Pin chucks
- cylander with a non-rotating, sliding collar?
- E-lecktrickle question.
- Question for Evan and others who are optically well versed?
- Cheap Spin Indexer
- Draw bar air ratchet
- which lathe
- Same Motor-new problem
- DRO on a SB 9 or 10K.
- Bending drill rod
- How to take a small nick out of a mill table
- Accuracy of digital verniers
- New Facing Head with HSS
- OT:"MSCVRT.dll not found" but is there?
- OT- Cold Computer
- Kalamazoo 5C collet chuck
- Tapping Fluid Sucks
- SB 9"? at estate sale
- what does this do?
- O.T. small milling machine Childs
- Now I have done it. I have 2 lathes now....
- Trash compactor for AL chips?
- ford escape
- it doesn't look like over £ twenty thousand pounds to me
- Belt Grinder Questions
- Had a bad day today
- Removing drive rivets holding brass plate
- inverter welder
- Collets
- Setting up two motors on the same circuit....how to give one priority over the other?
- Source for parting tool?
- OT - The Worst Thing To Spill In Your Truck
- OT- Quick computer question
- About how much torque should an R8 Drawbar have?
- OT, posting to this and other sites.
- ER32 or ER40?
- Suds/ machine coolant
- New Toy: Muffle Furnace
- Bolton lathe review?
- Threading tool project
- How to use boring bar?
- Bing
- My Kurt power drawbar retrofit (pics)
- Brown & Sharpe
- What if you don't have an abrasive chop saw?
- O/T Ray Tracing software suggestion.
- What Book on Machining (Milling) Should I Be Reading?
- Chuck-Which lathe?
- need to buy adapters...can't find
- pvc welding machine
- mini gloat
- How to measure ways to how bad they are worn?
- how snap on tools boxes are made cool video
- Rotary Broaching In Nylon
- Telescope design finalized
- Rotary Screw vs Piston Air Compressor
- south bend videos
- Need help from a Solidworks expert
- Quick Ball turning tool idea
- Tip of the day.....
- Capacitor failed in rotary phase converter
- Low cost bandsaw coolant rig
- Hole saw upgrade
- d1 chuck pin adjustment
- refreshing numerals on dials?
- My turn to gloat, not really.
- Where to find a 29 degree worm thread gage?
- Brass Weights
- Machining Projects on the Mini-Lathe and Mini-Mill
- Need some help from the bearing gurus please.
- Tachometer? How fast is my lathe turning?
- Two WWII era horizontal mills - $200 Des Moines
- National Oilwell Varco Hiring Machinists in Houston, TX Area
- BTC Set Tru chuck or Bison non Set Tru
- Cold Upstairs reduced airflow - OT
- Had great time at Horror Freight.....
- [news item] So which one of you is behind this?
- OT:CD/DVD hardware or software problem
