View Full Version : General
- Bridgeport `way wiper` felt guard
- Project notebooks/logs
- What to do with an edge finder that gives goofy reading?
- OT - Computer question - video compression
- 9" Ford axle splines
- South Bend Model 9 ????
- OT, Just for fun
- buying a 4" vise
- Reading through current HSM: Kasenite question.
- Entertainment Centre+
- Lathe Spindle Bearing Adjustment Question
- ot:Ask santa for dewalt nail gun
- OT, tractor Carb problem
- face spanner
- For want of a few drops of oil
- Band saw blade dull????
- Saw arbor jam-up prevention?
- An epiphany
- Wood sawblades on horizontal miller
- Myford New web sites
- D1-4 spindle, should chuck fit flush ?
- FIRST TOOL GLOAT w/pics
- OT: It's Back (the flu)
- OT: Ice skating!
- OT Keyboard for Baudot code?
- Motor gloat!
- Shop built mill?
- Adjusting bandsaw wheels
- Ever body has to start somewhere
- Spacing on concentric circles on 4 jaw chuck ?
- transport to east coast
- Hole spacing for a faceplate.
- OT Building an Orrery
- OT - Venus Fly Traps
- Unorthodox use of rotary table...
- Building a pvc pipe reduction
- Making a V belt pulley with a parting blade
- Using a 5C collet chuck with a South Bend 10K Lathe
- Trying to thread, what am I doing wrong?
- Machining impellers
- Distributing wear evenly
- Grinding wheel recommendations...
- OT - Anti drink driving
- Plastic injection mold
- calipers
- How books use to be made
- variable speed LeBlond lathe.
- tripped over a couple of tips
- Something interesting about our Sun
- acetylene bottles lying on their side?
- Milling noise
- Firefox Upgrade?
- Need L-tec PCM1000 Info
- OT: Comp Virus-AKA- Adobe & Java
- Trouble with school air compressors getting water in crankcase
- RPM's and feed speeds for drilling
- check out this site
- Die Grinder - Which one?
- Can You Say Mini Mill?
- Is this vise OK?
- Carbon arc muffle furnace?
- Rust Prevention
- Enco lathe
- Leupold Bore Sighter question
- Straightedges
- Christmas lights of Phoenix
- Stuck threaded Lathe Chucks
- Ball bearing socket
- PVC monopod (stocking-stuffer idea for Xmas)
- Motor Meltdown! WARNING: EXPLICIT IMAGES
- Was ist los meine schmutzig schweinehund?
- Mystery Mini Collet
- Semi Steel chuck bodies
- OT Security Shield Virus
- ENCO 10% off and Free Shipping Codes
- Acetylene torch hose valve
- OT-crystal growing in magnetic field
- milling a slot
- polished bolts?
- Running a lathe was fun today
- What is this odd plastic?
- Not politically correct
- OT Looking for more traction - adding weight
- Stainless steel bolts
- New Zealand steam locomotives
- Old Southbend instructional movies
- Angle Table finished!
- About to give up on my tachometer.
- Swaging Out Square Tube..... Thoughts !
- Very Interesting Blacksmith's Shop
- Expandable mandrels
- learning machine work
- OT Humor: Other Duties As Assigned
- Power tapping in the lathe
- Gear Hobber
- Spindle Bearing Adjusted Part 2
- How to Post manuals?
- Can anyone identify this machine?
- Gear Cube
- Upscaling projects
- An Interesting Aspect Of Photobucket
- Really BIG vise
- Are you smarter than a 5th grader?
- Grizzly mill G3616
- running an EDM on single phase with a VFD
- A request for help with hardware terminology
- Speeding up a small induction motor.
- New guy..Introduction
- Tachoes are cool, but if its counter..
- Set in place material for Fabrications??
- Which ER system for drills?
- OT- Gold Rush, The Series
- Motor(s) not coming up to speed...
- what do I need to know to machine dovetails?
- Elgin Lathe
- Mill grinding?
- Solar furnace
- Quill movement
- small tool gloat today
- 3 jaw work holding for tubing
- 5C friction collets
- Hertel carbide inserts
- 'flat' workbench
- Glacern vises
- Mitutoyo friction sleeve micrometer question
- Straight Edge Question
- How's that way frosting workin' out for yah?
- Electric motor calculations?
- Total Lunar Eclipse Monday
- Where to Buy 4 pt socket to suit chuck hole ?
- facing on lathe versus mill?
- Sunday Morning Help Needed: Pic
- Why was this thread closed ??
- Accelerated Training Institute Machinist's Course
- Why a Grease Cup and not a Grease Fitting???
- Wow, best $111.00 I've spent lately...heat!
- 4-indep-jaw chuck on rotary table: Centering not critical, right?
- Milling Fiberglass
- Whatsit?
- Born of a locomotive
- OT Free prefume for USA address
- OT: Another fine craftsman pursuing a lost art...?
- Delta toolmaker grinder project
- What is this oddball chuck?
- OT:need help 1995 monte dash lights and head light issue
- Vacant, new Chinese cities
- OT. How to move a Bridgeport.
- Should I pirate CAM software? (hypothetical question)
- South Bend Equipment
- Crane accidents.
- Milling on a periphery
- Hyster Forklift
- ER vs. R8 Collets
- OT: Text messaging for seniors
- Best online source for material?
- Introduction & looking for a little advice
- welding Stainless with Oxy-Acetylene
- Anyone know this small mill?
- Freight around Australia
- Acme thread needs full size end
- Best way to tighten a NMTB40 Toolholder
- Lunar Eclipse Tease
- OT – Keeping a drive snow-free
- OT best wishes
- OT going in debt in attempt to make money
- Options for D-shaft slot in handwheel
- bevel gear calculation question
- Hexasphericon toy video
- Yamatokoki Dividing Head
- Unknown Delta Lathe Whatsit
- Identify a Puller
- U. S. Navy Electromagnetic Aircraft Launcher
- A luddite approach to mechanized cutting
- Looking for Clausing Clutch Disks
- Books
- used Clausing Metosa
- What to charge for this machining job?
- Hand held GPS for hiking, camping, bicycling, etc, USA.
- Walnut Cleanup
- 1.5 HP 1 PH vs 1.5 HP 3 PH Motor
- Magazine Binding
- craigslist trash-or-treasure: Monarch lathe $650
- Bout darn time - shameless gloat
- Hertel Insert ID?
- Bored a big hole(3" dia.) in 1/4" mystery steel
- Got fired from Denny's restaruant.
- How to Machine a Weld?
- First Senior Moment
- How to transform air pressure....
- Gloat: Getting the lead out
- Magnetic v blocks
- World's largest aircraft...
- Rusted up chuck thread
- Fancy Lathework
- Facing or Turning
- Round column mill losing tram
- Pressure Switch
- Slowing an AC motor - diy skimmer problems
- Drip Oiler---with a secret
- Help calculating torque extension for RF connectors
- bushing-shaft clearance ???
- wilton vise re-build
- My first valvejob/seat replacement
- Speed/Feed chart question
- Issues with a new item. Advise ?
- McCulloch chain saw - no spark
- Tramming a round column mill
- vibratory polishing and protecting 28 tpi threads
- Invented something .Now??
- Two hours to go!
- Auction find
- OT USB Modem
- Re: Marvin Milling attachement Bearings
- Quick and dirty (and cheap) heat treat oven?
- OT: Merry Christmas to you and your family!
- The very best wishes to all my friends here
- Lathe drilling Question
- wHAT USUALLY CAUSES THIS KIND OF DAMAGE?
- It was like Christmas - DM cover photo
- Accuracy of the Busy bee 10x18 B2227L lathe
- Hi all you old bums!!! :D
- All I want for X-max is a
- Sad News from up North
- Is there a 13mm thread ?
- Video on running a lathe
- Tramming, Sweeping, Indicating....Which one???
- Metal Working Clubs?
- Not a Gloat, but a small haul
- Small hand wounds, a type of poll.
- What if I do this
- heating steel pins
- Thread Identification
- Swarfware
- OT Need an equation
- x mas morning
- OT: A test of Benford's Law
- A new hobby question pen making
- Building a 20 lb Thrust Pulse Jet Engine with Argus Valves
- Involute cutter identification.
- Hardinge Collet Price Check
- Rifle Rest project
- OT, it's over, all down hill from now on.....
- Bandsaw Verticle Mode Table Mod
- loupes for close work??
- Dial height gage problem
- Adhesives for 6061
- New shop layout - review requested (cross post)
- TOS lathe on Ebay
- Dividing head accuracy problem
- NEWS/Yamatokoki Rotary table
