View Full Version : General
- making a worm and gear
- Tapmatic attachment for cheap!
- OT-Internet signal relay equipment
- Dust collector attachment for my skilsaw
- Lathe Dog Project?
- How much end play is normal in South Bend 10K lathes?
- Odd broken tap
- Craftex B227L Lathe Gearbox noise fix
- Help, XP died and won't come back!
- Collets and Collets
- Handy addition to my mill
- OK, Photobucket stopped working...no more uploads
- Information on Tapping Heads
- Trunions for Disc Sander
- Greenlee DM 810A meter.
- woodstove fan PLANS
- power feed for Clausing 8530
- Paint question and example
- Interesting beer dispenser - fills from the bottom not the top
- Garage/den decoration ideas needed!
- Success does not come from group activities.
- coolant vs. no coolant
- Odd HSM Classified Ad
- After market lathe purchase
- Bench grinder runout/vibration
- Cheap Chip Control
- Had a good day today, HSM wise
- OT: wood lathe
- Benchmaster progress
- OT Dish Network Users?
- Rulers - my pet peeve
- Adding VFD to LeBlond Regal 13"
- Way OT- 2011 Jetta Thoughts
- *poof* Just like that...
- OT-Maybe: Machinist app for iphone
- Tying shoelaces
- Hilarious exhaust modification step x step. Warning; Loads of pics.
- drill chuck slipping in tailstock
- That foam,what do you call it?
- purposely work hardening stainless
- rotary broaching
- Parts washer solvent/solution question
- Going to Cabin Fever?
- hexagons in your shop OT
- machining something like an angle-bracket
- what to charge for making parts?
- OT: Computer question
- Major tool gloat!
- OT - You need to know!
- how to help stop spinning of the tail stock chuck
- Plagiarism in Wikipedia
- typical runout in 5C chucks?
- New saw arrived today!!
- History channel how its made episode: aluminum
- I need 6".
- What I did today= Wasted alot of mat'l
- [Home Shop Chemist] Citrus Cleaners -- A Note Of Thanks
- Qustions that need answers
- tooth bar and clamp on forks for backhoe tractor
- Is this a Tapmatic head?
- Source for a 16 deg included angle taper reamer?
- [Homeshop Chemist] Acid Wash Tip
- Who sells 5C collet boxes
- Some people need to be banned from the forum
- A question about the Cabin fever show
- rotary converter too small?
- Someone check me on this - dividing head.
- Free 'Ban Pass' for something I made?
- Looking for a VFD in Canada
- George Bulliss
- Stupid dog
- MC2100 motor control mods?
- OT Redding Ca to Eureka Ca
- herbert #5 senior pre optive lathe?
- Vortex Cold Air Gun Drawing/dims needed
- Smallest pratical sprocket?
- Bandsaw Blade recommendation?
- Vertical bandsaw- blade recommendations
- Turn-Pro bandsaw report
- 5C collets are ruining my threads :(
- need referral for a decent small St Louis area commercial shop
- Looking for more examples of this mechanism
- Condenser boilers OT
- Need a shop vac. What to look for/avoid?
- Best Arbor Press Size To Get
- what is this on my lathe?
- Layout fluid die...died
- My First pen.
- Which drill bit for a 3/8"x16 tap?
- SINO DRO manual rewrite
- Best way to ream to 0.944"?
- I do not need a shaper !!
- Another wiring question
- What's the right way to drill holes on a circle?
- Polishing on a lathe.
- Which involute gear cutters?
- Quick change MT2 usage?
- Best wishes to all...
- Automating scraping??
- Posting Disaster Photos
- OT- New Car Purchase Done- FINALLY!
- air leak at pressure switch on compressor
- 5 Cyl. Radial Engine Video
- Return of the Vintage Tach Thread
- Cutting carbide?
- ID these old threading tools?
- Source for Accurite scale wipers
- Power scrapers........ work how?
- One of the Last "Rosie the Riveters" has Died
- Finished the Economy Hit and Miss Model Engine
- Hydraulic lift to move mill dead?
- Best Brand Wire Wheel
- Swaging
- Help with drill press speed attachment?
- Ever get the look or message?
- HF grinder project
- Christmas presents I made this year
- Involute BEVEL gear cutter
- Re-aligning a good vice.
- Two jaw lathe chuck
- I've been had!
- Circular interpolation Tips
- 52 Bottles of wine.
- Scraping ! Why
- Wobbler steam engine--Back to the beginning---
- Scraping / Grinding / Lapping: Serious Discussion
- OT: More Computer problems.
- Circular saw OT
- Need a heater expert
- Tapmatic 50X disassembly
- Craftsman/Atlas Question
- Mounting a drill in the tailstock
- Testing a spindle?
- Internal Threading Help - Calculating bore size
- Moving the shop. Semi OT?
- Square holes
- Run away Locomotive and Enema Bandit
- The other new toy
- Pen mandrel
- Newbie questions: How do you use a counterbore bit?
- water heater for the shop
- By request---more Christmas presents
- OT new rant
- Plastic,which one?
- Building up (welding, etc) on zinc/potmetal?
- Need ideas for a T&C grinder head
- Cast Iron Brazing
- whatever next for machinists
- Magic Acid for brass????
- Bridgeport feed nut dimensions
- Micrometer ratchet preasure
- Angle-lock vise question
- grazing-incidence tone reversal
- What is it 2011
- Turning a Joystick
- Cutting my first ever gear!
- OT - new use for old tools and hardware
- New Toy
- Making 3 groove pulley
- Tormenting a dog.
- Rewire Enco 110-2075
- OT: Mistakenly deleted all contacts in AOL address book
- Need help with air spindle
- Enco shipping again
- OT: Looking for Web Space
- Catalog of surplus items.
- My attempt at toolmaking woodturning sprraling tool made by me
- accupro drill chuck
- Machine control rant: Machine control designers PAY ATTENTION!
- Sanding before painting
- Phase converter centrifugal switch
- OT: Radar Detectors.....Do they work?
- Cross slide nut, "fixing" question
- work holding question
- Tip Needed on Grinding Carbide Tooling
- need an arcane piece of terminology
- new on the board and have the usual dumb question
- Play in radial bearings
- Blocking things that slow down page loading???
- My machines get picked up next Wednesday!
- OT - Telephone Help
- Can someone identify what this is?
- Advice needed on a engine project
- Security! Security!!
- Torsion bar material: aluminum vs steel?
- Machine levelling on a concrete bench?
- Semi OT, Non copiable colored pencil
- Anyone in central Illinois wanna take a machining class?
- Whatszit tool?
- Not OT "vegetable peeler"
- Engineering Question BSP vs Tubing
- Alibre design issues getting started
- OT cementing neoprene
- Best cutting fluid for bandsaw, Aluminum?
- New to Me lathe
- O/T Flooding in Central Queensland
- How to fix a pencil?
- air compressor noise
- measuring female thread pitch?
- horizontal spindle runout
- Why such a high TPI on my mill leadscrew?
- Fastenal, what do you think?
- OT: Why is my Toro snowthrower stalling out? (more snow tomorrow!)
- Silent air compressor build
- Installing AXA 100 QCTP on BusyBee 10 x 18 lathe
- CREE Q5 LED light
- Bearing Question
- My machining project
- New toy finely hear!!!!
- ER-40 Collet For Emco "Compact Eight"
- Hercules cylindrical grinder
- Kurt-vs-Glacern?
- Arrgh!
- Bad day
- Circular lights
- Need help identifing a Cincinnati horizontal
- Biax for sale in the Netherlands
- Looking for a camera case for brons new small camera at least this one has freedelive
- 2 piece milling vise quest
- UPS rant
- Electrical branch switching... mutually exclusive.
- Q about using a DTI
- 50 SCFM @ 100 psia--Pure simplicity
- Rotary Tumbler Design
- Plumbing Problem - OT
- Advise on a new 28 pice E40 collet set
- HSS Disproportionate cost ?
- Stainless ER and DA collets?
- Belt orientation on 2x72 sander
- 3 in 1 info
- OTish Adding a swing crane to a vehicle hoist?
- [ELECTRONIC MAYHEM!] Toy Gloat!
- compound slide position
- O/T But,,,,,
- Anyone here ever mentored or helped with FIRST ROBOTICS?
- OT gs conversion
- Drilling question
- Auto oilier help
- Plans for a Small Roll
- 3-jaw chuck diagnostics
- How to chamfer a block of steel?
- need spindle help
- Collets
- CAD, where to start for a Mac user?
- Turning wood on a metal lathe
- OT: Recent CAD work with SketchUp
- OT: Need circut breaker help
- shop wear?
- OT: We went to the Zurich Zoo today
- OT the winter weather everyone is getting
