View Full Version : General
- OT: My feeble attempt at astrophotography
- Harbor Freight Coupons for Feb 2011?
- Milling machine crash
- OT sorta: small rant
- Early CNC project
- 6061
- An analog for big pieces?
- jones@shipman cnc surface grinder
- Enco ruff casting kit
- Another treadmill motor question
- Ot: Swmbo
- Kataka Linear Actuators - And a favor
- Oh what to do, rotary table
- Hemingway Kits
- Bike Accident - Brazed Lug Failure?
- Back up generators..
- Saucer sleds
- nimh aa loading capacity
- Weight Rack Finished In Time For Snow !!
- Pressing carriage bolt through aluminum
- Cutting 1/4 inch stainless rod
- Baldor Electric Sold
- Started my Face Plate
- Help I'm stumped - name of nut
- Levelling a lathe without foot screws?
- ID this oddball indicator?
- Hot Rolled Steel Classification
- Difference between Darex E-85 and E-90?
- Having a bit of Trouble with Tesla Turbine
- Tapping Machines
- Sitting Down at work---
- O.T> Share Pictures of our Shops,Garages,ETC.
- Gear pullers get me cussin'!
- Need help taking apart my HF minimill
- Starrett Tap Drill Chart
- What I was making during the crash - Titanium Pendant
- grind or machine a flywheel?
- Another rant: I'm leaving
- Anyone Attending Pioneer Park Days?
- no-slip protective spray
- I'm not leaving, I have a question - weld or fasten?
- Lube/coolant for Aluminum
- Need help finding the right power cord!
- Cutting a taper on a gib
- "Safe start" block
- Thanks for the Help
- Question on bending 1" dia 6061-T6
- Tree 2UVR spindle rebuild
- Triumph Tiger Cub
- Ferrous materials and heat treating
- coaxial indicator - out of calibration?
- Made some turret caps for a scope
- Line-boring project was a success, hoo-ahh!
- Thought on bending metal tubing...
- Making lots of 1.5" holes fast - how?
- Survey Question: Fire Extinguisher in Your Shop?
- Oldtiffie???
- Frosted silver graduated dials
- RIP: Ken Olsen, founder of Digital Equipment Corp.
- Hi Ma! I'm home.....what's to eat?
- Tangential tool flycutter
- Enco: 20% ($199)
- motor oil
- 6" Atlas broken tailstock clamp
- Viagra for the lathe
- Dangerous metals to use in hydraulic shop press?
- Criterion Boring Head
- Got snow! a snow rake that is?
- Flourecent Light Fixtures...Need Help???
- Hardening tool steel?
- Enco free ship for feb?
- Subscription
- Gasoline and the shop floor
- Elevating drill press table
- Cost of heat treating?
- Making a Fire Piston
- Are precision universal ground ball bearings equivalent to back to back
- Source for Magnesium flatbar or angle
- Any experience with "Victor Machinery Exchange"
- cogitating - parts washer filter
- OT - This'll drive you crazy!
- Horror Freight $20 off Coupon
- lucky me!
- ER-32 lathe spindle finished...finally!
- Minor tool gloat
- Brazing Gas tanks.
- ot Black Box for Cars
- AT&T "rationed" DSL?
- Damascus Steel (MW FebMar '11)
- tool post base
- Grinding ACME threading tool
- I am scared of my OA setup
- Help with analog dial calliper
- QCTP with upside down tools?
- OT ? Sealant
- Rear mounted tool posts.
- Ever wonder what's inside a HF digital caliper?
- OT-Interesting Naval history fact
- HSS inserts
- O.T.....Mubarak!
- ACER or KENT
- Stupid idiot with a chain saw.
- Sharpening Your End Mills
- Edge finder differences?
- How do you build parts like this?
- OT: Cracking lock on PDF file
- 0.25 micron diamond paste in toronto?
- Shop Gloat
- testing
- Turning or threading deeper bores
- Tensile strength of steel? (Why do they make it so hard!)
- Need a lesson in dynamic braking
- Arc welding close to electronic equip?
- Terminology clarification
- How does a VFD work?
- What kind of power does a Lathe take?
- hook up my surface grinder 3-phase
- Anodizing definitions?
- Question about import 13x40 lathe
- My First Steal - Surface Grinder
- Nother tool gloat
- torch or plasma?
- Duplex outlet dimensioned
- tools
- tools
- Help Wiring 3 Phase Foot Switch
- OT Browsers for Windows
- Rotating Trailer?
- OT CD Recovery Help
- Decent Lathe for Home Shop
- A big chunk of CNC'ed Billet ;)
- I'm sick & tried (sticky indicators)!
- The power of the press.
- My solution to fix my round column mill
- Diamond mfg-video
- types of steel-strenght
- Most useful spindle speeds for vertical mill?
- Solidworks question
- Survey: Fire Sprinklers in your shop
- Little wire tool that comes with dial calipers?
- New tooling
- Choice between VFD or 24volt DC.
- Sino DRO lathe function question???
- Run of the mill , mill ...sells high
- Churchill Crankshaft Grinding Machine Restoration
- Glue question
- And related to new tooling, never make more space in the shop
- Wiring three-way momentary switches?
- Scraping with an Asian flare
- Two homemade turrets
- plant auction GE electric motor facility
- test
- Lathe Abuse
- Dialing in the Tailstock
- bridgeport quill return spring
- Lathe Mods
- Pinging Lazlo
- Rear tool post made from a billet.
- Tool Post Grinder
- Anyone looking for a big-un? Lathe that is?
- OT: example of web spying and spiders
- wire wheel polishing
- Show us what you can do with your surface grinder!
- hardinges on kijiji, what's wrong with these?
- used machinery and tool site:
- How to cut threaded rod properly?
- Check out the rotary engine craftmanship
- Hertel Quality Check?
- Great vendor!
- What is your diagnosis?
- One large gear, for your viewing pleasure
- Carrying capacity of an I beam
- follow rest use
- Cutting 9" circle
- grinding a spindle bore
- Surface Grinder help
- finish bore by lapping - ""Floating" End Mill Sharpener"
- OT Air compressor under pressure
- Tool Glote
- Filtration Element
- Melting scrap brass
- Lathe unloaded at last!!
- do shapers produce nicer finishes when running backwards?
- Using a 4-jaw on a rotary table/dividing head?
- Burgmaster 1D Manual Needed
- Riggers are coming!
- OT sliding bushing without stiction
- OT Windows 7 Photo Gallery
- Jet Jvm830-1
- Boring Head: Criterion vs Import
- Baldor motor
- Custom cutter needed
- Tool Porn
- is their such a sleeve?..(newbe)
- Steam sawmill
- for the American brothers paying too much for old bridgeports see this like a new pin
- ID a shaper vise?
- VFD/RPC questions
- Craftsman 6" lathe questions
- Replacing my vise with these!
- Silver Solder Price!
- Sir John's Bridgeport is in great peril
- Asian Lathe Upgrade
- simple gearing - I have confused myself
- gauge
- Mixing collet brands
- Machining Ellipses
- camlock banjo design needed for wood lathe?
- bandsaw question
- good service - tracy tools
- Magnetic Chuck Back Rail ?????
- We're goning to be on TV
- BSF die
- need some advise - uninterruptible power supply
- Recommendation for End Milling Aluminum
- Hertel Drills - My Impressions
- Weird .. Boring bar flex on Aluminum??
- Threading dial missing....
- OT: What usually goes in the groove around the window in a garage door?
- split nut
- Tube expanding tools
- Looking for recommendations...
- OT: What is it question
- What could I do with this sad little lathe?
- 1500 grit sandpaper?
- Polishing Teflon
- Small end mill holders?
- Amusing chinese quality example
- Fray Milling machine rebuild
- Tool Gloat! (small)
- Robotic Hummingbird
- Bridgeport Help
- Flame Hardening Video
- Improving my lathe's compound's screw.
- Optics/Machining: converting an old lens
- Pinging Sir John
- What type of brass?
- Has anyone heard of Kellar Machine Rebuild
- Microfinishing belt designation question
- Thread milling a double start thread?
- PINGING: Frank Ford
- A Chain of Tools
- Jacobs Tapers (USA) ~ B_ Tapers (Europe)
- Suzuki Water Buffalo
- Lesson needed: use of dial indicators
- Metal Prices - Increases at Retail, Yet ?
- Warning: Major Spam Bot Sign-ups?
- Identifying a thread size
- Stainless Turning Questions?
- Wow! Sure miss it here!
