View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 [166] 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211
  1. Question on grafting 2 shafts together
  2. Sharpening knives
  3. Sharpening slab mills on surface grinder
  4. Had some fun at my 2ND job yesterday!!!
  5. Shars MT3 Drill Chuck - Worth Keeping?
  6. Rotab Slip Ring For Welding
  7. Making a Two Piece Back Plate - Need Some Clever Ideas
  8. Bridgeport Rebuild Book
  9. What does silicone caulking not stick to?
  10. VFD: Worm Vulnerability
  11. Tip: Inexpensive Source of Iron Bases for Fixtures/Projects
  12. Re thread milling
  13. oversize hole
  14. Silver Solder
  15. What Price?
  16. bought a gem on the week end!!!!
  17. looking for a chuck key...... Sources?
  18. Strange acetylene leak
  19. soft jaws anyone
  20. OT: a little joke we played this weekend on my step son
  21. My leather machines and stuff I make!
  22. How I was able to center my 5-C collet chuck
  23. Iron-pour at West Georgia University
  24. My little bandsaw!
  25. How to hold a chain saw on the mill?
  26. Is this an indication of a carbide bit that needs sharpening?
  27. recommended material help
  28. Cross Feed Stop
  29. Saimp step head mill
  30. Y Axis stop on a POS Bridgy
  31. Anyone familiar with Grizzly and imports--parts availability?
  32. Metal Art or Boat Anchor
  33. power cutoff limit switch for shapers
  34. 2" depth 0.030" feed shaper cuts in steel
  35. shaper the size of a soda can, hand made
  36. Bad News a Harbor Freight just opened by me
  37. The Right To Know !!!!!!!
  38. New Chinese or old Italian?
  39. Multiple parts
  40. Busy Place??
  41. NZ Earthquake?
  42. ultrasonic cleaner
  43. sectional auger flighting
  44. New Zealand Earthquake
  45. Small hand vise
  46. Anyone have a better cross drilling method?
  47. Working plate
  48. D.R.O.Question.? to buy or not to buy???
  49. My vfd lathe conversion
  50. Lift table using air bags
  51. Royal Electric Rubber Cord ?????
  52. Interesting way to drive a shaft while turning on center.
  53. Cabin Fever Pictures
  54. SB 9" Woodturning kit
  55. Compound Screw/Nut for SB 9"
  56. Clausing 5904 help
  57. So does machine mounts work
  58. OT- PDF applications to be filled out and emailed
  59. Source of Magnetic Chuck in Los Angeles?
  60. Spring not very airie
  61. Cogged belts
  62. Happy family tool gloat ;)
  63. Can i install a vfd on my mill
  64. Source for Stainless steel
  65. El cheapo block for bench work...
  66. OT: Renaming a link
  67. History of the 1st Micrometer
  68. can magnetic bases affect nearby electronics?
  69. Scraping conundrum, now contemplating suicide..
  70. What grade Stainless Steel?
  71. Anodizing and Ventilation
  72. drill chuck arbors
  73. Anyone know how Trud is doing.
  74. Advice needed using a mill to Lathe?
  75. enco tapping head
  76. Stanko lathe what a monster!
  77. Shop made Diacro tube bending mandrels?
  78. OT Can someone explain how this works
  79. Christchurch NZ earth quake? Don't we have members there?
  80. Wood lathe tool rest?
  81. Placing the punch mark?
  82. 64" lathe in the mid west for sale on e-bay
  83. Electric question, emergency situation.
  84. Indexable tooling
  85. Dixon Z transmission? (zero turn mowers)
  86. Weirdscience
  87. Does this tool exist?
  88. Beer!
  89. Question for the CNC lathe spindle speed control experts.
  90. MY new underpants ish
  91. OT: Here's why Metric is better.
  92. Simple "where to buy" question.
  93. More from Shetland Isles
  94. The best indexable mill I have tried(so far).
  95. Tool gloat
  96. Quick change tools for mills
  97. Space shuttle Discovery's last voyage...
  98. Using a spot welder makes the day go faster!!!
  99. A question about lathe/work-piece setup
  100. Gloat -well sort of.
  101. Jet drills
  102. Vise for mini mill
  103. CTC how do they stack up?
  104. Help with Marv Klotz program.
  105. Robot marathon
  106. strong magnets in toronto canada
  107. First threads on my new lathe
  108. Taping into Brain Trust Here: Folding Rule Source
  109. Where do you live and how long have you been maching
  110. How do (side,front)(relief,rake) angles differ between lathes and shapers?
  111. Bad TG-100 collet chuck?
  112. Tailstock quill hardness?
  113. Chinese Tools - A change in the balance of power
  114. Lathe ID help?
  115. Kwik Way Boring bar
  116. lathe bits?
  117. myford lathe heavily modified for ornamental turning (complex spirals, spirographs)
  118. Motorhome leveling cylinder...where to find parts?
  119. How fast can a lathe or mill be speeded up
  120. Thoughts on T+C grinder construction
  121. SANDVK holder
  122. Rocker Arm Attachment
  123. OT: I must be raising my daughter right!
  124. indexing design
  125. Ornamental cutting head is the older method better? it seems so and whay
  126. How to tell if a motor is reversible...
  127. Tilting at windmills
  128. Diamond (tangent) tool holder, which construction is better?
  129. Is my boring head backwards?
  130. Anybody in the greater Chicago -Northern Illinoise area
  131. Old bearings to new,tricky
  132. What does Machinery's Handbook normally sell for?
  133. Quick & dirty follow-rest.
  134. Thanks Guys!
  135. David Cofer?
  136. Forum Thread Ratings/Voting
  137. Lempco grinder, help id it
  138. 1x30 belt sander/grinder/deburr....er
  139. Machining thin discs to size.
  140. Multifix now half price
  141. tool gloat (shop made tools)
  142. Cheap source of 9x20 drive belts???
  143. Which edge finder
  144. What you did today/shop-made tool/gloat combo
  145. Trav-A-Dial spinoff
  146. Balancing Fly Cutter
  147. Pool Pump Motor
  148. Recommendation for a mill under $2000
  149. 7X16 mini lathe
  150. Correcting a crooked hole
  151. How much to press in?
  152. QCTP sphere cutter
  153. RGD tools from the UK
  154. A Nice On-Topic Article in the Toronto Globe and Mail
  155. Best way to make a horizontal milling arbor
  156. Nice manual Japanese mill.. (new)
  157. Machining Stainless
  158. Tool Gloat
  159. My new OA toy!
  160. OT, Ohio flooding
  161. O.T. New census
  162. quality carbide burrs?
  163. Old Craftsman Tools..... I just Can't See How They Did It
  164. Taiwanese 13x40 lathe wiring?
  165. 220 Volt Wiring Question
  166. Thread depth
  167. Small, model sized worm gear reducer
  168. Hardness testing files
  169. Leadscrew nut help!
  170. A question about live centers
  171. Lethal disks
  172. Bearings used in furnace inducer blower
  173. Face mills
  174. Computer stuff: getting what you pay for.
  175. O.T sort of what to save
  176. What you did but didn't mean to
  177. Tramming question.
  178. Girls like big tools!
  179. Bringing Some New Life to a 4 Jaw Chuck?
  180. Is EMC CNC usable by normal people?
  181. Need a surface grinder setup
  182. Mounting a chuck to a Phase II rotary table question ....
  183. milling spindle on ebay someone asked about this int 30
  184. pack rat???
  185. Bearings
  186. bumping gas mileage up
  187. Dumpsterite - gloat
  188. Canadian Museum of Making
  189. What is the proper name?
  190. need some help...SB 9c.. Missing a gear for a thread I want..
  191. OT: Another Computer Question
  192. Newbie Question how 2 thread plastic pipe?
  193. Are chinese drills and endmills 100% HSS?
  194. Blackening Stainless Steel
  195. OT, No Jack - No Problem or thinking outside the box
  196. Motor Frames: Descriptive Catalog Illustrating Frame Styles
  197. Finishing Stones for HSS
  198. my dumpster gloat
  199. OT How bad is your addiction
  200. Dividing tool
  201. 400 Series Toolpost
  202. Cam Action Clamp?
  203. OT Painting/changing color of tile and tub?
  204. Any reason not too?
  205. Still no power!!! More of a rant….
  206. Indi-cal & Last word dial
  207. Fine thread vs coarse...which'll hold better?
  208. Basic machining question
  209. Turning Large Work
  210. I have a job!!!
  211. What collet is this?
  212. Speeds and Feeds
  213. does kbctools sell chinese HSS bits?
  214. giant machine tools, construction, romania, for your viewing pleasure
  215. explain this price difference in round HSS bits
  216. OT Making a gate out of PVC pipe....
  217. Kennedy tool box parts source?
  218. O/T-Google maps high resolution.
  219. Multiplaz a good idea?
  220. QCTP - wedge or cylinder - anyone made one?
  221. Dimensions, plans & info for a 1/2 scale 32 Ford
  222. Taiwan 1340 lathe headstock alignment/mounting issues
  223. VFD: Automatic torque boost?
  224. Polar Bear Series & Green Grizzly, what is different
  225. Big rolling tool chests
  226. OT - Intel Motherboards/Chip Sets Starting to Ship
  227. 4 jaw chuck problem
  228. Generating true angle references
  229. Triangles, Triangles and triangles----
  230. MiniMill head drop
  231. Nature never intended
  232. Run out on craftsman 618 lathe
  233. HF 3" rotary table center hole thread?
  234. Small hole drilling in polycarbonate
  235. Oops! Look What I Fixed
  236. milling phenolics?
  237. Something to do at the weekend
  238. Adjusting The Bridgeport Horizontal Arbor
  239. Smithy lathe mill combo
  240. Tool Gloat!!..
  241. Watch this Video.
  242. Made some stuff this week.
  243. Any problem leaving something heavy on a Bridgeport table?
  244. ? about wire EDM
  245. PM45 mill VFD conversion. Need motor shaft turning down advice
  246. Slow Epoxy?
  247. Before trav-a-dial there was...
  248. Just fell in love with HSS
  249. Air compressor 3pahse or diesel/petrol? Which one?
  250. Expected runout for a 3 jaw chuck?
