View Full Version : General
- OT: Anger Management
- OT diploma frame plans?
- avoiding electrocution with a stick welder advice needed
- Corner Radius Corner Notching fixture?
- Mill needs more clearance
- Question Hair Trigger
- quick spacers for lathe
- Insert Fly Cutters
- dro pros
- 1018 vs 12L14
- Pointers about Old Article
- More Toys are always good----
- enlarging a motor shaft opinions
- How loud should a 5HP Baldor be?
- 450 hours later I got this
- Making a model hit and miss engine hit and miss.
- I Think I'll Pass on These
- sticking micrometer stem
- Poison Tea
- Wheel Lug stud Installation?
- How many of you are self-employed?
- Mounting igaging scales on a mini mill
- Semi OT: How old should children be before helping in the shop.
- DRO on a SB9
- sawing rubber
- Static shock from belt grinder?
- 64 1/2" Bandsaw Blades for cutting Stainless Steel
- what typically causes a thermal overload to trip
- Tapping gear hob ...sort off
- Toolholder to high, How to correct?
- OT: El Caminito del Rey: the king's little pathway
- OT: FBI plants tracking device under car over REDDIT post
- Taught my 7 year old to MIG weld
- Any suggestions on things to do in Oxnard CA?
- I've gone through 2 power vacs since I started Metal working
- Motor vibration
- fairchild lathe poem the art of the lathe
- What speed for indexable mil?
- quick change tool post
- Quill leaking badly.
- I need a lesson in using a Multi meter
- Single-pointing forces
- cutting a cylinder
- dip moulding
- How to use a pipe bender?
- AutoCAD users HELP!! Sino SDS6-3VF DRO (RS232 port version) question.
- Ever Drop a Finished Project?
- woodturning chisel toolholders from pipe ?
- Free circuit diagram program
- Advice on Air Compressor System for Shop
- Drill Doctor 750SP
- Tool Gloat or maybe not?
- lead screw,,
- source for 3-56 screws
- Tooling sources, greater LA area
- Need some advice form The "American Metal" Fans
- OT -The Turbo Encabulator
- Off-center turning
- homemade indexible lathe insert holders
- emco maximat mentor 10 universal quadrant
- o/t rant enco-ups
- If a machinery dealer rates something 5 out of a 10...
- Are you never even a little suspicious when?
- craftsman drill press spindle
- Fixing a little shaper.
- Kerzel meets Slinky----
- Tool Gloat - $250 Bridgeport
- Vacuum pump Maple Syrup
- Anyone Near Bloomington IN?
- Question for mattinker
- Very nice hydraulic cylinder materials supplier
- cyclone pictures
- cyclone pictures
- Kennedy box drawer slides
- Enco $25 shipping code for March
- Chaser Grinding Fixture
- Surface Plate Stand
- Gearbox question
- Should a Becker be my first milling machine??
- Wish more Tool/Carbide Mfgs had a website like ISCAR
- Basic relay questions
- Motor Rewinding Shop Needed in California
- Illumination of VFD display.
- Question for the woodworkers among us
- Question for Electricians
- Yet another ball turner...
- Chip breaker not chip breaking!!!!
- considering an upgrade to a grizzly g3616
- Tool mini-gloat
- long curly razor sharp chips
- Source for oil metering valves
- DRO Gloat
- Anybody needs VS Bridgeport, 6"x18" surface grinder or Cincinnati vertical mill-IL/WI
- Need to turn a cylinder to press fit
- Ride on Lawn Mower Tip
- Wheel dressers for surface and bench grinders
- Easy morse taper spindle adapter
- small Temmah lathe
- Regrinding a mill spindle
- Need help with a comparison: Grizzly G4016 and Enco 13x40 lathes
- Cold Rolled Or Hot Rolled
- Is anyone else having trouble seeing pictures on this site?
- Another job finished & out the door
- Rockwell drill press chuck removal
- Should I be impressed or not?
- Free light in your shop.
- Found a DC drive in my garage
- A classic steam marine engine
- atlas shaper help,
- additional question Re: Shaper versus mill,
- Yet another ball turner - more info and pics
- edelstaal mill
- Tsunami Hits Japan
- Grinders and Dust Collectors..........
- portable rotary planning machine
- Max rpm for dead centers
- rust removal electrolysis
- ID this scraper
- Follow rest question.
- Buyer beware. (Enco)
- heat shield material
- Intended working life-----
- OT: Here's a video I think most here would appreciate.
- Planer
- Brass prices are on the rise.
- Technical Fail: Nuclear Power In The News
- Need to make some machine tool covers--Sewing machine recommendations would be great
- Disolving brass
- Interesting video
- Another drive question
- Adrain at bbsystems
- Roland Camm 3 desktop cnc milling machine
- When using DRO be careful of r and d
- D T I is this right?
- Facemill using HSS bits, tangetial style
- giant machine tools, in toronto (can you believe it?)
- Air fittings profusion..... What's "standard"?
- Bandsaw fail!
- OT: 220v question
- Length of Travel
- Drilling Crossholes Through Round Stock
- OT: Wholly off-topic - new beer!
- "D" drills
- Pedersen PU 2 mill.
- Need help solving a conundrum
- **** New Small Machine Shop
- slightly OT "D" bit
- Help, Swiss Mike question...
- Maple Syrup Electric Supply.
- threading tool question
- Zone 3 taps??
- carbon-steel razor developping bow
- Giant compendium of gunsmithing documentation
- Dad over-engineers fix
- PayPal
- OT: Annual Spring Weedwacker Debate
- Price check Induma mill
- New ZX45 and new 12x24 lathe owner ...oil type?
- MT3 centering stub adapter
- Tips on running new oil lines
- OT: Pictures from Japan
- Hazards of Unknownium
- Loctite 680 not holding...
- Another Electrical Question
- Needed: Gamet Automatic Boring Head Manual.
- hot plates and annealing
- Length of Travel Solved.
- Harig Grind-All No.1- what do you do with yours?
- Zinc or Aluminum - Identifying Bracket Material
- Hardening stainless?
- One-way Slider Design
- Index 55??? Have a chance to buy something like it
- Bridgeport Mill quill feed speed
- Need some help finding a starrett micrometer
- follow rest use
- Shop Task Metal Lathe-Mill-Drill Swing 12" between centers 22".
- Advice wanted how to refurb Atlas Shaper cross rail?
- Lathe chuck alignment problem
- OT; fascinating quake map
- Wonky spot in the steel? (grooves not consistent)
- What kind of lathe is this?
- Antique Covel #15 Surface Grinder Questions
- Best way to drive a letterpress
- New Lathe
- OT What's the Ultimate Bike a Future Broken World.
- What is a "normal" surface grinder wheel speed?
- Anyone know about Shell Alvania 7 grease?
- New guy with bent spindle
- this weeks project new jig i designed
- Alternative to knurling?
- Adjustable rotary tables (play in the worm gear)
- shop power upgrade?
- Photo: 5 Axis waterjet
- I sold the bandsaw
- OT Thunderbird Email
- Telescope update
- Annoying 'special' thread!
- Password
- Mystery Cutter: What is it?
- POS Bridgeport spindle motor
- Cincinatti #2 T&C Grinder Table removal
- OT-Vista toolbar problem
- Got me a real truck
- Drilling through chrome?
- Necessary precision in T-nut slots?
- Shaper spring toolholder: which alloy to use?
- Another odd thread - thread...
- Ebays Newest Fees.............
- How do you clean up a mill's t-slots
- Noisy LED bulb
- OT: Brush Truck
- Marvin slotting attachment for an Atlas mill.
- Enco: 10% ($150) plus free shipping
- Mill conversion
- Boring head instructions needed
- OT: Want recommendation for a concealed carry knife.
- REMINGTON 476 Powerhammer
- Leaking carb.
- OT sorta - electric garage door opener/closer problem
- Enco 10% off and free shipping over $150
- Clamping Angle Iron
- Tool Gloat: My Scrapyard Rescue
- Tool gloat, aircraft drill bits by the hundreds
- 258 mpg Car made in China $600
- Pm1440hd
- Sharpening carbide milling cutter
- OT: Then Mensa invitational
- And I already altered my new lathe.
- Need a metric lead screw
- solution for round column mill/drill
- JOBS SHOPS in Florida? CNC, Solidworks, small lot runs?
- Reciprocating power hack saw
- I need my spring's spring back
- Get Me Started in Brass/Bronze Casting?
- lathe cutting tool; above or below axis, which is better?
- rotary steam snowplow
- New alloy
- Boostinjdm's Tooling Questions
- Mechanism for a perpetual calendar?
- how to thread a taper
- O/T DC 3's
- Looking for a good way to renew scale markings
- Poor Forum Performance - Ads.VillagePress.Com Suspected
- Blowed Harley emergency rebuild on cheap
- Cutting HSS bits
- Semi OT: New Camera Gloat
- Need help from the motor gurus...
- Help needed with Devilbiss compressor rebuild
- Reid Grinder
- HSM Web site slow????
