View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 [170] 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. Cross slide nut attachment point(s)?
  2. Lathe Diagnostics - South Bend
  3. Happy Easter
  4. Carbide Insert Thickness
  5. Acetylene tank warning sticker
  6. Skills USA Excellence Pt. II (Attn. Errol Groff)
  7. OT Small Engine Fuel Lines
  8. NMBT 40 tooling?
  9. O.T Does anyone know if they make led lights for outside use
  10. Turning PVC and Other Such Plastics
  11. Serious vibration on moderate cuts
  12. ELS Electronic Lead Screw
  13. Lathe safety rule #23
  14. Another group buy on OSG taps and dies..
  15. Rapid disassemble/assemble of a jeep and field guns
  16. Carriage bore for cross feed screw
  17. general crimping questions
  18. Miniature of the Pretty Hand Vise
  19. Nardini lathes
  20. OT: computer issue
  21. Boring out valve stems
  22. Magnetic vs glass DRO scales
  23. Tool and Cutter Grinder
  24. Arm and Hammer Washing Soda
  25. Where to go?
  26. 100,000. Lumen Bicycle Head Light.
  27. Restoring A Rollaway Industrial Electronic Air Cleaner
  28. Edge Factor Machining Content Video
  29. Cleaning brass on a tractor
  30. Good movie: Azorian
  31. Newbie Request for low-HP face mill recommendations: steel, good finish, no coolant
  32. Might be off topic...
  33. Puzzled...is my Chuck ruined ??
  34. O/T computer ? Nightly wireless connection repair
  35. Ideas for making passenger motorcyle pegs?
  36. Grinding jaws on 3 jaw chuck
  37. Are two-sided inserts weaker than one-sided inserts?
  38. machining chuck jaws
  39. How to save money listing on eBay
  40. anti-metric
  41. Chain failure
  42. Mounting a lathe chuck to a milling table?
  43. I need fifty cents
  44. flimsy looking setup on big lathe
  45. Wavy parallels - what for?
  46. Crazy weather, tornados, large loss of property and life
  47. Industrial vs. Automotive connectors for compressed air.
  48. Sheep shearing platform
  49. Advice on eating the CNC elephant?
  50. cable crimp sleeve swaging hole dimension
  51. Dividing head questions?
  52. Digital Calipers
  53. What to do with this fancy screw?
  54. One Man's Junk is another.....
  55. 9x20 replacement
  56. two vises vs one
  57. Salt water corrosion
  58. CDCO Machinery problem
  59. Enco Code???
  60. a bit OT but wood and metal combined
  61. Cast iron VS mild steel
  62. Buck 3 jaw pinion
  63. Pro Metric Imperial system
  64. Acetylene price update
  65. N.A.M.E.S 2012, Back To the Yack
  66. Removing cosmoline
  67. Motor wiring question.
  68. Floor safe
  69. the week end
  70. Way OT, Test the Brain
  71. Tapping 6-32 in 6k series Al, losing my mind
  72. threadcutting under lathe power
  73. security cameras
  74. must be cheap he's sold out WOW
  75. Arm & Hammer Derusting Question
  76. Geometry Help Needed
  77. Error reduction from dividing heads - a myth?
  78. Repairing T-Slots
  79. Burke #4
  80. Fuel????
  81. Bench mounting options for a lathe
  82. Tig welder terminology assistance please
  83. ER collet nut questions
  84. Machining hardened pin
  85. Machinist BBs?
  86. Drill Doctor selectable 110/220 Volts ?
  87. Very heavy small swing lathes
  88. OT-Diesel truck that’s been sitting for a While
  89. Question about mill table stops
  90. Tooling balls
  91. forming leaf springs
  92. Hardening 1026
  93. Modifying a Rotary Table
  94. Another shaper video
  95. silver solder
  96. Mickey Mouse would be proud
  97. We survived the Tornados.
  98. Busy Week of success and failure.
  99. Lonely bored guys w. too much free time who want to chat about topics that have
  100. Thank you NAMES volunteers!!
  101. OT: Any flatscreen monitor techs on the forum?
  102. Pressure Washer not working
  103. OT - Looks like we got Bin Laden
  104. Building Grapples for Trackhoe
  105. Cheap digital calipers 2 years on battery & still going
  106. cold saw, chop saw
  107. Rarity on Boston CL: glass lathe
  108. Baldor 500 series miter gauge - source
  109. ISO Band Saw & Bench Grinder. Difficulty: 110v
  110. Need a book recommendation
  111. Looking for a Buck Chuck Pinion
  112. Machining 8020
  113. Bin Laden takes a dive
  114. Vise line up on BP mill
  115. Factory Service Centers - Clearout Savings
  116. The best way to repair this steady rest?
  117. Holding end mills with MT3 collets
  118. Parked trailer security, dont steal my trailer!
  119. Highest rpm for a S.B. 9" lathe
  120. How are you supposed to use this deburring tool?
  121. Demagnetizers... anything I should know?
  122. Green Berets and Seals
  123. Midwest scraping workshop May 21, 22
  124. What is this guy doing wrong?
  125. Ok, I need help deciding on whether to buy or not to buy a welder
  126. Bargain Burnerd 12" four jaw chuck.
  127. CAD software
  128. Some seriously SWEET computer peripherals
  129. Extra room in the shop.
  130. Can I swap a Chevy 350 engine with a V6 engine?
  131. How to BUILD your own Demagnetizer
  132. Pos-I-Drive Screws?
  133. ER40 nut ID?
  134. Increasing the capacity of a small lathe
  135. Help selecting flashlight LEDs
  136. Tips on buying used granite surface plates
  137. The Sidewinder Missile
  138. Your favorite threading tool?
  139. Tool allowance
  140. OT Electric ?? re: commercial building ground
  141. For sale - 50 Issues of HSM Magazine
  142. Where To Find: Plastic Depth Stop Rings??
  143. Precision Hand Scraping Workshop May 21,22
  144. Nice home made drill press
  145. ? for Polymer Experts
  146. Electric Question - Neon & Relay
  147. OT: Paranorman Announced
  148. Heat treat oven
  149. Any Hams out there?
  150. Opinion please,,
  151. DRO advice please: Grizzly H6096
  152. 9x20 lathe, heavy cuts, HSS
  153. Material for Vise Jaws
  154. nuclear jet engines
  155. so what is the machinist calc pro
  156. Transport of delights
  157. What to do with worn grinding wheels?
  158. Jet 1340 Manual Needed
  159. What metal can be scraped
  160. Drill Press spindles - JT2 or MT2?
  161. Damn Thunderbird.
  162. OT: New (to me) site for posting photos
  163. 7 x 12 Bandsaw all terrain modification
  164. What is this gear called in English?
  165. Correcting lathe cutting a taper
  166. O-ring design philosophy
  167. FG603 bearings
  168. What can I do about long swarf blades?
  169. atlas horizontal mill
  170. Bridgeport lifting eye
  171. Circle Cutting Rule of Thumb
  172. I want a telescope too...
  173. Where Can I Find A New Chain For A Tucker Sno-Cat
  174. Heads up UK show
  175. HELP ASAP Vista Total Security 2011
  176. Building a gear.
  177. how I pay for tools
  178. Source for "flat" springs?
  179. Cool CNC crankshaft video
  180. GM foundry & assembly, 1930's video
  181. Machinists needed
  182. Opinions On These Tools
  183. OT: Bummer, it's raining again
  184. Caliper repair
  185. What type of coolant for carbide grinding
  186. Off Topic: 2000 Yukon Ride Height
  187. Lathe Stop
  188. Carriage lock covered by DRO
  189. Stairway Design (for moving 1 ton lathe to basement)
  190. How to use this vertex tapping chuck ?
  191. Tail stock 3MT to 3MT extension
  192. OT stale bread
  193. homemade ward cnc lathe
  194. A deal I stumbled on.
  195. Nice little row boat
  196. OT: My kind of boat/car
  197. Foundry day at CWU
  198. Part Identification Help Needed
  199. Grizzly G0602 or G4002 or G4003 Lathes
  200. I should have thought this was a good bargain what's wrong? it's not selling
  201. Haas Dealer Question
  202. Open Gear Lube, thoughts, recommendations
  203. worn morse taper
  204. Flat Aluminum Plate Dealers
  205. Medium for polishing drum?
  206. epoxy cure time
  207. Disolving screw with Alum
  208. DRO scale size
  209. Wood Socket Chisels
  210. So I was reading here before dinner...
  211. How to prepare new steel bench for painting ?
  212. OT: Business guidance...
  213. For our Minature Friends
  214. Dro
  215. Machine Gloat almost!
  216. New Member Introduction
  217. project I've been working on
  218. basic steel found in scrap i/d ?
  219. Hardinge TFB for sale - need moving advise
  220. Bolt with a long head?
  221. The M Ward scraping article
  222. OT: Big Sky Panorama
  223. OT.... installed SP3 and reboot is back!
  224. WTB:DVD: 7x10 Variable Speed Mini Lathe Operations
  225. Help w/plan for scraping my DoAll surface grinder
  226. OT- bird flight decoded and implemented
  227. Round column mills
  228. Nice Gov co mill (canadian)
  229. Canadian Suppliers
  230. New Member
  231. Tool Gloat - $1000 Hardinge TFB
  232. Price Disparity
  233. Trouble Finding
  234. OT Where to find this wrench(s)
  235. 3 phase power question
  236. Well, I finally purchased a decent welder..
  237. Round Discs
  238. Has anyone made an EDM/Spark Eroder?
  239. edlund 2 spd. gear box ?
  240. Bending ABS
  241. Motorcycle Gauge Panel Project
  242. Rotary table mod
  243. How would you make this part?
  244. Dura-Bar Source?
  245. A Tool Gloat .....Finally
  246. Heat from headstock bearings?
  247. Enco Lathe
  248. Big Nuts
  249. got the machinist calc pro
  250. How to sharpen Borite style boring bars...
