View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 [173] 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. Ring Gear cutting
  2. What do you lube with?
  3. Metric Thread Die Chaser Titaniumn
  4. Computer Choice
  5. milling vise
  6. Vibration in Doringer cold saw
  7. Common Source for .157" Rod
  8. Power Switch Upgrade
  9. Machining on TV, semi-ON topic
  10. pinging gwilson.....
  11. What type of steel for a vise jaw?
  12. Lathe alignment on ships
  13. OT: Source For Leather Gloves
  14. Job Opening - Houston, TX
  15. Insurance Documentation
  16. Cast Iron Bar for Making a Precision Straight Edge
  17. Any Enco Free Shipping Codes?
  18. Pinging Lazlo
  19. Transformer information question
  20. Wiring For Logan Lathe
  21. Electric Motor burnout
  22. Dayton Belt/Disc sander parts
  23. Uses for gage/ jo blocks
  24. specialty screw press?
  25. Wauseon, OH
  26. Gear Hobber Questions
  27. How to re-purpose propane pool heater?
  28. O.T. scanner tutorial
  29. U.S.machines:Arbor Release?
  30. The price increase has arrived!
  31. Any ideas for an accessorie cart?
  32. OT - Computer PSU voltages?
  33. OT: japan gets a 6.7 quake
  34. How do I keep .001 tolerance with cheapo digital calipers?
  35. Sort of OT: Clean & Oil Battery Movement Watch
  36. this looks cheap ????
  37. Propane tip for old oxy/acetylene cutting torch
  38. Labour rate/W/minimal equipment:
  39. Thrermal spray info needed!
  40. Metric external screw pitch gage - accuracy and prices?
  41. Adjusting procedure for metal bandsaw?
  42. Cutter for glass fibre material
  43. Slightly OT: Propane burner design
  44. When to say quit?
  45. Battery Pack design?
  46. Weird Stuff
  47. Help Wiring Transformer on CNC Knee Mill
  48. Pulley size
  49. Socket organization- what do you do?
  50. more portable drill troubles
  51. Help With Boring Bar
  52. switch voltage rating?
  53. OT; heating oil prices
  54. For All you PayPal Haters.....
  55. OT: Titanic Show
  56. Good "better" cordless drill
  57. Stumpy: Mark III
  58. Welding helmet of the future
  59. OT: Macro Lens Gloat
  60. Computer woes
  61. foot pedal design?
  62. Obama health care plan Vote Yes
  63. Center Finder Question
  64. Stub-Length Reamers?
  65. Bandsaw Tension Gage
  66. Hello. Blind Pig here...
  67. O.T. Mower Idler Pully Bearing Replacement
  68. Digital CNC Workshop
  69. 10,000 Year Clock
  70. OT Heavy Duty Power Systems Tech generators
  71. VFD and AM Radio
  72. Something new coming to a screen near you: realtime satellite views of Earth
  73. Shrink fit in aluminum
  74. correct use of carbide on 4340 normalized
  75. Goose neck/flexible tubing
  76. OT: B-17 "Liberty Belle" Fire
  77. OT: Fossil preservation?
  78. DOM Bushing Stock
  79. Pile Driver (Model)
  80. Almost OT?
  81. King Power Feed
  82. Power Pack Troubles
  83. wood saw riving knife from old saw blade??
  84. Small Asteroid comes close.
  85. Nicholson file foul up on Amazon
  86. Antifreeze as shop tool coolant ?
  87. cutting welds
  88. Variable Speed Drive or Contraption of Merit?
  89. Variable Speed Control or Contraption of Merit?
  90. carbideanddiamondtooling
  91. Resharpening Planer Blades
  92. Apply bluing to a roller, et al
  93. Looking for a hole punch like this...
  94. Electrical problem with a lathe.
  95. OT: Need New Water Heater
  96. OT ish, electrical safety
  97. OT: I won the lottery!! :)
  98. US Gov's Household products MSDS data base site and Toxnet
  99. UFO's!
  100. OT-Solar Chargers for Small Batteries
  101. Machine work done on shop pickup AC
  102. digital scale wobble
  103. OK to lie down MIG gas bottle?
  104. Fray mill lovers...
  105. Electric motor rescue....
  106. Think these drill presses are worth trying to save?
  107. Small shapers, any good???
  108. Somewhat OT... Small wind generator
  109. Boring Head/Bar Question
  110. OT - Do not understand the Mac love fest
  111. OT: Can the high output LEDs be used to initiate lasing, as in ruby laser?
  112. Build a dividing head
  113. OT: Need schematic diagram for Genie Pro garage door opener
  114. Southbend precision Lathe information
  115. Arca Swiss Camera Mounting Plate Dimensions?
  116. A score for my shop!
  117. Mill light?
  118. Ford 6.0 diesel hpop fix
  119. Winching
  120. Fit a BXA Tool Post
  121. Keyway cutters for a shaper?
  122. sterling silver jewelery repair question
  123. how do you keep your digital camera from fogging when going from cold to humid?
  124. pesky mice
  125. Forging vs casting?
  126. smallest cheapest motor than can burst up to 3kw
  127. Need suggestions for machining magneto part
  128. What's going on with photobucket?
  129. Digital Photo information
  130. OT Holy crap its hot outside!
  131. Kiss your Pi goodbye?
  132. Broken allen wrench
  133. Finding water, driving a point, rocks, your experience and tips
  134. minature air conditioning
  135. Spotting Drill to drill
  136. Stud busted off.
  137. Love or hate Harbor freight. 25% off is good.
  138. PVC and CPVC
  139. 2-cycle lawnmower engine…
  140. Forging/heat treating a hammer
  141. OT pocket camera
  142. Test Indicator Holder Idea
  143. T-Slot Nut Confusion
  144. Sorta OT: Fixing a Wooden Bed
  145. I need a bender.
  146. Press Adventures Continue
  147. Sorta OT: ain't it the way
  148. How do you make Threads on A Shaft?
  149. Sticky Indicators: Anyone have a simple fix?
  150. Storing a Magnetic Chuck
  151. material for QCTP holders
  152. Spiders Taking Over!
  153. Happy 4th Of July to all fellow Yanks ! (And my organically powered clock.)
  154. source for level vials
  155. Charlestown Navy Yard: chain forge and foundry
  156. Heavy equipment at work, images
  157. MES still alive and working?
  158. Over the counter Sprague coupled shaft
  159. OT- Bad Propane Tank Valve
  160. Newby Question
  161. Machining a concave surface
  162. TiN Coating, where to get done?
  163. Keep Those Fire Extinguishers Charged and Ready
  164. 8x36 mill riser
  165. My workshop videos
  166. I hate 2mm drill bits!
  167. Source for Small Amount of Copper Round
  168. Amplifying Exhaust Sound
  169. School me on hydraulics please
  170. So what is it ?
  171. Dallas Area Scraping Class
  172. Greatest shoal on earth
  173. How to indicate off a tilted workpiece?
  174. Tool Steel Charts/Uses
  175. OT-Outdoor AM/FM Antenna
  176. Adding powered wire wheel to clean horizontal band saw blade
  177. Must Haves! From Village Press
  178. Do you know what it feels like 5 seconds before your about to be struck by lightning?
  179. O/T PC Issue For Evan
  180. A boring question ?
  181. Mystery grease fitting
  182. gear question 0.020"
  183. Who needs machine tools anymore?
  184. Update; Ford 6.0 hpop fix (continued)
  185. Lubricating a cement mixer
  186. OT - Need e-mail program. Recommendations?
  187. Made your own cement mixer bowl?
  188. OT: What's going on with this windmill?
  189. Sharpening Angles-How to calc
  190. OT: machinist belt buckles
  191. How much to charge
  192. awesome webpage.
  193. Picking out a Machine?
  194. Aluminum grades
  195. Another shop fan bites the dust WTF? Any DIY options?
  196. Metric Woodruff style keys?
  197. OT - Annoying Phone Calls
  198. OT -- Need Web browser recommendations
  199. Cylindrical square v Granite Angle Plate
  200. Awww Nuts, Striped a thread.
  201. Need some help with a 2 sided part in RhinoCam
  202. SOT Penn Tool
  203. A surveyor's compass I made for David Brinkley
  204. OT - Tour de France live telemetry
  205. A gold heart pendant and earrings I made
  206. Your insurance company is cheating you be sure to ask for your refund.
  207. The steel die for coining the gold pendant and earrings
  208. OT -- Newer HDDs temperature sensitive?
  209. How to grind glass?
  210. Enco promo
  211. OT - hardwood floor re-finishing er rather re coating
  212. A brass and rosewood shoulder plane I made
  213. Electrical question - 12v
  214. ball cut program
  215. Computer power supply use
  216. My basic lathe wiring issue, or how dense am I?
  217. Proper use of carbide in 4140
  218. inspecting machinery before purchase
  219. PLC program!
  220. Milling welds
  221. What plastic for Trolling Motor base ??
  222. just how can the manage to do this??? so cheaply
  223. Quick project for sine bar
  224. For my friend Willy
  225. Tumbling small 6160 sluminum parts
  226. Username Change
  227. Tooting my own horn!
  228. Help with Bison Chuck, can we save it?
  229. Supermax CNC mill re-re-retrofit
  230. It's official: 50 years as a machinist
  231. Disgustingly OT: California buying bridge sections from China
  232. So, just how tight do ya tighten R-8's?
  233. Plexiglas Pontiac
  234. OT- Satellite Internet
  235. Spindle oil loss rate - SB9 (cast iron bearing)
  236. Sheep shearing machine is usable!
  237. OT End of an Era
  238. 40 years in august?
  239. OT: How to increase one's mental energy & focus?
  240. OT End of an era 2
  241. 100 years old machine video
  242. New guy saying hello
  243. wheel wobble on trailer
  244. New here hello
  245. Need Odd Size Machine Screw
  246. What gives with Cobalt?
  247. OT: S-10 tranny & clutch noise
  248. Propper Spaceing To Make A Drill Index
  249. Sad day for Myford
  250. I broke me lathe
