View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 [175] 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211
  1. Computer- WIN 98 possessed --MAXNC no go.
  2. I had some Swiss sheep to shear today!
  3. Calling all electronics experts
  4. Need a little help, please
  5. Power Table Feed
  6. looking for photo
  7. Carb adjusting screws
  8. Eliminate machine power cords?
  9. 2 speed gearbox needed
  10. ???Threading tool difference
  11. Awesome things you've found when buying a house (not-so-subtle tool gloat)
  12. Mac OS X Lion -- to upgrade or wait?
  13. Bronze/plain bearing lathe oiling question
  14. New project need advice
  15. OT:UK Royal mail query
  16. Question about a set up this months issue
  17. working with glass tubing
  18. 3D Taster holder
  19. OT GPS tracker?
  20. Why would they make a mill arbor like that?
  21. Want ot trade a mini lathe for a mini mill..
  22. Discount Machine Shop
  23. lathe help
  24. ZAY 7032G Mill help?
  25. Some days it dosen't........
  26. SCHSM - updated information?
  27. Welcome Mat
  28. Backlash issue
  29. Awesome exoskeleton from Japan, machining included
  30. Too Hot
  31. Higbee cut for 1x28 TPI?
  32. Built another welding and fabrication table
  33. Lathe bit cross section, NOT A GRINDING QUESTION
  34. Millrite spindle
  35. New addition to the shop!!!!
  36. Older Hammond tool grinder, worth buying?
  37. ShopBot CNC Camp in Vancouver, WA
  38. 4x6 bandsaw aggravation...
  39. Self locking flathead Allen capscrews?
  40. Smart Meters ....
  41. The Coyote story
  42. Logan 12 x 36 advice
  43. Problems CounterBoring
  44. OT: Amazing Wrestling Move
  45. Knurling Question
  46. speed control
  47. Warped Weld Table -- suggestions?
  48. OT: A new way of chainsaw sharpening, on the job.
  49. Phase Convert Burning Out Machine Motors?
  50. Threading - Knowing when to stop?
  51. A bench full of saws we made
  52. belt sander
  53. Anyone interested?
  54. Countersink sharpening
  55. OT - Please help me point a TV satellite dish on a boat in the right direction
  56. Enco $25 free ship code for Aug
  57. how to setup a rod end perpedicular to a drill
  58. compound mill drill tables
  59. Spring Die Cap
  60. Not everything is from China!
  61. OT: Anyone know anything about crt display repair?
  62. Coolant for the mill.
  63. Aluminum Shaft?
  64. Metal Band Saw Blade Speed?
  65. need an idea
  66. Modern Gobbler
  67. Satisfying Day...
  68. Wow, I'm getting into HSS.
  69. A bunch of Wooden Planes we made
  70. Possible shop tips while making starting rollers for a competition motorcycle.
  71. Looking for a new lathe...colchester or no?
  72. Best story you ever heard from an 'Old Timer' ???
  73. delema
  74. 1903 Pratt & Whitney 10" Toolmakers Lathe
  75. For all who know Brian Lawson, from NAMES group
  76. OT: Water + CO2 + sunlight = diesel fuel!
  77. Thanks for help, "D" bit, etc.
  78. Release agent for JB Weld?
  79. Shopfox Milling machine
  80. That was a hard days night
  81. 20 ton Shop Press for home use
  82. Butt welding tubing clamps
  83. Baldor Replacement Bearing Questions
  84. Help with this part
  85. Al/Ox wheel dressing?...HF tool grinder and other questions.
  86. Pippin' is easy...lathe diagnostics question
  87. Trying to fix my little 4x6
  88. Aluminum welding project presents a big dilemma
  89. DRO Magnetic Tape Encoders?
  90. electric motor question
  91. Power cords on Makita tools, disintegrating..
  92. OT - Fridge/freezer woes
  93. Four years, plus, since last ordering from McMaster-Carr
  94. Die Grinder - motor question, service?
  95. OT--Need Firefox help
  96. Most Reflective Reflector Tape?
  97. Monarch 10ee update
  98. Does this count as a fluid coolant system for a lathe
  99. Semi OT: The Trebuchet Challenge
  100. Metal question pond weeding
  101. Power hacksaw
  102. Which plastic?
  103. holding carburator slides in 3 jaw
  104. storing grinding belts -- ideas?
  105. What was this aluminum/steel bar used for?
  106. OT: Fixing water pipe problem
  107. rec.crafts.metalworking on Google groups, what happened?
  108. An important question for CNC users in Digital Machinist forum
  109. tig welding experience.
  110. Small crankshaft and connecting rod
  111. How to cut 1/2" thick Naval brass
  112. Does anyone reconize this Warning Light?
  113. Free lathe in Massachusetts!
  114. Well not exactly a tool gloat but ,,,
  115. Can you have a person gloat...? no pics
  116. Pictures: Astronomy, storm, desert and cactus
  117. Would I be able to drill and tap holes in the jaws on my JET lathe?
  118. 12-axle load
  119. New product
  120. R8 collett questions..
  121. C.I. surface plate -- scrap or scrape?
  122. My wife wants to come on here and talk to the other wives!
  123. A cannon I machined from 5" diameter stock
  124. Turning the cannon shown in the other 2 posts.
  125. Junk hyd cylinder needed
  126. Annie's Little Broom
  127. Ratchet or friction micrometer ?
  128. OT- off to the electric flying field
  129. south bend ..what model is this
  130. Does anyone live near Pleasanton CA ??
  131. Buckley Old Engine Show
  132. Mill alignment question.
  133. Polishing in the lathe
  134. OT: Bee Movie
  135. best end mill for slotting in 18 gauge galvanized steel 2, 3, or 4 flute?
  136. Soda Blasting????
  137. Digging in the new garage (more tool gloat)
  138. Glen Wilson Tool and Cutter Grinder
  139. Best alternate use of an endmill
  140. Copper - For Chimney Repair
  141. Need a suggestion.....
  142. Buy & sell website?
  143. OT- Hard Drive Failure
  144. Band saw guide
  145. Am I being picky
  146. Help please: Unintentional taper
  147. Nose Radius, theoretical v. practical
  148. QCTP What one should I buy??
  149. Brake master adapter
  150. OT: Windows 7
  151. You know you are getting old when....
  152. The things you "find"...as a work bench?
  153. Magnetic motor. Video, idea, discussion
  154. See any problems with the Smithsonian's Department of Innovation logo?
  155. Best mini mill?
  156. Enco 15% discount + Free shipping
  157. To our friends in Great Britain
  158. OT: Diesel motors, How do they adjust throttle?
  159. How to put a round pin in a square hole
  160. Float-Lock DP Vises: ratchet or screw?
  161. whats going on with ebay
  162. How ALIGN: 2 shafts?
  163. Two questions
  164. Material choice question
  165. OT neighbor's wireless modem problem
  166. Best solvent for stripping paint/grease/assorted filth off an old machine?
  167. Gearing Help for Rolling Mill (jeweler)
  168. How was this sprocket cut?
  169. Toyo Lathe parts
  170. The Fear of Finishing
  171. Solved Counterboring Problem???
  172. Bench grinder jig with a horizontal 'slide' for sharpening.
  173. Bronwen and I the big 4 0 on sunday
  174. gwilson: ellipsograph?
  175. The ellipsograph used in "The Woodwright's Shop"
  176. unknow milling
  177. An eBook on Naval Recip Steam Engines
  178. OT- Fusing radiator hose
  179. Small gear cutters.
  180. Clock repair question....
  181. Small tumble polisher and walnut hulls
  182. Darex drill sharpener support ending tomorrow
  183. New trend in hand tools
  184. Co2 Bulk fill
  185. OT - the massive caps used by car audio, um, enthusiasts :D
  186. Eureka!!?? A Rube Goldberg/backyard alternative
  187. Removing tapered spindle roller bearings
  188. OT - Blind Spot
  189. Are You a Prisoner of your Job?
  190. OT, cheap shipping
  191. Jeep transmission overhaul...should I get a good grade?
  192. electrical contact separator material
  193. Monkeyrak ladder stabilizer
  194. Back Gear Repair - too ambitious for a newb?
  195. Pillar tool
  196. Moving a Bridgeport long distance
  197. OT: Duracell Batteries
  198. Metal Cutting Circular Saws
  199. Automatic shop air hose cleaner/reel, anyone have one, where to get one?
  200. 20 Ton hydraulic jack question
  201. CDCO 5c chuck
  202. LEAST favorite shop task?
  203. Countersinking #8-32 1/4" tee nuts
  204. LeBlond sliding gap on G'liquidators
  205. cutting a notch in milling machine vise jaws?
  206. Question for Logan lathe owners
  207. Torch Hardening and Annealing Help
  208. How did they do that?
  209. Chucks and the minimum diameter they can grip
  210. Myford MF74 modifications
  211. OT Pond weeder ver. 1.1
  212. What Are They Putting In Gas These Days
  213. OT Cord/air hose jib
  214. Pantograph style tool support
  215. kindle ?
  216. what can I do with my new bed apart from sleep in it? serious question
  217. Anyone up on prices on a large used lathe ?
  218. Covel Hanchett mill
  219. Help cleaning QCTP innards
  220. Southern Fried Trailer Hitch
  221. Way OT: Can anyone understand what this AgNet weather announcer is saying?
  222. Boring, how to make 30 minutes last for hours
  223. True Endless Sanding Belts ?
  224. Calling All Nor Cal HSMs - Tool Show Aug 20
  225. free stuff
  226. Craftsman air compressor motor problem
  227. the Stanford solar car
  228. bandsaw crooked cut
  229. Drill or Countersink for 30° Included Angle
  230. USPS Tracking
  231. Kindle format/e reader/PDF books
  232. Metal that blocks magnetism?
  233. demagnetizers
  234. I Never Thought I'd See It - Metric Adjustable Wrenches
  235. my grizzly G3616 Mill is dead
  236. Suggested method of cutting drill arbors?
  237. HF Coupon?
  238. Best place to buy granite surface plates near Indianapolis?
  239. On Topic: Not all kids are lazy slugs
  240. A question about shipping from Canada to the US
  241. OT:SpaceX to give it a go
  242. Hexagonal Boring video
  243. work hardening stainless steel
  244. O/T Freight on equipment from US
  245. Setting dial bore gauges
  246. Odd drill bit
  247. B&S #585 vernier height gauge issue.
  248. tig welding experience part two
  249. OT, Whats going on with the Google...
  250. OT wire
