View Full Version : General
- Free to a good home(s); Southbend parts
- Steel Surface Prep
- OT - Internet Explorer Ques.
- Large Synoptic Survey Telescope
- report on Yale machine shop accident
- Ebay Makes me MAD there own RULES are worthless!!
- Cleaning Lead Screw
- Shortening an Aloris toolholder
- Concrete machine bench moved into the w'shop..... but......
- Stuck Taper pins
- 1/2 13 Unc Flange Nut
- OT: Computer help/Trojan repair
- OT Recovering a deleted file from my thumb drive
- Floating Tool Video?
- Replacable head end mills??????
- Newbee
- large threaded cone .. puzzle?
- My shop is too small
- Best way to cut .010" Blue Spring steel?
- Finishing
- phenolic resin cue ball
- OT: Could I run my modem, router etc off my PC's PSU?
- Another newbie
- Glass torch, could use some advice.
- how to make a idler wheel?
- Surface Grinder Questions
- SB 10L Toothed Spindle Drive Belt
- advice wanted: modifications for bearing inserts
- crude "survival" axe/knife
- Nothing Like Being Prepared!
- OT? Help with GenSet (electrical troubleshooting)
- Cutting strap on a bandsaw
- Moving my Surface Gringer to the New Shop.
- sheet metal bug -- diy tools?
- Wow they don't come much better than this!Alistair
- OT: Domain registration
- Paging Carld...shear tool questions
- What's Your Story?
- Standard Modern Plain Taper Attachment
- DESIGN ADVISE; Axial-adjustment
- Best way to scribe lines of graduation?
- How to: need a better finish from my mill
- sharpening cold saw at home
- Making heavy hex bolt to finished hex bolts
- Marking inserts?
- any thoughts on this QCTP??
- Wood work with metal work machines.
- Question re welding and magnets
- Super Fast Indicating
- OT woud like opinions on the VW diesel
- How much tension can a serpentine belt withstand?
- Strange Horizontal Cutter
- Going to take a look at a bridgy
- What is a good rust prevetative machinery paint?
- Question about using "Cherry Red"?
- magnetic field question
- Noob progress, of sorts...
- ??? antique welding rod ???
- Newbie confused
- Bridgeport motor
- OT . . madmodder question
- non-standard thread measurment
- OT Time stamp in google chrome
- re-surfacing ways - grinding vs scraping vs $$
- Hossfeld How-To's: Cam Dies
- OT Tracking Meg Usage
- OT storing vehicles long term and the battle against mice.
- Measure twice, cut once.
- Engine crane, cherry picker modification, outside use
- making big holes on a milling machine
- Cutting speed for solid carbide cutters
- OT...Nikon DSLR Problem
- Emco Plastic Injection Model 333
- Kraftformer
- Sizing a Huanyang VFD?
- Coolant system on Chinese machine tools....how to make them work....maybe.
- DIY radius "milling" cutter for use in boring head
- Making a simple die
- Dial test indicator repair
- Evaluating a lathe
- Where is Oldtiffie?
- maths help please
- T&C grinder - anyone recognise it?
- Machinist IRC chat now open.
- Really basic questions about sliding fits
- Earthquake in Virginia
- Boring Cylinders
- OT: more inexplicable insanity on ebay
- OT - computer firewall conflict
- Engine Rebuild - youtube series
- $100 screw cutting 12" lathe design
- 12" Atlas Parts Question!!!
- 24 hour shop in a bag.
- OT: TNT Duty fees
- For the blade makers
- OT: how to keep racoons away?
- Hard Spots In Metal???
- Shipping info
- AWOL Magazine
- OT: mass of eprom
- Grinding wheel balancing fixture
- Help Identify this fly cutter...
- replacement splined handle?
- oddball thread size
- what is this used for?
- belt grinder nearly finished
- E-bay shipping experience -warning
- Poor man's log splitter
- Question about 1" R8 collet
- Mitutoyo DRO help
- How to restore old Kennedy toolbox?
- I'm really happy - doing something useful
- 38'-44' 12" Craftsman Deluxe Lathe
- My attempt at a carriage indicator clamp.
- Vials for King Alignment Tool
- OT, viewing my pics as thumbnails in W7 pro....
- Our simulator is done.
- Lathe speed
- Canadian drill sharpener?
- OT JLG repair
- Need some more advice
- Scraping Class in Melbourne Australia.
- Milling off welding slag?
- The ultimate camera/video toy
- My tools might be in for a salt bath courtesy of Irene! Advice?
- Heads up re: September 1st
- Power Hacksaw Lift Mechanism
- Levelling a lathe on my concrete bench...
- Latest Slipjpoint knife
- photobucket help..
- Thanks for the greetings.
- Encouragement, futur and my opinion
- OT: Handy trick to reducing picture size
- OT: jigsaw puzzles for adults, puzzle glue,
- Is there any type of CDCO coupon?
- Metric Thread help needed.
- What is the value of endmill holders?
- You Learn Something Every Day (about billet that is)
- Enco codes?
- OT - Adjusting Voltage on a Small Generator
- Learned a valuable lesson, Without breaking anything or hurting myself
- Teaching Machine Shop From Home - Opinions?
- Tool Gloat...
- A Tip For New Members
- Sharpening HSS w/diamond---'thought that was a no-no
- More OT, partly at least- rpm reducers
- Low HP BP face milling QCTP blocks
- Atlas 12" QC "Guess you guys were right"!!!!!!!
- 45/90 built entirly on a lathe
- safety poster
- O/T US members and Irene
- Glendo Accu-finish tool grinders / hones?
- Aircraft grade aluminum solved
- Where to buy old dial indicators
- using a reciprocating saw for parting
- Worn Scroll Chuck Repair
- Back Up Generator Alarm...help!
- H140E DeValliere Lathe, anyone?
- OT Google Chrome---IE9 and cookies
- Machining Hardened Drill Blanks
- The dangers of to cheap a welding helmet.
- Help with Antique motor please!
- Help please with Antique Motor!
- Looking For S. Florida Members
- Another astrophoto
- Newbie: How far off the dovetail can I go?
- welding lenses question
- shop vac hose
- LMS high torque mini mill tramming issue
- Having Trouble With Acetal Nuts
- Shifer assembly
- What not to say to your wife!!!
- Help with backing plate for indexing head?
- Help with frozen joint needed.
- mystery machine in Poland
- OT - Transporting Propane bottles
- Bridgeport Slotting head
- Transfere Switch Power Cord
- OT: Weird PC issue killing me - help?
- What is it? Part 1
- Info / Plans wanted : Oil Lighters
- OT Proposed changes affecting EU & UK motorbike riders
- Drills/hard materials, reamers, driver bits and cleco's they ship international
- New Sino DRO on my mill
- Help with a generator transfer switch question
- Kurt D688 vise jaw stop
- IRONWORKER plans wanted
- Bending 12g sheet metal. Idea's/help?
- David Decaussin UMC-10
- Clausing vertical mill spindle bearing size?
- Mobile propane tank
- New Emcomat 17 S/D; anyone seen one in the flesh?
- Home Made Welding Electrodes
- Power feed for milling machine
- Converting to a QC gearbox on a SB 9c
- Tires that "won't take the bead" and air up. (ot)
- OT - Where is OZ?
- Rockwell Belt Grinder Wheels
- Uses for extra weed eater motors?
- Galling question.
- Coolant hose source?
- Grainger
- CO2 quick disconnect
- Shapers and Slotters
- New to Forum, Help Needed Identify Machines
- An eliptical question
- Random thoughts on work standards...
- Finished CO2 adapator!
- Knurling's bad for bearings - Fact or Fiction?
- coolant
- At what price would you not pass up a shaper regardless of room to put it?
- Mcgyver:
- OT : this is very cool!
- OK.. what am I missing????
- OT: GIANT F'NG MOTH(s)!!! o_O
- Rockwell 11x25 opinions? Tips for inspecting?
- 3003 Aluminum, how does it mill?
- OT- Sharpening saw chain
- Niffty press brake die
- How To Stake Or Rivit A Master Link In A Hyvo Chain
- DIY simple truck ramps - ideas?
- Buy Jet 1024 Metal Lathe Yes/No
- Keeping Screws Tight
- throttled coolant pump
- What is it? Part 2
- Sell an old friend?!
- Chemistry info
- OT - security cameras
- OT- Chainsaw reed valve
- Impossible Task?
- OT Submersable Well Pump
- Inverted boring bar
- Case hardening a bolt
- what material are air fittings made of?
- Hossfeld Bender Hydraulic Question
- Can't afford a welder?
- Old circle saw mill blade
- We don't need no stinkin' badges!"
- Very unusual toolpost?
- Grinder
- OT Copper A/C Tube Failure
- The Apple idrunk
- OT: Bedtime Stories for Children
- OT: Clueless shop or troublesome problem?
- Strange V-Block Clamp
- SB 9" Model "O" QC and Apron rebuild
- [Gloat!] Ultra Sonic Cleaner!
- Made a new metal storage drawer.
- Monarch 10ee "project", too ambitious?
