View Full Version : General
- ring sizes
- The Jaws of Crimp
- How to remove this bearing?
- Delrin to steel adhesive
- Can someone please explain this whistle valve?
- leather punch?
- Scraping newb to tinker with cheapo import lathe?
- Rotary broaching - the easy way
- sharpening a knife
- OT- Need a Computer
- First Time Gear & Keyslot Cutting
- Bantam Mk1 help please
- Who says the Chinese don't get it right ?
- Home Shop Turret Lathe
- Toy: Compaq iPaq 3835
- Machining Square in 6 jaw
- Quick & dirty tool tray for repetitive drilling in mill
- Makeshift puller
- Machinery Manuals
- Lathe chuck removal tips
- Easy to make & use adapter w/bathroom scale for weighing trailer tongue
- Bridgeport drawbar installation
- How does a hammer drill work?
- Recycling leftovers & scraps.
- Blowers and superchargers.
- Stainless steel fastners in aluminum engine cases
- How to get a good hand chamfer?
- Where to buy symbol stamps in UK?
- Humming and hawing... (10X18 lathe)
- Bronze Material Question
- Lathe Tail Stock
- Floating Reamer Holder for Tailstock
- Looking for anodizing supplier
- Looking for Bull Gear for an old lathe
- Help, size of replacement motor
- spraying metallic paint
- Security Alarm System for my Workshop.
- Questions on a First LC-30A milling machine.
- 1933 Southbend Model 420-ZB Toolmaker Lathe Restoration/Rescue
- "Wicking" & overhead lubrication reservoir.
- Making a real thin washer
- want to start a club
- Thanks
- How long does mixed coolant last
- Basic fit and slide question ?
- Oversized tool holders - What to do?
- Busy Bee Craftex Lathe??????
- OT-alt issue
- Money for old rope
- OT - Quaint Names (town, street, etc.)
- Q: MuellerNick's Top Slide Scraping Video
- Help: Odd pattern on CI surface plate?
- Bearing Cap for spindle on old headstock
- Laser Cutting Questions!
- OT: Copying Photobucket Links In Firefox
- metal shear
- I need a tap.....
- OT It was just a belt...
- OT - What is this tool?
- Turning copper
- way off topic buick v6 motor/trans
- Floppy Drive to USB replacements...
- building a two part vice
- Techs that leave your employ to compete with you.
- Bronze of brass for bearing material
- Options on fixing a little chipped cast iron ?
- B&S contact point threads
- Full Length Internal Tube Threading
- Shop made carbide boring bar?
- spot welder contact tips
- OT? - Just how short is your fuse?
- how to tell pancake motor power rating?
- Preparing to do the break-in on the Bolton lathe ... suggestions please. :)
- How many projects.....?
- 1/2" bronze plate got sawed up today.
- OT - wireless networking access point
- A machining ethics question
- The Turbo Encabulator.
- Scraping an aluminum straight edge -- worth it?
- Variable speed AC Drive
- Need weight for 16in Gould & Eberhardt shaper
- Slap Stick Panel Beating Tool from old file
- What is flat in the home shop?
- Electric lawnmower project..
- HSS (high speed steel) inserts
- Oregon Gears
- Milling Machine Horsepower Question
- No blade Dewalt
- help w/old Bridgeport
- Oldham shaft coupling repair
- Waterproofing A Plastic Tarp ?????
- OT - digital camera fault
- Maybe not OT? Kitchen lighting, DIY, give me some ideas!
- Another low cost rotary broaching tool
- Russian marsh tanks
- Adjustable Reamers
- Sandblaster question - OT
- 4-jaw independent chuck, 2 backplate questions
- Drilling small diameter hole deep
- learned a lesson!
- Questions for DC Motor Control Gurus
- Craig's List reply to CNC Machinist Ads
- Cylinder Chain Clamp
- Fragmentation Shield
- OT: Fixin' a buddy's tiller engine.
- Making Hex from 3/4" Round
- Buffing advice requested
- Filling a Bottle Jack
- cincinatti horizonal help
- I wanna play "What is it?"
- Taper turning on a turret lathe
- plasma cutter and magnetic field
- gaskets in propane nozzles
- ot about mig welder
- Southbend Owners
- Anilam Crusader II/ Crusader M Post Processor
- Anybody have experiance with the Shars Adujstable Universal Chucks?
- Slotting head
- OT: new member introduction
- New Member / Powermatic Lathe
- Need some help..want to make a flashlight
- Drill Press Electrical Problems
- OT, New money deal!
- Spring Loaded Nail Set
- Ralph Steiner Mechanical Principles 1930
- Buying a mill help
- Lathe cutting problem
- OT - Shop Lights & Ballasts
- 1/2" X16 thread???
- pressure seal with press-fit parts?
- Power Feed
- OT getting a printer to do Photos as per screen
- Pickle Fork?
- ot whatever happened to?
- Magnetic Anything.
- Dovetail Stock Source
- Excello 602 - Small Oil Leak
- Source for buying single drill bits for metric taps
- Bridgeport type M Help
- Induction Hardened Linear Bearing Rod
- Wilson Greatbatch: the death of a "humble tinkerer"
- OT - Couldn't find my pencil sharpener...
- Bearing seal or shield?
- Rocket City Rednecks -TV
- Boring tool holder
- 10" Lewis Shaper help
- OT, retrieving data off a virus'ed HD
- Spinning Copper Cones
- I would like to buy???
- 12x36 lathe at scrap yard anyone live near Murfreesboro TN?
- Anyone recognise this mill please ?
- OT (sort of)-cool webcam software
- motorcycles as sculpture
- Portable Bandsaw Vise
- Chinese Rebar Cutter
- O.T. The late great TARANTULA migration...
- Blade sharpening. I'm inexperienced.
- OT: Murphy's Law is having its way with me...
- Cupola Iron Pour in PA
- iphone sensor sample rate??
- Heating my Garage Shop
- OT - Motorcyling Dog
- Wow money for old rope
- Mikey broke his little miller
- O/T Wire service errors
- Bridgeport Electrics
- How about this for a first cnc mill?
- spindle lock-ing
- Engine turning aluminum
- O/T Airshow incident
- What is the best way to make these parts?
- Recent astrophotos with 10 inch scope
- Apply for "approved email sender" status?
- Accelerator for Cyanoacrylaten glues
- Heavy Metal: Billet Chutes
- Newbie's Tool non-gloat (modest tool, no pictures)
- forming stainless - a little bit
- Metal Working Technology Transfer - Dearth of Used Books
- Bolted Steel Beam Construction - Hole Placement
- moisture through concrete in shop?
- neodymium magnets and glue
- A dividing attachment I made
- Tool Desert
- Federal Light Bulb Legislation.
- O.T. Reno - why?
- Estate sale tools-Tools on the cheap
- Anyone need a honking Monarch?
- Kant Twist Clamp Knurler
- Don't care if it's Chinese - I want one of these...
- Slitting Saw, newbie??
- Shop Lighting recomnedations
- water pressure booster.
- rotary broaching broach.
- Anybody with a small CNC machine shop in the northeast?
- Slightly OT - A Cool Shop Dog
- steam toy
- Major milestone...cnc..
- Harbor Freight pipe bender mods
- Way OT - Horizontal Driveshaft Alignment
- Riffler filres I have made
- What kind of vice or mill attachment is this??
- I know what it is, but I dont know exactly what it is...
- Searching for a Lathe Manual
- powerful tap water
- Computer Help: HP TC4400 Tablet
- I am trying to buy another vehicle dealers are making me unhappy
- Way OT pewter rod
- Lathe problem - seems to cut too much?
- Threading tool Question
- Monarch lathe, Van Norman mill, Power-hacksaw available in NM
- Milling Machine Repair
- Lathe chatter problem
- flat battery OT [red wine misuse]
- Interrupted cuts between centers, noob ?
- Looking for used machinery in south Minnesota
- A chiseled relief pistol barrel made with rifflers
- O.T. How to deal with difficult people at work
- Maxi tourq rite collet closer still available?
- Gloat?!?
- OT: self-leveling floors
- Dial for Jet 1024P lathe tailstock
- Wet micrometer
- Auction in Lambertville, MI
- Active slide turning
- Nautilus T912 Treadmill w/ 3 HP Motor
- So I took my machine shop into the woods…
- Got a Benchmaster Mill - What are these zig-zag lines?
- How to solve three problems at once, a new electric service for my house and shop.
- Keeping lead-acid batteries in good condition.
- Video Clip
- Low cost motorcycle GPS
- OT Rotating Laser Levels
- The Post That Vanished
- Electronic wiring question
- Enco promo code
- Has anyone tried to sell their House???
- Enco Free Shipping Code
- How best to...
- Table Saw Rip Fence Improvements ???
- Bolting lathe to bench...positioning
- Holy Trepanning cut Batman!
- Pool hose for vacuum
- Anyone know how to change the nose wheel on a DH Vampire!
- What can these inserts be used for
- sudden change in dial caliper
- Lytro light-field camera
- Soft spot in grinding wheel?
- Halloween - Corpse / Casket
- I need a transmission idea
- Heavier Lathe Cabinet is Better, Right?
