View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 [179] 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210
  1. It's now official, it's a POS
  2. replacement lathe spindle & more
  3. Machine tools,old men,wheel rims and Techno
  4. Jones and Shipman 1014 Cyl Grinder
  5. Mill worklight.
  6. Where to buy steel dowel pins in small quantities?
  7. Way OT- Mattresses
  8. Another headstock alignment question
  9. Marushin Vertical Mill
  10. Is this a Chimera?
  11. Boring for a taperlock bush?
  12. Why are there so many different names for the same thing?
  13. Obscure question re 'synchros' aka selsyn..?
  14. Surface grinder with a Hemi
  15. What's with this PM I just received?
  16. Nardini TT 1230E lathe
  17. Face milling left to right v right to left ?
  18. Gismo for Vacuum Cleaner
  19. One for the knife makers - handle riveting
  20. as to Help!!! how to identify the thread spindle of chinese lathe
  21. B-crimp die drawing
  22. Skip (dumpster) diving
  23. OT- Gas Strut Noise
  24. Cold, Dry, Band
  25. Anybody built a robot
  26. End mill holder for lathe?
  27. Instruction manual for an electric circular saw
  28. 3 soft jaws or 6 hard jaws for a given application.
  29. OT: Satellite malfunction
  30. Purchasing end mills
  31. Milling spindle ideas
  32. Face Mill
  33. Changing light bulbs
  34. OT It's an addiction!
  35. For need of a regulator with return ports.
  36. Hi all, dro needed
  37. Eastwood spot welder
  38. Voltage Supply?
  39. "Friking LASER BEAMS" and safety -- looking for goggle information!
  40. Machining a rusty table?
  41. Benjamin Moore KP22 .vs. M22
  42. Magnetic circuits and solenoids.....?????
  43. used lathe
  44. WTB Millrite
  45. Concrete Adhesive?
  46. Solenoid Motor
  47. Flux for casting alu
  48. I need education on a self grip cut off tool
  49. attempting to recondition a old buzz saw
  50. How to sharpen a knife with the right tools?
  51. Stirling engine trouble.
  52. New Lube coolant applicator?
  53. OT: Flat Roof Coatings
  54. OT Cleaning Car Fuel Injectors
  55. in search of a metal shaper
  56. What were your Worst, Funnest, Craziest Job Interviews???
  57. Multiple bars from Plate or Bar
  58. What should I use in my parts washer?
  59. OT: Computer printer ink cartridge?
  60. Sort of OT - Homemade rocket hits 121000 feet
  61. Do, Do, Do,---Lookin' out my front door!!!
  62. Bandsaw blade and use survey
  63. Somewhat OT - Decent sub-$2K tig welder
  64. Astronomy Pics
  65. 115V input TB Woods VFD?
  66. Miniature cast iron engine block- collectible?
  67. OT - Weird Windows 7 problem
  68. Pinging Black Forrest----O/T
  69. Wooden "steam" engine
  70. solenoid engine research....
  71. Air Compressor freezing?
  72. Anti-Scaling Compound, what's everyone using?
  73. Help identifying tool and cutter grinder
  74. OT- Smart Meters and Exposure
  75. Air compressor set up question.
  76. De-rusting my tool gloat?
  77. If only I had a real shop at home...
  78. OT: Installation of Insulation in Shop
  79. Formulae needed
  80. Compac Indicator Question
  81. Threading drill rod with an HSS die?
  82. OT(?): How to patina a tablesaw quickly?
  83. clamping large items
  84. Boxford Lathe Configuration ?
  85. [catastrophic emergancy situation code brown] Microwave Oven Has Stopped Working
  86. ID this Lathe please
  87. PCB Design Software
  88. Radiator cores?
  89. Splinters (hands and feet).
  90. My Benchmaster Mill & Refurbishment Project
  91. 1/5 scale model machine prints
  92. YSTools?
  93. Crimping Die and Indexing parts ID
  94. Enco ?????
  95. O2 is flammable - true or false?
  96. Anyone used a dual blade steel cutting saw???
  97. Triplett Lathe
  98. Need Help With Pattern Making
  99. Craftex
  100. DIN standards 406-10, -11, -12
  101. Metallurgists or those with experience, finish ?
  102. 220 volt Lathe wiring
  103. OT Something you don't see everyday
  104. In the market for a new tumbler.
  105. Cleaning your surface scraping ink layout roller spreader thingy
  106. Jet 13-40" gear head lathe
  107. X-Mas Coming AND
  108. Best way to approach this job?
  109. Looking for a Chinese CNC small-lot manufacturer?
  110. Ideas for a friction joint?
  111. use Palmgren milling vise or Bridgeport milling vise?
  112. what are some brands of high quality tooling available used?
  113. tig welding copper
  114. How get Lever A-> Lever B? (see Pic)
  115. 2 new old mills
  116. ALTIVAR VFD fault - is it terminal?
  117. Rivett T1020 lathe
  118. Refinshing/repainting cast metal gears...need guidance
  119. Enco free shipping code?
  120. Siri and the Turing Test
  121. Proceedure for Attching CAD file?
  122. LIquid rheostat.
  123. Can anyone id this 15 inch sander/grinder?
  124. SAMAND surface grinder spindle bearing pre-load
  125. Home made lathe
  126. OT Excel Function Required
  127. Harbor Freight tubing roller with missing pieces
  128. EDM...I gotta get one of these!
  129. OT: Computer Monitor Questions
  130. OT - BEWARE - Weiser SmartKey Not Very Secure
  131. vertical bandsaws - are wood and metal machines interchangable?
  132. Cut 25mm steel - no sparks.
  133. Boyar-Schultz Surface Grinder Repairs.
  134. Quadra Chek QCIIE DRO information ??
  135. Friend looking for a shaper
  136. Non English Based Metal Machining Forums?
  137. Ralph Paterson PDF problems
  138. Epoxy Granite build link
  139. OT almost got in a wreck today
  140. Climb vs conventional cut for slotting profile
  141. bang stick
  142. Idea for shock mount in all axes.
  143. Hydraulic Cylinder Rebuild - oring backup orientation
  144. Keeping track of bits in a teardown
  145. What is this mystery tool?
  146. Need to bore a big a hole and not enough swing on lathe
  147. gary350 your private message folder is full!!!
  148. horizontal turntable lathe
  149. A geopolitical tooling question
  150. photobucket stinks
  151. Working with an audience
  152. Help, top slide re-assembling too tight
  153. Standard Modern Model Question
  154. Will this more than $25?
  155. got the Bridgeport running, but the back gear drive dogs won't fully disengage
  156. Acme Tap, help required ***Warning machining content
  157. 21.51 vs 32.52 Inserts
  158. OT-Another Perpetual Motion Machine!
  159. Digital Tachometer?
  160. capstan lathe
  161. Soldering On Batterys???
  162. releasing die holder
  163. Way off topic but I'm tired of this crap!
  164. what is the recomended way to put a slot in stainless angle
  165. rotating hand grips on handwheels
  166. My New (to me) Bridgeport w/CNC Conversion
  167. Bad 50 Ton Press Modification
  168. Electronic, electromagnetic help please...?
  169. First CNC Mill advice: Bridgeport R2E3?
  170. A little side job
  171. Treadmill motor wiring help needed please.
  172. Clutch engagement - South Bend 9A
  173. On topic. How to SilBraze Carbide
  174. OT - Retirement - All opinions welcomed
  175. Gear vs belt drive horz bandsaw, pros/cons?
  176. Belt speed
  177. Warner magnetic brake
  178. bolt in inches?
  179. are Lyndex R8 collets worth 2.5x the price of Enco R8 collets?
  180. Tool Gloat...
  181. suggestions for building a smoker
  182. Brazing info very good
  183. Shop Signs/Charts
  184. Picked Up an Atlas 7B Shaper!
  185. What might this oxy/acetylene set be worth?
  186. 1" micrometer with wood handle
  187. How much does it cost to run a shop?
  188. Threading inserts
  189. I heard someone talking about Joseph Whitworth on the radio
  190. metric in US..... old , or new?
  191. Forum attachments gone?
  192. What webcam for Mach 3 mill cam?
  193. Tailstock Test Bar
  194. Where do I find a Manual?
  195. Cutting 18x18x0.125" 4130 with too-small tools
  196. Best method or product to remove paint from machinery?
  197. Mold or Goo on long term storage screwdriver handles. Whatizzit?
  198. Boring 316L SS
  199. 9" Rong Fu cold saws?
  200. Another great old book find
  201. OT..Who broke my video camera?
  202. mystery tree mill head
  203. Where To Buy Small Diameter Titanium Rod?
  204. My first Knife
  205. The machinist code
  206. I wonder who this could be?
  207. Tips on an ER-32 collet stop?
  208. My Rivett lathe arrived today
  209. Grizzly's showroom?
  210. The power of Legos
  211. MidEast Model Engineering Expo october 22
  212. I need help with truck transmission parts nomenclature and diagnosis.
  213. Why are 2-stage compressor quieter?
  214. Does anyone with a home workshop have trouble with the neighbors?
  215. I am looking for a corded drill prefer 2vo v what would you recommend
  216. I am looking for a corded drill prefer 24ov or 110v what would you recommend
  217. OT: What is this?
  218. Will mist cooling work for heavy cuts?
  219. Small brill bits don't stay centered very well?
  220. Sneaking up to final dimesions good ... Bad ... Or ugly.
  221. Atlas 6x18,Sears 101-21400 Lathe
  222. In respect
  223. quantum levitation demonstration
  224. Older Heckert horizontal mill question?
  225. Change Gears for Hardinge HLV-EM
  226. Insert type tool holders (lathe) .. new and stupid.
  227. General musings on grinding wheels...
  228. pinging Madman
  229. 4th axis threading
  230. Hidden in 'Plane View' part1/3
  231. OT: Technical eBooks
  232. Home built rotary phase convertor
  233. Popcorn Steam Engine Model
  234. Atlas Lathe Threading Help
  235. Can indexable drills damage an old manual lathe?
  236. Machinist's Psalm
  237. Compound table for rotary table
  238. Moto GP racer Marco Simoncelli killed this morning at Malaysian GP.
  239. Good place to sell a machining-related item?
  240. Aloris changed their logo
  241. Old Metabo grinder/polisher?
  242. Woo Hoo, Santa's come early this year.
  243. TMX vs Fuerda 4 jaw chuck
  244. internal threads 200 pcs
  245. Machining suggestions for this part
  246. Chuck size
  247. Lube on threads in plastic
  248. I saw a Starship today!!
  249. Old Bailey No 7 Plane..... HELP !
  250. single phase motor, rotor locked on startup
