View Full Version : General
- Bridgeport type Motor needed!
- Machining info
- Accurate angle machining on Bridgeport
- Automatic switching hydraulic valve
- The "clueless shop" vs S-10 deal.......
- Taking Amp Readings
- What should I ask for?
- Income earning capacity of a home shop...
- backplate and cap screws
- New here
- Accuracy of D1-4 mounting..spindle bearing.... whatever?
- Sketchup Vs. DXF File... Ready FIGHT
- Hardinge Cataract Quick change Restoration Project
- Introduction & Advice Needed
- The price of spare parts....
- OT - Computer Assistance with CD Drive
- Any one in NE Indiana with a clean S.B. Lathe?
- I'm going to be rich! RICH, I tell you!!
- OT equipment total run time meter
- Something strange
- Cutting Internal Keyway in a Lathe
- blind keyway with a shaper.
- Sears 9 inch Metalcraft Lathe - the resurrection
- Motor hums and trips out
- Bending .125" chromoly plate without the right tools.
- Precision Universal Boring Head Disassembly
- Way OT: Anyone know 80c31 assembler?
- Anti-static workbench surface
- Painting my Rivett lathe
- LeBlond Regal 15x32, any drawbacks?
- Solenoid engine video...
- I feel a gloat coming on
- OT:Why does old lawnboy use up ignition modules?
- I can't complain about tool limitations...
- Wireless Surveillance Systems and the Home / Shop
- TOS-Olomouc FH 20 Mill. Opinions?
- Tell me about files
- Blinky jumpy silly animated emoticons
- Need source for plolished carbide rod for burnisher/steel
- hollow chuck lathe
- milling head runout
- Tool Gloat !!!
- ID Collets, anyone using them...
- Best way to align combination mill head to lathe?
- Do 3C collets have internal threads for a stop?
- How straight should I expect drill rod to be?
- Mini slitting saw, cheap!
- Making a headstock center?
- soldering HSS
- Wire Size Question
- Making hand-made rasps - a video well worth watching
- VFD 2-speed motor question
- Trying to find a "Tool Gloat" living in a vacuum
- Need ideas for swinging a 6" radius on a small surface
- Real machining question..
- O.T.---The Ice House Cat
- Turret lathe tooling I saw on the HSM
- My HF tool chest locker needed an upgrade....
- Not a tool gloat
- OT: Another what is it.
- OT: Train porn
- Rubber or Neoprene Gloves for Trinco
- OT Points of interest in Detroit
- Finding the face on the lathe.
- What I have been working on for the last year:
- Private messages problem
- Enco promo code: 20% off orders > $99
- For sale items?
- About hydraulic presses.......or at least one of them...
- Chimney Valley Navel Observatory
- Sources: Replacement Power Tool Cord
- American 14" Lathe
- 125 Graduations: How I did it
- First. Commissioned. Metalworking. Job.
- Tool gloat
- Grizzly Lathe G9732
- ot: mechanical flying bird
- Rechargeable digital caliper?????
- oiling a bridgeport
- Chinese mill 'X' handles out of phase?
- Oxy bottle question
- "ODF turntable" Is this a joke?
- Slide rule speed and feed calculator
- Anyone who was at the Am. Precision Model show this year...
- Interesting machining related items on EBay
- ER32 collet chuck for lathe...
- Pump for heating oil tanks
- adding wording to a project
- High velocity pump
- Water Pressure Powered Back-Up Sump Pump???
- Tail stock center Question.
- Belt/Pulley question
- Satellite TV Tripod
- OT: Anybody been in India lately?
- re-splining
- Somewhat OT - high-wear transparent film
- Help! I need a teeny-weensy bit of G-Code.
- [Electronics HO!!!] Fuji Plus Monitor Power Supply
- Way OT Tachometer
- Changing 60Hertz to 120Hertz?
- If I had a banjo, I'd play a blues song
- Bore welding MIG gun
- Anyone ever build an asymmetrical trailer?
- Haven't seen many good tooling deals on Ebay recently
- sharpen Anderson scraper
- Suitability of 4130 for blades?
- Vermont blacksmith shop disposal
- Hammer Drill Tool Gloat, Sort Of Anyway
- For all you guys with little shapers
- Pinging flylo
- Tramming Results
- Tubular scraper handle..... how is the blade held?
- OT: time-lapse assembly of a giant gantry milling machine
- Monarch 10EE on Craigslist (Louisville)
- OT, motorcycle frame alignment.
- OT. For Airplane Lovers
- New meaning for roaming cell phone
- Is a grade 8 bolt a good material to make an insert toolholder out of?
- CDCO 5C Collet Chuck yes or no?
- O.T. - Another Robot - But this one is something else!
- O/T I have seen stupid before, but....
- O/T Geometry in nature - not machining related
- O/T Quincy air compressor question
- New Hermes CG4 cutter grinder
- Grinding fixture?
- OT Another good landing
- Uses of the H chair
- How to stop aluminum corrosion
- American Precision Museum Show
- clamping force
- Jacob chuck nomenclature
- 5C collet holder questions
- expensive demonstration
- Acu-Rite Scale Mounting Info ???
- Japanes Dividing Head
- Choice of cutters vs performance
- Chatter on purpose?
- OT: Fabricating an Ice Making Vessel
- Slightly OT - Removing rust stains from UPVC plastic
- Seals Hard to Install
- New member,old machine man
- Wine Cork on the Lathe
- Bending Sheet metal perfectly.
- OT, looking for an external antenna for a Garmin automotive GPS
- Starting drills on centerline in lathe
- OT(?) combustable dust explosions
- Soldering copper to aluminum
- wheel for new (used) bench grinder
- OT- stubby white leds
- Woodwork Power Feed Rollers
- DST Change Battery BS
- Government Liquidation Auction?
- OT: 4 camera surveillance system cheap
- ER Collets for Work Holding
- Down side to a power drawbar.
- PSA - Inspect Your Fire Extinguishers
- Fast pitch lead screw source
- Pinging RussZHC
- Getting the old Bearing out
- Temporary work stand
- Machining? I'm going back to stone caving..
- Chuck runout
- OT but important - PC
- Lead screws
- cost
- How to cut a trough in the face of work
- Feed and Speed Software?
- Scraping exercise: Angle plate (Q's)
- NYC next week - anything of interest :-)?
- OT-Also Prostate Related
- Another humming motor question
- How to fix a bent chip pan
- The Leonardo da Vinci of Robots?
- OT or Not: Art is where you find it
- OT again- laser optics
- Sherline 4400
- I wanted a gallon
- 'Small' mill shopping, comparison.
- Slotting screw heads - favorite slot widths?
- OT- Kidney (and pancreas) transplants and being a donor questions
- Thanks Everybody! (first chips)
- Repairing a round hole which has been elongated
- Wheel for HF grinder
- Glass steam engine
- Absolutely Nothing To Do With Machining
- OT: Sunset at our place
- Radius turner
- Nice little mill/drill
- Billet
- Slide Rule Calculator Review
- all Glass steam engine
- wtb a millrite
- Where to get 2.5" .065" wall 4130 tube?
- For the motorcycle guys.
- Got a new wooden engineers toolbox
- Jensen Interceptor
- Strange Request---
- Tensile strength and Yield strength (pressing copper cones)
- I am insane... bought another lathe... a Rivett
- Van Norman slotting head tooling
- gear-head lathes
- Cutting aluminum extrusions.
- Fixing / resharpening diagonal cutters
- Q: Mitutoyo digimic repair -- encoder position?
- Very OT. Olde worlde little parcels
- Hsm Bbs
- Antique oil cups
- I think I finally got over the making scrap hump...
- OT: I'm a senior member?? What happened?
- ... Continued
- Remaining Pics
- Type of end mills for clear acrylic?
- drawer slides, anyone ever make some?
- what is this used for?
- Q: Colchester Student 6x24
- Mounting open linear bearings
- Ot Drug dealers on Craig's List?
- OT - What Type of Connector/Plug?
- DRO Repair
- Sorry lads - gotta have another gloat
- Slipping leadscrew
- Rivett report
- guidance needed.. square broaching?
- Jet 13x40 gear head lathe
- Huge TV for CAD MONITOR?
- Turning/ Boring insert tool recommendations?
- Where to find a good, cheap live center?
- Uses for Old Kirby Vacuum
- OT - Asteroid
- finishing a plate
- [Electronics HO!!!] Casio FX7500G
- Curious re: larger Chinese machines
- 3D Digitizer Gloat
- Lathe paint
- ? for Evan on PWM circuit
- self-riveting sheet metal
- making a silicone gasket, one side attached one side free
- DIY granite straight edge
- Way OT Computer Question
- I-Beam Prices
- how to light a 20m x 40m riding arena?
- What's causing this problem?
- How do they machine rifeling inside gun barrels.
- My first Mill
- Anyone deal with MSC J&L ?
- Precision 50 Ton 4 Post Press
- Trailer Question ?????
- Car Part ... What is it?
- digital vs dial
- Adapting a spin indexer to my lathe
