View Full Version : General
- Need a little guidance
- Chinese Motor Ratings?
- Vise nut
- Craigslist Captcha box blank
- Foot Switch Danger
- Replacing the carbide insert on a masonry drill?
- cobbled together 240v circuit
- For EddyCurr and those following the 3in1 Machine mods
- Help please, how do you make thread titles bold?
- Rough Milling an Engine Block
- Tightening a drill press quill.
- Flashlight gets really hot
- Drilling more stainless: WOW cutting fluids!
- slitting saw wander
- Odd insert holder
- Bevel gears grease or oil ?
- My all terrain Kalamazoo bandsaw
- HSM in binders.
- Sketchup
- Has anyone done Business with this site?
- Interesting Lego video
- Taking off tiny amounts on a lathe.
- Checking DRo accuracy
- small dc motors
- Sino DRO "5" digit problem solved
- making that spherical camera mount...
- New admin @ hobby- machinst
- Anyone want to help me with my 5-10hp Eddy current dynamometer project?
- Lathe Size vs. Project Size? What's too small?
- little winter project done
- Yet another update - nothing to report, sort of.
- ER32 collet length
- Rotary table or spacer/divider???
- Extracting Taper Pins
- OT: Starbucks from shipping containers
- Lathe repair advice requested
- Where to find a B&S #9 Arbor?
- OT locations
- Newbie with a lathe and needing some advice
- Another Whatsit
- Rebuilding a Craftsman 109.21270 lathe
- Swapping new chinese power feed for old bridgport, hints?
- OT synchronizing sound and video
- 30 years of HSM
- rotary table index plates?
- Where to find Gantry Wheels?
- Lathe threading help
- New hound
- Which dial indicator to buy?
- milling a casting for a lead weight mold
- Craftex Lathe 9"x19"
- no.5 barns lathe
- The Gremlins have struck again.
- 10,000 year clock
- new to me Airco welder
- V twin specials
- A project too far?
- PWM for mill power feed, MOSFET question?
- OT - disassembling a Keurig coffee maker...
- 10" Atlas half nuts in brass?
- Enco jan codes
- CNC Mill Servo Spindle Conversion
- mostly OT - Reading forum, software?
- Rotary abrasive tumbler?
- mounting a dro on a 12x36 lath
- Question about Bridgeport leadscrew nuts
- Faceplate vs. 4 Jaw Chuck
- Need help in Identifying part
- UPS scam, again!
- New site software $$$?
- credit card security #
- How day doo dis?
- OT:Tax question about my new shop
- Need Faceplate
- Tapping Help needed.
- OT : A different type of gloat
- Question for grizzly lathe owners
- Useful keyboard shortcuts
- OT: Cost effective way to ship a 300lb piece of equipment: Nashville TN to Dubuque IA
- retractable threading tool holder
- Solution to Problem
- 1/2-16 acme?
- Steel Recomendation Needed
- Wholesale Tool opinions please?
- O/T Culligan water softener problems
- Material question for DIY H/T furnace
- Aurora forecast for tonight
- epoxy/granite projects
- Mesa Tools
- Boring/Facing head in action
- Tapping head info.
- Single axis DRO
- Help with Brown & Sharpe T/C grinder attachment
- Need rotary table recommendations...
- Pi, errr, Diameter Tape Makers
- Blind Hole Keyway
- Tank sealant??
- New guy - new toy
- Bridgeport Knee binding
- MSC 25% off + free shipping code
- Oerlikon feature, ebay listing
- Special grease for bronze bushing
- Wide flat belt conveyor pully
- VPI paper life?
- WD-40 causes rust ??
- Alexandra Palace Model Engineering Show
- Work holding on a drill press table.
- Digital Readout for an old rockwell mill?
- Air to air heat exchanger for electric dryer
- Dynapath Control Upgrade
- bracket
- Recommend metal Nibbler
- Milling Dovetails
- Real world, common sense CCMT insert experience?
- LP Gas Regulator Question
- Machining a Casting
- looking at some tooling
- question about TNMC 32NV insert
- auto drain for compressor?
- WMW Romania lathe
- Harbor freight spot welder won't work.
- Looking For Rex(?) Tingey Plans
- Semi-OT Heating Fuels
- Correcting external jaw runout?
- Tank lining for vibratory polisher
- Buying and Using Servos
- scrapping a bridgeport
- 13/16-14 Plug or hose fitting
- Norman W. Edmund 1916-2012
- OT Email
- OT: A goldmine of physics toys for free
- Putting a radius in a length of 1/4" rod
- My wife gave her Canon 60D away!
- Magic trick
- Favorite Smart Phone Apps.
- Model / Value of this SB lathe
- CNC questions....
- Replacing Oil in Mill Head?
- On my way back...
- What type of mill for small shop
- Looking for info on press.
- Really tight quill feed on my rockwell
- What is a "Troll"
- Somewhat OT...
- Model Steam Donkey Engine
- Threading Bar
- OT Quiz - Guess what we are building.
- N.American made pump oiler?
- Refinished my baby lathe
- for the black pipe air guys
- Recommended way to attach a captive nut
- Is a rough surface aerodynamically 'slipperier ' than a smooth one?
- Question about brass
- De-rusting drill bits - Electrolysis OK?
- Timing belt speed reducer with changeable pulleys
- Atlas QCGB rebuild: gear/shaft repair question
- OT Sewing Machine Speed Controller
- Lathe test bar
- Lathe Indicator Holder
- Found my angle plate
- Chirping Grizzly G0619 mill?
- Let's see some bench grinder drill & tool sharpeners
- How to accurately value equipment?
- How to level my Mill and Lathe?
- Sort of a gloat.
- OT antique aircraft manual
- good site to follow solar events
- Electroluminescent Sheets and Wires
- Temporary gear repairs
- Ebay seller 800 watt
- Where to you purchase band saw blades
- How would you repair this lathe topslide tapped hole?
- Super Glue Tutorial
- Mid-60's BP power x-feed lube?
- Opinions wanted on multitool & Baileigh grinder
- This is what I want for my Birthday
- Enco free shipping code
- Bridgeport Lube Line Question
- More on Black Iron pipe fittings
- Metric chucking reamers under and over
- Procunier tap machine lead screws
- Gib, shape and material
- Steel sugestion
- Aluminum spring???
- Lathe Chuck Lubrication
- Not getting a good finish when using my craftsman 618
- How do I tell if a tapered roller bearing is good?
- Rotary table quandary...
- Question about propane - supply line
- OT Anyone have experience with laser tape measure?
- Made my first tool today (For squaring my mill head)
- press fit advice from the press fit guru's
- I must be gittin over the hill
- Atlas 10 motor wiring
- Keyways in the Shaper
- Coated Abrasive Belt Lubricants
- Learn something new every day.
- Tap Storage Ideas Needed
- OT - pocket door recommendations
- Check my math,electrical,solar type question
- is there a "for sale" area here?
- Brown & Sharpe #2 Universal Milling Machine
- Does This Guy Realize What He's Doing???
- Question Re: "V" belts:
- Little Propane Forge Complete And Proven
- Look what swallowed my Mill
- tom senior mark 2 milling machine
- Best way to show internal oil passages in a shaft for training aid?
- is it possible?
- Most useful tool you thought you'd never use?
- Closure Recommendations
- Milling slots, do you drill/bore ends holes first?
- Cover for Outdoor Camera
- ID mystery objects please
- Clausing 8520
- OT Swarm of robot quadracopters
- micrometers
- Metal Spinning on Hobby Benchtop lathes?
- Modify CO2 extinguisher to chill steel ?
- What happened to MEK?
- Telescopic Gage Question ???
- Can't Find a Thread....yes I'm search retarded
- Tailstock ID help
- buying direct from CHINA
- How do I calibrate this thing? (Starrett 98-6 Level)
- Locking Y axis...
- New Toy
- Multi-Purpose Touch Probe/Tool Height Setter
- What is your favourite tool
- OT of sorts: Refractometer
- Gear cutting book
- Enco tapping head auto reverse?
- Questions on old live center
- Threaded insert for resin parts?
- Kudos to Grizzly's customer service.
- Darex identification and questions...
- O.T. My New Novel is out
- Lathe headstock taper, anyone recognise?
- CDN Members: Auction 2/07 in Concord, Ont.
- Hieght gauge
- 4-jaw chuck for my Atlas 10"
- Double check my machine lubrication strategy
- How to make a cabinet scraper?
- I think my mill power feed may be a failure...
- Gantry I beam requirements
- Seeing Double
- Kondia Powermill One Shot Oiler
- Enco Superbowl promo code: 20% off orders >$150
- Questions about cutting large transmission case with a plasma torch
- Anyone use Canode blue for scraping?
