View Full Version : General
- Opinions wanted on large 3/4"-1" drill chucks
- Sine Bar Question
- Need to know buffing 101 for dummies
- face mill question
- KX3 Surprises
- Another reason I like vfd drives, Safety
- Portable Band Saw question....tires actually
- has HF cornered the market?
- In the market...
- Metabo bench grinder opinions?
- reboring the hole in a circular saw blade
- OT: For Black Forest, Windmills
- Digital caliper carriage DRO for mini-lathe
- Tilting Milling/DP Vise
- Why is my lathe so good?
- OT- photo interrupter question
- Threading question
- OT Magslips, selsyns, synchros, resolvers.....and auto alternators.
- 10" Atlas back gear
- Another country strives to build machine tool industry..
- Vehicle aircon compressors - how much power do they take?
- Magnetic DRO scale
- Sharp first milling machine
- Last Chance before Scrapping
- Shell mills for 40 taper?
- Advice - Single-point threading 17-4 Stainless
- My daughter's first mill/lathe project
- An Apology
- deep slot milling; coolant?
- Fixture plate for rotary table?
- Is it ok to share projects?
- The Oacillating Belt Sander
- First two projects on my new toys
- Burke Mill-parts needed
- Square D reversing switch help
- thought'd be more useful...
- embarassing moment, sort of
- What are these?
- Taper holding "power"
- Heat treating 17-4 pH for color vs. condition???
- Cubic zircona steam engine
- Paid a visit to Starrett
- Jacobs "N" chucks?
- Clocks and Gear Trains: Design Technique
- OT: Watch what you say around kids!
- OT- Low temp solder?
- Making a table for the mill - iron or steel?
- Drive centers
- Acu-rite III problems, anyone?
- Auto-oiler ideas.
- home made parting tool
- ~!@#$%^&*() Gates belt nomenclature
- Tool for Wire Clamping
- USB microscope
- Gorton mill worth a look?
- Sir John: Your new Bridgeport is ready
- removing roll pin from blind hole
- Proper finish for a heat sink
- Model T Snowmobile Meet
- Enco February Code 20%
- Looking for: Atlas M1-300 Vise Drawings/Dimensions?
- OT Photography-NiMH
- Mr. Monk is here!
- Determining angle via height
- Rolling a hinge in 22 gauge steel
- Making tiny parts
- HSS Threading Tool Rake Angles
- Hand scraping question: time?
- Tiny part I turned down because it was too tiny
- We needed a new rail torch table, so I built one.
- can I slow down a drill press??
- Olympus OM-D for astrophotography
- Is this lathe chuck munted?
- metalfishies: fun little EDC pocket tool and pretty good beginner's project
- Happy Birthday to me
- Why don't you see the old wooden tool chests anymore?
- Best place to buy chuck jaws?
- Back Rake on HSS parting tool?
- Close up Photographs?
- is $450 for a CM 9x20 lathe a good deal
- DRO,s
- XP fonts ?
- Vacation @ N.A.M.E.S.
- Buffing wheel
- Knurling to a diameter
- question about insert screws
- Chuck for dividing head?
- US Patent Office adopts "first to file" system
- Adding hydraulic angling of a dozer blade Part I
- New collet rack project
- Looking for a dynamically balanced steel roller/drum
- [ELECTRONICS HO!!] Need LED project help.
- Machine accessories - can you afford them?
- Machine Tools ala History Channel
- Anyone know about Ab Arboga Maskiner machines?
- Fonts for pantograph
- Which ER collet chuck is stiffer?
- Eletric Motor Help
- Carbide insert for ACME threading
- OT - Woodworking handheld circular saws
- do it yourself coolant system
- my attempt at scraping a straight edge (video)
- Cheap EMCO lathe in Massachusetts...
- OT - Bizarre Behavior of Web Browsers
- OT question for an electrical engineer
- 8620 Ht?
- O/T HP to IPAD SYNC
- First come, first served, with one exception
- HSS threading tool grind
- Helix Angle I don’t get it.
- I kinda got my a$$ reamed for
- Emco Maximat opinions???
- Excitement at my shop today.
- Is ther such thing as a CNC REPAIR company???
- Insert boring bar design confusion
- OT- spec on this mosfet
- Renewing Scrap
- More OT- you tube and internet freeze
- Carbide insert endmill?
- High density/mass material
- biax bl 40 scraper
- Air Nibbler Punch - Repair?
- Neat machine
- First multi part lathe project.
- Babbage's Mechanical Notation - Modern Successors?
- Servo 150 problems?
- How hard is it to mill a QCTP holder
- Sanding Belt Recommendations Needed
- interesting eBay pricing
- I bought a milling machine. Now what?
- Rhodes Shaper on E-bay
- save a shaper
- Using LED lights for shop lighting?
- McMaster-Carr Catalog
- Tailstock turret disassembly help.
- Bending 1/8" aluminum flat bar.
- Whole sale tool Vertical mill
- Tapered bronze bearings?
- Lorch 8mm WW Watchmakers Lathe
- Swarf control on a mill.
- OT fun with ziploc bags
- A recent project I completed.
- ordered the Canode
- Stirling hot air wall fan
- Keyway questions
- Glue made for Polyethylene
- Tractor hole digger repair
- OT E-mail Hacked
- ENCO Free Shipping Any Size Order - 3 days only
- New idea?
- OT:Astrophotos
- single point diamond dresser
- MicroCentric air chuck?
- Nylon Screw: Fine or Coarse Thread?
- Hi everyone.
- food grade stainless holed sheet
- RIDGID Li-Ion vs DeWalt 18V NiCd
- First success
- Extremely High Electric Bill
- Help with modifying back plate internal threads..
- OT: ...Sort of..Learning CAD Software
- OT Chronic Pain
- Con rod query
- curious: how many grinders do you have?
- Blew it!
- buying a 4 jaw chuck
- Cool lil Grizzly mill...
- Calling Shiraz,President of Grizzly
- Alignment Issue
- Shaper alert - GSA in ME
- CAD Drawings.... Sort of.
- Variable Speed Belt Drive
- Unusual Activity
- private message
- Haimer 3D Taster (sensor) replacement probes
- Craftsman Lathe, SB 9" question
- Magnetic Floor Sweeper On Sale
- Jib crane for the lathe.
- shop frustrations
- Welding cart tires
- OT:Sarpening rotary cutter blades
- Suggestions for cutting an Aluminum circle
- O-1 Steel Heat Treatment Question
- Micro DRO
- Precision Mathews 11x27vf
- High Speed Spindle FAQ
- OT: Chang Jiang M1S
- Mystery Object
- Heads Up--Clausing 8520 in Vancouver Area..
- ordering replacement tooling
- Dividing Head: Universal versus Semi-Universal
- Transformer question
- Homebuilt radial engine
- OT Regulator Repair
- Lifting with a boat winch....
- Home Shop Machinist magazine
- hand threading
- Boring a partially tapered hole?
- I went back to work this week
- Case hardening basics
- I heard a new one today
- My newest addition
- Critique my reference sheet
- like, totally man!
- why do parallels have holes?
- 660 bronze or oilite?
- Lathe chart
- Bridgeport Variable Speed Drive Questions
- How to Lap Micrometer Faces?
- fowler micrometer help
- Poor Mans DRO ?
- 4 way electric/cnc tool post
- Drill/mill, the tool NOT the machine plus noob mill question
- Micro Mill Giving Me Problems
- How do I drill hole to a certain depth?
- We're Back
- First Project Wheel Chair (Dog)
- Restoration / Reproduction of Old Labels & Decals
- Nearly got killed today!
- emco compact 10 collet closer
- John Stevenson a question
- OT Plumbing-Re-crimp PEX fittings?
- Ni-Cad Batteries
- sine bar parallel
- 16th Annual NEMES Model Engineering Show
- what are the two most important machines to start your shop?
- Grizzly Bandsaw mods and (pics)
- OK, tried the Canode blue
- Google by-passing IE (and others?):
- Bridge crane
- Building a Mini Dozer
- Are these threading dies defective?
- coolant pump
- Invasion of the Spammers
- Electric experts.. Question
- OT-Making a Sapling Puller
- Advice on Building an Elevator
- look what I found in my surface plate
- Weld In Tank Bungs
- West Cleveland Metal Workers
- Vertical vs Horizontal Mill???
- Nice job lot
- OT - some what
- OT, glass sight gauge for water tank?
- Arbor Press Modification
- Oil, Water, Air Hardening Steel for Turning Tools
- How to measure runout on an abrasive surface?
- Proper Storage of Grinding Wheels
- Heat treating/Welding question
- Can this part be made in a home shop?
