View Full Version : General
- Old School Accuracy?
- This may sound silly but....
- drilling indexing holes in backplate?
- Sherline 8.0mm collet fixture - steel? aluminum?
- Help with hydraulic pump
- I cut the openings in the large transmission case....
- Insert tools - Before I post to fleabay
- Does stalling a motor cause any damage?
- Stuart Abrazor?
- Time for an engine expert....
- Yet Another Shameless Tool Gloat.
- Grizzly Mill GO916
- Mill vise trays and T slot covers
- Headstock Oil for Eisen Lathe in 1-Gal. Jugs?
- Yet another vfd question
- OT- bright colors in the shop
- Dumb question I have.
- OT We All Should Look @ This.
- Questions about mounting a VFD
- Which machine to cut a rack ?
- Help choosing an insert
- Converting a non-screwcutting lathe to CNC?
- 2 strokes
- Milling machine brake
- Polycarbonate Shrinkage?
- Looking for 500 lb chain fall
- Yet Another IC Engine "Breakhrough"
- OT- Looking for a Light weight, long reach manlift
- Looking for Filter Material for a Belt Sander
- Cell phone tracking.
- My attempt at screw jacks and ACME...
- RANT Sort of on topic Timing Belts and 4 Valve Heads
- OT: New Toy At Work -- Injection Molding Press
- Interesting projects site:
- Another "someone has too much free time" engine conversion
- Miniature Hardware and materials
- My Fray rebuild - its done
- Re-Tram Rigid Head Mill
- Compressor gloat
- Lifting ideas for somewhat heavy items and small spaces
- 303 stainless cracked after boring
- OT: Other auto belts that are stupider than timing belts
- Cleaning a Machine Tool.
- Making an R8 arbor
- enco shipping code for march
- How I made a spindle square.
- The BOYE is home! & pics of the Jewelers lathe
- OT: rheostat/thermostat for incubator
- Question on Craigs list tool...
- Recreational Rigging--Moving a Mill
- Forum problem?
- Couple Jet 1024 question???
- M2al Hss?
- lathe DOC question
- A better vise than the Kurt?
- RE: McMaster-Carr Catalogs
- Finger Lights
- OT: Setting up a login website?
- Library Book Sales
- tap buying help please
- motor speeds
- Got the American home!
- Deburring Question
- My Tool Gloat Air Bearing Spindle
- Small abrasive cut-off saw
- Is there a rising interest in low cutting force interests?
- Gear Grinding
- OT - Washing machine recommendation?
- Intro and first post
- Need Help With Drills For Hardened Steel
- Tongue & Groove chuck Jaws?
- Spindle question
- Clausing 5900 disassembly for move
- Bolt size
- How would you build this? A prosthetic attachment
- Carriage Wheel Spins under load???
- Robotic cow milker
- $900 Hardinge HLV H that I am passing up
- Stud installer?
- Vibration finally fixed!
- Threading to a point?
- Series 1 BP J head quill feed inquiry
- This looks good for a mill table
- How much for a Colchester Chipmaster ????
- How to weld delrin gear
- KBIC DC controller/chopsaw motor question
- This should be Brian Rupnow's next project
- Noob Question: "Washboard" finish?
- Cant see Practical Machinist
- Need info on HF Combination Step Block and Clamp Set - 3/8"-16 NC Studs, 1/2" Clamps
- anyone interested or heard of this?
- A GREAT hand-made lathe!
- 4130 steel - simply poor machinability or...
- Help Identify Brown & Sharpe Dividing Head
- Worster Lathe Co.????
- help with this forum display.
- Mill Fixturing
- single lip countersink tool - sharpen?
- newbie mill question.
- Burnerd Collet Chuck key -- you have one?
- Speeds/Feeds different for milling vs. turning?
- any model cannon buffs?
- source for polycarbonate/lexan tube
- What size clamp kit for my Ab Arborga Maskiner mill?
- One more blooming wire-tie tool
- Grizzly Lathe Options
- Need a Tip: How to Lightly Oil a Lot of Small Screws
- How to set head angle on a mill?
- PSA Zero!
- Set Screw in R-8 Bridgeport Quill
- O/T for the old car guys:
- colchester student headstock MT5??
- Problem with "New Posts" function
- UK 3 phase question static convertor transwave etc
- I helped rescue an old Dake 102 arbor press
- 2 inch x 8 TPI backplate
- a place for unknow machines
- inverted V ways
- Munroe effect cone testing.
- B&S #9 collets
- 'lectrical stuff, control panel art
- Changes
- 3AT collet setup...
- Lighted Magnifier for tired eyes $1.09/delv
- P&W Collets
- Yay! Bought a "real" CNC lathe project!
- Tip: Analog Clock Face as a Protractor
- Testing hardening results
- L0 dog drive face plate! & 5c collet chuck?
- How would you fix this
- Need some 4C collets...
- OT: Ribbon Cable Repair
- Interesting Project
- Now this is nice
- chuck key for craftsman four jaw chuck
- Short throw, leakproof hydraulic actuator
- Standard brazing rod
- ID lathe
- 1/2" aluminum
- Help me understand the collets on my Maskiner mill.
- Tungaloy, workin' GOOD today.
- Tips for scrap-ing
- O/T Wood mill
- Michigan tornadoes:
- Bandsaw - More of my stupidity
- need ID help please
- Electrical poser; sharpen your pencils.
- Pluses and minuses for Kitts Tools Co.
- WOT (way off topic) need some music help.
- uses for a boring head on a lathe
- Naive question about parallels
- Happy to find HSM collection..
- Sheet Metal 3-in-ones... what sizes?
- "New" Machine Day!
- Hercules 3 L V milling machine
- info on charts
- tailstock centering article
- 3/4" pipe tap in ABS
- CNC Mill fix
- Temperature control
- Die Pin thingamajigs - whats the correct name?
- phase converter???
- New shop, with NO electricity. = $$$$$
- O1 - Hardening, Oxy-Acetylene & Knurled Workpiece
- Complaint about forum format and animated ads
- Need Material for Spring
- Deleting a post?
- Carburetor improvements
- Turning a Morse taper...
- After a Long Time
- Can I braze/solder to a impact socket?
- Sleeving my throttle bodies (lots of pictures)
- O1 tool steel
- File metal flush
- Forum changes: please take a look at Search from an iPhone
- Terminology for pal nut type washer
- My Japanese Mill
- Boring head hardness
- knives
- [Giant Machine Porn] Curtiss Wright, 12,000 ton extrusion press, and Buffalo NY.
- 7/16" British standard Pipe
- 3 phase motor & hp question.
- Cycletrol 150 DC motor control?
- Drill-Index, hole spacing?
- Question about micro switches and emergency stops
- strange sounds
- O.T. fire extinguisher question...
- Boyar Schultz parts?
- Ad says J-head but looks like an M?
- finishing off a thread
- hand honing tips for cylinders needed
- Determining Taper in Headstock
- Today at the building supply store
- ot: wifi etc.
- WW / 8mm collets and edge finding
- New to me mill
- QCGB repair?
- Any UK people know this company?
- cold saw woes
- footswitch question
- I couldn't believe my eyes when I saw this
- Hearing protectors recommendation
- [Machine Porn] Warning, not for the faint of heart...
- 4" rotary table
- Problem settimg up IMO VFD
- Total OT - comic relief
- ot: Iowa resident
- Sump Pumps
- Request from a friend: safety gloves for knife-sharpening.
- No More EBay Bucks!!!!
- End of an era, end of printed encyclopedias
- Enco 12x36 lathe motor quit
- atlas/craftsman 618 accuracy
- 123 blocks, 11 or 23 hole?
- OT - Anyone seen the Doomsday Bunker Show?
- Looked Easy But....
- Boring head
- Long Chang replacement parts
- What do you guys do with a rotary table?
- OT: This should be interesting
- State of the art accuracy 60 years ago?
- PM issue, (private msg)
- [Windows XP] [Computer Fail] Windows forgot my password
- Shop made all-thread
- Old Bport vise or chinese angle lock?
- Link belt.... Help!
- past issues of HSM
- circlip grooves
- Gear cutting
- Pictures in post
- OT- Goo in the fuel tank
- Source for durable/hi-flex stepper motor wire?
- Stevenson's Soft Dentures
- PM
- Calculate multi pulley/spindle speed...how?
- Potential Security Threat
- New blocks on the kid?
- Way OT: New "How to drive" info
- Broach bushing standards?
- How Hot before stopping?
- my grizzly G3616 Mill is dead
- ot: tunnel digging as a hobby
- Had to try it.
- If all goes well....new(to me) Rivett 1020S Saturday
- Gib Screw
- Quick'n'dirty
- How Does A Speed Control For Flex Shaft Grinder Work?
- Anyone know a Affordable VFD for a 1hp Bport?
- Outside chuck jaws up for grabs ---
