View Full Version : General
- hand powered fork lift
- Need Encoder for Mach3 Threading
- Adjustable height welding table ideas?
- Daton Tool Gloat
- Exciting New Use Found For Cats
- A turning mystery
- OT: Hot Rod Power Tour
- OT: Truck tractor burnt to the ground
- OT, But maybe helpful to the non computer experts here?
- O/T Small 2 cycle engine:
- Current Enco codes?
- 70th Anniversary Battle of Midway
- New guy with yes, an Atlas.
- Lubeing an Electric Motor
- OT did you ever get that feeling
- Willis lathes questions
- Nozzle for plastic injection machine
- Want to make a collet chuck...
- HELP, mill emergency
- New member: a short intro
- Sigourmey M-100 Sensitive Drilling Machine
- Off topic charities do they deserve our money yes or no?
- Link belt Mower Deck
- M18x24 dowel pin?
- gloat but kinda o/t (chisels)
- OT but useful I think - PU spare tire holders
- Question re stripping paint with pressure washer
- Need advice and suggestions..Moving BP mill...
- Birk Petersen
- Solar plane completes 17 hour intercontinental flight
- Setting top slide angle accurately.
- Rebuild Bridgeport Mill near Florida
- Boring Head Question
- Spool gun work
- Way OT: Traffic counter hose layout question
- OT But Im Happy
- Albrecht chuck rebuild questions...
- Tilting or angle vise for mill
- any 14" South Bend owners?
- Advantage of a Lantern Toolpost?
- Replacing drive pulley?
- Pipe union question: oil, dope, or...
- OT Help with truck eletrical problem
- Where to get small stainless rod?
- Southbend MT3 Collet Chuck
- Last part of the big grill...charcoal pans
- Tachometer/speedometer cable source?
- Tubing for Bike Forks
- The Belt Sander saw!
- How are thin precision tubes made?
- Machine moving UK Style
- Anyone familiar with both a 10" and 12" Atlas?
- VFD questions for a clausing 8520 mill
- spindle grease
- OT: Another probability question
- Bad idea?
- OT: Special Information Tones, DTMF Keypad Sequence
- Crowned Pulley Specs?
- gasoline tank material
- Knurling 4140
- Cutting lathe toolbits to size... dremel?
- Power supply inductor query.
- OT goggle chrome
- OT: Garage door opener rolling code question....more probability??
- How do I make a worm?
- OT Air bag fitment in vehicles.
- OT. The Friday Puzzle
- DROs left on?
- Motorcycle Question
- OT Click & Clack
- [COMPUTERS!!!] Image Recognition Software
- Repairing milling attachment for Craftsman/atlas lathe
- do boring bars need hardening?
- Is there a long taper spindle mount smaller than L-00?
- OT-Interesting stuff for motorheads, F1 vs. Nascar engines.
- Standard Modern Lathes
- surface grinder chuck
- Help with Marv Klotz software
- Paintless repair tools
- Topical, But A Dumb Question
- J+S 540 Voltage question?
- On screen measurement software recommendation
- helical gears I made
- Epistle on electric motor bearings part 1
- We got there!
- Making a worm and gear for a Sheldon lathe
- My latest find. . .Buffalo Forge Co post drill press
- How to flare EMT pipe.
- Attitude
- Propane vs MAPP substitute
- Funky dial gauge fitting
- I need to find some software
- Extreme closeup video of metal cutting
- OT; FiFi just flew over the house
- Kinda O/T gloat
- Truck Shows, B-29s and Battle of Midway
- washboard roads
- Rotary table
- OT: UK AAIB is 100 years old, re-publishes first report
- Riser Block for a Mill/Drill
- Cutting Nylon with horizontal bandsaw.
- OT Inbox.com
- Way OT, Bidet toilet seat.
- Probably OT: Tree Finder
- I made adjustable "feet" for my BP...
- This is interesting
- machining pulley sheaves
- Pneumatic cylinder construction?
- An interesting tool idea, only partially mine...
- Solder alloy question
- Opinions?
- Tips for turning parts on manual lathes from CTE Mag.
- help with split nut on BP
- Wooden Handles for Cast Iron Camelback Straight Edge?
- No more floating propane tanks, and I used some of the cursed curved angles
- calling OIL MAC-Dan God shave the queen
- BP home...Pics of the drop trailer for those interested..
- OT: building a rain barrel
- beefing up a small lathe
- Metal Cutting Video
- Tons of gear info here
- Advise on remodeling a shed into a shop
- Odd Government Grant?
- One Shot Lube System Question
- ENCO 20% Savings
- Metal Bangers
- I need shed help? advice
- Need advice on threads w/o chasing dial
- Lathe pulley repair with pics
- Lathe bed extension
- What exactly do I need for VFD and bridgeport?
- Closeup of lathe cutting tool at work
- Beaver milling machine
- The old arguments
- Tool gloat - auction
- American Pacemaker lathe
- Why not a used larger lathe?
- Reversible Tapping Heads
- flat graphite
- Bad day in the shop
- Bower Machine Scope
- properties of materials
- Making new/replacement brass name plates?
- Procunier, ETTCO, Enco, Chinese tapping heads
- Square D Breaker Specs: For Shop
- what does this lathe look like and why is it not making more money??
- Catch of the day! Doctor needed!
- I went to an auction today..
- New tool post
- spring power
- Sad day for Canadian woodworkers
- O.T. Potential generator concerns
- OT : Overpaid?
- my new shed
- OT: European socialist governments
- Boxford CUD to BUD?
- successful treadmill conversion
- Identifying cast iron or cast steel ??
- electric jack
- drill chuck key "blues"
- Drawer liner smells like skunk....
- Somthing new from paypal..
- Harrison 600 Univeral Mill
- OT; tired of getting junk in your keyboard?
- Slowly getting there
- 58 Bridgeport knee question
- upgrading shop power
- The two collars test in a lathe factory....... Hendy factory tour
- Masonry vs. Metal Grinding Wheels
- Is this lathe worth buying???
- Craftsman Univesal Wrenches (914018)
- A scam I think, O/T
- OT problem with Utube vids after 11.3 flash upgrade
- Got some new indicators
- Spring loaded ball oil zerts
- OT 2000 Ford f-350 transmission
- OT. Need some electric help.
- Mill drill advice, if you please.
- You guys tempted by treadmill mtor drive
- Favor Please-Logan Leadscrew measurement
- Hit and miss engined go-kart
- 13" South Bend in North Florida on CL
- Cleaning up a bridge anvil
- E-bay question
- timing belt of Bport, what does it time?
- O/T Home mold problem
- OT sargent & greenleaf lock on gun safe
- Free Shipping at MSC
- Jacobs No 16 ball bearing dismantle
- Surface grinder search
- knurl info
- Got a treadmill motor,now what?
- Incra - precision rule sets
- OT: self gloat
- Plastic stress relief
- Making a wheel to go with a worm gear
- Jacob's chuck and center drill: the drill press farce continues....
- Yet another treadmill motor question!
- Mounting 3-Jaw To Rotary Table
- Fan motor wiring help
- Scraping question
- End Mill Brand quality
- My Tool Haul...
- Ridgid ratchet pipe threader question
- ?? VFD 110V in/220V out / spindle options for DIY CNC machine ??
- Bargain Bridgeport - Springfield, Missouri.
- Pinning mill vise to table?
- sort of o/t, low voltage d.c. question
- Help with screwy four jaw chuck
- OT Clumsy Bastard.
- Trigonometry Calculator
- Slinky spring toy
- shopbuilt garden sprinklers, material selection
- Hobart C-250 Mig Welder
- OT: Question about a large propane tank with chamber inside
- dealing with muffler heat
- positive root agitator
- Remote Driveway gate opener ??
- New (to me) horizontal mill
- Using chalk around a lathe
- motor reversed wo change
- powder coat painting attempt
- Pratt Burnerd Three Jaw Chuck Cleaning
- OT - HVAC power question
- Possible tool gloat? Good price on a M5 darex sharpener?
- Want to learn how to cast metal
- Vee belt pulley specs
- Worm and wheel, revised.
- OT Track day fun
- Testing/information on hydraulic pump
- UK plastic prototyper recommendation?
- Responsibly disposing of fluids and waste
- Question on WWII mobile machine shops
- Slightly OT
- Vacuum Tanks
- Wiring Question
- Adcock and Shipley 1ES
- Return springs for Encos,Grizzly,rong Fu etc...
- A Waterwheel Tale---
- Canadian Post Office and Evan
- Craftsman 109 / AA Lathe Question
- Aluminum Epoxy?
- 1 1/2 Morse Taper
- craigs list item i think i want
- What material to use for these?
- Question about Prussian Blue
- 1/2 gloat 1/2 project
- ER or MT collets
- Maybe, the problem with vacuum, flame eater, atmospheric engines?
- 5S gloat
