View Full Version : General
- My Lathe is uglier than your Lathe!
- Speaking of water power
- Sandblasters...
- Large stationary steam engine fully explained.
- Kondia right angle attachment
- Epoxy counter tops?
- Progress on the mill
- Tapping 3/4 pipe threads in 416 Stainless
- Sorting and storing small drills <.060
- Who thinks George should lift the ban on Nick?
- A Small Grinder
- lapping paste in oil suspension.
- Grinder - continued
- Laser Gloat!
- Got a killer deal on an Emco V13 today...
- HSM Rigging: Hindsight is 20/20
- making a gas tank
- Converted 9C to almost a 9A
- OT Tropical Depresion Debbie
- Honing in a lathe
- Need help identifying odd fitting
- Cheap digital Ultrasonic thickness units
- Electrolysis Question
- Musical Instrument Museum
- Oliver Spinning Lathe 159M
- Can't see the plate inside the cover...
- Diamond Tool Holder
- South Bend Quick Change Collet chuck from Grizzly
- It's true... apparently one never DOES have enough tools
- Jet 124(?) Metal Lathe
- Zerust plastic storage boxes?
- Martin Model castings
- Electrolysis - that went wrong...
- When you don't have a chip conveyor....
- OT: annihilating the moon would solve virtually all of the world's problems
- Anybody got a parts manual for a Dake Dura-Press Force 10 press?
- OT: Nutso packaging drives me crazy.
- I need some material
- holes?????
- clipper belt lacer 0-6
- Mendocino Motor - The Build Continues
- A roundabout way:
- Steel + Aluminum ok?
- bob cad
- Metric threads on an imperial lathe (Oh now! not again!)
- Is it just me, or has Google been sucking recently? (For machining content)
- Anyone made a trommel?
- Tool post ?
- things cast in aluminum
- Bandsaw blade brush?
- For the Electrical Guru`s
- Tailstock barrel repair
- shopmade hydraulic press video
- Rigging and mileage
- Degree conversion help
- Human powered helicopter :)
- Making rubber bits
- OT: GM V6 motors
- Do they make a nut for this
- how do lever collet closers work?
- Getting 58' bridgeport set up and somthing is missing
- Hacked account
- Wired remote control/electronics
- Enco Free Shipping Code
- Looking for Sieg Milling machine owners
- F1 Car Cut in Half
- Hardinge mill ?
- Very basic threading question
- Vernon Shaper
- OT fuel economy vs. emissions
- O/T Nuther Pet story
- Linear Shafts Oxidized near electrical fire?
- Summer and Winter
- British isles resisence
- rotary valve/steam chest
- bench vise (vice) nut retaining pin?
- Gooseneck & rigidity?
- who uses G7160 Machine Mount grizzly
- Doorbell Problem
- Rebuilding an engine in 2 minutes
- OT: Any herpetologists on the forum?
- Tool gloat
- Electroloysis update
- What I learned yesterday
- A Triumph of animation
- OT: napalm with camping stove,
- How to Drill Accuretly
- OT Is there any hope?
- Rolling pin for the wife
- The "new" photobucket, IMG code links, and sideways scrolling.
- Machining Cast Aluminum
- Adventures in Engine Turning
- "the tool that can reproduce itself"
- Tool Gloat!
- OT- Generator troubleshooting question.
- Making chips finally
- OT - What Not to Say
- Camera lens question
- OT - Ethanol, a scam?
- Change gear ID?
- Slightly OT - Miller CP300
- Navy training at the Rouge
- Cutting a 2 mm pitch on an imperial lathe
- Best material (metal) for model train wheels?
- Starter Ring Gear Question
- MSC promo code: 25% off + free shipping
- Looking for precision keyless chuck for drill press
- Emco Maximat V10P lahe motor
- john was correct all along I am a clumsy bar steward
- This is getting out of hand....
- OT: Roads, they need some work.
- OT mold non-release compound
- Interesting old gear construction
- Weight of Steel.
- Looking at mini mill’s I am down to 2 units
- Insert recommendation
- need a tool fix ? then read on
- Bandsaw blade direction - does it matter?
- OT Sticky UK pub tables
- My 1st paying job!
- 1980 Boxford Redo
- 6 cycle engine article
- Deutches Museum of technology, Munich, Germany
- All this for $1 on CL...
- OT For all my Golfing/Machining buddies
- Happy & safe 4th for all!
- Craigslist machinery ad
- Small project
- Wooden Helicopter blades?
- Noobie here, looking for info......
- OT - Vobfus PC virus
- OT: European Researchers Claim Discovery of Higgs Boson
- Woodruff cutter use
- Floating Tap and Reamer Holder
- European sources for Imperial machine screws
- Mystery Metal
- Wheel stud material
- Got the K&T Mill Put in the Garage Today
- Walgreens?
- OT: You need this tool...
- The Great Shop Move, Part II
- Another clumsy bar steward.
- Found affordable rotary broach, any feedback
- Paging 90LX_Notch...
- A great toy
- Interference for heat fit
- What is this pan for?
- Question for the bearing gurus
- Can't get clothes clean
- Wood lathe with granite base??
- Focus on calipers
- OT- Wax On, Wax Off
- Opinions Needed.....New End Mill or Used
- Aluminum tubing flaring
- Rockwell Surface Grinder
- Anyone deal with Indiana Oxygen?
- Jacobs Chuck Repair
- Little tool gloat, and question
- Sort of OT, Tubing Bender
- Finally!
- paper interface
- Hobart Beta 250 mig welder
- Name this item!
- OT--How many axes of motion do you need to get this degree of freedom?
- I.D. anyone?
- Currently Active Users: (79 members and 323 guests)
- No one in Great Britain making cast bullet stuff?
- diy chamfered EM's cutting well
- Looking for some heavy scrap plate?
- OT Loaded ammo puller
- cutting tool help, please
- OT, plane trip
- Surface Grinder
- Carbide tips
- Fatigue-proof, grade 8 bolt, or...
- Don't you just love it when vendors change parts and don't tell you?
- Please recommend a keyless chuck for a 3 in 1 machine
- May be a Tool Glote
- A Great Toy #2
- OT? Does Motor Oil Age?
- Telescope gage trouble partly identified....
- Why do some people WANT to appear Illiterate?
- Emco FB-2 Stand?
- 2 questions for you smart folk...Gap needed for plain bearings and a PVC question
- Machinery's Handbook Question.
- griding my tools
- grinding my tools
- grinding my tos
- visitor/member data
- Cam chain
- OT: U.S. Navy LCAC in action
- OT - A nice collection of aircraft...
- Water resistent machine lights
- Wilton vise disassembly problem
- Grizzly Lathe Assembly
- Brazing Iron?
- AXA toolpost recommendation?
- Old Oil: NO! But What About Old AntiFreeze?
- thomson bearings
- OT......Smart vs Dumb
- Grey Pearlitic cast iron
- "PAL" Vertical Mill by Hunter Prince
- DIY Bullet Puller
- Powering the leadscrew, which parts?
- 45' pipe fitting in lathe
- Is your smart phone your friend?
- What brand:auto center punch?
- Pulleys, RPM, counter shaft etc...
- Dug Up Another Backyard Treasure
- I have broken 2 taps this month... WTF
- Cheap chinese rotary tables?
- facing a large pipe
- Smells of a coal fired boiler
- OT Crank needed - 276 Desoto Hemi
- OT..... Photochromic Lenses
- Confusion!! re: Air filters, coalescing filters, desiccant dryers, water separators
- Enco 15% Off – No Exclusions?
- Decent Fuel Pump
- OT - Metal? Mysterium? Cannonball?
- Drill rod, for brake rod
- OT- fiberglassing .001
- OT: Fractal images
- Engine Flushing?
- Slicer software
- Do you charge for clean up time?
- How to set two leg type calipers..?
- Made a work stop for my lathe.
- Fukushima Report - OT
- What else do you call it?
- Another bad paintjob!
- Slightly OT, the latest rabbit hole to go down....
- Is this Arbor too far gone? (image attached)
- OT - Replacement eye cups for a Nikon binocular (where to buy)
- diameter of rod for hand thread
- Brian builds an Atkinson Engine
- X class solar flare plume headed this way
- Digital Machinist Magazine
- acronym meaning
- manual for Hughes model 1 tubing bender?
- Very OT: need technical and legal help with police misconduct complaint
- OT - Plastic Tarps
- OT : Riggers Needed
- Bridgeport Optical Measuring System
- Hardinge Lathe, what model is it ???
- Revitalizing old hard red rubber suction cups.
- buck chuck grip
- New use for your SHAPER
- Fuel pump for welder engine
- Rather strange sizes of taps and dies
- Delrin/acetal and gasoline
