View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 [203] 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Surface Plate Ledges
  2. Considering a small Bridgeport
  3. Need Ideas For Dog Drive
  4. Vertex 8" Rotab CNC help needed
  5. What to do with a wife like this?
  6. Has anyone added a taper attachment to a G9249
  7. Small Gloat. Tapping head
  8. Own a Grizzly G5960 or G7958 Lathe?
  9. Opinions on Drill Sharpening Tools
  10. EZ Tram revisited
  11. Press Article
  12. Core Drill How much can it enlarge an existing hole
  13. Semi OT - Wood Working Project: A Christmas Gift (Easily made in machine shop!)
  14. Wade CAV Lathe
  15. DRO for milling machine
  16. KO LEE S612 surface grinder help
  17. Atlas lathe, special purpose
  18. Cool thingy for hand drilling a straight hole for fellow far-sighted Machinists.
  19. Oil or sawing fluid for non production bandsawing?
  20. How do you cut small diameter round stock?
  21. DRO Glass v Magnetic Scales
  22. welder machinist
  23. Need a US address and email address.
  24. cutting metric threads on a 12x36 lathe
  25. Anyone know what this tool is?
  26. Worden Grinder
  27. Ummm .. thats pretty good accuracy
  28. grinder configurations
  29. OT- Priming Bulb
  30. OT - The Use of this Site is Becoming User Un-Freindly
  31. Tired of snow. you need to make this
  32. OT - Ebay Postage from China
  33. I want to build a hydraulic hanging scale, need a little help
  34. Steel Supplier in CT and MA
  35. Manual Bridgeport Series One 2J Head CNC Retrofit
  36. What will the New Year bring?
  37. Machine leveling pads
  38. Delco Electric Bench Grinder
  39. Removal of Albrecht chuck from Hamilton Drill press
  40. Curious as to how this part was cast, and from what.
  41. Tramming in reverse
  42. What is a "muffled" oven?
  43. OT: Need help sourcing a motor
  44. Need help identifying an insert hold down screw
  45. Clamp gloat
  46. Need dimensions for BXA / 200 tool post
  47. Potential tool porn:CNC tube bender
  48. Older Brown & Sharpe "Made in England" = Moore & Wright?
  49. Evo cold saw or the cheap harbor freight 80 dollar version (carbide tipped circ. saw)
  50. Rigging info
  51. Secrets of a Garden Sprayer Pump.
  52. scraping
  53. High Vacuum Pumps
  54. Rocket Track Tolerance
  55. I'm guna buy a case of this stuff
  56. Lathe installation
  57. OT- looking for cool machine shop poster 24x36 portrait
  58. MT4 collets?
  59. When is the Cabin Fever Expo in Yorktown,Pa.?
  60. Are power feed motors the same as CNC servos?
  61. Drilling Acrylic
  62. OT: hand bubblers
  63. Construction Of 12-inch Gun On U.S.S. Texas
  64. Can hot-rolled steel become a good straight edge?
  65. Drilling normal to a conic?
  66. My First Video Model Shaper
  67. MSC - Parmount tools
  68. 5C to Cat30 adaptor
  69. Plastic Injection I’m getting closer!!!
  70. Mills & Lathes - what to get vs avoid
  71. RF-45 and clone info needed
  72. Backhoe repair/welder question
  73. LegoMill
  74. "Made in an ISO9001 Factory"
  75. D Bit question
  76. 19" x-axis bed travel requirement?
  77. Ear protection
  78. Honing lathe tools for best surface finish?
  79. Testing furnace heat exchanger
  80. Fits - Bearings and Shafts
  81. OT - Circuit tracer
  82. De-burring file
  83. Its been a loooonnnng Holiday
  84. tramming the mill with a brake rotor
  85. Twice as nice!
  86. Made in the US making a comeback
  87. more on the Big E
  88. Acquiring cast iron
  89. Become a machinist, 1942 style.
  90. Need help with a 3 in 1 machine and tools.
  91. belt grinder
  92. Enlarging hole in carbide disc
  93. Elliott no 5 T & C grinder what voltage ???
  94. Any One Having Trouble With Ebay Searches????
  95. Anyone have an Enco code for January?
  96. non cnc plasma tracer (new)
  97. Grizzley G0484 mill
  98. More gears! WOO HOO!
  99. Question On Diamond Nibs
  100. Hello from New Zealand.
  101. Metal Suppliers (Central Indiana)?
  102. Lapping vs sanding vs scraping to improve cross-slide, compound
  103. QC Keychain...how it's made?
  104. Where is Evan?
  105. Breaking the Mold: Could Additive Manufacturing Resuscitate a Once-Proud U.S. Industr
  106. Dr Demo
  107. Semi-OT: Making a Straight Edge / Saw Guide?
  108. Slotter for Lathe
  109. straight edge for scraping
  110. Skew bevel gears
  111. Broach Styles (A, B, C, etc.). . .what's the difference?
  112. MT4 collets so far...
  113. I need ideas how to make a miniature linear motion damping cylinder
  114. Crowdsourcing: Anyone tried it?
  115. Plastic injection mold allowances
  116. Completely OT - (Spawned from Grind Hard's thread!) Cool Microcontroller!
  117. Crummy lumpy bondo finish
  118. Lathe insert quickly going bad
  119. Scraping questions from youtube video
  120. Ingenious Mechanisms
  121. Blasting and polishing.
  122. Amazon ad gone and I'm back
  123. OT Drove Jeep without air filter of 6000 mi, now what?
  124. Anybody Know the Meaning of "Octoid" as Applies to Gears?
  125. Need dimensions for wire crimping die
  126. Stepper motors
  127. Any Experience With a Type STVO Toolholder?
  128. care and feeding of granite surface plates??
  129. Once an old car guy - always an old car guy
  130. OT: Did anyone ever produce a DART rotary engine?
  131. Ball Turner Design - Opinions?
  132. How to Trim Al. Edges
  133. Computer Aided Drafting
  134. Carbide Bit? Help....
  135. Thread measuring wires - an idea for you
  136. Shop Safety: An Idea
  137. Runout question
  138. ball bearing ratings- odd use
  139. OT PM Irony
  140. Cooling down a mini-mill motor
  141. Grinding wheel arbor size help
  142. patternmakers vice
  143. Newbie question on tool holders (how impracticle would this be?)
  144. Questions about leveling my lathe.
  145. Quill stop
  146. Parallel's, recommendations and grinding wheels.
  147. starter motor armature pole count
  148. Technique for measuring width of sloped ridge
  149. Measuring small bores?
  150. OT; Delete Java?
  151. Thread necromancy needed - locking a dial
  152. Am I slipping over the edge - Endmills
  153. Spreadsheet for product devlopement
  154. OT: Paperwork and Record Keeping
  155. Scraper sharpening tool
  156. What about coolant?
  157. I figured out what was wrong with my lathe - Now where do I get the part?
  158. Servo Feed Rebuilders
  159. OT: "Those horrible wire nuts"
  160. Forget your OCC this is how we do it - warning, machining content!
  161. climb milling; lower chip thickness on exit improves carbide life
  162. Add a camera to a toolmakers microscope?
  163. pushing a broach?
  164. Hot Melt Glues???
  165. Mystery Metal ???
  166. Shopmaster 3 in 1 leadscrew dial calibration
  167. Starting cutting tool inventory.
  168. Taper attachment for a Turn-Pro lathe
  169. Art Deco Motorcycle
  170. O.T. Businesses taking your money without permission!
  171. machining help needed
  172. New Member in Cali (USA)
  173. Steampunk I-pod?
  174. The Aggravation Of Owning A Chinese Rotary Table
  175. Threading with die holder on the mini lathe
  176. What do you do with a hitch ball this big?
  177. OT deal finder in Chrome
  178. Spare Time Activity - Build a Bender
  179. "When Bubba owned your machine before you...."
  180. Grizzly lathe knurling tool feedback?
  181. Bloom & BILLET Mill
  182. OT is there a foot doctor in the house?
  183. [DANGER: ON TOPIC DISCUSSION CONTAINS MACHINING QUESTION] What is "Whirling?"
  184. OT! Heavy equipment hub assemblys
  185. Tooling for a rotary table.
  186. Lathe supports
  187. Would this fly on the lathe?
  188. Check out this line boring and welding!
  189. OT -- A tour of the International Space Station
  190. Resurrection of an old Yates No. 137 Grinder
  191. Guns, Gun Laws, 3D Printing, And You.
  192. OT - looking to replace my oscilloscope
  193. USA equivilent of Remap
  194. Scraping - How many points per inch is this?
  195. What happened to the advanced search button?
  196. Antique Acu-Rite DRO features / capability?
  197. anything new in the world of way oils?
  198. Lathe auto shut off
  199. Why Make A Spring Like This?
  200. Rotary table top as lathe face plate?
  201. Need advice buying "benchtop" Mill...
  202. Need Help finding replacement Duracraft metal bandsaw gears
  203. How to cut rack-gear on vert, mill
  204. Drilling New Knobs To Line Up With Old Holes
  205. Diamond plates for flatening waterstone question
  206. Biax 7/EL fiber gear
  207. Electronics help...reversing an electrical motor with a switch
  208. Stick wax lubricant ?
  209. Anyone know the name of this fastener?
  210. New chevy battery terminal clamps - WTF?
  211. OT- Need help on relay contact condenser
  212. This is going to get closed too... BUT--
  213. identifying motor
  214. Dividing head question
  215. machine dovetail manufacturing ?
  216. Seeking Opinions on new Grizzly lathe
  217. Which lathes have the following characteristics?
  218. Y-tube Tripod
  219. Old Books Online
  220. Any one here ever build a stud welder?
  221. Anyone Build a Solder or Heat Treat Oven?
  222. Digitising manual lathe.
  223. Identify this Bridgeport?
  224. bridgeport 3phase with static converter would my power feed over heat ?
  225. As been said "Everything old is new again"!
  226. polymer concrete
  227. OT: Advise on E-Commerce Web Site for Sales
  228. Kurt Power drawbar problems.
  229. Chip compactor
  230. What type of metal to use for ER collet chuck?
  231. Mirror Mounts, what use
  232. Plaster for Lost Wax Molding
  233. Philip duclos odds n ends hit and miss engine
  234. Straightening a Bent Bar of UHMW Polyethylene
  235. please critique...(scraping 1st surface)
  236. Odd ball threaded studs
  237. "little" Gloat
  238. Oil groove test with cnc
  239. OT: Health question on strokes
  240. Missing two posters here:
  241. Air Spindex - shop made spindle
  242. OT: generator quality
  243. Swaging Forming Pipe
  244. How do I set up my steady?
  245. OT: Harvesting Parts From A Laser Printer
  246. Die making question.....
  247. enco codes
  248. igage question
  249. OT: Garage Door Opener - Real Circuit Modification to Disable when Door Is Locked
  250. Gear Question
