View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 [205] 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Quill and spindle questions on my new-to-me Bridgeport
  2. measuring with a micrometer
  3. alibre question on importing geometry
  4. Australia: New mill 3 phase V singe phase dilemma ?
  5. Lathe Torque, HP, Speed, feed etc...
  6. how deep plasma cut hardening
  7. Who is this forum for?
  8. Southbend lathe...worth attention?
  9. Spindle deflection, how much is too much?
  10. "Best" Gatling plans...?
  11. Internal Helicals DIY
  12. Quick change tool post
  13. what ahesive for small leather belt splice
  14. Victor 16mm drill chuck key
  15. Drill Doctor question
  16. Saw an interesting trailer once
  17. Derbyshire 750
  18. CNC Workshop, what happened?
  19. Motor for a home made welding positioner
  20. OT: Oil Seal Replacement in Plymouth Breeze
  21. Which boring bar set
  22. Crazyflie Nano Quadcopter
  23. Relay question for the non-electrically challenged amongst us.
  24. Home Modelling is for the birds----
  25. What grade Dura-bar for scraping?
  26. Wrecked car hauler trailer repair
  27. How do I recess my flywheel face?
  28. rockwell 21-100 spindle pulley problems. taking apart my spindle pulley.
  29. rotary table how do you use one
  30. Turning titanium?
  31. Your thoughts on making this part?
  32. new dials? What material?
  33. Another VFD question
  34. A-side from measuring, what else do you use your calipers for ?
  35. Flat drive belt recomendations
  36. Building a tool to build another tool, DIY scissor platform
  37. Weldments Anyone?
  38. Florida bound!
  39. Mill Drill Possibility
  40. OT - worth a chuckle; problem fixation and car problems
  41. Alibre is always confusing....
  42. Soldering Gun Problems
  43. question about way to slide fit?
  44. OT - How can I make a narrated slideshow with a pointer on the screen?
  45. Where's Evan?
  46. Tools I made for work.
  47. Lever Collet Closer Repair
  48. 3.5 to usb conversion?
  49. A36 versus 1018
  50. Scratch built Allman Engine
  51. Rear axle materials- good for?
  52. Myford 7/super 7 quick change toolpost will it fit a ML4?
  53. Boring bars 101
  54. Australia: VH Mill recommendations ?
  55. OT Meteor strike in Russia
  56. Gears For K&T Model 2H Vertical Head
  57. Two Monarch 10
  58. DC power supply for larger sized VFD's
  59. Why put DRO x-axis scale on back edge of mill table?
  60. Paintable Plastic for Outdoor Use
  61. Questions about Atlas/Craftsman lathes and collet closers and clutches
  62. "Railroad Chalk" = dustless chalk?
  63. Model Engineer's Handbook, Tubal Cain - content question.
  64. OT, maybe daft, question re alternators, VFDs etc.
  65. Anodizing Question...........
  66. NEMES annual show
  67. Lathe and tooling reecommendations for cutting shotgun shell.
  68. OT - Is Insurance a complete scam and waste of money?
  69. Irwin versus Lenox band saw blades?
  70. How to drill holes in the back edge of the table for DRO?
  71. How would you line up QCTP b/bar holder with lathe centerline?
  72. Ye olde "help the noob with first purchase" thread
  73. hss inserts
  74. Ideas are Cheap - Auto Variable Speed Spindle for Cutoff, Facing
  75. concave radius tool for Atlas?
  76. Shop safety concern.
  77. Scraping and Machine Repair Help
  78. OT Auction link to a Harrison 15x40 Lathe I'm selling 2/27/13 (Nebraska)
  79. Questions re: Aluminum Oxidization
  80. New purchase lathe or lathe/mill
  81. Dave DeCaussin -owner of Fadal - builds small mill after selling Fadal
  82. Cutting up gas strut?
  83. DRO scale choice
  84. How useful are machnists' clamps?
  85. The Meteorite, and Some More of My Novel
  86. Making Graduated Collars
  87. Austin roadtrip - TORMACH and TechShop
  88. lathe identification help, please
  89. Biax 7/EL weird bearing and what I can replace it with (or is this still being made)
  90. Wood workers and Metal workers.
  91. Have a mill but no lathe-
  92. How does this pedal-powered machine work?
  93. Etalon replacement parts?
  94. Source for "timing belts" and pulleys?
  95. When your stock isn't large enough
  96. single lead 4 pitch or a quadruple lead 16 pitch ???
  97. bridgeport 6F power feed ?
  98. NEMES Show Photos
  99. Gas shut off valves
  100. Ammco ratchet sketch needed
  101. Plasma cut edge hardness
  102. Guess what? bought a lathe!
  103. Repurpose junk lathe
  104. Introduction, a Plane Maker
  105. Holdridge radius tool on Practical Machinist
  106. What did I buy?
  107. Are dovetails supposed to work like this?
  108. New-to-me Bridgeport and VFD running for the first time.
  109. When to stop trying to fix something????
  110. 5 ton crane nearly free in Detroit area
  111. Alibre less confusing........
  112. what shaft for guideways
  113. Lathe Leveling
  114. Working 932 bearing bronze
  115. Holding rough stock in collets
  116. New Member Intro
  117. Investment Casting Video
  118. Cutting .010" wide pocket?
  119. High current 12 volt relay
  120. Broken Back Gear
  121. Shop Smells
  122. Fascinating technology
  123. Totally surprised!!!!!
  124. Band sawed a railroad crosstie!!
  125. Quality of finish
  126. I've been putting Lane's shaper to work.
  127. How to resharpen a tap without fancy grinder things?
  128. Free Lathe
  129. Chuck adapter plate
  130. A Different Home Model Maker
  131. question about electric motors.
  132. Identify components in Bridgeport electrical box
  133. Tap differences
  134. A Simple, Cheap and Useful Millrite Mod:
  135. Mach 3 Mill
  136. Hello Post from new member
  137. Rusttee iron
  138. Power Angle for old Snow Plow
  139. Square guideways on Y & Z axis ?
  140. A intersting video I found
  141. OT- crap ware
  142. ship build 101?
  143. OT: Machine vision
  144. New vfd will not power up the bridgeport
  145. Value of a burke no.4 horizontal mill
  146. about to purchase Grizzly G 0704 Mill/Drill
  147. Band saw motor won't turn at full speed after replacing blown cap
  148. Where's the real danger?
  149. Internal gear update
  150. alyoominiyum casting
  151. Different screw type on mars rover
  152. Getting old, yes, machinery related!
  153. Drill/tap organizer
  154. Key stock
  155. rant - ereplacement parts - avoid like the plague :(
  156. damaged LCD display on micrometer head
  157. One of the nicest i have seen:
  158. on the other hand - Rural King good customer service
  159. OT faces of Christchurch
  160. Frozen door locks
  161. Not sure if its gloat worthy...but new to me lathe being picked up in a few hours..
  162. Grizzley Mill Vise Question?
  163. 100 year old shop still in use
  164. Dead sump pump?
  165. Scientists discover graphene super capacitor, extr. high energy density, like battery
  166. Air pressure and CFM for K.O.Lee air bearing
  167. Vise jaw lift
  168. a little OT, but at least machinery/repair/rebuild related - and yes a GLOAT!
  169. What's the deal with Kennedy tool boxes?
  170. Cutting Bolts in the lathe.
  171. please help identifying new machine
  172. Are Kurt and Kurt clone vise parts interchangeable?
  173. Vee block clamp ideas please
  174. Help me put this to use please-P&W "centering" indicator
  175. Camera and card update
  176. A good day in the shop
  177. leather drive belts
  178. Computer question re "7"...... is it still available despite the new "phone app "8"?
  179. Ok, now that I have the power..do I have the speed?? Carbide insert questions...
  180. Stock storage
  181. OT - Any suggestions on a good quality wheelbarrow?
  182. Lifting chucks and vises
  183. OT: Pet hates.
  184. How to fix a Horror Fright double ended tool grinder
  185. OT, mostly: Something you don't see much anymore
  186. boring a smooth hole...
  187. Model Railroad Question
  188. Drill/tap organizer revisited
  189. Sand blaster pickup tubes
  190. Mini Milling Machines!
  191. Drill tap organizer
  192. Images of the Maudslay block-making machinery
  193. Axle shafts
  194. please recommend a boring bar
  195. Dinner time! Can of worms
  196. Beginner Exercise
  197. Bridgeport t-slots too snug
  198. Spindle brake purpose ?
  199. Program Similar to CAD
  200. re my metalic steel garage and condensation
  201. Doxford opposed piston engine model
  202. Identity this lathe please
  203. Advice for machining Cushman soft jaws
  204. Excello touble
  205. The Tailgate question revisited: An investigation using CFD
  206. O T - Worth a Chuckle
  207. Crank & collet, Atlas 618
  208. Recommendations for surplus places to visit in Orlando?
  209. Power for machines
  210. OT: Hard Drive Data Destruction
  211. Cool Clamps
  212. Mauser tools
  213. Old timey machine shop, alive and well
  214. OT - Bird goes fishing
  215. How to relieve "memory" in thick, sheet, vinyl?
  216. Bandsaw blade guides
  217. A Machinist and Biker
  218. Lamp Shade Frames
  219. Surface Gage Question
  220. Prepare the SB10 Saddle before scraping (Now that I have my Biax running again)
  221. Calling on George.
  222. Any one going to the Houstex manufacturing show?
  223. aluminum cost per lb
  224. Loaded the newer Alibre..... Boy howdy, they sure changed THAT
  225. 6 micro inch surface finish - hard or not?
  226. Bent Keys, Any Hope?
  227. Another Tailstock Alignment Method
  228. Hand Tap Chamfer Specs?
  229. And another one bites the dust.
  230. A Little Valentine's Day Project
  231. Kool Mist troubles
  232. Just a re-hello!
  233. From Shaving to Murder; Why People Should Have Their Throats Slashed
  234. Making a very accurate try-square
  235. New computer technology and they say it's available for download.
  236. What to flush gear box's with?
  237. "drip brush" for coolant?
  238. Thinking Of Down Sizing
  239. OT? Meter Repair
  240. CNC Seminar Day at Cabin Fever Expo
  241. Unknown Manufactor of Air Compressor
  242. another taper attachment Q
  243. Helical Gears on a Standard Hobbing Machine
  244. Camera Gloat mark II
  245. Air Bearing Question..... Spindle & Housing Tolerances...... Anyone....
  246. OT - voltage and current for LCD lamp
  247. OT What is VAT?
  248. Another one just bit the dust!
  249. clamshell nut
  250. dial indicator help!
