View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 [207] 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Basic milling question...
  2. Broken handle
  3. Anyone order from SHARS ?? high shipping rates
  4. Glass Scale needed!
  5. OT : my friend got 4 years in federal prison today
  6. Trailer sway control question because smart people come here
  7. Grizzly G9729 Combination Lathe/ Mill
  8. Lubricating 45 Mill/Drill
  9. OT man uses excavator to dig out his basement with house still in place!
  10. Timesaver lapping compounds
  11. dovetail supplier
  12. Enco free shipping $49
  13. Indexing plates - The chicken and egg problem
  14. Walter face mill!
  15. Harvel Grinder Questions
  16. Atlas 10 inch metal lathe with quick change
  17. Easy to build toe jack
  18. the Good the Bad & the Ugly....some new toys
  19. Meiji BM1 long reach binocular microscope
  20. Generosity of some folks---WOW!!!
  21. Machining a square end on round stock
  22. Help! indicator driving me crazy.
  23. Anilam Wizard 211 Linear Encoder Replacement Cable?
  24. What's it called?
  25. OT, StartNow
  26. What Type of O Ring to Drive Watchmakers Lathe
  27. OT: Interesting electronic part...... 3000F capacitor
  28. A handy little trick
  29. More on refractories
  30. OT: Common sense
  31. Free toolpost grinder
  32. Forming Sheet metal
  33. 5C indexing collet block Is this new?
  34. How to produce ball ends on a rod ?
  35. Cut my first gear today!
  36. milled cube parallels in cast iron
  37. multiple hardness grades for diamond?
  38. Tinkercad.com
  39. Abrasive Machine Co. No. 1-1/2
  40. Belt making process
  41. SolidWorks exploded assembly problems
  42. Why so down on lantern toolposts?
  43. OT: 'nuther compouter question
  44. DoAll 6"x12" surface grinder
  45. Large radius tube bender ideas
  46. Long shot: technologiss milling machine.
  47. Drive Pins
  48. First Lathe and Mill need advice
  49. A nice app for the shop
  50. QCTP More rigid design
  51. Delta Drill press rebuild help.
  52. Fastener referance. Its a PDF
  53. Machining Metric 8.8 grade medium carbon steel bolts?
  54. Were machinists of old just slobs or lazy?
  55. Yow! Cl ..
  56. Leveling pad attachment question
  57. How I got here from a new member
  58. Standardized/generic fixture solutions for one-off parts?
  59. OT: RAF photo op
  60. Cool, but OT: Amazon raises Apollo F1 engines
  61. Step back in time
  62. If you need a 5/16-24 spiral point USA tap...
  63. Free WP Davis Lathe (Lodi, CA)
  64. benchtop bed mill headstock counterweight
  65. Drill press belt slippage
  66. Electrical grounding question
  67. sanding belt speed
  68. Glacern vs Orange
  69. O/T How Do I Calculate The Lift Height of a Chain Hoist
  70. How do you calculate surface speed for facing?
  71. Winters Drill Bit City - opening the box (USA drill content)
  72. Machinist gift ideas?
  73. In case you have to do......
  74. Where to get hard woods for cheap?
  75. flat spring
  76. Excello 602 repower??
  77. OT PEX plumbing
  78. Logan 11x30 Model?
  79. O.T. what would you do if it was hailing on your steed?
  80. Weldable PTFE?
  81. OT: New words & definitions.
  82. Question: Mill Power Feed
  83. OT: Intellectual rights of my current employer over my own product?
  84. Rotary Table Tooling?
  85. Drill finally painted
  86. Model Shaper
  87. O.T. neat storage solution
  88. Lathe chuck key clearances?
  89. Getting ready for new mill
  90. split collar
  91. Osama lathe foot brake
  92. Photobucket seems to have used their brains......
  93. lathe contactor problem? -- need help
  94. OT Toyota gearbox mounting bolt layout
  95. OT- What Size UPS
  96. ER collet system
  97. Surgical steel
  98. Sieg X2 spindle alignment
  99. Old Bridgeport Shaper!
  100. OT For the Aviation and WWII History Buffs Here
  101. cxa holders on a bxa tool post?
  102. The Sawmill Dream comes true! Pics, so you know it happened!
  103. Questions About Building A New SHOP
  104. A tale of two spindles
  105. DRO Help Needed!
  106. Machining small valve spindles
  107. Off to Taiwan
  108. Machine shop video
  109. Sharing a lathe - with a woodworker
  110. HSS lathe tooling help, with pics
  111. Photos to Identify please - Dad's lathe, accessories, other items Part 1
  112. Photos to Identify please - Dad's lathe, accessories, other items Part 2
  113. Repairing gage blocks
  114. Unimat 3
  115. Aluminum/Steel contact
  116. ebay ad
  117. jukebox
  118. ceramic vs carbide
  119. Need to Make a Shop Press Faster
  120. cost of shipping
  121. Where would this Motor be used?
  122. Chevalier FM3VS is home, anyone have one?
  123. Turning Tungsten
  124. new /real old lathe
  125. Looking for a surface grinder or small horizontal mill
  126. steam engine model attemp
  127. Advice for shop made machinist vise hold downs
  128. Power honing - ideas on what oil I can use
  129. lathe leadscrew accuracy
  130. Making a cutter to cut quill threads.
  131. Grizzly question
  132. mounting spindle bearings
  133. acetal for change gears?
  134. Anyone familiar with this old British drill press model?
  135. welding table
  136. Gibb Problem on South Bend Rebuild
  137. looking for an ISO G 1/8 tap
  138. soft mounting large 10hp electric motor - springs?
  139. Split pin vs solid shear pin
  140. small size Enco Turret Toolpost, innards
  141. what compound angle .0001
  142. OT need to make font bigger
  143. Holding a large drill in tail stock???
  144. Pipe thread taper angle
  145. Hearing aids in the shop.
  146. surface finish
  147. Grinder Table Automation, The Rest of the Story
  148. Monarch model C ?
  149. Q/T Smartphones
  150. Gimmee a boot---
  151. Lead shot for Mini mill column
  152. OT Man down
  153. Electroplating/Anodizing without sulfuric acid???
  154. Model Engines --- NOT
  155. To keep from hijacking the sawmill thread
  156. Where are you when you're here?
  157. Threaded insert for Aluminum
  158. tough carbide insert
  159. Telescope gage mod
  160. Tipping dies
  161. need help with some brain storming
  162. Can this drill press be saved?
  163. For engine fans
  164. Gear chart for lathes cannot attach
  165. OT, Why did the two "touch lamps" next to our bed both go bad at the same time??
  166. Homemade cutting oil pump for the lathe
  167. Check valve in fuel line
  168. Burned out on Run out
  169. Dies
  170. Titanium fasteners and galling?
  171. tool bit for cold roll
  172. What can I use as a gap filler?
  173. Heat Treating For Dummies
  174. Tool storage
  175. Thread Question
  176. Wiring 480 3p heater-bands
  177. OT: russian sausage vs chinese knife
  178. What are heavy equipment pins made of?
  179. Pilot Bearing Fit on Ford 3.0L - Can't Get the Crank in My Lathe
  180. If you want a Maximat V13, ya gotta buy the container it comes in
  181. How much threading info would you need and how much is too much?
  182. Off the wall idea
  183. video of working models
  184. Coal
  185. Pissed off with Ebay buyers
  186. GEARS – Portland, OR
  187. Help finding telescoping tubing thread?
  188. PHOTOBUCKET - Q. not addressed by sticky
  189. WHAT HAPPENED? VFD or Motor died?
  190. Need to redo my compound and crossfeed on old heavy 10
  191. Grizzly vs Percision Mathews
  192. O/T worlds rarest motorcycle
  193. OT: Internet Explorer Choices
  194. Lathe leadscrew INaccuracy
  195. THIS is a machine shop
  196. 2 Flute HSS end mill
  197. Cage/Lantern Gears
  198. Time to build a sloting tool
  199. Enco double deal!
  200. Is there a mobile version or app for HSM?
  201. ENCO - 10% OFF + Free Shipping
  202. Clutch---again
  203. making bull nose centers?
  204. excellent videos from a tool and die pro
  205. OT Honest your Honour I forgot my pin numbering
  206. Very rare video-Logging in the age of Steam
  207. Good Machining, Good Design, Nice Sculptures
  208. Surface Gages
  209. OT driving in Russia
  210. OT Fast & Loud... ClearCoat Over Rust
  211. Old Gasboy Pump Rebuild
  212. OT - Rotary Position Sensor / "Address Switch"
  213. Tangential Lathe Tool
  214. Anyone else push their machines limits ? Or is it just me
  215. Anyone else having problems with BALDOR motors?
  216. This old Tool - Anyone familiar with Comet-FGII 55º and 60º threading tool?
  217. Tips on making swivel pads for clamps?
  218. Craftsman motor problem
  219. Almost free 5c collets,did I learn a lesson.
  220. Projects In Wood-Remember the Book?
  221. $200.00 3D printer?
  222. putting a carrage (feed) stop on my PM 1027 lathe. Anyone ever do anything like this?
  223. Getter done
  224. Should threaded steam pipe also be welded
  225. making a V-rib belt
  226. Clausing 105
  227. Another Ebay Fee Increase Comming !!!!!
  228. Another What Is It.
  229. Actually disolves Permatex sealant
  230. OT: The Loram Railway grinder, seen at night
  231. Who's going to the N.A.M.E.S Show
  232. Which VFD for CNC mill conversion???
  233. OT: Very useful Android GPS App
  234. Where did Sebastion stamp their numbers?
  235. OT: Gotta new job... and a rant about the old one.
  236. Flylo - Answer you damn PM's
  237. Making quick change tool post holders (picture heavy)
  238. Christen and co Swiss lathe
  239. Photos of Lathe Brake - and my first post.
  240. Camp stove repair project
  241. OT but related: Trinity College Firefighting Robot Meet
  242. Made a Keyway Broach bushing this morning.
  243. OT: Diodes and indicator lights
  244. A real optimist...... A REAL optimist...... selling a mill
  245. Increasing top speed of Sherline lathe?
  246. The impossible sander
  247. OT- high voltage module
  248. Anodizing Heater From a Tea Kettle
  249. How To Bore Out Soft Jaws?
  250. Is it possible to keep chips out of the inside of a chuck?
