View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 [208] 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Grounding rod placement???
  2. OT what kind of speed rating on these tires?
  3. Zamak casting/plating ??s
  4. How do you measure swing on a lathe?
  5. Combining 2 millrites into 1
  6. Small Book Gloat!
  7. finally making chips!
  8. Fitting a face plate - need an adapter
  9. Adventures with a sawblade
  10. air-film shear
  11. OT: Daughter thinks my new fixturing table is the best Lego setup.
  12. New (to me) small, old lathe; how to proceed?
  13. Can't Search Forum
  14. Forum URL
  15. Drill Chuck Removal
  16. Sourch for 5/8" turned/ground/polish/chrome plate rod?
  17. OT: Forum Software / runing a forum?
  18. Weldon shank EM... carbide?!
  19. A question re hilti drill .
  20. Grinder; Please help identify (pic)
  21. End Mill Alignment in Sharpening Fixture
  22. Only 4 days left on my Kickstarter pen project!
  23. Source for spur gears
  24. Ingersoll Rand Type 30 Compressor Head, questions
  25. Looking for reasonably priced gear cutters... any leads?
  26. Changing my Air cleaners What do you think?
  27. Oh,okay I'll take that
  28. OT: New Source for Unobtainium...NASA to Start Mining Asteroid!
  29. Lite sheetmetal forming
  30. OT/Propane freezing
  31. Collet Block that indexes
  32. Calculating the Size of the Tap Drill
  33. OT: Mystery solved...It's not thieves breaking in. It's .......
  34. Re-tram on turret swing?
  35. Hotel deals for Cabin Fever?
  36. Latest Plane From the Brese Plane Shop
  37. Grizzly quicklock indicator base
  38. Telescoping Bore Gages
  39. Shop Made Tools 2013 book. Just arrived!!
  40. Speedy Metals Discount Codes
  41. Need Dimensions from Craftsman Lathe Tool Post
  42. Fine Feed
  43. How Much Force Does It Take To Get Your Lathe Saddle Moving???
  44. Coolant, when to use ?
  45. Made a simple sheet metal knockout punch
  46. McGyver is my hero
  47. SketchUp performance
  48. Which way angular contact bearings in pillar drill.
  49. 1949 Mercury dwarf car
  50. Cabin Fever
  51. Machining convex profiles
  52. Shop Made Tools 2013 Book
  53. What do you call these?
  54. Third motor control within 20 hours of use on DC motor?
  55. Dialing in a shaft...
  56. OT- FireFox Being Shunned?
  57. My Taper Attachment -- and Backlash
  58. Maximizing carbide life
  59. Nova; Ancient Computer
  60. ER series - common 8° angle?
  61. Diaries of a Subaru (ot)
  62. how do i find my thread in shop made tools?
  63. Machinist calculator for $1
  64. Forming a bowl
  65. what would be the ultimate machined straight edge for scraping?
  66. casting aluminum
  67. What to do with a drill press column?
  68. CL advert of the day..................... big lathe 48'' swing - $800
  69. ALTENEDER Straight Edge
  70. OT: I hate Fu@#~king Adobe
  71. Hi everyone!! and South Bend users!!!
  72. Coupling Structural Pipe
  73. Is PhotoBucket "improved" again?
  74. OT: Inflation in Germany
  75. What Tool.. Im Confused!!
  76. Is it repairable. TV struck by lightening.
  77. no dovetail cutter? no problem. Introducing --- Weld-on dovetails.
  78. I could not give them away!
  79. Zoro Tools - any experience with?
  80. Placement of set screws
  81. SB thread dials.... opposite?
  82. ER collet clamping range
  83. I have seen the light.
  84. High heat-resistant aluminum?
  85. The "Almost" Flood---
  86. What steel is this?
  87. OT: My daughter went to her first horse show!
  88. I think I might be sick with something
  89. Lathe speed control
  90. OT- Old Iron rescued. WW2 Russian Tank, ISU-152
  91. N.A.M.E.S. expo 2013
  92. Cabin Fever 2013 pics by Chucketn
  93. Looking at a Pre WWII lathe
  94. Hydraulic piston repair- piston rings?
  95. OT - Steel cables and TV Antenna?
  96. Knurling upto a head - help ideas please.....
  97. OT- T5HO electronic ballast: Will it function without dedicated ground?
  98. Southbend 13" Backgear
  99. Students wanted of May 31 SCRAPING and REBUILDING Seminar
  100. silver soldering vs soldering of bandsaw blades
  101. Bolts That Can Kill !!!!!!!
  102. expandable fluids
  103. Replicating a Sickle Bar Drive Assembly.
  104. tips for dialing in a 6 jaw chuck.
  105. Ex-Cell-o Remex RRS7155 Tape Reader Documentation
  106. Anyone dealt with Can-Do Machinery Sales in Chatsworth, CA?
  107. A question about youtube videos
  108. Engraving Anodized Aluminum
  109. Belt Lacing Tool
  110. Outside Jaws Wanted!!
  111. OT Driving Cheap Speakers 3 ohm/ 6 ohm
  112. I need to make some dummy rockets...
  113. Flat belt driven lathe.
  114. OT: Wow!! The HE washing machines really do save water....and money.
  115. New Enco free shipping code
  116. Quick ??? from new-b
  117. McLean Finger Plate Vise - Atlas 618
  118. OT: I'm having a tough time seeing this as part of a pressure cooker.
  119. DNMG carbide inserts
  120. where to find metal corner protectors in canada
  121. Pratt and Whitney 16c lathe.
  122. What not to do with a MIG welder
  123. Road trip for a surface grinder-need advise
  124. Vactra #2 for paper shredder?
  125. Shop made Taps....
  126. Sort of OT. Dwolla internet payment system
  127. Hardened D2 as scraper blade?
  128. Need Help - Estimating Value and Finding a Home for Machinery
  129. How does an axial hole in a threaded piece affect its tensile strength?
  130. OT Fertilizer Plant explosion in Texas
  131. OT - upgrade electrical panel or buy a generator?
  132. Turcite - Rulon - Garlock - Moglice
  133. Opinions on new mill
  134. Soft Jaw applications ?
  135. Labeling
  136. Do taps wear out?
  137. How would you cut this?
  138. Ideal Demagnetizer trouble?
  139. Back in the shop, somewhat...
  140. OT slingshot mania
  141. Some People have to much Time on there Hands
  142. Does material change size or disappear and reappear?
  143. Unimat tool holder
  144. I read this and thought of Sir John...
  145. Jig borer
  146. Import Caster Weight Capacity?
  147. Bill Volna's Retirement Sandbox
  148. Why so few project threads?
  149. Whatzit? Anyone know what this is, please?
  150. OT: Help, Another computer problem. SpeedUpMyPC by uniblue
  151. Speedy Metals having Website issues?
  152. "How did they make the first lathe?"
  153. 1943 Monarch 10ee; need DC Controller installed; Detroit area
  154. PayPal "Bill Me Later"?
  155. 1340 sharp model j
  156. Removing a Vista Install from an old harddrive.
  157. Etching problem
  158. Can't get the rim off the axle
  159. What did you machine today?
  160. Windows XP Security pro virus?
  161. 20 ton Hydraulic Press Project
  162. Ratchet Tool PSA
  163. Missed the N.A.M.E.S. Show Damnit!
  164. My Dad's old Gerstner Toolbox (long winded)
  165. Compression spring supplier in Canada ?
  166. Gunter Bettinger's Mini-Motor Site (Stirling, vacuum, flammenfresser, etc)
  167. Just Another Chuck Mounting Question...
  168. Question on Sheldon lathe...
  169. OT, sort of: Tablets for reading
  170. People who can't touch machinery without something going wrong.
  171. What size power supply for motor.
  172. Nylon Spacer Source?
  173. Boiler Clock - project
  174. Made a longer/extened tail-stock quill
  175. Where to buy assortmented nuts, bolts, set-screws, etc... ???
  176. OT California solvent ban, can't find naphtha?
  177. Project: Angle grinder guide mechanism to cut sheet straight
  178. N.A.M.E.S. expo 2014
  179. Interesting mechanism at N.A.M.E.S.
  180. Quick die-filer question...
  181. Control circuit help
  182. Made a couple MT3 center drill holders...
  183. How bad an idea is this VMC?
  184. Alistair is a grandpa again
  185. Stuck 5C collet, I think...
  186. parts cleaner solent???
  187. Miler welder generator
  188. Pinging chucketn
  189. OT? Nice little live steam train set for sale..
  190. OT: Massive landslide at Kennecott Bingham Canyon copper mine
  191. Joe Martin Foundation & Craftmanship Museum
  192. Machining books
  193. Welding to a Toyota clutch centre
  194. Nylon insert, substitute ??
  195. Time to cook the car body on a rotisserie
  196. No Project Posts? Is Wood Project OK
  197. A little OT - a science quiz
  198. Tool Gloat: New 20 Inch Drill Press
  199. steam power?
  200. stepper motor nomenclature
  201. Tool Gloat !
  202. Coverting VHS to DVD?
  203. My new ray gun
  204. The Mechatronist comes thru again
  205. A Slimline Four Jaw Chuck
  206. Installing a Mitutoyo Quill DRO
  207. Installing a hydraulic gauge to read it easily?
  208. Job Opportunity in S.E. Michigan - PLC Programmer
  209. Craigslist, Lathe heads up.
  210. Noise Coolant Pump
  211. Craigslist Anchorage
  212. OSG group buy on Taps and Dies...
  213. Home from Cabin Fever, NAMES et al!
  214. My little sander burnt out, do these motors have fuses?
  215. DIY post hole digger -- good idea / bad idea?
  216. Help I.D. these boring heads
  217. Tool gloat
  218. DRO agian
  219. Machine tapping in lathe
  220. plasma smoke rings
  221. dumb little project, still satisfying
  222. dumb little project CONTINUED
  223. OT: ipad
  224. How does a Temperature and Pressure Relief Valve Work?
  225. Dump the camshaft, regenerative recoup, 30% less gas and 50% lower emissions
  226. Spannende Spane (Cutting Tools) 1982; 30 minute movie
  227. Reading a vernier Caliper
  228. Teens enter vocational school, come out with jobs, no debt
  229. removing hardened teeth
  230. Linear bearings for an X-Y table
  231. Sir Branson to shoot the works
  232. normalising steel in a kithen oven
  233. coupons from enco
  234. Aluminum piston in cast iron cylinder
  235. Strong gardening fork
  236. Talking about chinese QUALITY????
  237. Tiny tool gloat, my first!
  238. Chinese Motor Improvement
  239. Any HSM'ers in Honolulu, HI that can help?
  240. summer project- what the @#$$ did i get myself into??!!
  241. OT, How a bicycle is made (in 1945)
  242. Bridgeport power feed basket case
  243. Optical Tube coupling (suggestion)
  244. Endmill as a boring bar.
  245. OT: Safely emptying Glass "glass grenade" of carbon tet
  246. Any New Projects comong up?
  247. I Pad photo posting?
  248. Annealing a file
  249. Thursday's Job....Blind hole end bell
  250. OT: Landing gear from 9/11 plane found in New York alley.
