View Full Version : General
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 [209] 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. OT: I won my appeal
  2. Cabin Fever Expo Photos Up
  3. Polyurethane splat on face shield...
  4. How to make plastic t-handles for 1/4-20 threaded rod and nuts
  5. Can't edit a title?
  6. What to do with a tiny XY table?
  7. hair clipper sharpening
  8. PSME supplier
  9. Book on building heat teat ovens
  10. Injection Mold Project
  11. how would you make these?
  12. a bandsaw question?
  13. Lost the 3rd leg in my RPC
  14. What to do About Rust "Welded" Parts?
  15. little bit of a tool gloat.
  16. Bush hog repair
  17. vfd supply question
  18. R8 Spindle Seating/Runout Problem
  19. Enco shipping codes?
  20. Whats the best home and shop wireless security system now?
  21. Quality Magnifying Visor or Swing Arm Thingy?
  22. recycling scrap plastics into useable products-any personal experiences?
  23. Concrete Floor Thickness for Shop
  24. defogging a double-paned window
  25. WAY OT, Dwyer CO2 absorption fluid
  26. Valve guide material selection
  27. Drive gears for an 18" slip roll.
  28. sharp 1340 j
  29. Another metric rant..... maybe not what you expect
  30. OT: Advances in space travel
  31. Anyone else have this problem with Firefox?
  32. Need a better process....
  33. help and/or suggestions for rack and pinion replacement
  34. You asked for a pic
  35. OT: Sound Frequency Measuring Device
  36. New here...intro and some pics.
  37. Making stamps out of aluminum
  38. Gear Material question
  39. A Webster Moment---
  40. Tell me about a South Bend 13" lathe
  41. Boring deep holes, how do you keep the chips from piling up on the bar?
  42. OT:Oh crap,that doesn't look good!
  43. does MT4-to-R8 exist? in canada?
  44. How much does home brew type 2 anodizing improve corrosion resistance???
  45. LMS 3536 lathe
  46. Metal Thickness vs Gauge
  47. Hacksaw for sale
  48. Machine Axis & DRO Letter Designation
  49. Machining a tubing die
  50. Enco code
  51. Static phase converter shorted
  52. Evans posts
  53. Making a small collet for a "Precise" hand grinder? (plus tool gloat)
  54. Baby gloat
  55. making a lapping plate
  56. A Proud Father!
  57. My Alva Allen B-2 Punch Press
  58. Show off your shop-built machine bases
  59. Where to find: 7/16-14 stub acme tap?
  60. Endmill Geometry Question
  61. Who Else Is Watching "Big Brain Theory" On Discovery?
  62. OT: Airless Tires create Math Question
  63. building tool post grinder
  64. Pages missing from Shop Made Tools thread?
  65. ac/dc resistance
  66. ENCO Additional 20% thru Friday
  67. Using a die to make thread
  68. drill press on off switch on off went out what is a good one
  69. OT;Replacement dog/
  70. Safety hazard with treadmill motors
  71. Square D Magnetic Starter, 220V coil or transformer and 120v?
  72. Which insert facemill?
  73. Vertical shaper
  74. 305mm rotors, hub, and caliber
  75. Reversing my lathe motor...
  76. Unhardened dowel pins
  77. cast iron definition
  78. Bandsaw throws the blade
  79. [ot] Fire...
  80. Good idea collet holder with straight shank held by chuck ?
  81. Practical Machinist site down?
  82. Miniature angle iron needed
  83. Is a 'B-Taper' common in "your" part of the world ?
  84. How to size a DC choke?
  85. OT Re: "separate" a GFI outlet??
  86. More craigslist spelling entertainment
  87. micrometer question.
  88. Metric Fixation
  89. .0625 hole 3 inches deep in Brass
  90. Anti-chainsuck mechanism (home brew)
  91. Making a tiny filing rest
  92. Portable Crane for Pickup Bed Mount Plans
  93. Kinda OT if it weren't for the 30 million some odd posts...
  94. Good Reference On Motors
  95. Threading something long w/o steady rest
  96. Sanity check. Elementary school math.
  97. Self-made: Sliding tap holder...
  98. Bridgeport Quill Master / How Does It Work
  99. 4x6 bandsaw blade thinkness: .020 or .025 ???
  100. Audiolumitron Question for Evan
  101. Firsat 3D printed gun fired, would you pull the trigger?
  102. 30% off ENCO
  103. Jet Mill-Drill, wire question.
  104. Grizzly DRO Accuracy
  105. OT, Knife Sharpening Techniques
  106. Noga or alternative
  107. do you own metric and imperial micrometers?
  108. surface plate value?
  109. Boring bars suck, use endmills instead
  110. Way to seal glass to brass?
  111. It's not easy finding electronic parts
  112. Blacksmiths...forging tool steel...??
  113. Using a Tubing Micrometer for General Purpose Measuring?
  114. Emco Unimat DB200 vs. SL1000
  115. Our Future!
  116. Why do Steady and Follow rests have left handed threads ?
  117. Thermal Imaging
  118. Material (concrete ???) for woodworking drum-sanders bed ? (pics inside)
  119. What material for QCTP Tool Holders
  120. Chemical question for EVAN the rocket scientist
  121. Gearbox question
  122. Lathe Oiling
  123. Another ENCO code
  124. Glass vs magnetic
  125. A better use for 3D printing and a brighter future for manufacturing
  126. Steam Powered Box Factory Video
  127. Will Georgineer please check his PM's
  128. South Bend Outside Jaws Wanted.. Measurments in Pictures!!
  129. Found it !!!!!!!!!!!!!!!!!!!
  130. Will a Delrin idler gear make things much more quieter ?
  131. Mill chip guard question
  132. Boring/drilling 1" cannon barrel
  133. OT..Cant find chips (electrical)
  134. Old Time Steam Powered Factory
  135. Is This table any good
  136. OT: Charge Pumps
  137. Repairing A Stainless Steel Propeller
  138. Firefox update a bust?
  139. Do v-belts have a shelf life and are some brands better than others ?
  140. Metric threads on QCGB lathe
  141. OT First world third world.
  142. Hi all: Duck dynasty:
  143. Chuck escape
  144. 30% off Today only at MSC
  145. self adjusting steady rest
  146. Considerations for cutting worm gear threads
  147. OT: Annular Solar Eclipse (May 09, 2013 - 5:30 EDT)
  148. ENCO 25% Off ACU-RITE DROs + Free Shipping on orders of $99 or more!
  149. OT. Horror Fright ad knock off I thought was funny.
  150. OT: Truly punishing
  151. fm radio
  152. Really Nice Homebuilt Grill
  153. A2-6, A2-8 collet chuck
  154. Tungsten Round Stock Supplier (US)
  155. Back on the temperature measuring camera subject...
  156. Flame hardened 4142 CFHT or use 1018 for Gear cutter...
  157. Maybe OT? Stainless Grab Bars 90% off!
  158. 5 cylinder radial running
  159. Help needed in design of a pin cutoff machine
  160. MT taper collets for lathes
  161. Pre impregnated thread lock bolts
  162. What is the purpose of this screw and locking nut
  163. How strong are "split cotter" fasteners?
  164. Tool Gloat
  165. N.a.m.e.s. Show photos
  166. Lathe: Slow down all spindle speeds by xx% - make bottom pulley xx% smaller ???
  167. Vertical radius cutter (video and pic)
  168. Knurling to build up diameter
  169. tool review WT quick acting knurling tool
  170. Tool gloat: Shop Wench's new toy
  171. V ground profiles, where to get them?
  172. Small Stainless Smoother with KOA
  173. Math problem for the simple minded ME!
  174. I found the answer to my milling machine need!
  175. Kao Fong VF-VMC Mill Parts
  176. Is there a market for these ?
  177. Self-made: motor pulley
  178. I drove about 730 miles today...
  179. Gear grease for open gears - Logan 820 lathe
  180. Need Help With A Rod Cutter
  181. A steam powered box mill in N. CA
  182. KNUX inserts dimensions, available in smaller?
  183. Tapping stand adapters, how do they hold the taps?
  184. Shop vac recommendations
  185. Double row angular contact ball bearings?
  186. Welcome to new member..
  187. Tach generator/KB control PCB question
  188. Do It Yourselfers / Backyard Inventors in China - interesting photos
  189. Removing nut from milling machine arbor
  190. More double row angular contact bearings.. zero/negative clearance?
  191. collet chuck choice.
  192. Geez... you Canadians piss off everyone.
  193. rotary manual shear
  194. Oil ring groove on a lathe
  195. Tool Gloat: Lathe and tooling haul plus question on taper attachment
  196. Mill drum switch for VFD directional control
  197. My welding/fixturing table arrived today!!!!!
  198. O.T. industrial lawn mower
  199. Jet lathe - missing lube point?
  200. Making a graphite piston
  201. Polishing crankshaft journals?
  202. diy atomising nozzles
  203. OT: NOOOOOOOoooooo!!!! (Say it isn't so!)
  204. OT- Ambient Temperature Gauge For Automobile
  205. OT: Google
  206. Enco 15% OFF!
  207. First Post - Colchester Student Head Bushing Adapter Question
  208. OT (sort of) odd question... anyone have info on the "Hexcrawler"?
  209. Quick change toolposts
  210. I need some help picking a boring bar.
  211. Where to buy a good straightedge
  212. QCTP for Unimat?
  213. OT- Electric Fence
  214. Light on welding helmet?
  215. speedymetal.com ??
  216. Anvil
  217. The new Bligeport - first installment.
  218. HSM-Built Steel Guitar
  219. dropped my test indicator, where to get tips?
  220. Air compressor "upgrade"
  221. Enlarging holes
  222. Raw material find for metro Detroiters
  223. Sir Johns New Retirement Career, Great Help Needed!
  224. is this too good to be true?
  225. JFK collet closer - how to remove hub??
  226. Help with lathe setup.
  227. Anyone interested in a small project ?
  228. Caught Up At Last!
  229. Can anyone help me with their experience and offer me advice ?
  230. B2227L-lathe carriage adjustment
  231. You guys might enjoy this steam video of an old operating business making boxes
  232. new tools
  233. Southbend 9" Spindle thread size!! Boxford?
  234. ER 40 collet set, good price/good accuracy ??? advise
  235. Trailer ramps question
  236. Darwin award candidate
  237. A small morning project
  238. G power
  239. Boxford lathe manual with lots of charts, tables, and instructions for machinist!
  240. Thinking about making a Arbor Press and looking for opinions.
  241. OT: What is this connector?
  242. Steel Rules
  243. fiber gear repair??
  244. New Mill Is Home
  245. OK. You won the $600M Powerball. Now what?
  246. New Dorian AXA QCTP
  247. happy birthday Al.
  248. OT: Rare 19th C Howell torpedo discovered off the coast of Coronado, Calif
  249. compressed gas mixtures
  250. A pair of Allman Engines we have been building
